[geos-commits] [SCM] GEOS branch master updated. 03e8090d9a2019402dbb0d3c2931eac75d11030e
git at osgeo.org
git at osgeo.org
Mon Nov 9 01:14:18 PST 2020
the project "GEOS".
via 03e8090d9a2019402dbb0d3c2931eac75d11030e (commit)
from 26cd4782faf7451c7a3df6a33a462b2669ef5153 (commit)
revisions in full, below.
commit 03e8090d9a2019402dbb0d3c2931eac75d11030e
Author: Sandro Santilli <strk at kbt.io>
Date: Sat Nov 7 12:19:44 2020 +0100
Port Z handling in JTS Intersection
References #1063
diff --git a/include/geos/algorithm/LineIntersector.h b/include/geos/algorithm/LineIntersector.h
index 8b1232e..2ac07fe 100644
--- a/include/geos/algorithm/LineIntersector.h
+++ b/include/geos/algorithm/LineIntersector.h
@@ -343,8 +343,56 @@ private:
geom::Coordinate intersectionSafe(const geom::Coordinate& p1, const geom::Coordinate& p2,
const geom::Coordinate& q1, const geom::Coordinate& q2) const;
+ * Finds the endpoint of the segments P and Q which
+ * is closest to the other segment.
+ * This is a reasonable surrogate for the true
+ * intersection points in ill-conditioned cases
+ * (e.g. where two segments are nearly coincident,
+ * or where the endpoint of one segment lies almost on the other segment).
+ * <p>
+ * This replaces the older CentralEndpoint heuristic,
+ * which chose the wrong endpoint in some cases
+ * where the segments had very distinct slopes
+ * and one endpoint lay almost on the other segment.
+ * @param p1 an endpoint of segment P
+ * @param p2 an endpoint of segment P
+ * @param q1 an endpoint of segment Q
+ * @param q2 an endpoint of segment Q
+ * @return the nearest endpoint to the other segment
+ static geom::Coordinate nearestEndpoint(const geom::Coordinate& p1,
+ const geom::Coordinate& p2,
+ const geom::Coordinate& q1,
+ const geom::Coordinate& q2);
+ static double zGet(const geom::Coordinate& p, const geom::Coordinate& q);
+ static double zGetOrInterpolate(const geom::Coordinate& p,
+ const geom::Coordinate& p0,
+ const geom::Coordinate& p1);
+ static geom::Coordinate zGetOrInterpolateCopy(const geom::Coordinate& p,
+ /// \brief
+ /// Return a Z value being the interpolation of Z from p0 to p1 at
+ /// the given point p
+ static double zInterpolate(const geom::Coordinate& p,
+ const geom::Coordinate& p1,
} // namespace geos::algorithm
} // namespace geos
diff --git a/src/algorithm/LineIntersector.cpp b/src/algorithm/LineIntersector.cpp
index 10878b7..080590c 100644
--- a/src/algorithm/LineIntersector.cpp
+++ b/src/algorithm/LineIntersector.cpp
@@ -41,10 +41,6 @@
#include <iostream>
#endif
-#ifndef COMPUTE_Z
-#define COMPUTE_Z 1
-#endif // COMPUTE_Z
using namespace std;
using namespace geos::geom;
@@ -52,54 +48,6 @@ using namespace geos::geom;
namespace geos {
namespace algorithm { // geos.algorithm
-namespace { // anonymous
- * Finds the endpoint of the segments P and Q which
- * is closest to the other segment.
- * This is a reasonable surrogate for the true
- * intersection points in ill-conditioned cases
- * (e.g. where two segments are nearly coincident,
- * or where the endpoint of one segment lies almost on the other segment).
- * <p>
- * This replaces the older CentralEndpoint heuristic,
- * which chose the wrong endpoint in some cases
- * where the segments had very distinct slopes
- * and one endpoint lay almost on the other segment.
