[geos-commits] [SCM] GEOS branch master updated. 7d4e17336f45d39aa2debd91237eed461aa5da09
git at osgeo.org
git at osgeo.org
Thu Nov 26 13:01:29 PST 2020
the project "GEOS".
via 7d4e17336f45d39aa2debd91237eed461aa5da09 (commit)
via 0dcb3214ee06a42d61f6ae6fe4798039a5fb7961 (commit)
from 352d07a45ea4d7b8a17962e7d02ba9a69dce891d (commit)
revisions in full, below.
commit 7d4e17336f45d39aa2debd91237eed461aa5da09
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Nov 26 13:01:09 2020 -0800
Note that SimpleSTRtree is now the tree used in the C API
diff --git a/NEWS b/NEWS
index 3f2a081..01de82a 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ Changes in 3.9.0
- CAPI: GEOSPreparedNearestPoints (#1007, Sandro Santilli)
- CAPI: GEOSPreparedDistance (#1066, Sandro Santilli)
- SimpleSTRTree spatial index implementation (Paul Ramsey)
+ - SimpleSTRTree used for C API (Paul Ramsey)
- Improvements:
- Stack allocate segments in OverlapUnion (Paul Ramsey)
commit 0dcb3214ee06a42d61f6ae6fe4798039a5fb7961
Date: Thu Nov 26 12:59:56 2020 -0800
Change CAPI STRTree functions to use the SimpleSTRtree so
that third parties can also get the performance win of the
new tree.
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 44fb257..9cfa0b0 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -70,7 +70,6 @@ using geos::io::WKTWriter;
using geos::io::WKBReader;
using geos::io::WKBWriter;
-using geos::index::strtree::STRtree;
typedef std::unique_ptr<Geometry> GeomPtr;
@@ -1311,14 +1310,14 @@ extern "C" {
return GEOSPreparedDistance_r(handle, g1, g2, dist);
- STRtree*
+ GEOSSTRtree*
GEOSSTRtree_create(size_t nodeCapacity)
return GEOSSTRtree_create_r(handle, nodeCapacity);
void
- GEOSSTRtree_insert(geos::index::strtree::STRtree* tree,
+ GEOSSTRtree_insert(GEOSSTRtree* tree,
const geos::geom::Geometry* g,
void* item)
@@ -1326,7 +1325,7 @@ extern "C" {
void
- GEOSSTRtree_query(geos::index::strtree::STRtree* tree,
+ GEOSSTRtree_query(GEOSSTRtree* tree,
GEOSQueryCallback cb,
void* userdata)
@@ -1335,7 +1334,7 @@ extern "C" {
const GEOSGeometry*
- GEOSSTRtree_nearest(geos::index::strtree::STRtree* tree,
+ GEOSSTRtree_nearest(GEOSSTRtree* tree,
const geos::geom::Geometry* g)
return GEOSSTRtree_nearest_r(handle, tree, g);
@@ -1351,7 +1350,7 @@ extern "C" {
void
- GEOSSTRtree_iterate(geos::index::strtree::STRtree* tree,
+ GEOSSTRtree_iterate(GEOSSTRtree* tree,
GEOSQueryCallback callback,
void* userdata)
@@ -1359,7 +1358,7 @@ extern "C" {
char
- GEOSSTRtree_remove(geos::index::strtree::STRtree* tree,
+ GEOSSTRtree_remove(GEOSSTRtree* tree,
void* item)
@@ -1367,7 +1366,7 @@ extern "C" {
void
- GEOSSTRtree_destroy(geos::index::strtree::STRtree* tree)
+ GEOSSTRtree_destroy(GEOSSTRtree* tree)
GEOSSTRtree_destroy_r(handle, tree);
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index b13a6e0..6bf1240 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -37,7 +37,7 @@
#include <geos/geom/Coordinate.h>
#include <geos/geom/IntersectionMatrix.h>
#include <geos/geom/Envelope.h>
-#include <geos/index/strtree/STRtree.h>
+#include <geos/index/strtree/SimpleSTRtree.h>
#include <geos/index/strtree/GeometryItemDistance.h>
#include <geos/index/ItemVisitor.h>
#include <geos/io/WKTReader.h>
@@ -112,7 +112,7 @@
#define GEOSPreparedGeometry geos::geom::prep::PreparedGeometry
#define GEOSCoordSequence geos::geom::CoordinateSequence
#define GEOSBufferParams geos::operation::buffer::BufferParameters
-#define GEOSSTRtree geos::index::strtree::STRtree
+#define GEOSSTRtree geos::index::strtree::SimpleSTRtree
#define GEOSWKTReader_t geos::io::WKTReader
