[geos-commits] [SCM] GEOS branch master updated. 2ad9efe1479beccf1fc204094f5fb8d39a82053e
git at osgeo.org
git at osgeo.org
Thu Nov 26 14:05:33 PST 2020
the project "GEOS".
via 2ad9efe1479beccf1fc204094f5fb8d39a82053e (commit)
from 7d4e17336f45d39aa2debd91237eed461aa5da09 (commit)
revisions in full, below.
commit 2ad9efe1479beccf1fc204094f5fb8d39a82053e
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Nov 23 13:19:56 2020 +0100
Port ElevationModel class from JTS
Closes #1070
Differences from JTS:
- Cells are all initialized upfront, no heap allocations
- CoordinateSequence::hasZ implemented as non-virtual
- ElevationModel::populateZ uses CoordinateFilter instead
of CoordinateSequenceFilter (see note 1)
Note1:
Using CoordinateFilter instead of CoordinateSequenceFilter
allows CoordinateSequence to clear the dimension cache which
would otherwise not properly set the sequence as having Z
(see #435)
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index 976b2cc..e8eeca5 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -222,6 +222,10 @@ public:
virtual std::size_t getDimension() const = 0;
+ bool hasZ() const {
+ return getDimension() > 2;
* Returns the ordinate of a coordinate in this sequence.
* Ordinate indices 0 and 1 are assumed to be X and Y.
diff --git a/include/geos/operation/overlayng/ElevationModel.h b/include/geos/operation/overlayng/ElevationModel.h
new file mode 100644
index 0000000..199efbc
--- /dev/null
+++ b/include/geos/operation/overlayng/ElevationModel.h
@@ -0,0 +1,170 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2020 Sandro Santilli <strk at kbt.io>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last Port: operation/overlayng/ElevationModel.java a0e53557
+#pragma once
+#include <geos/export.h>
+#include <geos/geom/Envelope.h> // for composition
+// Forward declarations
+namespace geos {
+ namespace geom {
+ class Geometry;
+namespace geos { // geos.
+namespace operation { // geos.operation
+namespace overlayng { // geos.operation.overlayng
+ * \brief
+ * A simple elevation model used to populate missing Z values
+ * in overlay results.
+ * The model divides the extent of the input geometry(s)
+ * into an NxM grid.
+ * The default grid size is 3x3.
+ * If the input has no extent in the X or Y dimension,
+ * that dimension is given grid size 1.
+ * The elevation of each grid cell is computed as the average of the Z
+ * values
+ * of the input vertices in that cell (if any).
+ * If a cell has no input vertices within it, it is assigned
+ * the average elevation over all cells.
+ * If no input vertices have Z values, the model does not assign a Z
+ * value.
+ * The elevation of an arbitrary location is determined as the
+ * Z value of the nearest grid cell.
+ * An elevation model can be used to populate missing Z values
+ * in an overlay result geometry.
+ * @author Martin Davis
+class GEOS_DLL ElevationModel {
+private:
+ class ElevationCell {
+ private:
+ int numZ = 0;
+ double sumZ = 0.0;
+ double avgZ;
+ public:
+ bool isNull() const
+ return numZ == 0;
+ void add(double z)
+ ++numZ;
+ sumZ += z;
+ void compute()
+ avgZ = DoubleNotANumber;
+ if (numZ > 0)
+ avgZ = sumZ / numZ;
+ double getZ() const
+ return avgZ;
+ static const int DEFAULT_CELL_NUM;
+ geom::Envelope extent;
+ int numCellX;
+ int numCellY;
+ double cellSizeX;
+ double cellSizeY;
+ std::vector<ElevationCell> cells;
+ bool isInitialized = false;
+ bool hasZValue = false;
+ double averageZ = DoubleNotANumber;
+ void init();
+ ElevationCell& getCell(double x, double y); //, bool isCreateIfMissing);
+ int getCellOffset(int ix, int iy) {
+ return (numCellX * iy + ix);
+protected:
+ void add(double x, double y, double z);
+public:
+ static std::unique_ptr<ElevationModel> create(const geom::Geometry& geom1,
+ const geom::Geometry& geom2);
+ static std::unique_ptr<ElevationModel> create(const geom::Geometry& geom1);
+ ElevationModel(const geom::Envelope& extent, int numCellX, int numCellY);
+ void add(const geom::Geometry& geom);
+ * Gets the model Z value at a given location.