- * @param p1 an endpoint of segment P
- * @param p2 an endpoint of segment P
- * @param q1 an endpoint of segment Q
- * @param q2 an endpoint of segment Q
- * @return the nearest endpoint to the other segment
-Coordinate
-nearestEndpoint(const Coordinate& p1, const Coordinate& p2,
- const Coordinate& q1, const Coordinate& q2)
- const Coordinate* nearestPt = &p1;
- double minDist = Distance::pointToSegment(p1, q1, q2);
- double dist = Distance::pointToSegment(p2, q1, q2);
- if(dist < minDist) {
- minDist = dist;
- nearestPt = &p2;
- dist = Distance::pointToSegment(q1, p1, p2);
- minDist = dist;
- nearestPt = &q1;
- dist = Distance::pointToSegment(q2, p1, p2);
- nearestPt = &q2;
- return *nearestPt;
-} // anonymous namespace
/*public static*/
double
LineIntersector::computeEdgeDistance(const Coordinate& p, const Coordinate& p0, const Coordinate& p1)
@@ -347,21 +295,6 @@ LineIntersector::computeIntersection(const Coordinate& p, const Coordinate& p1,
if((p == p1) || (p == p2)) { // 2d only test
isProperVar = false;
-#if COMPUTE_Z
- intPt[0] = p;
-#if GEOS_DEBUG
- cerr << "RobustIntersector::computeIntersection(Coordinate,Coordinate,Coordinate) calling interpolateZ" << endl;
-#endif
- double z = interpolateZ(p, p1, p2);
- if(!std::isnan(z)) {
- if(std::isnan(intPt[0].z)) {
- intPt[0].z = z;
- else {
- intPt[0].z = (intPt[0].z + z) / 2;
result = POINT_INTERSECTION;
return;
@@ -426,6 +359,9 @@ LineIntersector::computeIntersect(const Coordinate& p1, const Coordinate& p2,
return NO_INTERSECTION;
+ * Intersection is collinear if each endpoint lies on the other line.
bool collinear = Pq1 == 0 && Pq2 == 0 && Qp1 == 0 && Qp2 == 0;
if(collinear) {
#if GEOS_DEBUG
@@ -449,13 +385,17 @@ LineIntersector::computeIntersect(const Coordinate& p1, const Coordinate& p2,
* since at this point we know that the inputLines must
* intersect.
+ Coordinate p;
+ double z = std::numeric_limits<double>::quiet_NaN();
if(Pq1 == 0 || Pq2 == 0 || Qp1 == 0 || Qp2 == 0) {
-#if COMPUTE_Z
- int hits = 0;
- double z = 0.0;
-#endif
+#if GEOS_DEBUG
+ cerr << " intersection is NOT proper" << endl;
+#endif
/* Check for two equal endpoints.
* This is done explicitly rather than by the orientation tests
* below in order to improve robustness.
@@ -469,81 +409,61 @@ LineIntersector::computeIntersect(const Coordinate& p1, const Coordinate& p2,
* LINESTRING ( -48.51001596420236 -22.063180333403878,
* 19.850257749638203 46.29709338043669 )
- * which used to produce the result:
+ * which used to produce the INCORRECT result:
* (20.31970698357233, 46.76654261437082, NaN)
- if(p1.equals2D(q1) || p1.equals2D(q2)) {
- intPt[0] = p1;
-#if COMPUTE_Z
- if(!std::isnan(p1.z)) {
- z += p1.z;
- hits++;
-#endif
+ if (p1.equals2D(q1)) {
+ p = p1;
+ z = zGet(p1, q1);
- else if(p2.equals2D(q1) || p2.equals2D(q2)) {
- intPt[0] = p2;
-#if COMPUTE_Z
- if(!std::isnan(p2.z)) {
- z += p2.z;
- hits++;
-#endif
+ else if (p1.equals2D(q2)) {
+ p = p1;
+ z = zGet(p1, q2);
+ else if (p2.equals2D(q1)) {
+ p = p2;
+ z = zGet(p2, q1);
+ else if (p2.equals2D(q2)) {
+ p = p2;
+ z = zGet(p2, q2);
* Now check to see if any endpoint lies on the interior of the other segment.
