[geos-commits] [SCM] GEOS branch master updated. 352d07a45ea4d7b8a17962e7d02ba9a69dce891d
git at osgeo.org
git at osgeo.org
Thu Nov 26 10:18:58 PST 2020
the project "GEOS".
via 352d07a45ea4d7b8a17962e7d02ba9a69dce891d (commit)
from 34442d22bacbdc733d41d6948f8f3e33044e68dc (commit)
revisions in full, below.
commit 352d07a45ea4d7b8a17962e7d02ba9a69dce891d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Nov 26 10:18:02 2020 -0800
Add MortonCode and HilbertCode for future use.
Also add relevant tests. Back out removal of
the float-store flag for 32-bit platforms.
diff --git a/configure.ac b/configure.ac
index fceccc9..9b64ba3 100644
--- a/configure.ac
+++ b/configure.ac
@@ -202,8 +202,17 @@ AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -pedantic], [dummy_cv_pedantic
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [dummy_cv_wall], [-Wall], [], [WARNFLAGS="$WARNFLAGS -Wall"], [])
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wno-long-long], [dummy_cv_wno_long_long], [-Wno-long-long], [], [WARNFLAGS="$WARNFLAGS -Wno-long-long"], [])
+# To make numerical computation more stable, we use --ffloat-store
+# on 32-bit platforms
+NUMERICFLAGS=""
+# 32-bit platforms have a 4-byte pointer
+AC_CHECK_SIZEOF([void *])
+if test $ac_cv_sizeof_void_p -eq 4 ; then
+ AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ffloat-store], [dummy_cv_ffloat_store], [-ffloat-store], [], [NUMERICFLAGS="$NUMERICFLAGS -ffloat-store"], [])
+fi
HUSHWARNING="-DUSE_UNSTABLE_GEOS_CPP_API"
-DEFAULTFLAGS="${WARNFLAGS} ${HUSHWARNING} ${OVERLAYNG_FLAGS}"
+DEFAULTFLAGS="${WARNFLAGS} ${NUMERICFLAGS} ${HUSHWARNING} ${OVERLAYNG_FLAGS}"
AM_CXXFLAGS="${AM_CXXFLAGS} ${DEFAULTFLAGS}"
AM_CFLAGS="${AM_CFLAGS} ${DEFAULTFLAGS}"
@@ -442,6 +451,8 @@ AC_OUTPUT([
include/geos/simplify/Makefile
include/geos/triangulate/Makefile
include/geos/triangulate/quadedge/Makefile
+ include/geos/shape/Makefile
+ include/geos/shape/fractal/Makefile
include/geos/util/Makefile
include/geos/version.h
src/index/Makefile
@@ -476,6 +487,8 @@ AC_OUTPUT([
src/simplify/Makefile
src/triangulate/Makefile
src/triangulate/quadedge/Makefile
+ src/shape/Makefile
+ src/shape/fractal/Makefile
src/util/Makefile
swig/geos.i
swig/Makefile
diff --git a/include/geos/Makefile.am b/include/geos/Makefile.am
index 1b2094c..09ba8db 100644
--- a/include/geos/Makefile.am
+++ b/include/geos/Makefile.am
@@ -16,6 +16,7 @@ SUBDIRS = \
precision \
simplify \
triangulate \
+ shape \
util
EXTRA_DIST =
diff --git a/include/geos/shape/Makefile.am b/include/geos/shape/Makefile.am
new file mode 100644
index 0000000..1c303f2
--- /dev/null
+++ b/include/geos/shape/Makefile.am
@@ -0,0 +1,11 @@
+# This file is part of project GEOS (http://trac.osgeo.org/geos/)
+SUBDIRS = \
+ fractal
+EXTRA_DIST =
+geosdir = $(includedir)/geos/shape
+geos_HEADERS =
diff --git a/include/geos/shape/fractal/HilbertCode.h b/include/geos/shape/fractal/HilbertCode.h
index 0000000..46012ef
--- /dev/null
+++ b/include/geos/shape/fractal/HilbertCode.h
@@ -0,0 +1,127 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2020 Paul Ramsey <pramsey at cleverelephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <geos/export.h>
+#include <string>
+// Forward declarations
+namespace geos {
+namespace geom {
+class Coordinate;
+namespace geos {
+namespace shape { // geos.shape
+namespace fractal { // geos.shape.fractal
+ * Encodes points as the index along finite planar Hilbert curves.