+ * If the location lies outside the model grid extent,
+ * this returns the Z value of the nearest grid cell.
+ * If the model has no elevation computed (i.e. due
+ * to empty input), the value is returned as {@link Double#NaN}.
+ * @param x the x ordinate of the location
+ * @param y the y ordinate of the location
+ * @return the computed model Z value
+ double getZ(double x, double y);
+ * \brief
+ * Computes Z values for any missing Z values in a geometry,
+ * using the computed model.
+ * If the model has no Z value, or the geometry coordinate dimension
+ * does not include Z, no action is taken.
+ * @param geom the geometry to elevate
+ void populateZ(geom::Geometry& geom);
+} // namespace geos.operation.overlayng
diff --git a/include/geos/operation/overlayng/Makefile.am b/include/geos/operation/overlayng/Makefile.am
index 0dd90d8..8efcceb 100644
--- a/include/geos/operation/overlayng/Makefile.am
+++ b/include/geos/operation/overlayng/Makefile.am
@@ -13,6 +13,7 @@ geos_HEADERS = \
EdgeMerger.h \
EdgeNodingBuilder.h \
EdgeSourceInfo.h \
+ ElevationModel.h \
IndexedPointOnLineLocator.h \
InputGeometry.h \
IntersectionPointBuilder.h \
diff --git a/include/geos/operation/overlayng/OverlayNG.h b/include/geos/operation/overlayng/OverlayNG.h
index 505e918..30219e4 100644
--- a/include/geos/operation/overlayng/OverlayNG.h
+++ b/include/geos/operation/overlayng/OverlayNG.h
@@ -3,6 +3,7 @@
* Copyright (C) 2020 Paul Ramsey <pramsey at cleverelephant.ca>
@@ -10,6 +11,10 @@
+ * Last Port: operation/overlayng/OverlayNG.java 459bc7f8e
#pragma once
diff --git a/src/operation/overlayng/ElevationModel.cpp b/src/operation/overlayng/ElevationModel.cpp
index 0000000..d672dee
--- /dev/null
+++ b/src/operation/overlayng/ElevationModel.cpp
@@ -0,0 +1,277 @@
+ * Last Port: operation/overlayng/ElevationModel.java 459bc7f8
+#include <geos/operation/overlayng/ElevationModel.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/CoordinateFilter.h>
+#include <geos/geom/CoordinateSequenceFilter.h>
+#include <memory> // for unique_ptr
+#ifndef GEOS_DEBUG
+# define GEOS_DEBUG 0
+#endif
+#if GEOS_DEBUG
+# include <iostream>
+#endif
+namespace {
+ template<typename T>
+ T clamp(const T& v, const T& low, const T& high) {
+ return v < low ? low : high < v ? high : v;
+using geos::geom::Coordinate;
+using geos::geom::CoordinateSequence;
+using geos::geom::Geometry;
+using geos::geom::Envelope;
+/* public static */
+std::unique_ptr<ElevationModel>
+ElevationModel::create(const geom::Geometry& geom1, const geom::Geometry& geom2)
+ Envelope extent;
+ if (! geom1.isEmpty() ) {
+ extent.expandToInclude(geom1.getEnvelopeInternal());
+ if (! geom2.isEmpty() ) {
+ extent.expandToInclude(geom2.getEnvelopeInternal());
+ std::unique_ptr<ElevationModel> model ( new ElevationModel(extent, DEFAULT_CELL_NUM, DEFAULT_CELL_NUM) );
+ if (! geom1.isEmpty() ) model->add(geom1);
+ if (! geom2.isEmpty() ) model->add(geom2);
+ return model;
+ElevationModel::create(const geom::Geometry& geom1)
+ Envelope extent;
+ return model;
+const int ElevationModel::DEFAULT_CELL_NUM = 3;
+ElevationModel::ElevationModel(const Envelope& nExtent, int nNumCellX, int nNumCellY)
+ extent(nExtent),
+ numCellX(nNumCellX),
+ numCellY(nNumCellY)
+ cellSizeX = extent.getWidth() / numCellX;
+ cellSizeY = extent.getHeight() / numCellY;
+ if(cellSizeX <= 0.0) {
+ numCellX = 1;
+ if(cellSizeY <= 0.0) {
+ numCellY = 1;
+ cells.resize(numCellX * numCellY);
+/* public */
+void
+ElevationModel::add(const Geometry& geom)