else if(Pq1 == 0) {
- intPt[0] = q1;
-#if COMPUTE_Z
- if(!std::isnan(q1.z)) {
- z += q1.z;
- hits++;
-#endif
+ p = q1;
+ z = zGetOrInterpolate(q1, p1, p2);
else if(Pq2 == 0) {
- intPt[0] = q2;
-#if COMPUTE_Z
- if(!std::isnan(q2.z)) {
- z += q2.z;
- hits++;
-#endif
+ p = q2;
+ z = zGetOrInterpolate(q2, p1, p2);
else if(Qp1 == 0) {
- intPt[0] = p1;
-#if COMPUTE_Z
- z += p1.z;
- hits++;
-#endif
+ p = p1;
+ z = zGetOrInterpolate(p1, q1, q2);
else if(Qp2 == 0) {
- intPt[0] = p2;
-#if COMPUTE_Z
- z += p2.z;
- hits++;
-#endif
+ p = p2;
+ z = zGetOrInterpolate(p2, q1, q2);
-#if COMPUTE_Z
-#if GEOS_DEBUG
- cerr << "LineIntersector::computeIntersect: z:" << z << " hits:" << hits << endl;
-#endif // GEOS_DEBUG
- if(hits) {
- intPt[0].z = z / hits;
else {
+#if GEOS_DEBUG
+ cerr << " intersection is proper" << endl;
+#endif // GEOS_DEBUG
isProperVar = true;
- intPt[0] = intersection(p1, p2, q1, q2);
+ p = intersection(p1, p2, q1, q2);
+#if GEOS_DEBUG
+ cerr << " computed intersection point: " << p << endl;
+ z = zInterpolate(p, p1, p2, q1, q2);
+#if GEOS_DEBUG
+ cerr << " computed proper intersection Z: " << z << endl;
+ intPt[0] = Coordinate(p.x, p.y, z);
#if GEOS_DEBUG
cerr << " POINT_INTERSECTION; intPt[0]:" << intPt[0].toString() << endl;
@@ -555,14 +475,6 @@ int
LineIntersector::computeCollinearIntersection(const Coordinate& p1, const Coordinate& p2,
-#if COMPUTE_Z
- double ztot;
- int hits;
- double p2z;
- double p1z;
- double q1z;
- double q2z;
#if GEOS_DEBUG
cerr << "LineIntersector::computeCollinearIntersection called" << endl;
@@ -570,270 +482,84 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1, const Coordi
endl;
- bool p1q1p2 = Envelope::intersects(p1, p2, q1);
- bool p1q2p2 = Envelope::intersects(p1, p2, q2);
- bool q1p1q2 = Envelope::intersects(q1, q2, p1);
- bool q1p2q2 = Envelope::intersects(q1, q2, p2);
+ bool q1inP = Envelope::intersects(p1, p2, q1);
+ bool q2inP = Envelope::intersects(p1, p2, q2);
+ bool p1inQ = Envelope::intersects(q1, q2, p1);
+ bool p2inQ = Envelope::intersects(q1, q2, p2);
- if(p1q1p2 && p1q2p2) {
+ if(q1inP && q2inP) {
#if GEOS_DEBUG
- cerr << " p1q1p2 && p1q2p2" << endl;
-#endif
- intPt[0] = q1;
-#if COMPUTE_Z
- ztot = 0;
- hits = 0;
- q1z = interpolateZ(q1, p1, p2);
- if(!std::isnan(q1z)) {
- ztot += q1z;
- hits++;
- ztot += q1.z;
- hits++;
- if(hits) {
- intPt[0].z = ztot / hits;
-#endif
- intPt[1] = q2;
-#if COMPUTE_Z
- ztot = 0;
- hits = 0;
- q2z = interpolateZ(q2, p1, p2);
- if(!std::isnan(q2z)) {
- ztot += q2z;
- hits++;
- ztot += q2.z;
- hits++;
- if(hits) {
- intPt[1].z = ztot / hits;
+ cerr << " q1inP && q2inP" << endl;
#endif
+ intPt[0] = zGetOrInterpolateCopy(q1, p1, p2);
+ intPt[1] = zGetOrInterpolateCopy(q2, p1, p2);
#if GEOS_DEBUG
cerr << " intPt[0]: " << intPt[0].toString() << endl;
cerr << " intPt[1]: " << intPt[1].toString() << endl;
#endif
return COLLINEAR_INTERSECTION;
- if(q1p1q2 && q1p2q2) {
+ if(p1inQ && p2inQ) {
#if GEOS_DEBUG
- cerr << " q1p1q2 && q1p2q2" << endl;
-#endif
- intPt[0] = p1;
-#if COMPUTE_Z
- ztot = 0;
