[geos-commits] [SCM] GEOS branch master updated. c79133f302d72093f7123befcd21c357ce60f08c
git at osgeo.org
git at osgeo.org
Tue Nov 24 20:54:51 PST 2020
the project "GEOS".
via c79133f302d72093f7123befcd21c357ce60f08c (commit)
from 60eb9895f72f8e494897c463d3ac5df83f782b49 (commit)
revisions in full, below.
commit c79133f302d72093f7123befcd21c357ce60f08c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Nov 24 20:54:44 2020 -0800
quiet CI build warning
diff --git a/tests/unit/index/strtree/SimpleSTRtreeTest.cpp b/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
index 7fa2869..5bae49b 100644
--- a/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
+++ b/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
@@ -60,8 +60,9 @@ void object::test<1>
void
visitItem(void* item) override
- count++;
- // geom::Point* pt = static_cast<geom::Point*>(item);
+ geom::Point* pt = static_cast<geom::Point*>(item);
+ if (!pt->isEmpty())
+ count++;
// std::cout << pt << std::endl;
Summary of changes:
tests/unit/index/strtree/SimpleSTRtreeTest.cpp | 5 +++--
1 file changed, 3 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
