[geos-commits] [SCM] GEOS branch master updated. 089f87756b5230b61c34648c3126b8dca9b98c32
Tue Jan 14 07:04:59 PST 2020
the project "GEOS".
       via  089f87756b5230b61c34648c3126b8dca9b98c32 (commit)
      from  a096c8324e78558b5fd029e8c80acc743df4acab (commit)
revisions in full, below.
commit 089f87756b5230b61c34648c3126b8dca9b98c32
Author: Marian Krivos <nezmar at tutok.sk>
Date:   Fri Jan 10 19:00:57 2020 +0100
    Rename geos::M_PI to less intrusive MATH_PI (that don't collide with standard <cmath> name
diff --git a/doc/example.cpp b/doc/example.cpp
index bc1f324..678e821 100644
--- a/doc/example.cpp
+++ b/doc/example.cpp
@@ -443,7 +443,7 @@ do_all()
     geoms->push_back(create_rectangle(-5, -5, 10, 10)); // a square
     geoms->push_back(create_rectangle(-5, -5, 10, 20)); // a rectangle
     // The upper-right quarter of a vertical ellipse
-    geoms->push_back(create_arc(0, 0, 10, 20, 0, M_PI / 2));
+    geoms->push_back(create_arc(0, 0, 10, 20, 0, MATH_PI / 2));
     geoms->push_back(create_sinestar(10, 10, 100, 5, 2).release()); // a sine star
 #endif
diff --git a/include/geos/constants.h b/include/geos/constants.h
index 8a07b28..7d4bb61 100644
--- a/include/geos/constants.h
+++ b/include/geos/constants.h
@@ -32,14 +32,11 @@ typedef __int64 int64;
 #include <cinttypes>
-#ifdef M_PI
-#undef M_PI
-#endif
 typedef int64_t int64;
 namespace geos {
-constexpr double M_PI = 3.14159265358979323846;
+constexpr double MATH_PI = 3.14159265358979323846;
diff --git a/src/geom/util/SineStarFactory.cpp b/src/geom/util/SineStarFactory.cpp
index 5abcfc7..d96225c 100644
--- a/src/geom/util/SineStarFactory.cpp
+++ b/src/geom/util/SineStarFactory.cpp
@@ -65,7 +65,7 @@ SineStarFactory::createSineStar() const
         // the angle for the current arm - in [0,2Pi]
         // (each arm is a complete sine wave cycle)
-        double armAng = 2 * M_PI * armAngFrac;
+        double armAng = 2 * MATH_PI * armAngFrac;
         // the current length of the arm
         double armLenFrac = (cos(armAng) + 1.0) / 2.0;
@@ -73,7 +73,7 @@ SineStarFactory::createSineStar() const
         double curveRadius = insideRadius + armMaxLen * armLenFrac;
         // the current angle of the curve
-        double ang = i * (2 * M_PI / nPts);
+        double ang = i * (2 * MATH_PI / nPts);
         double x = curveRadius * cos(ang) + centreX;
         double y = curveRadius * sin(ang) + centreY;
         pts[iPt++] = coord(x, y);
diff --git a/src/operation/buffer/BufferParameters.cpp b/src/operation/buffer/BufferParameters.cpp
index 852b62a..4b66a59 100644
--- a/src/operation/buffer/BufferParameters.cpp
+++ b/src/operation/buffer/BufferParameters.cpp
@@ -125,7 +125,7 @@ BufferParameters::setQuadrantSegments(int quadSegs)
 double
 BufferParameters::bufferDistanceError(int quadSegs)
-    double alpha = M_PI / 2.0 / quadSegs;
+    double alpha = MATH_PI / 2.0 / quadSegs;
     return 1 - cos(alpha / 2.0);
diff --git a/src/util/GeometricShapeFactory.cpp b/src/util/GeometricShapeFactory.cpp
index 9f5b231..3d9b234 100644
--- a/src/util/GeometricShapeFactory.cpp
+++ b/src/util/GeometricShapeFactory.cpp
@@ -161,8 +161,8 @@ GeometricShapeFactory::createArc(double startAng, double angExtent)
     env.reset();
     double angSize = angExtent;
-    if(angSize <= 0.0 || angSize > 2 * M_PI) {
-        angSize = 2 * M_PI;
+    if(angSize <= 0.0 || angSize > 2 * MATH_PI) {
+        angSize = 2 * MATH_PI;
     double angInc = angSize / (nPts - 1);
@@ -191,8 +191,8 @@ GeometricShapeFactory::createArcPolygon(double startAng, double angExtent)
     env.reset();
diff --git a/tests/unit/capi/GEOSDistanceTest.cpp b/tests/unit/capi/GEOSDistanceTest.cpp
index 229ecba..0b8cef1 100644
--- a/tests/unit/capi/GEOSDistanceTest.cpp
+++ b/tests/unit/capi/GEOSDistanceTest.cpp
@@ -92,7 +92,7 @@ random_polygon(double x, double y, double r, size_t num_points)
     for(size_t i = 0; i < num_points; i++) {
-        angle[i] = 2 * geos::M_PI * std::rand() / RAND_MAX;
+        angle[i] = 2 * geos::MATH_PI * std::rand() / RAND_MAX;
         radius[i] = r * std::rand() / RAND_MAX;
Summary of changes:
 doc/example.cpp                           | 2 +-
 include/geos/constants.h                  | 5 +----
 src/geom/util/SineStarFactory.cpp         | 4 ++--
 src/operation/buffer/BufferParameters.cpp | 2 +-
 src/util/GeometricShapeFactory.cpp        | 8 ++++----
 tests/unit/capi/GEOSDistanceTest.cpp      | 2 +-
 6 files changed, 10 insertions(+), 13 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