- hits = 0;
- p1z = interpolateZ(p1, q1, q2);
- if(!std::isnan(p1z)) {
- ztot += p1z;
- hits++;
- ztot += p1.z;
- hits++;
- if(hits) {
-#endif
- intPt[1] = p2;
-#if COMPUTE_Z
- ztot = 0;
- hits = 0;
- p2z = interpolateZ(p2, q1, q2);
- if(!std::isnan(p2z)) {
- ztot += p2z;
- hits++;
- ztot += p2.z;
- hits++;
- if(hits) {
+ cerr << " p1inQ && p2inQ" << endl;
#endif
+ intPt[0] = zGetOrInterpolateCopy(p1, q1, q2);
+ intPt[1] = zGetOrInterpolateCopy(p2, q1, q2);
- if(p1q1p2 && q1p1q2) {
+ if(q1inP && p1inQ) {
#if GEOS_DEBUG
- cerr << " p1q1p2 && q1p1q2" << endl;
-#endif
- intPt[0] = q1;
-#if COMPUTE_Z
- ztot = 0;
- hits = 0;
- ztot += q1z;
- hits++;
- ztot += q1.z;
- hits++;
- if(hits) {
-#endif
- intPt[1] = p1;
-#if COMPUTE_Z
- ztot = 0;
- hits = 0;
- ztot += p1z;
- hits++;
- ztot += p1.z;
- hits++;
- if(hits) {
+ cerr << " q1inP && p1inQ" << endl;
#endif
+ // if pts are equal Z is chosen arbitrarily
+ intPt[1] = zGetOrInterpolateCopy(p1, q1, q2);
#if GEOS_DEBUG
#endif
- return (q1 == p1) && !p1q2p2 && !q1p2q2 ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
+ return (q1 == p1) && !q2inP && !p2inQ ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
- if(p1q1p2 && q1p2q2) {
+ if(q1inP && p2inQ) {
#if GEOS_DEBUG
- cerr << " p1q1p2 && q1p2q2" << endl;
-#endif
- intPt[0] = q1;
-#if COMPUTE_Z
- ztot = 0;
- hits = 0;
- ztot += q1z;
- hits++;
- ztot += q1.z;
- hits++;
- if(hits) {
-#endif
- intPt[1] = p2;
-#if COMPUTE_Z
- ztot = 0;
- hits = 0;
- ztot += p2z;
- hits++;
- ztot += p2.z;
- hits++;
- if(hits) {
+ cerr << " q1inP && p2inQ" << endl;
#endif
#if GEOS_DEBUG
#endif
- return (q1 == p2) && !p1q2p2 && !q1p1q2 ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
+ return (q1 == p2) && !q2inP && !p1inQ ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
- if(p1q2p2 && q1p1q2) {
+ if(q2inP && p1inQ) {
#if GEOS_DEBUG
- cerr << " p1q2p2 && q1p1q2" << endl;
-#endif
- intPt[0] = q2;
-#if COMPUTE_Z
- ztot = 0;
- hits = 0;
- ztot += q2z;
- hits++;
- ztot += q2.z;
- hits++;
- if(hits) {
-#endif
- intPt[1] = p1;
-#if COMPUTE_Z
- ztot = 0;
- hits = 0;
- ztot += p1z;
- hits++;
- ztot += p1.z;
- hits++;
- if(hits) {
+ cerr << " q2inP && p1inQ" << endl;
#endif
+ intPt[0] = zGetOrInterpolateCopy(q2, p1, p2);
#if GEOS_DEBUG
#endif
- return (q2 == p1) && !p1q1p2 && !q1p2q2 ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
+ return (q2 == p1) && !q1inP && !p2inQ ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
- if(p1q2p2 && q1p2q2) {
+ if(q2inP && p2inQ) {
#if GEOS_DEBUG
- cerr << " p1q2p2 && q1p2q2" << endl;
-#endif
- intPt[0] = q2;
-#if COMPUTE_Z
- ztot = 0;
- hits = 0;
- ztot += q2z;
- hits++;
- ztot += q2.z;
- hits++;
- if(hits) {
-#endif
- intPt[1] = p2;
-#if COMPUTE_Z
- ztot = 0;
- hits = 0;
- ztot += p2z;
- hits++;
- ztot += p2.z;
- hits++;
- if(hits) {
+ cerr << " q2inP && p2inQ" << endl;
#endif
#if GEOS_DEBUG
#endif
- return (q2 == p2) && !p1q1p2 && !q1p1q2 ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
+ return (q2 == p2) && !q1inP && !p1inQ ? POINT_INTERSECTION : COLLINEAR_INTERSECTION;
@@ -874,24 +600,6 @@ LineIntersector::intersection(const Coordinate& p1, const Coordinate& p2,
precisionModel->makePrecise(intPtOut);
-#if COMPUTE_Z
- double ztot = 0;
- double zvals = 0;
- double zp = interpolateZ(intPtOut, p1, p2);
- double zq = interpolateZ(intPtOut, q1, q2);
- if(!std::isnan(zp)) {
- ztot += zp;
- zvals++;
- if(!std::isnan(zq)) {
- ztot += zq;
- zvals++;
- if(zvals) {
- intPtOut.z = ztot / zvals;
return intPtOut;
@@ -916,6 +624,142 @@ LineIntersector::intersectionSafe(const Coordinate& p1, const Coordinate& p2,
return ptInt;
+/* private static */
+double
+LineIntersector::zGet(const Coordinate& p, const Coordinate& q)
+ double z = p.z;
+ if ( std::isnan(z) ) {
+ z = q.z; // may be NaN
+ return z;
+double
+LineIntersector::zInterpolate(const Coordinate& p, const Coordinate& p1, const Coordinate& p2)
+#if GEOS_DEBUG
+ cerr << " zInterpolate " << p << ", " << p1 << ", " << p2 << std::endl;
+#endif
+ double p1z = p1.z;
+ double p2z = p2.z;
+ if (std::isnan(p1z)) {
+ return p2z; // may be NaN
+ if (std::isnan(p2z)) {
+ return p1z; // may be NaN
+ if (p.equals2D(p1)) {
+ return p1z; // not NaN
+ if (p.equals2D(p2)) {
+ return p2z; // not NaN
+ double dz = p2z - p1z;
+ if (dz == 0.0) {
+ return p1z;
+#if GEOS_DEBUG
+ cerr << " Interpolating Z from distance of p along p1-p2" << endl;
+#endif
+ // interpolate Z from distance of p along p1-p2
+ double dx = (p2.x - p1.x);
+ double dy = (p2.y - p1.y);
+ // seg has non-zero length since p1 < p < p2
+ double seglen = (dx * dx + dy * dy);
+ double xoff = (p.x - p1.x);
+ double yoff = (p.y - p1.y);
+ double plen = (xoff * xoff + yoff * yoff);
+ double frac = sqrt(plen / seglen);
+ double zoff = dz * frac;
+ double zInterpolated = p1z + zoff;
+#if GEOS_DEBUG
+ cerr << " interpolated Z: " << zInterpolated << std::endl;
+#endif
+ return zInterpolated;
+double
+LineIntersector::zGetOrInterpolate(const Coordinate& p, const Coordinate& p1, const Coordinate& p2)
+ double z = p.z;
+ if (! std::isnan(z) ) return z;
+ return zInterpolate(p, p1, p2); // may be NaN
+Coordinate
+LineIntersector::zGetOrInterpolateCopy(
+ const Coordinate& p,
+ const Coordinate& p1,
+ const Coordinate& p2)
+ Coordinate pCopy = p;
+ double z = zGetOrInterpolate(p, p1, p2);
+ pCopy.z = z;
+ return pCopy;
+double
+ const Coordinate& p2,
+ const Coordinate& q1,
+ const Coordinate& q2)
+#if GEOS_DEBUG
+ cerr << " zInterpolate(5 coords) called" << endl;
+ double zp = zInterpolate(p, p1, p2);
+#if GEOS_DEBUG
+ cerr << " zp: " << zp << endl;
+ double zq = zInterpolate(p, q1, q2);
+#if GEOS_DEBUG
+ cerr << " zq: " << zq << endl;
+ if (std::isnan(zp)) {
+ return zq; // may be NaN
+ if (std::isnan(zq)) {
+ return zp; // may be NaN
+#if GEOS_DEBUG
+ cerr << " averaging Z" << endl;
+ // both Zs have values, so average them
+ return (zp + zq) / 2.0;
+Coordinate
+LineIntersector::nearestEndpoint(const Coordinate& p1, const Coordinate& p2,
+ const Coordinate& q1, const Coordinate& q2)
+ const Coordinate* nearestPt = &p1;
+ double minDist = Distance::pointToSegment(p1, q1, q2);
+ double dist = Distance::pointToSegment(p2, q1, q2);
+ if(dist < minDist) {
+ minDist = dist;
+ nearestPt = &p2;
+ dist = Distance::pointToSegment(q1, p1, p2);
+ minDist = dist;
+ nearestPt = &q1;
+ dist = Distance::pointToSegment(q2, p1, p2);
+ nearestPt = &q2;
+ return *nearestPt;
} // namespace geos.algorithm
} // namespace geos
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 5949522..edda8c1 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -62,6 +62,7 @@ geos_unit_SOURCES = \
algorithm/PointLocatorTest.cpp \
algorithm/RobustLineIntersectionTest.cpp \
algorithm/RobustLineIntersectorTest.cpp \
+ algorithm/RobustLineIntersectorZTest.cpp \
capi/GEOSBufferTest.cpp \
capi/GEOSBuildAreaTest.cpp \
capi/GEOSCAPIDefinesTest.cpp \
@@ -203,6 +204,7 @@ geos_unit_SOURCES = \
operation/overlayng/OverlayNGSnappingOneTest.cpp \
operation/overlayng/OverlayNGStrictModeTest.cpp \
operation/overlayng/OverlayNGTest.cpp \
+ operation/overlayng/OverlayNGZTest.cpp \
operation/overlayng/PrecisionReducerTest.cpp \
operation/overlayng/PrecisionUtilTest.cpp \
operation/overlayng/UnaryUnionNGTest.cpp \
diff --git a/tests/unit/algorithm/RobustLineIntersectorZTest.cpp b/tests/unit/algorithm/RobustLineIntersectorZTest.cpp
new file mode 100644
index 0000000..08733de
--- /dev/null
+++ b/tests/unit/algorithm/RobustLineIntersectorZTest.cpp
@@ -0,0 +1,317 @@
+// Ported from JTS junit/algorithm/RobustLineIntersectorZTest.java e85881c1c179a49976fe38f0dbbff7d9fa61e65a
+#include <tut/tut.hpp>
+#include <utility.h>
+// geos
+#include <geos/algorithm/LineIntersector.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/LineSegment.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+using namespace geos::geom;
+typedef geos::algorithm::LineIntersector RobustLineIntersector;
+#define DoubleNaN std::numeric_limits<double>::quiet_NaN()
+namespace tut {
+// Test Group
+struct test_robustlineintersectorz_data {
+ void checkIntersection(const LineSegment& line1, const LineSegment& line2,
+ const Coordinate& p1, const Coordinate& p2)
+ checkIntersectionDir(line1, line2, p1, p2);
+ checkIntersectionDir(line2, line1, p1, p2);
+ LineSegment line1Rev(line1.p1, line1.p0);
+ LineSegment line2Rev(line2.p1, line2.p0);
+ checkIntersectionDir(line1Rev, line2Rev, p1, p2);
+ checkIntersectionDir(line2Rev, line1Rev, p1, p2);
+ void checkIntersectionDir(
+ const LineSegment& line1,
+ const LineSegment& line2,
+ RobustLineIntersector li;
+ li.computeIntersection(
+ line1.p0, line1.p1,
+ line2.p0, line2.p1);
+ ensure_equals(li.getIntersectionNum(), 2u);
+ Coordinate actual1 = li.getIntersection(0);
+ Coordinate actual2 = li.getIntersection(1);
+ // normalize actual results
+ if (actual1.compareTo(actual2) > 0) {
+ actual1 = li.getIntersection(1);
+ actual2 = li.getIntersection(0);
+ ensure_equals_xyz( actual1, p1 );
+ ensure_equals_xyz( actual2, p2 );
+ const Coordinate& pt)
+ checkIntersectionDir(line1, line2, pt);
+ checkIntersectionDir(line2, line1, pt);
+ checkIntersectionDir(line1Rev, line2Rev, pt);
+ checkIntersectionDir(line2Rev, line1Rev, pt);
+ ensure_equals(li.getIntersectionNum(), 1u);
+ Coordinate actual = li.getIntersection(0);
+ ensure_equals_xyz( actual, pt );
+ static Coordinate pt(double x, double y, double z) {
+ return Coordinate(x, y, z);
+ static Coordinate pt(double x, double y) {
+ return Coordinate(x, y);
+ static LineSegment line(double x1, double y1, double z1,
+ double x2, double y2, double z2)
+ return LineSegment(Coordinate(x1, y1, z1),
+ Coordinate(x2, y2, z2));
+ double x2, double y2)
+ return LineSegment(Coordinate(x1, y1), Coordinate(x2, y2));
+typedef test_group<test_robustlineintersectorz_data> group;
+typedef group::object object;
+group test_robustlineintersectorz_group(
+ "geos::algorithm::RobustLineIntersectorZ");
+// Test Cases
+// 1 - testInterior
+template<>
+template<>
+void object::test<1>
+ checkIntersection(
+ line(1, 1, 1, 3, 3, 3),
+ line(1, 3, 10, 3, 1, 30),
+ pt(2, 2, 11)
+// 2 - testInterior2D
+template<>
+template<>
+void object::test<2>
+ line(1, 1, 3, 3),
+ line(1, 3, 3, 1),
+ pt(2, 2)
+// testInterior3D2D
+template<>
+template<>
+void object::test<3>
+ checkIntersection( line(1, 1, 1, 3, 3, 3), line(1, 3, 3, 1),
+ pt(2, 2, 2));
+// testInterior2D3D
+template<>
+template<>
+void object::test<4>
+ checkIntersection( line(1, 1, 3, 3), line(1, 3, 10, 3, 1, 30),
+ pt(2, 2, 20));
+// testInterior2D3DPart
+ // result is average of line1 interpolated and line2 p0 Z
+template<>
+template<>
+void object::test<5>
+ line(1, 3, 10, 3, 1, DoubleNaN),
+ pt(2, 2, 6));
+// testEndpoint
+template<>
+template<>
+void object::test<6>
+ checkIntersection( line(1, 1, 1, 3, 3, 3), line(3, 3, 3, 3, 1, 30),
+ pt(3, 3, 3));
+// testEndpoint2D
+template<>
+template<>
+void object::test<7>
+ checkIntersection( line(1, 1, 3, 3), line(3, 3, 3, 1),
+ pt(3, 3, DoubleNaN));
+// testEndpoint2D3D
+template<>
+template<>
+void object::test<8>
+ // result Z is from 3D point
+ checkIntersection( line(1, 1, 1, 3, 3, 3), line(3, 3, 3, 1),
+ pt(3, 3, 3));
+// testInteriorEndpoint
+template<>
+template<>
+void object::test<9>
+ checkIntersection( line(1, 1, 1, 3, 3, 3), line(2, 2, 10, 3, 1, 30),
+ pt(2, 2, 10));
+// testInteriorEndpoint3D2D
+template<>
+template<>
+void object::test<10>
+ // result Z is interpolated
+ checkIntersection( line(1, 1, 1, 3, 3, 3), line(2, 2, 3, 1),
+ pt(2, 2, 2));
+// testInteriorEndpoint2D3D
+template<>
+template<>
+void object::test<11>
+ checkIntersection( line(1, 1, 3, 3), line(2, 2, 10, 3, 1, 20),
+ pt(2, 2, 10));
+// testCollinearEqual
+template<>
+template<>
+void object::test<12>
+ checkIntersection( line(1, 1, 1, 3, 3, 3), line(1, 1, 1, 3, 3, 3),
+ pt(1, 1, 1), pt( 3, 3, 3));
+// testCollinearEqual3D2D
+template<>
+template<>
+void object::test<13>
+ checkIntersection( line(1, 1, 1, 3, 3, 3), line(1, 1, 3, 3),
+// testCollinearEndpoint
+template<>
+template<>
+void object::test<14>
+ checkIntersection( line(1, 1, 1, 3, 3, 3), line(3, 3, 3, 5, 5, 5),
+ pt(3, 3, 3));
+// testCollinearEndpoint3D2D
+template<>
+template<>
+void object::test<15>
+ checkIntersection( line(1, 1, 1, 3, 3, 3), line(3, 3, 5, 5),
+ pt(3, 3, 3));
+// testCollinearContained
+template<>
+template<>
+void object::test<16>
+ checkIntersection( line(1, 1, 1, 5, 5, 5), line(3, 3, 3, 4, 4, 4),
+ pt(3, 3, 3), pt(4, 4, 4));
+// testCollinearContained3D2D
+template<>
+template<>
+void object::test<17>
+ checkIntersection( line(1, 1, 1, 5, 5, 5), line(3, 3, 4, 4),
+} // namespace tut
diff --git a/tests/unit/operation/overlayng/OverlayNGZTest.cpp b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
index 0000000..6ee56af
--- /dev/null
+++ b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
@@ -0,0 +1,56 @@
+// Test Suite for handling of Z in geos::operation::overlayng::OverlayNG class.
+// geos
+#include <geos/operation/overlayng/OverlayNG.h>
+// std
+#include <memory>
+using namespace geos::operation::overlayng;
+using geos::io::WKTReader;
+namespace tut {
+// Test Group
+// Common data used by all tests
+struct test_overlayngz_data {
+ WKTReader r;
+ void checkIntersection(const std::string& wktA, const std::string& wktB, const std::string& wktExpected)
+ std::unique_ptr<Geometry> a = r.read(wktA);
+ std::unique_ptr<Geometry> b = r.read(wktB);
+ std::unique_ptr<Geometry> expected = r.read(wktExpected);
+ std::unique_ptr<Geometry> result = OverlayNG::overlay(a.get(), b.get(), OverlayNG::INTERSECTION);
+ ensure_equals_geometry(expected.get(), result.get());
+typedef test_group<test_overlayngz_data> group;
+group test_overlayngz_group("geos::operation::overlayng::OverlayNGZ");
+// Test Cases
+// testLineIntersectionInterpolated
+template<>
+template<>
+void object::test<1> ()
+ checkIntersection("LINESTRING (0 0 0, 10 10 10)", "LINESTRING (10 0 0, 0 10 10)", "POINT(5 5 5)");
+} // namespace tut
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index 40db8bc..c3da601 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -92,6 +92,21 @@ instanceOf(InstanceType const* instance)
return dynamic_cast<Type const*>(instance);
+inline void
+ensure_equals_xyz(geos::geom::Coordinate const& actual,
+ geos::geom::Coordinate const& expected)
+ ensure_equals("Coordinate X", actual.x, expected.x );
+ ensure_equals("Coordinate Y", actual.y, expected.y );
+ if ( std::isnan(expected.z) ) {
+ ensure("Coordinate Z should be NaN", std::isnan(actual.z) );
+ } else {
+ ensure_equals("Coordinate Z", actual.z, expected.z );
// Geometries structure comparators
Summary of changes:
include/geos/algorithm/LineIntersector.h | 48 ++
src/algorithm/LineIntersector.cpp | 596 ++++++++-------------
tests/unit/Makefile.am | 2 +
.../unit/algorithm/RobustLineIntersectorZTest.cpp | 317 +++++++++++
tests/unit/operation/overlayng/OverlayNGZTest.cpp | 56 ++
tests/unit/utility.h | 15 +
6 files changed, 658 insertions(+), 376 deletions(-)
create mode 100644 tests/unit/algorithm/RobustLineIntersectorZTest.cpp
create mode 100644 tests/unit/operation/overlayng/OverlayNGZTest.cpp
hooks/post-receive
More information about the geos-commits