+ * The planar Hilbert Curve is a continuous space-filling curve.
+ * In the limit the Hilbert curve has infinitely many vertices and fills
+ * the space of the unit square.
+ * A sequence of finite approximations to the infinite Hilbert curve
+ * is defined by the level number.
+ * The finite Hilbert curve at level n H(n) contains 2^n+1 points.
+ * Each finite Hilbert curve defines an ordering of the
+ * points in the 2-dimensional range square containing the curve.
+ * Curves fills the range square of side 2^level.
+ * Curve points have ordinates in the range [0, 2^level - 1].
+ * The index of a point along a Hilbert curve is called the Hilbert code.
+ * The code for a given point is specific to the level chosen.
+ * This implementation represents codes using 32-bit integers.
+ * This allows levels 0 to 16 to be handled.
+ * The class supports encoding points in the range of a given level curve
+ * and decoding the point for a given code value.
+ * The Hilbert order has the property that it tends to preserve locality.
+ * This means that codes which are near in value will have spatially proximate
+ * points. The converse is not always true - the delta between
+ * codes for nearby points is not always small. But the average delta
+ * is small enough that the Hilbert order is an effective way of linearizing space
+ * to support range queries.
+ * @author Martin Davis
+ * @see MortonCode
+class GEOS_DLL HilbertCode {
+public:
+ * The maximum curve level that can be represented.
+ static constexpr int MAX_LEVEL = 16;
+ static geom::Coordinate decode(uint32_t level, uint32_t i);
+ static uint32_t encode(uint32_t level, uint32_t x, uint32_t y);
+ * The number of points in the curve for the given level.
+ * The number of points is 2^(2 * level).
+ * @param level the level of the curve
+ * @return the number of points
+ static uint32_t levelSize(uint32_t level);
+ * The maximum ordinate value for points
+ * in the curve for the given level.
+ * The maximum ordinate is 2^level - 1.
+ * @return the maximum ordinate value
+ static uint32_t maxOrdinate(uint32_t level);
+ * The level of the finite Hilbert curve which contains at least
+ * the given number of points.
+ * @param numPoints the number of points required
+ * @return the level of the curve
+ static uint32_t level(uint32_t numPoints);
+private:
+ static uint32_t deinterleave(uint32_t x);
+ static uint32_t interleave(uint32_t x);
+ static uint32_t prefixScan(uint32_t x);
+ static uint32_t descan(uint32_t x);
+ static void checkLevel(int level);
+} // namespace geos.shape.fractal
diff --git a/include/geos/shape/fractal/HilbertEncoder.h b/include/geos/shape/fractal/HilbertEncoder.h
index 0000000..61c0010
--- /dev/null
+++ b/include/geos/shape/fractal/HilbertEncoder.h
@@ -0,0 +1,60 @@
+#pragma once
+#include <string>
+#include <vector>
+namespace geos {
+namespace geom {
+class Coordinate;
+class Geometry;
+class Envelope;
+namespace geos {
+class GEOS_DLL HilbertEncoder {
+public:
+ HilbertEncoder(uint32_t p_level, geom::Envelope& extent);
+ uint32_t encode(const geom::Envelope* env);
+ static void sort(std::vector<geom::Geometry*>& geoms);
+private:
+ uint32_t level;
+ double minx;
+ double miny;
+ double strideX;
+ double strideY;
diff --git a/include/geos/shape/fractal/Makefile.am b/include/geos/shape/fractal/Makefile.am
index 0000000..105a0d3
--- /dev/null
+++ b/include/geos/shape/fractal/Makefile.am
@@ -0,0 +1,13 @@
+SUBDIRS =
+EXTRA_DIST =
+geosdir = $(includedir)/geos/shape/fractal
+geos_HEADERS = \
+ HilbertCode.h \
+ HilbertEncoder.h \
+ MortonCode.h
diff --git a/include/geos/shape/fractal/MortonCode.h b/include/geos/shape/fractal/MortonCode.h
index 0000000..6743f87
--- /dev/null
+++ b/include/geos/shape/fractal/MortonCode.h
@@ -0,0 +1,139 @@
+#pragma once
+#include <string>
+namespace geos {
+namespace geom {
+class Coordinate;
+namespace geos {
+ * Encodes points as the index along the planar Morton (Z-order) curve.
+ * The planar Morton (Z-order) curve is a continuous space-filling curve.
+ * The Morton curve defines an ordering of the
+ * points in the positive quadrant of the plane.
+ * The index of a point along the Morton curve is called the Morton code.
+ * A sequence of subsets of the Morton curve can be defined by a level number.
+ * Each level subset occupies a square range.
+ * The curve at level n M(n) contains 2^(n + 1) points.
+ * It fills the range square of side 2^level.
+ * The code for a given point is identical at all levels.
+ * The level simply determines the number of points in the curve subset
+ * and the size of the range square.
+ * The Morton order has the property that it tends to preserve locality.
+ * is small enough that the Morton order is an effective way of linearizing space
+ * @see HilbertCode
+class GEOS_DLL MortonCode {
+public:
+ * Computes the index of the point (x,y)
+ * in the Morton curve ordering.
+ * @param x the x ordinate of the point
+ * @param y the y ordinate of the point
+ * @return the index of the point along the Morton curve
+ static uint32_t encode(int x, int y);
+ * Computes the point on the Morton curve
+ * for a given index.
+ * @param index the index of the point on the curve
+ * @return the point on the curve
+ static geom::Coordinate decode(uint32_t index);
+ * The number of points is 2<sup>2 * level</sup>.
+ * The maximum ordinate is 2<sup>level</sup> - 1.
+ * The level of the finite Morton curve which contains at least
+private:
+ static void checkLevel(uint32_t level) ;
diff --git a/src/Makefile.am b/src/Makefile.am
index 2e5bc25..38a8b2f 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
precision \
simplify \
triangulate \
+ shape \
util
EXTRA_DIST = dirlist.mk CMakeLists.txt info.plist.in
@@ -49,4 +50,5 @@ libgeos_la_LIBADD = \
precision/libprecision.la \
simplify/libsimplify.la \
triangulate/libtriangulate.la \
+ shape/libshape.la \
util/libutil.la
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 6d1d9bf..5b7361c 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -18,6 +18,7 @@
#include <geos/operation/union/CascadedPolygonUnion.h>
#include <geos/operation/union/OverlapUnion.h>
#include <geos/operation/overlay/OverlayOp.h>
@@ -29,6 +30,7 @@
#include <geos/geom/MultiPolygon.h>
#include <geos/geom/util/PolygonExtracter.h>
#include <geos/index/strtree/STRtree.h>
// std
#include <cassert>
#include <cstddef>
@@ -153,6 +155,7 @@ CascadedPolygonUnion::Union()
* This makes unioning more efficient, since vertices are more likely
* to be eliminated on each round.