+ class Filter: public geom::CoordinateSequenceFilter {
+ ElevationModel& model;
+ bool hasZ;
+ public:
+ Filter(ElevationModel& nModel) : model(nModel), hasZ(true) {}
+ void filter_ro(const geom::CoordinateSequence& seq, std::size_t i) override
+#if 0
+ if (! seq.hasZ()) {
+ hasZ = false;;
+ return;
+#endif
+ const Coordinate& c = seq.getAt(i);
+#if GEOS_DEBUG
+ std::cout << "Coordinate " << i << " of added geom is: "
+<< c << std::endl;
+#endif
+ model.add(c.x, c.y, c.z);
+ bool isDone() const override {
+ // no need to scan if no Z present
+ return ! hasZ;
+ bool isGeometryChanged() const override {
+ return false;
+ Filter filter(*this);
+ geom.apply_ro(filter);
+/* protected */
+void
+ElevationModel::add(double x, double y, double z)
+ if (std::isnan(z))
+ return;
+ hasZValue = true;
+ ElevationCell& cell = getCell(x, y); //, true);
+ cell.add(z);
+/* private */
+void
+ElevationModel::init()
+ isInitialized = true;
+ int numCells = 0;
+#if GEOS_DEBUG
+ int offset = 0;
+#endif
+ for (ElevationCell& cell : cells )
+ if (!cell.isNull()) {
+ cell.compute();
+#if GEOS_DEBUG
+ std::cout << "init: cell" << offset
+ << " getZ: " << cell.getZ()
+ << std::endl;
+#endif
+ numCells++;
+ sumZ += cell.getZ();
+#if GEOS_DEBUG
+ ++offset;
+#endif
+ averageZ = DoubleNotANumber;
+ if (numCells > 0) {
+ averageZ = sumZ / numCells;
+#if GEOS_DEBUG
+ std::cout << "init: numCells: " << numCells
+ << " averageZ: " << averageZ << std::endl;
+#endif
+/* public */
+double
+ElevationModel::getZ(double x, double y)
+ if (! isInitialized)
+ init();
+ const ElevationModel::ElevationCell& cell = getCell(x, y); //, false);
+ if (cell.isNull())
+ return averageZ;
+ return cell.getZ();
+/* public */
+void
+ElevationModel::populateZ(Geometry& geom)
+ // short-circuit if no Zs are present in model
+ if (! hasZValue)
+ return;
+ init();
+ class Filter: public geom::CoordinateFilter {
+ public:
+ Filter(ElevationModel& nModel) : model(nModel) {}
+ void filter_rw(geom::Coordinate* c) const override
+#if GEOS_DEBUG
+ std::cout << "Input coord: " << *c << std::endl;
+#endif
+ if (std::isnan( c->z )) {
+ c->z = model.getZ(c->x, c->y);
+#if GEOS_DEBUG
+ std::cout << "New coord: " << *c << std::endl;
+#endif
+#if GEOS_DEBUG
+ std::cout << "ElevationModel::poplateZ calling apply_rw(CoordinateSequenceFilter&) against" <<
+ //std::type_name<decltype(ci)>()
+ typeid(geom).name()
+ << std::endl;
+#endif
+ geom.apply_rw(&filter);
+/* private */
+ElevationModel::ElevationCell&
+ElevationModel::getCell(double x, double y) //, bool isCreateIfMissing
+ int ix = 0;
+ if (numCellX > 1) {
+ ix = (int) ((x - extent.getMinX()) / cellSizeX);
+ ix = clamp(ix, 0, numCellX - 1);
+ int iy = 0;
+ if (numCellY > 1) {
+ iy = (int) ((y - extent.getMinY()) / cellSizeY);
+ iy = clamp(iy, 0, numCellY - 1);
+ int cellOffset = getCellOffset(ix, iy);
+#if GEOS_DEBUG
+ std::cout << "Cell of coordinate " << x << "," << y
+ << " is " << ix << "," << iy
+ << " offset " << cellOffset << std::endl;
+#endif
+ assert ( cellOffset < numCellX * numCellY );
+ ElevationModel::ElevationCell& cell = cells[cellOffset];
+ return cell;
diff --git a/src/operation/overlayng/Makefile.am b/src/operation/overlayng/Makefile.am
index 205273d..ee52fbc 100644
--- a/src/operation/overlayng/Makefile.am
+++ b/src/operation/overlayng/Makefile.am
@@ -12,6 +12,7 @@ libopoverlayng_la_SOURCES = \
EdgeMerger.cpp \
EdgeNodingBuilder.cpp \
EdgeSourceInfo.cpp \
+ ElevationModel.cpp \
IndexedPointOnLineLocator.cpp \
