[geos-commits] [SCM] GEOS branch master updated. d1a55313b602b600d2e568336581b5d90fe8482e
git at osgeo.org
git at osgeo.org
Fri Nov 13 07:11:08 PST 2020
the project "GEOS".
via d1a55313b602b600d2e568336581b5d90fe8482e (commit)
from 91e9df7650fd56409e383331d4a199996b4944d0 (commit)
revisions in full, below.
commit d1a55313b602b600d2e568336581b5d90fe8482e
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Nov 13 16:08:15 2020 +0100
Simplify and improve NearestPoint CAPI tests
diff --git a/tests/unit/capi/GEOSNearestPointsTest.cpp b/tests/unit/capi/GEOSNearestPointsTest.cpp
index 1b7a6f2..17cb706 100644
--- a/tests/unit/capi/GEOSNearestPointsTest.cpp
+++ b/tests/unit/capi/GEOSNearestPointsTest.cpp
@@ -48,6 +48,48 @@ struct test_capigeosnearestpoints_data {
finishGEOS();
+ void checkNearestPoints(const char* wkt1, const char* wkt2,
+ double x1, double y1,
+ double x2, double y2)
+ geom1_ = GEOSGeomFromWKT(wkt1);
+ ensure(nullptr != geom1_);
+ geom2_ = GEOSGeomFromWKT(wkt2);
+ ensure(nullptr != geom2_);
+ GEOSCoordSequence* coords_ = GEOSNearestPoints(geom1_, geom2_);
+ unsigned int size;
+ GEOSCoordSeq_getSize(coords_, &size);
+ ensure_equals(size, 2u);
+ double ox, oy;
+ /* Point in geom1_ */
+ GEOSCoordSeq_getOrdinate(coords_, 0, 0, &ox);
+ GEOSCoordSeq_getOrdinate(coords_, 0, 1, &oy);
+ ensure_equals(ox, x1);
+ ensure_equals(oy, y1);
+ /* Point in geom2_ */
+ GEOSCoordSeq_getOrdinate(coords_, 1, 0, &ox);
+ GEOSCoordSeq_getOrdinate(coords_, 1, 1, &oy);
+ ensure_equals(ox, x2);
+ ensure_equals(oy, y2);
+ GEOSCoordSeq_destroy(coords_);
+ void checkNearestPointsNull(const char* wkt1, const char* wkt2)
+ ensure(nullptr == coords_);
typedef test_group<test_capigeosnearestpoints_data> group;
@@ -64,16 +106,7 @@ template<>
void object::test<1>
- geom1_ = GEOSGeomFromWKT("POLYGON EMPTY");
- geom2_ = GEOSGeomFromWKT("POLYGON EMPTY");
- ensure(nullptr != geom1_);
- ensure(nullptr != geom2_);
- GEOSCoordSequence* coords_;
- coords_ = GEOSNearestPoints(geom1_, geom2_);
- ensure(nullptr == coords_);
+ checkNearestPointsNull("POLYGON EMPTY", "POLYGON EMPTY");
template<>
@@ -81,40 +114,12 @@ template<>
void object::test<2>
- geom1_ = GEOSGeomFromWKT("POLYGON((1 1,1 5,5 5,5 1,1 1))");
- // geom2_ = GEOSGeomFromWKT("POINT(8 8)");
- geom2_ = GEOSGeomFromWKT("POLYGON((8 8, 9 9, 9 10, 8 8))");
- ensure(nullptr != coords_);
- unsigned int size;
- GEOSCoordSeq_getSize(coords_, &size);
- ensure(2 == size);
- double x1, x2, y1, y2;
- /* Point in geom1_
- GEOSCoordSeq_getOrdinate(coords_, 0, 0, &x1);
- GEOSCoordSeq_getOrdinate(coords_, 0, 1, &y1);
- /* Point in geom2_
- GEOSCoordSeq_getOrdinate(coords_, 1, 0, &x2);
- GEOSCoordSeq_getOrdinate(coords_, 1, 1, &y2);
+ checkNearestPoints(
+ "POLYGON((1 1,1 5,5 5,5 1,1 1))",
+ "POLYGON((8 8, 9 9, 9 10, 8 8))",
+ 5, 5, 8, 8
- ensure(5 == x1);
- ensure(5 == y1);
- ensure(8 == x2);
- ensure(8 == y2);
- GEOSCoordSeq_destroy(coords_);
template<>
@@ -122,39 +127,36 @@ template<>
void object::test<3>
- geom2_ = GEOSGeomFromWKT("POINT(2 2)");
+ "POINT(2 2)",
+ 2, 2, 2, 2
- ensure(2 == x1);
- ensure(2 == y1);
- ensure(2 == x2);
- ensure(2 == y2);
+template<>
+template<>
+void object::test<4>
+ "LINESTRING(1 5,5 5,5 1,1 1)",
+ "POINT(2 2)",
+ 2, 1, 2, 2
+template<>
+template<>
+void object::test<5>
+ "LINESTRING(0 0,10 10)",
+ "LINESTRING(0 10,10 0)",
+ 5, 5, 5, 5
} // namespace tut
diff --git a/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp b/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp
index 3217668..ff18b75 100644
--- a/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp
+++ b/tests/unit/capi/GEOSPreparedNearestPointsTest.cpp
@@ -51,6 +51,52 @@ struct test_capigeospreparednearestpoints_data {
finishGEOS();
+ pgeom1_ = GEOSPrepare(geom1_);
+ ensure(nullptr != pgeom1_);
+ GEOSCoordSequence* coords_ = GEOSPreparedNearestPoints(pgeom1_, geom2_);
+ double ox, oy;
typedef test_group<test_capigeospreparednearestpoints_data> group;
@@ -67,17 +113,7 @@ template<>
- pgeom1_ = GEOSPrepare(geom1_);
- ensure(nullptr != pgeom1_);
- coords_ = GEOSPreparedNearestPoints(pgeom1_, geom2_);
template<>
@@ -85,39 +121,12 @@ template<>
+ 5, 5, 8, 8
- ensure_equals(size, 2u);
- /* Point in pgeom1_
- ensure_equals(x1, 5);
- ensure_equals(y1, 5);
- ensure_equals(x2, 8);
- ensure_equals(y2, 8);
template<>
@@ -125,39 +134,11 @@ template<>
- ensure_equals(x1, 2);
- ensure_equals(y1, 2);
- ensure_equals(x2, 2);
- ensure_equals(y2, 2);
+ "POINT(2 2)",
+ 2, 2, 2, 2
template<>
@@ -165,40 +146,23 @@ template<>
- geom1_ = GEOSGeomFromWKT("LINESTRING(1 5,5 5,5 1,1 1)");
- ensure_equals(y1, 1);
+ "POINT(2 2)",
+ 2, 1, 2, 2
+template<>
+template<>
+ 5, 5, 5, 5
} // namespace tut
Summary of changes:
tests/unit/capi/GEOSNearestPointsTest.cpp | 148 +++++++++---------
tests/unit/capi/GEOSPreparedNearestPointsTest.cpp | 182 +++++++++-------------
2 files changed, 148 insertions(+), 182 deletions(-)
hooks/post-receive
More information about the geos-commits
