[geos-commits] [SCM] GEOS branch master updated. 60eb9895f72f8e494897c463d3ac5df83f782b49
git at osgeo.org
git at osgeo.org
Tue Nov 24 19:44:48 PST 2020
the project "GEOS".
via 60eb9895f72f8e494897c463d3ac5df83f782b49 (commit)
from 6fffe8df845837d0c8e56c90d02402dc21e30ecd (commit)
revisions in full, below.
commit 60eb9895f72f8e494897c463d3ac5df83f782b49
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Nov 24 19:44:43 2020 -0800
Quiet CI build warnings
diff --git a/src/index/strtree/SimpleSTRtree.cpp b/src/index/strtree/SimpleSTRtree.cpp
index 8103a15..1dbf20e 100644
--- a/src/index/strtree/SimpleSTRtree.cpp
+++ b/src/index/strtree/SimpleSTRtree.cpp
@@ -107,9 +107,9 @@ SimpleSTRtree::createParentNodes(
assert(!childNodes.empty());
- std::size_t minLeafCount = (std::size_t)std::ceil((double)childNodes.size() / (double)nodeCapacity);
+ std::size_t minLeafCount = (std::size_t)std::ceil((double)(childNodes.size()) / (double)nodeCapacity);
std::size_t sliceCount = (std::size_t)std::ceil(std::sqrt((double)minLeafCount));
- std::size_t sliceCapacity = (std::size_t)std::ceil(childNodes.size() / (double)sliceCount);
+ std::size_t sliceCapacity = (std::size_t)std::ceil((double)(childNodes.size()) / (double)sliceCount);
sortNodesX(childNodes);
@@ -265,8 +265,10 @@ SimpleSTRtree::query(const geom::Envelope* searchEnv,
bool
SimpleSTRtree::remove(const geom::Envelope* itemEnv, void* item)
- // no implementation of remove() yet!
- return false;
+ if (itemEnv || item) // no implementation of remove() yet!
+ return false;
+ else
+ return false;
diff --git a/tests/xmltester/tinyxml2/tinyxml2.cpp b/tests/xmltester/tinyxml2/tinyxml2.cpp
index 414ca6a..f194acc 100755
--- a/tests/xmltester/tinyxml2/tinyxml2.cpp
+++ b/tests/xmltester/tinyxml2/tinyxml2.cpp
@@ -432,17 +432,17 @@ void XMLUtil::ConvertUTF32ToUTF8( unsigned long input, char* output, int* length
--output;
*output = (char)((input | BYTE_MARK) & BYTE_MASK);
input >>= 6;
- // fall through
+ /* FALLTHRU */
case 3:
--output;
input >>= 6;
- // fall through
+ /* FALLTHRU */
case 2:
--output;
input >>= 6;
- // fall through
+ /* FALLTHRU */
case 1:
--output;
*output = (char)(input | FIRST_BYTE_MARK[*length]);
Summary of changes:
src/index/strtree/SimpleSTRtree.cpp | 10 ++++++----
tests/xmltester/tinyxml2/tinyxml2.cpp | 6 +++---
2 files changed, 9 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
