[geos-commits] [SCM] GEOS branch master updated. 1b6521ef1c8ecd8098e8d27233030b689a33992f
git at osgeo.org
git at osgeo.org
Mon Nov 2 15:38:12 PST 2020
the project "GEOS".
via 1b6521ef1c8ecd8098e8d27233030b689a33992f (commit)
via 94b4dc53f62634a8c2e9545c2311254c4f83aaae (commit)
via 73a73ebc4054064ef22b1c18dd0f74b6d7cdd160 (commit)
from ba34ee20395a4d30027776de4a734a88bf8767b8 (commit)
revisions in full, below.
commit 1b6521ef1c8ecd8098e8d27233030b689a33992f
Merge: 94b4dc5 ba34ee2
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Nov 2 15:36:41 2020 -0800
Merge branch 'master' of https://git.osgeo.org/gitea/geos/geos
commit 94b4dc53f62634a8c2e9545c2311254c4f83aaae
Date: Mon Nov 2 15:36:34 2020 -0800
Comment out accidental test case
diff --git a/tests/unit/operation/valid/MakeValidTest.cpp b/tests/unit/operation/valid/MakeValidTest.cpp
index bad9f26..53bc8ec 100644
--- a/tests/unit/operation/valid/MakeValidTest.cpp
+++ b/tests/unit/operation/valid/MakeValidTest.cpp
@@ -69,39 +69,39 @@ void object::test<1>
ensure(validGeom->isValid());
-template<>
-template<>
-void object::test<2>
+// template<>
+// template<>
+// void object::test<2>
- std::ifstream ifs("GoesBathymetryBug.txt");
- std::string content((std::istreambuf_iterator<char>(ifs)),
- (std::istreambuf_iterator<char>()));
+// std::ifstream ifs("GoesBathymetryBug.txt");
+// std::string content((std::istreambuf_iterator<char>(ifs)),
+// (std::istreambuf_iterator<char>()));
- geos::io::WKTReader reader;
- auto geom(reader.read(content));
+// geos::io::WKTReader reader;
+// auto geom(reader.read(content));
- // auto gf = GeometryFactory::getDefaultInstance();
+// // auto gf = GeometryFactory::getDefaultInstance();
- // auto cs = gf->getCoordinateSequenceFactory()->create(std::move(v));
- // auto lr = gf->createLinearRing(std::move(cs));
- // auto errplyg = gf->createPolygon(std::move(lr));
+// // auto cs = gf->getCoordinateSequenceFactory()->create(std::move(v));
+// // auto lr = gf->createLinearRing(std::move(cs));
+// // auto errplyg = gf->createPolygon(std::move(lr));
- // ensure(!errplyg->isValid());
+// // ensure(!errplyg->isValid());
- MakeValid mkvalid;
- auto validGeom = mkvalid.build(geom.get());
- ensure("MakeValid output is not valid", validGeom->isValid());
+// MakeValid mkvalid;
+// auto validGeom = mkvalid.build(geom.get());
+// ensure("MakeValid output is not valid", validGeom->isValid());
- geos::io::WKTWriter writer;
- writer.setOutputDimension(2);
- writer.setTrim(true);
- std::string result = writer.write(validGeom.get());
- std::cout << result << std::endl;
+// geos::io::WKTWriter writer;
+// writer.setOutputDimension(2);
+// writer.setTrim(true);
+// std::string result = writer.write(validGeom.get());
+// std::cout << result << std::endl;
commit 73a73ebc4054064ef22b1c18dd0f74b6d7cdd160
Date: Mon Nov 2 14:55:36 2020 -0800
Use shuffle instead of random_shuffle to avoid C++ deprecations, use a type-strong enumeration
diff --git a/include/geos/algorithm/LineIntersector.h b/include/geos/algorithm/LineIntersector.h
index 771a524..8b1232e 100644
--- a/include/geos/algorithm/LineIntersector.h
+++ b/include/geos/algorithm/LineIntersector.h
@@ -128,14 +128,7 @@ public:
/// Same as above but doesn't compute intersection point. Faster.
static bool hasIntersection(const geom::Coordinate& p, const geom::Coordinate& p1, const geom::Coordinate& p2);
- // These are deprecated, due to ambiguous naming
- enum {
- DONT_INTERSECT = 0,
- DO_INTERSECT = 1,
- COLLINEAR = 2
- enum {
+ enum intersection_type : unsigned char {
/// Indicates that line segments do not intersect
NO_INTERSECTION = 0,
diff --git a/src/noding/snapround/HotPixelIndex.cpp b/src/noding/snapround/HotPixelIndex.cpp
index 157d06e..58e1533 100644
--- a/src/noding/snapround/HotPixelIndex.cpp
+++ b/src/noding/snapround/HotPixelIndex.cpp
@@ -17,6 +17,7 @@
#include <geos/index/ItemVisitor.h>
#include <geos/geom/CoordinateSequence.h>
+#include <random>
#include <algorithm> // for std::min and std::max
#include <cassert>
#include <memory>
@@ -89,7 +90,10 @@ HotPixelIndex::add(const CoordinateSequence *pts)
for (size_t i = 0, sz = pts->size(); i < sz; i++)
idxs.push_back(i);
- std::random_shuffle(idxs.begin(), idxs.end());
+ std::random_device rd;
+ std::mt19937 g(rd());
+ std::shuffle(idxs.begin(), idxs.end(), g);
for (auto i : idxs) {
add(pts->getAt(i));
@@ -103,7 +107,9 @@ HotPixelIndex::add(const std::vector<geom::Coordinate>& pts)
for (size_t i = 0, sz = pts.size(); i < sz; i++)
idxs.push_back(i);
add(pts[i]);
index 7eeda21..bad9f26 100644
@@ -6,10 +6,13 @@
#include <geos/geom/Polygon.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/operation/valid/MakeValid.h>
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
// std
#include <cmath>
#include <string>
#include <vector>
+#include <fstream>
using namespace geos::geom;
using namespace geos::operation::valid;
@@ -66,4 +69,40 @@ void object::test<1>
+template<>
+template<>
+void object::test<2>
+ std::ifstream ifs("GoesBathymetryBug.txt");
+ std::string content((std::istreambuf_iterator<char>(ifs)),
+ (std::istreambuf_iterator<char>()));
+ geos::io::WKTReader reader;
+ auto geom(reader.read(content));
+ // auto gf = GeometryFactory::getDefaultInstance();
+ // auto cs = gf->getCoordinateSequenceFactory()->create(std::move(v));
+ // auto lr = gf->createLinearRing(std::move(cs));
+ // auto errplyg = gf->createPolygon(std::move(lr));
+ // ensure(!errplyg->isValid());
+ MakeValid mkvalid;
+ auto validGeom = mkvalid.build(geom.get());
+ ensure("MakeValid output is not valid", validGeom->isValid());
+ geos::io::WKTWriter writer;
+ writer.setOutputDimension(2);
+ writer.setTrim(true);
+ std::string result = writer.write(validGeom.get());
+ std::cout << result << std::endl;
} // namespace tut
Summary of changes:
include/geos/algorithm/LineIntersector.h | 9 +------
src/noding/snapround/HotPixelIndex.cpp | 10 +++++--
tests/unit/operation/valid/MakeValidTest.cpp | 39 ++++++++++++++++++++++++++++
3 files changed, 48 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits
