[geos-commits] [SCM] GEOS branch master updated. ba34ee20395a4d30027776de4a734a88bf8767b8
git at osgeo.org
git at osgeo.org
Mon Nov 2 15:24:30 PST 2020
the project "GEOS".
via ba34ee20395a4d30027776de4a734a88bf8767b8 (commit)
via d4c133f62167fcb780949c2a53cce8e9f13b6353 (commit)
from a1eed0f993839c4cff5ccfb1644e8b6a2ff2cc1d (commit)
revisions in full, below.
commit ba34ee20395a4d30027776de4a734a88bf8767b8
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Nov 2 12:24:36 2020 +0100
Add GEOSPreparedNearestPoints in C-API
Implement for LineString input
Closes #1007
diff --git a/NEWS b/NEWS
index 34d6548..641eff7 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ Changes in 3.9.0
- New things:
- MaximumInscribedCircle and LargestEmptyCircle (JTS-530, Paul Ramsey)
- CAPI: Fixed precision overlay operations (Sandro Santilli, Paul Ramsey)
+ - CAPI: GEOSPreparedNearestPoints (#1007, Sandro Santilli)
- Improvements:
- Stack allocate segments in OverlapUnion (Paul Ramsey)
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 17a2fb2..ac14777 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -1299,6 +1299,12 @@ extern "C" {
return GEOSPreparedWithin_r(handle, pg1, g2);
+ CoordinateSequence*
+ GEOSPreparedNearestPoints(const geos::geom::prep::PreparedGeometry* g1, const Geometry* g2)
+ return GEOSPreparedNearestPoints_r(handle, g1, g2);
STRtree*
GEOSSTRtree_create(size_t nodeCapacity)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 903475c..dd0b2bd 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -882,6 +882,14 @@ extern char GEOS_DLL GEOSPreparedWithin_r(GEOSContextHandle_t handle,
const GEOSPreparedGeometry* pg1,
const GEOSGeometry* g2);
+/* Return 0 on exception, the closest points of the two geometries otherwise.
+ * The first point comes from pg1 geometry and the second point comes from g2.
+extern GEOSCoordSequence GEOS_DLL *GEOSPreparedNearestPoints_r(
+ GEOSContextHandle_t handle,
+ const GEOSPreparedGeometry* pg1,
+ const GEOSGeometry* g2);
* STRtree functions
@@ -1868,6 +1876,7 @@ extern char GEOS_DLL GEOSPreparedIntersects(const GEOSPreparedGeometry* pg1, con
extern char GEOS_DLL GEOSPreparedOverlaps(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
extern char GEOS_DLL GEOSPreparedTouches(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
extern char GEOS_DLL GEOSPreparedWithin(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
+extern GEOSCoordSequence GEOS_DLL *GEOSPreparedNearestPoints(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index c8abec2..6a9f6ce 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -2940,6 +2940,17 @@ extern "C" {
+ GEOSPreparedNearestPoints_r(GEOSContextHandle_t extHandle,
+ const geos::geom::prep::PreparedGeometry* pg, const Geometry* g)
+ using namespace geos::geom;
+ return execute(extHandle, [&]() -> CoordinateSequence* {
+ return pg->nearestPoints(g).release();
// STRtree
diff --git a/include/geos/geom/prep/BasicPreparedGeometry.h b/include/geos/geom/prep/BasicPreparedGeometry.h
index d66bc1d..49c0f65 100644
--- a/include/geos/geom/prep/BasicPreparedGeometry.h
+++ b/include/geos/geom/prep/BasicPreparedGeometry.h
@@ -171,6 +171,11 @@ public:
bool within(const geom::Geometry* g) const override;
+ * Default implementation.
+ std::unique_ptr<geom::CoordinateSequence> nearestPoints(const geom::Geometry* g) const override;
std::string toString();
diff --git a/include/geos/geom/prep/PreparedGeometry.h b/include/geos/geom/prep/PreparedGeometry.h
index 5e166ee..a8a0df3 100644
--- a/include/geos/geom/prep/PreparedGeometry.h
+++ b/include/geos/geom/prep/PreparedGeometry.h
@@ -19,13 +19,17 @@
#ifndef GEOS_GEOM_PREP_PREPAREDGEOMETRY_H
#define GEOS_GEOM_PREP_PREPAREDGEOMETRY_H
+#include <vector>
+#include <memory>
#include <geos/export.h>
// Forward declarations
namespace geos {
-namespace geom {
-class Geometry;
+ namespace geom {
+ class Geometry;
+ class Coordinate;
+ class CoordinateSequence;
@@ -192,6 +196,16 @@ public:
* @see Geometry#within(Geometry)
virtual bool within(const geom::Geometry* geom) const = 0;
+ /** \brief
+ * Compute the nearest locations on the base {@link Geometry} and
+ * the given geometry.
+ * @param geom the Geometry to compute the nearest point to
+ * @return true the nearest points
+ virtual std::unique_ptr<geom::CoordinateSequence> nearestPoints(const geom::Geometry* g) const = 0;
diff --git a/include/geos/geom/prep/PreparedLineString.h b/include/geos/geom/prep/PreparedLineString.h
index 7d70d2f..33c4322 100644
--- a/include/geos/geom/prep/PreparedLineString.h
+++ b/include/geos/geom/prep/PreparedLineString.h
@@ -23,6 +23,7 @@
#include <geos/geom/prep/BasicPreparedGeometry.h> // for inheritance
#include <geos/noding/SegmentString.h>
#include <geos/noding/FastSegmentSetIntersectionFinder.h>
+#include <geos/operation/distance/IndexedFacetDistance.h>
#include <memory>
@@ -41,6 +42,8 @@ class PreparedLineString : public BasicPreparedGeometry {
private:
std::unique_ptr<noding::FastSegmentSetIntersectionFinder> segIntFinder;
mutable noding::SegmentString::ConstVect segStrings;
+ mutable std::unique_ptr<operation::distance::IndexedFacetDistance> indexedDistance;
+ operation::distance::IndexedFacetDistance* getIndexedFacetDistance() const;
protected:
public:
@@ -55,6 +58,7 @@ public:
noding::FastSegmentSetIntersectionFinder* getIntersectionFinder();
bool intersects(const geom::Geometry* g) const override;
diff --git a/src/geom/prep/BasicPreparedGeometry.cpp b/src/geom/prep/BasicPreparedGeometry.cpp
index 65fca75..27f0c9f 100644
--- a/src/geom/prep/BasicPreparedGeometry.cpp
+++ b/src/geom/prep/BasicPreparedGeometry.cpp
@@ -21,6 +21,7 @@
#include <geos/geom/Coordinate.h>
#include <geos/algorithm/PointLocator.h>
#include <geos/geom/util/ComponentCoordinateExtracter.h>
+#include <geos/operation/distance/DistanceOp.h>
namespace geos {
namespace geom { // geos.geom
@@ -147,6 +148,13 @@ BasicPreparedGeometry::within(const geom::Geometry* g) const
return baseGeom->within(g);
+std::unique_ptr<geom::CoordinateSequence>
+BasicPreparedGeometry::nearestPoints(const geom::Geometry* g) const
+ operation::distance::DistanceOp dist(baseGeom, g);
+ return dist.nearestPoints();
std::string
BasicPreparedGeometry::toString()
diff --git a/src/geom/prep/PreparedLineString.cpp b/src/geom/prep/PreparedLineString.cpp
index 09ca4ea..da9d022 100644
--- a/src/geom/prep/PreparedLineString.cpp
+++ b/src/geom/prep/PreparedLineString.cpp
@@ -19,8 +19,11 @@
#include <geos/geom/prep/PreparedLineString.h>
#include <geos/geom/prep/PreparedLineStringIntersects.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/CoordinateSequenceFactory.h>
#include <geos/noding/SegmentStringUtil.h>
namespace geos {
@@ -61,6 +64,28 @@ PreparedLineString::intersects(const geom::Geometry* g) const
return PreparedLineStringIntersects::intersects(prep, g);
+/* private */
+operation::distance::IndexedFacetDistance*
+PreparedLineString::
+getIndexedFacetDistance() const
+ if(! indexedDistance ) {
+ indexedDistance.reset(new operation::distance::IndexedFacetDistance(&getGeometry()));
+ return indexedDistance.get();
+PreparedLineString::nearestPoints(const geom::Geometry* g) const
+ const GeometryFactory *gf = getGeometry().getFactory();
+ const CoordinateSequenceFactory *cf = gf->getCoordinateSequenceFactory();
+ operation::distance::IndexedFacetDistance *idf = getIndexedFacetDistance();
+ return cf->create(idf->nearestPoints(g));
} // namespace geos.geom.prep
} // namespace geos
diff --git a/src/geom/prep/PreparedPolygon.cpp b/src/geom/prep/PreparedPolygon.cpp
index 130562d..001a547 100644
--- a/src/geom/prep/PreparedPolygon.cpp
+++ b/src/geom/prep/PreparedPolygon.cpp
@@ -39,7 +39,7 @@ namespace prep { // geos.geom.prep
// public:
PreparedPolygon::PreparedPolygon(const geom::Geometry* geom)
- : BasicPreparedGeometry(geom), segIntFinder(nullptr), ptOnGeomLoc(nullptr)
+ : BasicPreparedGeometry(geom)
isRectangle = getGeometry().isRectangle();
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 87a56b2..5949522 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -106,6 +106,7 @@ geos_unit_SOURCES = \
capi/GEOSPointOnSurfaceTest.cpp \
capi/GEOSPolygonizeTest.cpp \
capi/GEOSPreparedGeometryTest.cpp \
+ capi/GEOSPreparedNearestPointsTest.cpp \
capi/GEOSProjectTest.cpp \
capi/GEOSRelateBoundaryNodeRuleTest.cpp \
capi/GEOSRelatePatternMatchTest.cpp \
diff --git a/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp b/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp
new file mode 100644
index 0000000..3217668
--- /dev/null
+++ b/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp
@@ -0,0 +1,205 @@
+// $Id: GEOSPreparedNearestPointsTest.cpp 2424 2009-04-29 23:52:36Z mloskot $
+// Test Suite for C-API GEOSPreparedNearestPoints
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capigeospreparednearestpoints_data {
+ GEOSGeometry* geom1_;
+ GEOSGeometry* geom2_;
+ const GEOSPreparedGeometry* pgeom1_;
+ static void
+ notice(const char* fmt, ...)
+ std::fprintf(stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capigeospreparednearestpoints_data()
+ : geom1_(nullptr), geom2_(nullptr), pgeom1_(nullptr)
+ initGEOS(notice, notice);
+ ~test_capigeospreparednearestpoints_data()
+ GEOSGeom_destroy(geom2_);
+ GEOSPreparedGeom_destroy(pgeom1_);
+ GEOSGeom_destroy(geom1_);
+ geom1_ = nullptr;
+ geom2_ = nullptr;
+ geom1_ = nullptr;
+ finishGEOS();
+typedef test_group<test_capigeospreparednearestpoints_data> group;
+typedef group::object object;
+group test_capigeospreparednearestpoints_group("capi::GEOSPreparedNearestPoints");
+// Test Cases
+template<>
+template<>
+void object::test<1>
+ geom1_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ pgeom1_ = GEOSPrepare(geom1_);
+ geom2_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ ensure(nullptr != pgeom1_);
+ ensure(nullptr != geom2_);
+ GEOSCoordSequence* coords_;
+ coords_ = GEOSPreparedNearestPoints(pgeom1_, geom2_);
+ ensure(nullptr == coords_);
+template<>
+template<>
+void object::test<2>
+ geom1_ = GEOSGeomFromWKT("POLYGON((1 1,1 5,5 5,5 1,1 1))");
+ geom2_ = GEOSGeomFromWKT("POLYGON((8 8, 9 9, 9 10, 8 8))");
+ ensure(nullptr != coords_);
+ unsigned int size;
+ GEOSCoordSeq_getSize(coords_, &size);
+ ensure_equals(size, 2u);
+ double x1, x2, y1, y2;
+ /* Point in pgeom1_
+ GEOSCoordSeq_getOrdinate(coords_, 0, 0, &x1);
+ GEOSCoordSeq_getOrdinate(coords_, 0, 1, &y1);
+ ensure_equals(x1, 5);
+ ensure_equals(y1, 5);
+ /* Point in geom2_
+ GEOSCoordSeq_getOrdinate(coords_, 1, 0, &x2);
+ GEOSCoordSeq_getOrdinate(coords_, 1, 1, &y2);
+ ensure_equals(x2, 8);
+ ensure_equals(y2, 8);
+ GEOSCoordSeq_destroy(coords_);
+template<>
+template<>
+void object::test<3>
+ geom2_ = GEOSGeomFromWKT("POINT(2 2)");
+ ensure(nullptr != geom1_);
+ /* Point in geom1_
+ ensure_equals(x1, 2);
+ ensure_equals(y1, 2);
+ ensure_equals(x2, 2);
+ ensure_equals(y2, 2);
+template<>
+template<>
+void object::test<4>
+ geom1_ = GEOSGeomFromWKT("LINESTRING(1 5,5 5,5 1,1 1)");
+ ensure_equals(y1, 1);
+} // namespace tut
commit d4c133f62167fcb780949c2a53cce8e9f13b6353
Date: Mon Nov 2 21:54:39 2020 +0100
Fix debug build of Envelop.inl
diff --git a/include/geos/geom/Envelope.inl b/include/geos/geom/Envelope.inl
index 3a7c049..73f32b3 100644
--- a/include/geos/geom/Envelope.inl
+++ b/include/geos/geom/Envelope.inl
@@ -25,6 +25,10 @@
#include <geos/geom/Envelope.h>
+#if GEOS_DEBUG
+# include <iostream>
+#endif
namespace geos {
namespace geom { // geos::geom
Summary of changes:
NEWS | 1 +
capi/geos_c.cpp | 6 ++
capi/geos_c.h.in | 9 ++
capi/geos_ts_c.cpp | 11 +++
include/geos/geom/Envelope.inl | 4 +
include/geos/geom/prep/BasicPreparedGeometry.h | 5 ++
include/geos/geom/prep/PreparedGeometry.h | 20 ++++-
include/geos/geom/prep/PreparedLineString.h | 4 +
src/geom/prep/BasicPreparedGeometry.cpp | 8 ++
src/geom/prep/PreparedLineString.cpp | 25 ++++++
src/geom/prep/PreparedPolygon.cpp | 2 +-
tests/unit/Makefile.am | 1 +
...sTest.cpp => GEOSPreparedNearestPointsTest.cpp} | 98 ++++++++++++++++------
13 files changed, 163 insertions(+), 31 deletions(-)
copy tests/unit/capi/{GEOSNearestPointsTest.cpp => GEOSPreparedNearestPointsTest.cpp} (53%)
hooks/post-receive
More information about the geos-commits