InputGeometry.cpp \
IntersectionPointBuilder.cpp \
diff --git a/src/operation/overlayng/OverlayNG.cpp b/src/operation/overlayng/OverlayNG.cpp
index baba411..6b6ad1d 100644
--- a/src/operation/overlayng/OverlayNG.cpp
+++ b/src/operation/overlayng/OverlayNG.cpp
@@ -3,6 +3,7 @@
@@ -10,12 +11,17 @@
#include <geos/operation/overlayng/OverlayNG.h>
#include <geos/operation/overlayng/Edge.h>
#include <geos/operation/overlayng/EdgeNodingBuilder.h>
#include <geos/operation/overlayng/InputGeometry.h>
#include <geos/operation/overlayng/IntersectionPointBuilder.h>
#include <geos/operation/overlayng/LineBuilder.h>
@@ -32,11 +38,17 @@
#include <algorithm>
#ifndef GEOS_DEBUG
#define GEOS_DEBUG 0
#endif
+#if GEOS_DEBUG
+# include <geos/io/WKTWriter.h>
+#endif
@@ -135,21 +147,57 @@ OverlayNG::geomunion(const Geometry* geom, const PrecisionModel* pm, noding::Nod
std::unique_ptr<Geometry>
OverlayNG::getResult()
- if (OverlayUtil::isEmptyResult(opCode, inputGeom.getGeometry(0), inputGeom.getGeometry(1), pm)) {
+ const Geometry *ig0 = inputGeom.getGeometry(0);
+ const Geometry *ig1 = inputGeom.getGeometry(1);
+ if ( OverlayUtil::isEmptyResult(opCode, ig0, ig1, pm) )
return createEmptyResult();
- // special logic for Point-Point inputs
- if (inputGeom.isAllPoints()) {
- return OverlayPoints::overlay(opCode, inputGeom.getGeometry(0), inputGeom.getGeometry(1), pm);
+ * The elevation model is only computed if the input geometries have Z values.
+ std::unique_ptr<ElevationModel> elevModel;
+ if ( ig1 ) {
+ elevModel = ElevationModel::create(*ig0, *ig1);
+ } else {
+ elevModel = ElevationModel::create(*ig0);
+ std::unique_ptr<Geometry> result;
- // special logic for Point-nonPoint inputs
- if (! inputGeom.isSingle() && inputGeom.hasPoints()) {
- return OverlayMixedPoints::overlay(opCode, inputGeom.getGeometry(0), inputGeom.getGeometry(1), pm);
+ if (inputGeom.isAllPoints()) {
+ // handle Point-Point inputs
+ result = OverlayPoints::overlay(opCode, ig0, ig1, pm);
+ else if (! inputGeom.isSingle() && inputGeom.hasPoints()) {
+ // handle Point-nonPoint inputs
+ result = OverlayMixedPoints::overlay(opCode, ig0, ig1, pm);
+ else {
+ // handle case where both inputs are formed of edges (Lines and Polygons)
+ result = computeEdgeOverlay();
+#if GEOS_DEBUG
+ io::WKTWriter w;
+ w.setOutputDimension(3);
+ w.setTrim(true);
+ std::cout << "Before populatingZ: " << w.write(result.get()) << std::endl;
+#endif
+ * This is a no-op if the elevation model was not computed due to
+ * Z not present
+ elevModel->populateZ(*result);
+#if GEOS_DEBUG
+ std::cout << " After populatingZ: " << w.write(result.get()) << std::endl;
+#endif
- return computeEdgeOverlay();
+ return result;
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 51129c8..adf5d1a 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -195,6 +195,7 @@ geos_unit_SOURCES = \
operation/overlay/validate/FuzzyPointLocatorTest.cpp \
operation/overlay/validate/OffsetPointGeneratorTest.cpp \
operation/overlay/validate/OverlayResultValidatorTest.cpp \
+ operation/overlayng/ElevationModelTest.cpp \
operation/overlayng/RingClipperTest.cpp \
operation/overlayng/LineLimiterTest.cpp \
operation/overlayng/OverlayGraphTest.cpp \
diff --git a/tests/unit/operation/overlayng/ElevationModelTest.cpp b/tests/unit/operation/overlayng/ElevationModelTest.cpp
index 0000000..347f079
--- /dev/null
+++ b/tests/unit/operation/overlayng/ElevationModelTest.cpp
@@ -0,0 +1,254 @@
+// Test Suite for geos::operation::overlayng::ElevationModel class.
