[geos-commits] [SCM] GEOS branch master updated. 91e9df7650fd56409e383331d4a199996b4944d0
git at osgeo.org
git at osgeo.org
Thu Nov 12 17:54:45 PST 2020
the project "GEOS".
via 91e9df7650fd56409e383331d4a199996b4944d0 (commit)
via 86bd0f0903c9effca511776955541750e08829bb (commit)
via cd2431685a813be1aca85fa1e70e1fb59393c16e (commit)
via 15db8e952edc5b9b75cc556cc7fcd141950dc7ad (commit)
from 03e8090d9a2019402dbb0d3c2931eac75d11030e (commit)
revisions in full, below.
commit 91e9df7650fd56409e383331d4a199996b4944d0
Merge: 03e8090 86bd0f0
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Nov 12 20:54:23 2020 -0500
Merge branch 'segment-node-list'
commit 86bd0f0903c9effca511776955541750e08829bb
Date: Thu Nov 12 19:56:24 2020 -0500
Add const to SegmentNodeList methods
diff --git a/include/geos/noding/SegmentNodeList.h b/include/geos/noding/SegmentNodeList.h
index 83b0812..80c46c6 100644
--- a/include/geos/noding/SegmentNodeList.h
+++ b/include/geos/noding/SegmentNodeList.h
@@ -67,7 +67,7 @@ private:
* @param splitEdges the split edges for this edge (in order)
- void checkSplitEdgesCorrectness(std::vector<SegmentString*>& splitEdges);
+ void checkSplitEdgesCorrectness(const std::vector<SegmentString*>& splitEdges) const;
* Create a new "split edge" with the section of points between
@@ -77,7 +77,7 @@ private:
* ownership of return value is transferred
- std::unique_ptr<SegmentString> createSplitEdge(SegmentNode* ei0, SegmentNode* ei1);
+ std::unique_ptr<SegmentString> createSplitEdge(const SegmentNode* ei0, const SegmentNode* ei1) const;
* Extracts the points for a split edge running between two nodes.
@@ -89,7 +89,7 @@ private:
* @param ei1 the end node of the split edge
* @return the points for the split edge
- void createSplitEdgePts(SegmentNode* ei0, SegmentNode* ei1, std::vector<geom::Coordinate>& pts);
+ void createSplitEdgePts(const SegmentNode* ei0, const SegmentNode* ei1, std::vector<geom::Coordinate>& pts) const;
* Adds nodes for any collapsed edge pairs.
@@ -106,7 +106,7 @@ private:
* which are pre-existing in the vertex list.
void findCollapsesFromExistingVertices(
- std::vector<std::size_t>& collapsedVertexIndexes);
+ std::vector<std::size_t>& collapsedVertexIndexes) const;
* Adds nodes for any collapsed edge pairs caused by inserted nodes
@@ -116,12 +116,12 @@ private:
* the vertex must be added as a node as well.
void findCollapsesFromInsertedNodes(
- bool findCollapseIndex(SegmentNode& ei0, SegmentNode& ei1,
- size_t& collapsedVertexIndex);
+ bool findCollapseIndex(const SegmentNode& ei0, const SegmentNode& ei1,
+ size_t& collapsedVertexIndex) const;
- void addEdgeCoordinates(SegmentNode* ei0, SegmentNode* ei1, std::vector<geom::Coordinate>& coordList);
+ void addEdgeCoordinates(const SegmentNode* ei0, const SegmentNode* ei1, std::vector<geom::Coordinate>& coordList) const;
// Declare type as noncopyable
SegmentNodeList(const SegmentNodeList& other) = delete;
diff --git a/src/noding/SegmentNodeList.cpp b/src/noding/SegmentNodeList.cpp
index c3a7c74..12d8ad4 100644
--- a/src/noding/SegmentNodeList.cpp
+++ b/src/noding/SegmentNodeList.cpp
@@ -104,7 +104,7 @@ SegmentNodeList::addCollapsedNodes()
/* private */
void
SegmentNodeList::findCollapsesFromExistingVertices(
- std::vector<size_t>& collapsedVertexIndexes)
+ std::vector<size_t>& collapsedVertexIndexes) const
if(edge.size() < 2) {
return; // or we'll never exit the loop below
@@ -123,7 +123,7 @@ SegmentNodeList::findCollapsesFromExistingVertices(
/* private */
void
SegmentNodeList::findCollapsesFromInsertedNodes(
size_t collapsedVertexIndex;
@@ -146,8 +146,8 @@ SegmentNodeList::findCollapsesFromInsertedNodes(
/* private */
bool
-SegmentNodeList::findCollapseIndex(SegmentNode& ei0, SegmentNode& ei1,
+SegmentNodeList::findCollapseIndex(const SegmentNode& ei0, const SegmentNode& ei1,