index::strtree::STRtree index(STRTREE_NODE_CAPACITY);
typedef std::vector<geom::Polygon*>::iterator iterator_type;
diff --git a/src/shape/Makefile.am b/src/shape/Makefile.am
index 0000000..8bdb8aa
--- /dev/null
+++ b/src/shape/Makefile.am
@@ -0,0 +1,12 @@
+SUBDIRS = \
+ fractal
+noinst_LTLIBRARIES = libshape.la
+libshape_la_SOURCES =
+libshape_la_LIBADD = \
+ fractal/libshapefractal.la
diff --git a/src/shape/fractal/HilbertCode.cpp b/src/shape/fractal/HilbertCode.cpp
index 0000000..484f475
--- /dev/null
+++ b/src/shape/fractal/HilbertCode.cpp
@@ -0,0 +1,199 @@
+#include <geos/shape/fractal/HilbertCode.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/util/IllegalArgumentException.h>
+#include <cstdint>
+namespace geos {
+// Fast Hilbert curve algorithm by http://threadlocalmutex.com/
+// From C++ https://github.com/rawrunprotected/hilbert_curves
+//(public domain)
+/*public static*/
+uint32_t HilbertCode::levelSize(uint32_t level)
+ return (uint32_t)std::pow(2, 2*level);
+/*public static*/
+uint32_t HilbertCode::maxOrdinate(uint32_t level)
+ return (uint32_t)std::pow(2, level) - 1;
+/*public static*/
+uint32_t HilbertCode::level(uint32_t numPoints)
+ uint32_t pow2 = (uint32_t) ((std::log(numPoints)/std::log(2)));
+ uint32_t level = pow2 / 2;
+ uint32_t size = levelSize(level);
+ if (size < numPoints)
+ level += 1;
+ return level;
+uint32_t
+HilbertCode::deinterleave(uint32_t x)
+ x = x & 0x55555555;
+ x = (x | (x >> 1)) & 0x33333333;
+ x = (x | (x >> 2)) & 0x0F0F0F0F;
+ x = (x | (x >> 4)) & 0x00FF00FF;
+ x = (x | (x >> 8)) & 0x0000FFFF;
+ return x;
+uint32_t
+HilbertCode::interleave(uint32_t x)
+ x = (x | (x << 8)) & 0x00FF00FF;
+ x = (x | (x << 4)) & 0x0F0F0F0F;
+ x = (x | (x << 2)) & 0x33333333;
+ x = (x | (x << 1)) & 0x55555555;
+ return x;
+uint32_t
+HilbertCode::prefixScan(uint32_t x)
+ x = (x >> 8) ^ x;
+ x = (x >> 4) ^ x;
+ x = (x >> 2) ^ x;
+ x = (x >> 1) ^ x;
+ return x;
+uint32_t
+HilbertCode::descan(uint32_t x)
+ return x ^ (x >> 1);
+/*private static*/
+void
+HilbertCode::checkLevel(int level)
+ if (level > MAX_LEVEL) {
+ throw util::IllegalArgumentException("Level out of range");
+/* public static */
+geom::Coordinate
+HilbertCode::decode(uint32_t level, uint32_t i)
+ checkLevel(level);
+ i = i << (32 - 2 * level);
+ uint32_t i0 = deinterleave(i);
+ uint32_t i1 = deinterleave(i >> 1);
+ uint32_t t0 = (i0 | i1) ^ 0xFFFF;
+ uint32_t t1 = i0 & i1;
+ uint32_t prefixT0 = prefixScan(t0);
+ uint32_t prefixT1 = prefixScan(t1);
+ uint32_t a = (((i0 ^ 0xFFFF) & prefixT1) | (i0 & prefixT0));
+ geom::Coordinate c;
+ c.x = (a ^ i1) >> (16 - level);
+ c.y = (a ^ i0 ^ i1) >> (16 - level);
+ return c;
+uint32_t
+HilbertCode::encode(uint32_t level, uint32_t x, uint32_t y)
+ x = x << (16 - level);
+ y = y << (16 - level);
+ uint32_t A, B, C, D;
+ // Initial prefix scan round, prime with x and y
+ uint32_t a = x ^ y;
+ uint32_t b = 0xFFFF ^ a;
+ uint32_t c = 0xFFFF ^ (x | y);
+ uint32_t d = x & (y ^ 0xFFFF);
+ A = a | (b >> 1);
+ B = (a >> 1) ^ a;
+ C = ((c >> 1) ^ (b & (d >> 1))) ^ c;
+ D = ((a & (c >> 1)) ^ (d >> 1)) ^ d;
+ uint32_t a = A;
+ uint32_t b = B;
+ uint32_t c = C;
+ uint32_t d = D;
+ A = ((a & (a >> 2)) ^ (b & (b >> 2)));