+// Last port:
+// modules/core/src/test/java/org/locationtech/jts/operation/overlayng/ElevationModelTest.java
+// 459bc7f8e4057dd05c0576b88d1550d552bf132d
+#include <tut/tut.hpp>
+#include <utility.h>
+// geos
+#include <geos/constants.h> // for DoubleNotANumber
+// std
+#include <memory>
+#include <initializer_list>
+using namespace geos::geom;
+using namespace geos::operation::overlayng;
+using geos::io::WKTReader;
+using geos::DoubleNotANumber;
+using geos::io::WKTWriter;
+namespace tut {
+// Test Group
+// Common data used by all tests
+struct test_overlayng_elevationmodel_data {
+ WKTReader r;
+ WKTWriter w;
+ const double TOLERANCE = 0.00001;
+ test_overlayng_elevationmodel_data()
+ w.setTrim(true);
+ void checkElevation(const std::string& wkt1, const std::string& wkt2, std::initializer_list<double> ords)
+ std::unique_ptr<Geometry> g1 = r.read(wkt1);
+ std::unique_ptr<Geometry> g2 = r.read(wkt2);
+ std::unique_ptr<ElevationModel> model = ElevationModel::create(*g1, *g2);
+ unsigned int numPts = ords.size() / 3;
+ assert ( 3 * numPts == ords.size());
+ for ( std::initializer_list<double>::iterator i=ords.begin(), e=ords.end();
+ i != e; ++i )
+ double x = *i++;
+ double y = *i++;
+ double expectedZ = *i;
+ double actualZ = model->getZ(x, y);
+ ensure_distance(expectedZ, actualZ, TOLERANCE);
+ void checkElevation(const std::string& wkt1, std::initializer_list<double> ords)
+ checkElevation(wkt1, "POINT EMPTY", ords);
+ void checkElevationPopulateZ(const std::string& wkt,
+ const std::string& wktNoZ,
+ const std::string& wktZExpected)
+ std::unique_ptr<Geometry> geom = r.read(wkt);
+ std::unique_ptr<ElevationModel> model = ElevationModel::create(*geom);
+ std::unique_ptr<Geometry> geomNoZ = r.read(wktNoZ);
+ model->populateZ(*geomNoZ);
+ std::unique_ptr<Geometry> geomZExpected = r.read(wktZExpected);
+ geomNoZ->normalize();
+ geomZExpected->normalize();
+ std::string obtainedWKT = w.write(geomNoZ.get());
+ std::string expectedWKT = w.write(geomZExpected.get());
+ ensure_equals(obtainedWKT, expectedWKT);
+typedef test_group<test_overlayng_elevationmodel_data> group;
+typedef group::object object;
+group test_overlayng_elevationmodel_group("geos::operation::overlayng::ElevationModel");
+// Test Cases
+// testBox
+template<>
+template<>
+void object::test<1> ()
+ checkElevation(
+ "POLYGON Z ((1 6 50, 9 6 60, 9 4 50, 1 4 40, 1 6 50))",
+ 0,10, 50, 5,10, 50, 10,10, 60,
+ 0,5, 50, 5,5, 50, 10,5, 50,
+ 0,4, 40, 5,4, 50, 10,4, 50,
+ 0,0, 40, 5,0, 50, 10,0, 50
+// testLine
+template<>
+template<>
+void object::test<2> ()
+ checkElevation(
+ "LINESTRING Z (0 0 0, 10 10 10)",
+ -1,11, 5, 11,11, 10,
+ 0,10, 5, 5,10, 5, 10,10, 10,
+ 0,5, 5, 5,5, 5, 10,5, 5,
+ 0,0, 0, 5,0, 5, 10,0, 5,
+ -1,-1, 0, 5,-1, 5, 11,-1, 5
+// testMultiLine
+template<>
+template<>
+void object::test<3> ()
+ checkElevation(
+ "MULTILINESTRING Z ((0 0 0, 10 10 8), (1 2 2, 9 8 6))",
+ -1,11, 4, 11,11, 7,
+ 0,10, 4, 5,10, 4, 10,10, 7,
+ 0,5, 4, 5,5, 4, 10,5, 4,
+ 0,0, 1, 5,0, 4, 10,0, 4,
+ -1,-1, 1, 5,-1, 4, 11,-1, 4
+// testTwoLines
+template<>
+template<>
+void object::test<4> ()
+ checkElevation( "LINESTRING Z (0 0 0, 10 10 8)",
+ "LINESTRING Z (1 2 2, 9 8 6))",
+ * Tests that XY geometries are scanned correctly (avoiding reading Z)
+ * and that they produce a model Z value of NaN
+// testLine2D()
+template<>
+template<>
+void object::test<5> ()
+ checkElevation( "LINESTRING(0 0, 10 0)",
+ { 5, 5, DoubleNotANumber }
+// testLineHorizontal
+template<>
+template<>
+void object::test<6> ()
+ checkElevation("LINESTRING Z (0 5 0, 10 5 10)",
+ 0,10, 0, 5,10, 5, 10,10, 10,
+ 0,5, 0, 5,5, 5, 10,5, 10,
+ 0,0, 0, 5,0, 5, 10,0, 10
+// testLineVertical
+template<>
+template<>
+void object::test<7> ()
+ checkElevation("LINESTRING Z (5 0 0, 5 10 10)",
+ 0,10, 10, 5,10, 10, 10,10, 10,
+ 0,0, 0, 5,0, 0, 10,0, 0
+// tests that single point Z is used for entire grid and beyond
+// testPoint()
+template<>
+template<>
+void object::test<8> ()
+ checkElevation("POINT Z (5 5 5)",
+ 0,9, 5, 5,9, 5, 9,9, 5,
+ 0,5, 5, 5,5, 5, 9,5, 5,
+ 0,0, 5, 5,0, 5, 9,0, 5
+// tests that Z is average of input points with same location
+// testMultiPointSame
+template<>
+template<>
+void object::test<9> ()
+ checkElevation("MULTIPOINT Z ((5 5 5), (5 5 9))",
+ 0,9, 7, 5,9, 7, 9,9, 7,
+ 0,5, 7, 5,5, 7, 9,5, 7,
+ 0,0, 7, 5,0, 7, 9,0, 7
+// testPopulateZLine
+template<>
+template<>
+void object::test<10> ()
+ checkElevationPopulateZ("LINESTRING Z (0 0 0, 10 10 10)",
+ "LINESTRING (1 1, 9 9)",
+ "LINESTRING (1 1 0, 9 9 10)"
+// testPopulateZBox
+template<>
+template<>
+void object::test<11> ()
+ "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))",
+ "POLYGON Z ((1 1 0, 1 9 5, 9 9 10, 9 1 5, 1 1 0))"
+} // namespace tut
diff --git a/tests/unit/operation/overlayng/OverlayNGZTest.cpp b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
index cbe4d8c..f56ab10 100644
--- a/tests/unit/operation/overlayng/OverlayNGZTest.cpp
+++ b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
@@ -4,7 +4,7 @@
// Ported from JTS
// modules/core/src/test/java/org/locationtech/jts/operation/overlayng/OverlayNGZTest.java
-// c1a2e9a3cd723ebfb6c79e9daf5217f562f470e0
+// f3ebebb71ea838d00d29e564cf4de667a3b9a968
@@ -12,6 +12,8 @@
// geos
+#include <geos/io/WKTWriter.h>
+#include <geos/io/WKTReader.h>
// std
#include <memory>
@@ -19,6 +21,7 @@
namespace tut {
@@ -29,6 +32,13 @@ namespace tut {
struct test_overlayngz_data {
WKTReader r;
+ WKTWriter w;
+ test_overlayngz_data()
+ w.setTrim(true);
void checkOverlay(int opCode, const std::string& wktA, const std::string& wktB, const std::string& wktExpected)
@@ -36,7 +46,11 @@ struct test_overlayngz_data {
std::unique_ptr<Geometry> b = r.read(wktB);
std::unique_ptr<Geometry> expected = r.read(wktExpected);
std::unique_ptr<Geometry> result = OverlayNG::overlay(a.get(), b.get(), opCode);
- ensure_equals_geometry_xyz(result.get(), expected.get());
+ expected->normalize();
+ result->normalize();