assert(ei1.segmentIndex >= ei0.segmentIndex);
// only looking for equal nodes
@@ -215,7 +215,7 @@ SegmentNodeList::addSplitEdges(std::vector<SegmentString*>& edgeList)
/*private*/
void
-SegmentNodeList::checkSplitEdgesCorrectness(std::vector<SegmentString*>& splitEdges)
+SegmentNodeList::checkSplitEdgesCorrectness(const std::vector<SegmentString*>& splitEdges) const
const CoordinateSequence* edgePts = edge.getCoordinates();
assert(edgePts);
@@ -244,7 +244,7 @@ SegmentNodeList::checkSplitEdgesCorrectness(std::vector<SegmentString*>& splitEd
/*private*/
-SegmentNodeList::createSplitEdge(SegmentNode* ei0, SegmentNode* ei1)
+SegmentNodeList::createSplitEdge(const SegmentNode* ei0, const SegmentNode* ei1) const
std::vector<Coordinate> pts;
createSplitEdgePts(ei0, ei1, pts);
@@ -254,7 +254,7 @@ SegmentNodeList::createSplitEdge(SegmentNode* ei0, SegmentNode* ei1)
/*private*/
void
-SegmentNodeList::createSplitEdgePts(SegmentNode* ei0, SegmentNode* ei1, std::vector<Coordinate>& pts)
+SegmentNodeList::createSplitEdgePts(const SegmentNode* ei0, const SegmentNode* ei1, std::vector<Coordinate>& pts) const
//int npts = ei1->segmentIndex - (ei0->segmentIndex + 2);
bool twoPoints = (ei1->segmentIndex == ei0->segmentIndex);
@@ -311,8 +311,7 @@ SegmentNodeList::getSplitCoordinates()
/*private*/
void
-SegmentNodeList::addEdgeCoordinates(SegmentNode* ei0, SegmentNode* ei1, std::vector<Coordinate>& coordList)
+SegmentNodeList::addEdgeCoordinates(const SegmentNode* ei0, const SegmentNode* ei1, std::vector<Coordinate>& coordList) const {
// Append pts to coordList
commit cd2431685a813be1aca85fa1e70e1fb59393c16e
Date: Thu Nov 12 19:49:59 2020 -0500
Return SegmentString by unique_ptr
index 4b93e6c..83b0812 100644
- SegmentString* createSplitEdge(SegmentNode* ei0, SegmentNode* ei1);
+ std::unique_ptr<SegmentString> createSplitEdge(SegmentNode* ei0, SegmentNode* ei1);
index 1a3a727..c3a7c74 100644
@@ -22,6 +22,7 @@
#include <algorithm>
#include <geos/profiler.h>
+#include <geos/util.h>
#include <geos/util/GEOSException.h>
#include <geos/noding/SegmentNodeList.h>
#include <geos/noding/NodedSegmentString.h>
@@ -199,8 +200,8 @@ SegmentNodeList::addSplitEdges(std::vector<SegmentString*>& edgeList)
continue;
- SegmentString* newEdge = createSplitEdge(eiPrev, ei);
- edgeList.push_back(newEdge);
+ std::unique_ptr<SegmentString> newEdge = createSplitEdge(eiPrev, ei);
+ edgeList.push_back(newEdge.release());
#if GEOS_DEBUG
testingSplitEdges.push_back(newEdge);
#endif
@@ -242,12 +243,12 @@ SegmentNodeList::checkSplitEdgesCorrectness(std::vector<SegmentString*>& splitEd
/*private*/
-SegmentString*
+std::unique_ptr<SegmentString>
- return new NodedSegmentString(new CoordinateArraySequence(std::move(pts)), edge.getData());
+ return detail::make_unique<NodedSegmentString>(new CoordinateArraySequence(std::move(pts)), edge.getData());
commit 15db8e952edc5b9b75cc556cc7fcd141950dc7ad
Date: Thu Nov 12 19:44:45 2020 -0500
Remove heap alloc in SegmentNodeList
index 9ebb740..1a3a727 100644
@@ -245,9 +245,9 @@ SegmentNodeList::checkSplitEdgesCorrectness(std::vector<SegmentString*>& splitEd
SegmentString*
- std::unique_ptr<std::vector<Coordinate>> pts(new std::vector<Coordinate>);
- createSplitEdgePts(ei0, ei1, *pts);
- return new NodedSegmentString(new CoordinateArraySequence(pts.release()), edge.getData());
+ std::vector<Coordinate> pts;
+ createSplitEdgePts(ei0, ei1, pts);
+ return new NodedSegmentString(new CoordinateArraySequence(std::move(pts)), edge.getData());
Summary of changes:
include/geos/noding/SegmentNodeList.h | 16 ++++++++--------
src/noding/SegmentNodeList.cpp | 30 +++++++++++++++---------------
2 files changed, 23 insertions(+), 23 deletions(-)
hooks/post-receive
More information about the geos-commits
