[geos-commits] [SCM] GEOS branch master updated. 07e60468a9a155c63b06fa1e24db7c113f03004a
git at osgeo.org
git at osgeo.org
Fri Nov 6 11:08:19 PST 2020
the project "GEOS".
via 07e60468a9a155c63b06fa1e24db7c113f03004a (commit)
from fa24fb2f3bd84cd70309f8594aa29738661e94ca (commit)
revisions in full, below.
commit 07e60468a9a155c63b06fa1e24db7c113f03004a
Author: sumeerbhola <sumeer at cockroachlabs.com>
Date: Wed Sep 2 09:45:45 2020 -0400
Fix segfault in SimplePointInAreaLocator caused by casting MultiPolygon to Polygon
Closes #1047
References https://github.com/cockroachdb/cockroach/issues/53254
Signed-off-by: Sandro Santilli <strk at kbt.io>
diff --git a/src/algorithm/locate/SimplePointInAreaLocator.cpp b/src/algorithm/locate/SimplePointInAreaLocator.cpp
index e6ba6b2..df3a39e 100644
--- a/src/algorithm/locate/SimplePointInAreaLocator.cpp
+++ b/src/algorithm/locate/SimplePointInAreaLocator.cpp
@@ -67,15 +67,17 @@ SimplePointInAreaLocator::locateInGeometry(const Coordinate& p, const Geometry*
if (geom->getNumGeometries() == 1) {
- return locatePointInPolygon(p, dynamic_cast<const Polygon*>(geom->getGeometryN(0)));
- } else {
- for (size_t i = 0; i < geom->getNumGeometries(); i++) {
- const Geometry* gi = geom->getGeometryN(i);
- auto loc = locateInGeometry(p, gi);
- if(loc != Location::EXTERIOR) {
- return loc;
+ auto poly = dynamic_cast<const Polygon*>(geom->getGeometryN(0));
+ if (poly) {
+ return locatePointInPolygon(p, poly);
+ // Else it is a collection with a single element. Will be handled below.
+ for (size_t i = 0; i < geom->getNumGeometries(); i++) {
+ const Geometry* gi = geom->getGeometryN(i);
+ auto loc = locateInGeometry(p, gi);
+ if(loc != Location::EXTERIOR) {
+ return loc;
diff --git a/tests/unit/algorithm/PointLocatorTest.cpp b/tests/unit/algorithm/PointLocatorTest.cpp
index bc63b07..a230d96 100644
--- a/tests/unit/algorithm/PointLocatorTest.cpp
+++ b/tests/unit/algorithm/PointLocatorTest.cpp
@@ -5,6 +5,7 @@
#include <tut/tut.hpp>
// geos
#include <geos/io/WKTReader.h>
+#include <geos/algorithm/locate/SimplePointInAreaLocator.h>
#include <geos/algorithm/PointLocator.h>
#include <geos/geom/PrecisionModel.h>
#include <geos/geom/GeometryFactory.h>
@@ -56,6 +57,14 @@ runPtLocator(Location expected, const Coordinate& pt,
ensure_equals(loc, expected);
+void
+runSimplePtLocator(Location expected, const Coordinate& pt,
+ const std::string& wkt)
+ GeomPtr geom(reader.read(wkt));
+ Location loc = geos::algorithm::locate::SimplePointInAreaLocator::locate(pt, geom.get());
+ ensure_equals(loc, expected);
// Test Cases
@@ -111,5 +120,15 @@ void object::test<5>
"MULTIPOINT ((1 1), (0 0))");
+// 6 - TestPointLocator Point inside GeometryCollection containing MultiPolygon, using SimplePointInAreaLocator.
+template<>
+template<>
+void object::test<6>
+ runSimplePtLocator(Location::INTERIOR, Coordinate(0, 0),
+ "GEOMETRYCOLLECTION (MULTIPOLYGON (((-1 -1, 1 -1, 1 1, -1 1, -1 -1))))");
} // namespace tut
Summary of changes:
src/algorithm/locate/SimplePointInAreaLocator.cpp | 20 +++++++++++---------
tests/unit/algorithm/PointLocatorTest.cpp | 19 +++++++++++++++++++
2 files changed, 30 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits
