[geos-commits] [SCM] GEOS branch master updated. fa24fb2f3bd84cd70309f8594aa29738661e94ca
git at osgeo.org
git at osgeo.org
Fri Nov 6 10:46:26 PST 2020
the project "GEOS".
via fa24fb2f3bd84cd70309f8594aa29738661e94ca (commit)
from 531b9e623107a325a87cc5cbf7c6a399217b3fdd (commit)
revisions in full, below.
commit fa24fb2f3bd84cd70309f8594aa29738661e94ca
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 6 10:37:40 2020 -0800
Correctly handle higher-dimension empty geometries in the WKB reader.
diff --git a/.gitignore b/.gitignore
index 8084631..bdb9610 100644
--- a/.gitignore
+++ b/.gitignore
@@ -18,6 +18,7 @@ Makefile
*.swp
*.trs
*.exe
+.DS_Store
macros/libtool.m4
macros/ltoptions.m4
macros/ltsugar.m4
diff --git a/src/geom/Point.cpp b/src/geom/Point.cpp
index 5c3d083..4536640 100644
--- a/src/geom/Point.cpp
+++ b/src/geom/Point.cpp
@@ -44,6 +44,7 @@ namespace geom { // geos::geom
const static FixedSizeCoordinateSequence<0> emptyCoords2d(2);
const static FixedSizeCoordinateSequence<0> emptyCoords3d(3);
/*protected*/
Point::Point(CoordinateSequence* newCoords, const GeometryFactory* factory)
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index a2b21c9..aa13d29 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -279,6 +279,12 @@ std::unique_ptr<Point>
WKBReader::readPoint()
readCoordinate();
+ // POINT EMPTY
+ if (std::isnan(ordValues[0]) && std::isnan(ordValues[1])) {
+ return std::unique_ptr<Point>(factory.createPoint(hasZ ? 3 : 2));
if (hasZ) {
return std::unique_ptr<Point>(factory.createPoint(Coordinate(ordValues[0], ordValues[1], ordValues[2])));
@@ -318,6 +324,10 @@ WKBReader::readPolygon()
cout << "WKB numRings: " << numRings << endl;
#endif
+ if(numRings == 0) {
+ return factory.createPolygon(hasZ ? 3 : 2);
std::unique_ptr<LinearRing> shell;
if(numRings > 0) {
shell = readLinearRing();
diff --git a/tests/unit/io/WKBReaderTest.cpp b/tests/unit/io/WKBReaderTest.cpp
index 82cd14d..5e2f2e9 100644
--- a/tests/unit/io/WKBReaderTest.cpp
+++ b/tests/unit/io/WKBReaderTest.cpp
@@ -52,6 +52,14 @@ struct test_wkbreader_data {
wktreader(gf.get())
+ GeomPtr
+ readHex(const std::string& hexwkb)
+ std::stringstream hexin(hexwkb);
+ GeomPtr g(wkbreader.readHEX(hexin));
+ return g;
void
testInput(const std::string& hexwkb,
const std::string& expected)
@@ -524,5 +532,46 @@ void object::test<23>
+// EMPTY WKB TESTS
+template<>
+template<>
+void object::test<24>
+ GeomPtr g;
+ // POINT EMPTY
+ g = readHex(std::string("0101000000000000000000F87F000000000000F87F"));
+ ensure_equals("POINT EMPTY isEmpty", g->isEmpty(), 1);
+ ensure_equals("POINT EMPTY getCoordinateDimension", g->getCoordinateDimension(), 2);
+ // POINT Z EMPTY
+ g = readHex(std::string("0101000080000000000000F87F000000000000F87F000000000000F87F"));
+ ensure_equals("POINT Z EMPTY isEmpty", g->isEmpty(), 1);
+ ensure_equals("POINT Z EMPTY getCoordinateDimension", g->getCoordinateDimension(), 3);
+ // LINESTRING EMPTY
+ g = readHex(std::string("010200000000000000"));
+ ensure_equals("LINESTRING EMPTY isEmpty", g->isEmpty(), 1);
+ ensure_equals("LINESTRING EMPTY getCoordinateDimension", g->getCoordinateDimension(), 2);
+ // LINESTRING Z EMPTY
+ g = readHex(std::string("010200008000000000"));
+ ensure_equals("LINESTRING Z EMPTY isEmpty", g->isEmpty(), 1);
+ ensure_equals("LINESTRING Z EMPTY getCoordinateDimension", g->getCoordinateDimension(), 3);
+ // POLYGON EMPTY
+ g = readHex(std::string("010300000000000000"));
+ ensure_equals("POLYGON EMPTY isEmpty", g->isEmpty(), 1);
+ ensure_equals("POLYGON EMPTY getCoordinateDimension", g->getCoordinateDimension(), 2);
+ // POLYGON Z EMPTY
+ g = readHex(std::string("010300008000000000"));
+ ensure_equals("POLYGON Z EMPTY isEmpty", g->isEmpty(), 1);
+ ensure_equals("POLYGON Z EMPTY getCoordinateDimension", g->getCoordinateDimension(), 3);
} // namespace tut
Summary of changes:
.gitignore | 1 +
src/geom/Point.cpp | 1 +
src/io/WKBReader.cpp | 10 +++++++++
tests/unit/io/WKBReaderTest.cpp | 49 +++++++++++++++++++++++++++++++++++++++++
4 files changed, 61 insertions(+)
hooks/post-receive
More information about the geos-commits