#define GEOSWKTWriter_t geos::io::WKTWriter
#define GEOSWKBReader_t geos::io::WKBReader
@@ -2966,18 +2966,18 @@ extern "C" {
// STRtree
- geos::index::strtree::STRtree*
+ GEOSSTRtree*
GEOSSTRtree_create_r(GEOSContextHandle_t extHandle,
return execute(extHandle, [&]() {
- return new geos::index::strtree::STRtree(nodeCapacity);
+ return new GEOSSTRtree(nodeCapacity);
void
GEOSSTRtree_insert_r(GEOSContextHandle_t extHandle,
- geos::index::strtree::STRtree* tree,
+ GEOSSTRtree* tree,
void* item)
@@ -2988,7 +2988,7 @@ extern "C" {
void
GEOSSTRtree_query_r(GEOSContextHandle_t extHandle,
void* userdata)
@@ -3001,7 +3001,7 @@ extern "C" {
const GEOSGeometry*
GEOSSTRtree_nearest_r(GEOSContextHandle_t extHandle,
const geos::geom::Geometry* geom)
return (const GEOSGeometry*) GEOSSTRtree_nearest_generic_r(extHandle, tree, geom, geom, nullptr, nullptr);
@@ -3009,7 +3009,7 @@ extern "C" {
const void*
GEOSSTRtree_nearest_generic_r(GEOSContextHandle_t extHandle,
const void* item,
const geos::geom::Geometry* itemEnvelope,
GEOSDistanceCallback distancefn,
@@ -3053,7 +3053,7 @@ extern "C" {
void
GEOSSTRtree_iterate_r(GEOSContextHandle_t extHandle,
void* userdata)
@@ -3065,7 +3065,7 @@ extern "C" {
char
GEOSSTRtree_remove_r(GEOSContextHandle_t extHandle,
void* item) {
return execute(extHandle, 2, [&]() {
@@ -3075,7 +3075,7 @@ extern "C" {
void
GEOSSTRtree_destroy_r(GEOSContextHandle_t extHandle,
- geos::index::strtree::STRtree* tree)
+ GEOSSTRtree* tree)
delete tree;
diff --git a/include/geos/index/strtree/SimpleSTRtree.h b/include/geos/index/strtree/SimpleSTRtree.h
index baf79a4..6baa271 100644
--- a/include/geos/index/strtree/SimpleSTRtree.h
+++ b/include/geos/index/strtree/SimpleSTRtree.h
@@ -140,6 +140,8 @@ public:
void insert(const geom::Envelope* itemEnv, void* item) override;
+ void iterate(ItemVisitor& visitor);
void query(const geom::Envelope* searchEnv, std::vector<void*>& matches) override;
void query(const geom::Envelope* searchEnv, ItemVisitor& visitor) override;
diff --git a/src/index/strtree/SimpleSTRtree.cpp b/src/index/strtree/SimpleSTRtree.cpp
index 1dbf20e..b8724e1 100644
--- a/src/index/strtree/SimpleSTRtree.cpp
+++ b/src/index/strtree/SimpleSTRtree.cpp
@@ -17,6 +17,7 @@
#include <geos/geom/Geometry.h>
+#include <geos/util.h>
#include <vector>
#include <cassert>
@@ -59,6 +60,8 @@ SimpleSTRtree::insert(geom::Geometry* geom)
void
SimpleSTRtree::insert(const geom::Envelope* itemEnv, void* item)
+ if (itemEnv->isNull())
+ return;
SimpleSTRnode *node = createNode(0, itemEnv, item);
nodes.push_back(node);
@@ -175,7 +178,7 @@ SimpleSTRtree::build()
if (built) return;
if (nodes.empty()) {
- root = createNode(0);
+ root = nullptr;
else {
std::vector<SimpleSTRnode*> nodeTree = createHigherLevels(nodes, -1);
@@ -185,16 +188,21 @@ SimpleSTRtree::build()
built = true;
+void
+SimpleSTRtree::iterate(ItemVisitor& visitor)
+ for(auto* leafNode: nodes) {
+ visitor.visitItem(leafNode->getItem());
/* public */
void
SimpleSTRtree::query(const geom::Envelope* searchEnv, ItemVisitor& visitor)
- if(!built) {
- build();
+ build();
- if(nodes.empty()) {
- assert(root == nullptr);
+ if(nodes.empty() || !root) {
return;
@@ -226,12 +234,9 @@ SimpleSTRtree::query(const geom::Envelope* searchEnv,
void
SimpleSTRtree::query(const geom::Envelope* searchEnv, std::vector<void*>& matches)
- if(!built) {
- build();
+ build();
return;
@@ -265,10 +270,9 @@ SimpleSTRtree::query(const geom::Envelope* searchEnv,
bool
SimpleSTRtree::remove(const geom::Envelope* itemEnv, void* item)
- if (itemEnv || item) // no implementation of remove() yet!