+ B = ((a & (b >> 2)) ^ (b & ((a ^ b) >> 2)));
+ C ^= ((a & (c >> 2)) ^ (b & (d >> 2)));
+ D ^= ((b & (c >> 2)) ^ ((a ^ b) & (d >> 2)));
+ uint32_t a = A;
+ uint32_t b = B;
+ uint32_t c = C;
+ uint32_t d = D;
+ A = ((a & (a >> 4)) ^ (b & (b >> 4)));
+ B = ((a & (b >> 4)) ^ (b & ((a ^ b) >> 4)));
+ C ^= ((a & (c >> 4)) ^ (b & (d >> 4)));
+ D ^= ((b & (c >> 4)) ^ ((a ^ b) & (d >> 4)));
+ // Final round and projection
+ uint32_t a = A;
+ uint32_t b = B;
+ uint32_t c = C;
+ uint32_t d = D;
+ C ^= ((a & (c >> 8)) ^ (b & (d >> 8)));
+ D ^= ((b & (c >> 8)) ^ ((a ^ b) & (d >> 8)));
+ // Undo transformation prefix scan
+ uint32_t a = C ^ (C >> 1);
+ uint32_t b = D ^ (D >> 1);
+ // Recover index bits
+ uint32_t i0 = x ^ y;
+ uint32_t i1 = b | (0xFFFF ^ (i0 | a));
+ return ((interleave(i1) << 1) | interleave(i0)) >> (32 - 2 * level);
diff --git a/src/shape/fractal/HilbertEncoder.cpp b/src/shape/fractal/HilbertEncoder.cpp
index 0000000..d853b7c
--- /dev/null
+++ b/src/shape/fractal/HilbertEncoder.cpp
@@ -0,0 +1,91 @@
+#include <geos/shape/fractal/HilbertEncoder.h>
+#include <geos/geom/Envelope.h>
+#include <geos/geom/Geometry.h>
+#include <cstdint>
+#include <vector>
+namespace geos {
+HilbertEncoder::HilbertEncoder(uint32_t p_level, geom::Envelope& extent)
+ : level(p_level)
+ int hside = (int)std::pow(2, level) - 1;
+ minx = extent.getMinX();
+ strideX = extent.getWidth() / hside;
+ miny = extent.getMinY();
+ strideY = extent.getHeight() / hside;
+uint32_t
+HilbertEncoder::encode(const geom::Envelope* env)
+ double midx = env->getWidth()/2 + env->getMinX();
+ uint32_t x = (uint32_t) ((midx - minx) / strideX);
+ double midy = env->getHeight()/2 + env->getMinY();
+ uint32_t y = (uint32_t) ((midy - miny) / strideY);
+ return HilbertCode::encode(level, x, y);
+void
+HilbertEncoder::sort(std::vector<geom::Geometry*>& geoms)
+ struct HilbertComparator {
+ HilbertEncoder& enc;
+ HilbertComparator(HilbertEncoder& e)
+ : enc(e) {};
+ bool
+ operator()(const geom::Geometry* a, const geom::Geometry* b)
+ return enc.encode(a->getEnvelopeInternal()) > enc.encode(b->getEnvelopeInternal());
+ geom::Envelope extent;
+ for (const geom::Geometry* geom: geoms)
+ if (extent.isNull())
+ extent = *(geom->getEnvelopeInternal());
+ else
+ extent.expandToInclude(*(geom->getEnvelopeInternal()));
+ if (extent.isNull()) return;
+ HilbertEncoder encoder(12, extent);
+ HilbertComparator hilbertCompare(encoder);
+ std::sort(geoms.begin(), geoms.end(), hilbertCompare);
+ return;
diff --git a/src/shape/fractal/Makefile.am b/src/shape/fractal/Makefile.am
index 0000000..4dfa260
--- /dev/null
+++ b/src/shape/fractal/Makefile.am
@@ -0,0 +1,13 @@
+noinst_LTLIBRARIES = libshapefractal.la
+AM_CPPFLAGS = -I$(top_srcdir)/include
+libshapefractal_la_SOURCES = \
+ HilbertCode.cpp \
+ HilbertEncoder.cpp \
+ MortonCode.cpp
+libshapefractal_la_LIBADD =
diff --git a/src/shape/fractal/MortonCode.cpp b/src/shape/fractal/MortonCode.cpp
index 0000000..bf1715a
--- /dev/null
+++ b/src/shape/fractal/MortonCode.cpp
@@ -0,0 +1,136 @@
+#include <geos/shape/fractal/MortonCode.h>
+#include <cstdint>
+namespace geos {
+* The number of points in the curve for the given level.