- return false;
- else
- return false;
+ ::geos::ignore_unused_variable_warning(itemEnv);
+ ::geos::ignore_unused_variable_warning(item);
+ assert(false);
@@ -280,10 +284,15 @@ operator<<(std::ostream& os, SimpleSTRtree& tree)
os << "nodeCapacity: " << tree.getNodeCapacity() << std::endl;
os << "nodes.size(): " << tree.getNumLeafNodes() << std::endl;
os << "built: " << tree.getBuilt() << std::endl;
- os << "tree: " << std::endl;
- if (tree.getRoot())
+ if (tree.getRoot()) {
+ os << "tree: " << std::endl;
tree.getRoot()->toString(os, 1);
+ else {
+ os << "tree: empty" << std::endl;
return os;
@@ -293,6 +302,9 @@ operator<<(std::ostream& os, SimpleSTRtree& tree)
std::pair<const void*, const void*>
SimpleSTRtree::nearestNeighbour(ItemDistance* itemDist)
+ if (!this->getRoot()) {
+ return std::pair<const void*, const void*>(nullptr, nullptr);
SimpleSTRdistance strDist(this->getRoot(), this->getRoot(), itemDist);
return strDist.nearestNeighbour();
@@ -302,6 +314,9 @@ SimpleSTRtree::nearestNeighbour(ItemDistance* itemDist)
const void*
SimpleSTRtree::nearestNeighbour(const geom::Envelope* p_env, const void* p_item, ItemDistance* itemDist)
+ return nullptr;
std::unique_ptr<SimpleSTRnode> ssn(new SimpleSTRnode(0, p_env, (void*)p_item));
SimpleSTRdistance strDist(getRoot(), ssn.get(), itemDist);
std::pair<const void*, const void*> result = strDist.nearestNeighbour();
@@ -313,6 +328,9 @@ SimpleSTRtree::nearestNeighbour(const geom::Envelope* p_env, const void* p_item,
SimpleSTRtree::nearestNeighbour(SimpleSTRtree& tree, ItemDistance* itemDist)
+ if (!(this->getRoot() && tree.getRoot())) {
SimpleSTRdistance strDist(this->getRoot(), tree.getRoot(), itemDist);
@@ -321,6 +339,9 @@ SimpleSTRtree::nearestNeighbour(SimpleSTRtree& tree, ItemDistance* itemDist)
bool
SimpleSTRtree::isWithinDistance(SimpleSTRtree& tree, ItemDistance* itemDist, double maxDistance)
+ return false;
return strDist.isWithinDistance(maxDistance);
Summary of changes:
NEWS | 1 +
capi/geos_c.cpp | 15 ++++----
capi/geos_ts_c.cpp | 22 ++++++------
include/geos/index/strtree/SimpleSTRtree.h | 2 ++
src/index/strtree/SimpleSTRtree.cpp | 55 +++++++++++++++++++++---------
5 files changed, 59 insertions(+), 36 deletions(-)
hooks/post-receive
More information about the geos-commits