+* The number of points is 2<sup>2 * level</sup>.
+* @param level the level of the curve
+* @return the number of points
+uint32_t
+MortonCode::levelSize(uint32_t level)
+ return (uint32_t) std::pow(2, 2 * level);
+* The maximum ordinate value for points
+* in the curve for the given level.
+* The maximum ordinate is 2<sup>level</sup> - 1.
+* @return the maximum ordinate value
+uint32_t
+MortonCode::maxOrdinate(uint32_t level)
+ return (uint32_t) std::pow(2, level) - 1;
+* The level of the finite Morton curve which contains at least
+* the given number of points.
+* @param numPoints the number of points required
+* @return the level of the curve
+uint32_t
+MortonCode::level(uint32_t numPoints)
+ uint32_t pow2 = (uint32_t) ( (std::log(numPoints)/std::log(2)));
+ uint32_t sz = levelSize(level);
+ if (sz < numPoints)
+ level += 1;
+ return level;
+void
+MortonCode::checkLevel(uint32_t level)
+ throw util::IllegalArgumentException("Level not in range");
+* Computes the index of the point (x,y)
+* in the Morton curve ordering.
+* @param x the x ordinate of the point
+* @param y the y ordinate of the point
+* @return the index of the point along the Morton curve
+uint32_t
+MortonCode::encode(int x, int y)
+ return (interleave(y) << 1) + interleave(x);
+uint32_t
+MortonCode::interleave(uint32_t x)
+ x &= 0x0000ffff; // x = ---- ---- ---- ---- fedc ba98 7654 3210
+ x = (x ^ (x << 8)) & 0x00ff00ff; // x = ---- ---- fedc ba98 ---- ---- 7654 3210
+ x = (x ^ (x << 4)) & 0x0f0f0f0f; // x = ---- fedc ---- ba98 ---- 7654 ---- 3210
+ x = (x ^ (x << 2)) & 0x33333333; // x = --fe --dc --ba --98 --76 --54 --32 --10
+ x = (x ^ (x << 1)) & 0x55555555; // x = -f-e -d-c -b-a -9-8 -7-6 -5-4 -3-2 -1-0
+ return x;
+* Computes the point on the Morton curve
+* for a given index.
+* @param index the index of the point on the curve
+* @return the point on the curve
+geom::Coordinate
+MortonCode::decode(uint32_t index)
+ uint32_t x = deinterleave(index);
+ uint32_t y = deinterleave(index >> 1);
+ return geom::Coordinate(x, y);
+uint32_t
+MortonCode::deinterleave(uint32_t x)
+ return x;
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index fa5a2a7..51129c8 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -226,6 +226,8 @@ geos_unit_SOURCES = \
triangulate/quadedge/QuadEdgeTest.cpp \
triangulate/quadedge/VertexTest.cpp \
triangulate/VoronoiTest.cpp \
+ shape/fractal/HilbertCodeTest.cpp \
+ shape/fractal/MortonCodeTest.cpp \
util/NodingTestUtil.cpp \
util/UniqueCoordinateArrayFilterTest.cpp
diff --git a/tests/unit/shape/fractal/HilbertCodeTest.cpp b/tests/unit/shape/fractal/HilbertCodeTest.cpp
index 0000000..b28ebaa
--- /dev/null
+++ b/tests/unit/shape/fractal/HilbertCodeTest.cpp
@@ -0,0 +1,125 @@
+// Test Suite for HilbertCode class.
+// tut
+#include <tut/tut.hpp>
+// geos
+#include <geos/constants.h>
+// std
+using geos::shape::fractal::HilbertCode;
+using geos::geom::Coordinate;
+namespace tut {
+// Common data used by tests
+struct test_hilbertcode_data {
+ void checkDecode(uint32_t order, uint32_t index, int x, int y)
+ Coordinate p = HilbertCode::decode(order, index);
+ //System.out.println(p);
+ ensure_equals(x, (int) p.x);
+ ensure_equals(y, (int) p.y);
+ void checkDecodeEncodeForLevel(uint32_t level)
+ uint32_t n = HilbertCode::levelSize(level);
+ for (int i = 0; i < n; i++) {
+ checkDecodeEncode(level, i);
+ void
+ checkDecodeEncode(uint32_t level, uint32_t index)
+ Coordinate p = HilbertCode::decode(level, index);
+ uint32_t encode = HilbertCode::encode(level, (uint32_t)(p.x), (uint32_t)(p.y));
+ ensure_equals(index, encode);
+typedef test_group<test_hilbertcode_data> group;
+typedef group::object object;
+group test_hilbertcode_group("geos::shape::fractal::HilbertCode");
+template<>
+template<>
+void object::test<1>
+ ensure_equals( HilbertCode::levelSize( 0 ), 1);
+ ensure_equals( HilbertCode::levelSize( 1 ), 4);
+ ensure_equals( HilbertCode::levelSize( 2 ), 16);
+ ensure_equals( HilbertCode::levelSize( 3 ), 64);
+ ensure_equals( HilbertCode::levelSize( 4 ), 256);
+ ensure_equals( HilbertCode::levelSize( 5 ), 1024);
+ ensure_equals( HilbertCode::levelSize( 6 ), 4096);
+template<>
+template<>
+void object::test<2>
+ ensure_equals( HilbertCode::level( 1 ), 0);
+ ensure_equals( HilbertCode::level( 2 ), 1);
+ ensure_equals( HilbertCode::level( 3 ), 1);
+ ensure_equals( HilbertCode::level( 4 ), 1);
+ ensure_equals( HilbertCode::level( 5 ), 2);
+ ensure_equals( HilbertCode::level( 13 ), 2);
+ ensure_equals( HilbertCode::level( 15 ), 2);
+ ensure_equals( HilbertCode::level( 16 ), 2);
+ ensure_equals( HilbertCode::level( 17 ), 3);
+ ensure_equals( HilbertCode::level( 63 ), 3);
+ ensure_equals( HilbertCode::level( 64 ), 3);
+ ensure_equals( HilbertCode::level( 65 ), 4);
+ ensure_equals( HilbertCode::level( 255 ), 4);
+ ensure_equals( HilbertCode::level( 256 ), 4);
+template<>
+template<>
+void object::test<3>
+ checkDecode(1, 0, 0, 0);
+ checkDecode(1, 1, 0, 1);
+ checkDecode(3, 0, 0, 0);
+ checkDecode(3, 1, 0, 1);
+ checkDecode(4,0, 0, 0);
+ checkDecode(4, 1, 1, 0);
+ checkDecode(4, 24, 6, 2);
+ checkDecode(4, 255, 15, 0);
+ checkDecode(5, 124, 8, 6);
+template<>
+template<>
+void object::test<4>
+ checkDecodeEncodeForLevel(4);
+ checkDecodeEncodeForLevel(5);
+} // namespace tut
diff --git a/tests/unit/shape/fractal/MortonCodeTest.cpp b/tests/unit/shape/fractal/MortonCodeTest.cpp
index 0000000..b606653
--- /dev/null
+++ b/tests/unit/shape/fractal/MortonCodeTest.cpp
@@ -0,0 +1,119 @@
+// Test Suite for MortonCode class.
+// tut
+// geos
+// std
+using geos::shape::fractal::MortonCode;
+namespace tut {
+struct test_mortoncode_data {
+ void checkDecode(uint32_t index, int x, int y)
+ Coordinate p = MortonCode::decode(index);
+ uint32_t n = MortonCode::levelSize(level);
+ checkDecodeEncode(i);
+ void
+ checkDecodeEncode(uint32_t index)
+ uint32_t encode = MortonCode::encode((uint32_t)(p.x), (uint32_t)(p.y));
+typedef test_group<test_mortoncode_data> group;
+group test_mortoncode_group("geos::shape::fractal::MortonCode");
+template<>
+template<>
+ ensure_equals( MortonCode::levelSize( 0 ), 1);
+ ensure_equals( MortonCode::levelSize( 1 ), 4);
+ ensure_equals( MortonCode::levelSize( 2 ), 16);
+ ensure_equals( MortonCode::levelSize( 3 ), 64);
+ ensure_equals( MortonCode::levelSize( 4 ), 256);
+ ensure_equals( MortonCode::levelSize( 5 ), 1024);
+ ensure_equals( MortonCode::levelSize( 6 ), 4096);
+template<>
+template<>
+ ensure_equals( MortonCode::level( 1 ), 0);
+ ensure_equals( MortonCode::level( 2 ), 1);
+ ensure_equals( MortonCode::level( 3 ), 1);
+ ensure_equals( MortonCode::level( 4 ), 1);
+ ensure_equals( MortonCode::level( 5 ), 2);
+ ensure_equals( MortonCode::level( 13 ), 2);
+ ensure_equals( MortonCode::level( 15 ), 2);
+ ensure_equals( MortonCode::level( 16 ), 2);
+ ensure_equals( MortonCode::level( 17 ), 3);
+ ensure_equals( MortonCode::level( 63 ), 3);
+ ensure_equals( MortonCode::level( 64 ), 3);
+ ensure_equals( MortonCode::level( 65 ), 4);
+ ensure_equals( MortonCode::level( 255 ), 4);
+ ensure_equals( MortonCode::level( 256 ), 4);
+template<>
+template<>
+ checkDecode(0, 0, 0);
+ checkDecode(1, 1, 0);
+ checkDecode(2, 0, 1);
+ checkDecode(3, 1, 1);
+ checkDecode(4, 2, 0);
+ checkDecode(24, 4, 2);
+ checkDecode(124, 14, 6);
+ checkDecode(255, 15, 15);
+template<>
+template<>
+} // namespace tut
Summary of changes:
configure.ac | 15 +-
include/geos/Makefile.am | 1 +
include/geos/{math => shape}/Makefile.am | 8 +-
include/geos/shape/fractal/HilbertCode.h | 127 +++++++++++++
.../fractal/HilbertEncoder.h} | 39 ++--
include/geos/shape/fractal/Makefile.am | 13 ++
include/geos/shape/fractal/MortonCode.h | 139 ++++++++++++++
src/Makefile.am | 2 +
src/operation/union/CascadedPolygonUnion.cpp | 3 +
src/shape/Makefile.am | 12 ++
src/shape/fractal/HilbertCode.cpp | 199 +++++++++++++++++++++
src/shape/fractal/HilbertEncoder.cpp | 91 ++++++++++
src/shape/fractal/Makefile.am | 13 ++
src/shape/fractal/MortonCode.cpp | 136 ++++++++++++++
tests/unit/Makefile.am | 2 +
tests/unit/shape/fractal/HilbertCodeTest.cpp | 125 +++++++++++++
tests/unit/shape/fractal/MortonCodeTest.cpp | 119 ++++++++++++
17 files changed, 1028 insertions(+), 16 deletions(-)
copy include/geos/{math => shape}/Makefile.am (53%)
create mode 100644 include/geos/shape/fractal/HilbertCode.h
copy include/geos/{algorithm/PointInRing.h => shape/fractal/HilbertEncoder.h} (50%)
create mode 100644 include/geos/shape/fractal/Makefile.am
create mode 100644 include/geos/shape/fractal/MortonCode.h
create mode 100644 src/shape/Makefile.am
create mode 100644 src/shape/fractal/HilbertCode.cpp
create mode 100644 src/shape/fractal/HilbertEncoder.cpp
create mode 100644 src/shape/fractal/Makefile.am
create mode 100644 src/shape/fractal/MortonCode.cpp
create mode 100644 tests/unit/shape/fractal/HilbertCodeTest.cpp
create mode 100644 tests/unit/shape/fractal/MortonCodeTest.cpp
hooks/post-receive
More information about the geos-commits