+ std::string obtainedWKT = w.write(result.get());
+ std::string expectedWKT = w.write(expected.get());
void checkIntersection(const std::string& wktA, const std::string& wktB, const std::string& wktExpected)
@@ -65,100 +79,155 @@ group test_overlayngz_group("geos::operation::overlayng::OverlayNGZ");
// Test Cases
-// testLineIntersectionPointInterpolated
+// testPointXYPointDifference
template<>
template<>
- checkIntersection("LINESTRING (0 0 0, 10 10 10)", "LINESTRING (10 0 0, 0 10 10)", "POINT(5 5 5)");
+ checkDifference("MULTIPOINT ((1 1), (5 5))", "POINT Z (5 5 99)",
+ "POINT Z(1 1 99)");
+// checks that Point Z is preserved
+// testPointPolygonIntersection
template<>
template<>
- "LINESTRING (0 0 0, 10 10 10)",
- "LINESTRING (10 0 0, 5 5 999, 0 10 10)",
- "POINT(5 5 999)"
+ checkIntersection("POINT Z (5 5 99)", "POLYGON Z ((1 9 5, 9 9 9, 9 1 5, 1 1 1, 1 9 5))",
+ "POINT Z(5 5 99)");
-// testLineLineXYDifferenceLineInterpolate
+// testLineIntersectionPointZInterpolated
template<>
template<>
- checkDifference(
- "LINESTRING (5 5, 6 6)",
- "MULTILINESTRING ((0 0 0, 5 5 5), (6 6 6, 10 10 10))"
+ checkIntersection("LINESTRING (0 0 0, 10 10 10)", "LINESTRING (10 0 0, 0 10 10)",
+ "POINT(5 5 5)");
-// testLineLineUnionOverlay
+// testLineIntersectionPointZValue
template<>
template<>
- checkUnion(
- "LINESTRING (5 5 990, 15 15 999)",
- "MULTILINESTRING Z((0 0 0, 5 5 990), (5 5 990, 10 10 10), (10 10 10, 15 15 999))"
+ checkIntersection("LINESTRING (0 0 0, 10 10 10)", "LINESTRING (10 0 0, 5 5 999, 0 10 10)",
+ "POINT(5 5 999)");
-// testLinePolygonIntersectionLine
+// testLineOverlapUnion
template<>
template<>
- "LINESTRING Z (0 0 0, 5 5 5)",
- "POLYGON Z ((1 9 5, 9 9 9, 9 1 5, 1 1 1, 1 9 5))",
- "LINESTRING Z (1 1 1, 5 5 5)"
+ checkUnion("LINESTRING (0 0 0, 10 10 10)", "LINESTRING (5 5 990, 15 15 999)",
+ "MULTILINESTRING Z((0 0 0, 5 5 990), (5 5 990, 10 10 10), (10 10 10, 15 15 999))");
-// testLinePolygonDifferenceLine
+// testLineLineXYDifferenceLineInterpolated
template<>
template<>
- checkDifference(
- "LINESTRING Z (0 5 0, 10 5 10)",
- "MULTILINESTRING Z((0 5 0, 1 5 2), (9 5 8, 10 5 10))"
+ checkDifference("LINESTRING (0 0 0, 10 10 10)", "LINESTRING (5 5, 6 6)",
+ "MULTILINESTRING ((0 0 0, 5 5 5), (6 6 6, 10 10 10))");
-// testLinePolygonXYDifferenceLine
+// testLinePolygonIntersection
template<>
template<>
- checkDifference(
- "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))",
- "MULTILINESTRING Z((0 5 0, 1 5 1), (9 5 9, 10 5 10))"
+ checkIntersection("LINESTRING Z (0 0 0, 5 5 5)", "POLYGON Z ((1 9 5, 9 9 9, 9 1 5, 1 1 1, 1 9 5))",
+ "LINESTRING Z (1 1 1, 5 5 5)");
+// testLinePolygonDifference
+template<>
+template<>
+ checkDifference("LINESTRING Z (0 5 0, 10 5 10)", "POLYGON Z ((1 9 5, 9 9 9, 9 1 5, 1 1 1, 1 9 5))",
+ "MULTILINESTRING Z((0 5 0, 1 5 2), (9 5 8, 10 5 10))");
+// testPointXYPolygonIntersection
+template<>
+template<>
+ checkIntersection("POINT (5 5)", "POLYGON Z ((1 9 50, 9 9 90, 9 1 50, 1 1 10, 1 9 50))",
+ "POINT Z(5 5 50)");
+// XY Polygon gets Z value from Point
+// testPointPolygonXYUnionn
+template<>
+template<>
+ checkUnion("POINT Z (5 5 77)", "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))",
+ "POLYGON Z((1 1 77, 1 9 77, 9 9 77, 9 1 77, 1 1 77))");
+// testLinePolygonXYDifference
+template<>
+template<>
+ checkDifference("LINESTRING Z (0 5 0, 10 5 10)", "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))",
+ "MULTILINESTRING Z((0 5 0, 1 5 1), (9 5 9, 10 5 10))");
-//// TODO: add Z population from model
-//// testLineXYPolygonDifferenceLine
-//template<>
-//template<>
-//void object::test<8> ()
-// checkDifference(
-// "LINESTRING (0 5, 10 5)",
-// "POLYGON Z ((1 9 5, 9 9 9, 9 1 5, 1 1 1, 1 9 5))",
-// "MULTILINESTRING Z((0 5 0, 1 5 2), (9 5 8, 10 5 10))"
+// testLineXYPolygonDifference
+template<>
+template<>
+void object::test<12> ()
+ checkDifference("LINESTRING (0 5, 10 5)", "POLYGON Z ((1 9 50, 9 9 90, 9 1 50, 1 1 10, 1 9 50))",
+ "MULTILINESTRING Z((0 5 50, 1 5 30), (9 5 70, 10 5 50))");
+// testPolygonXYPolygonIntersection
+template<>
+template<>
+void object::test<13> ()
+ checkIntersection("POLYGON ((4 12, 2 6, 7 6, 11 4, 15 15, 4 12))", "POLYGON Z ((1 9 50, 9 9 90, 9 1 50, 1 1 10, 1 9 50))",
+ "POLYGON Z((2 6 50, 3 9 60, 9 9 90, 9 5 70, 7 6 90, 2 6 50))");
+// testPolygonXYPolygonUnion
+template<>
+template<>
+void object::test<14> ()
+ checkUnion("POLYGON ((0 3, 3 3, 3 0, 0 0, 0 3))", "POLYGON Z ((1 9 50, 9 9 90, 9 1 50, 1 1 10, 1 9 50))",
+ "POLYGON Z((0 0 10, 0 3 50, 1 3 20, 1 9 50, 9 9 90, 9 1 50, 3 1 20, 3 0 50, 0 0 10))");
+// Test that operation on XY geoms produces XY (Z = NaN)
+// testPolygonXYPolygonXYIntersection
+template<>
+template<>
+void object::test<15> ()
+ checkIntersection("POLYGON ((4 12, 2 6, 7 6, 11 4, 15 15, 4 12))", "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))",
+ "POLYGON ((2 6, 3 9, 9 9, 9 5, 7 6, 2 6))");
+// from https://trac.osgeo.org/geos/ticket/435
+// testLineXYLineIntersection
+template<>
+template<>
+void object::test<16> ()
+ "LINESTRING(0 0,0 10,10 10,10 0)",
+ "LINESTRING(10 10 4,10 0 5,0 0 5)",
+ "GEOMETRYCOLLECTION Z(POINT Z(0 0 5), LINESTRING Z(10 0 5, 10 10 4))"
} // namespace tut
Summary of changes:
include/geos/geom/CoordinateSequence.h | 4 +
include/geos/operation/overlayng/ElevationModel.h | 170 +++++++++++++
include/geos/operation/overlayng/Makefile.am | 1 +
include/geos/operation/overlayng/OverlayNG.h | 5 +
src/operation/overlayng/ElevationModel.cpp | 277 +++++++++++++++++++++
src/operation/overlayng/Makefile.am | 1 +
src/operation/overlayng/OverlayNG.cpp | 66 ++++-
tests/unit/Makefile.am | 1 +
.../operation/overlayng/ElevationModelTest.cpp | 254 +++++++++++++++++++
tests/unit/operation/overlayng/OverlayNGZTest.cpp | 173 +++++++++----
10 files changed, 891 insertions(+), 61 deletions(-)
create mode 100644 include/geos/operation/overlayng/ElevationModel.h
create mode 100644 src/operation/overlayng/ElevationModel.cpp
create mode 100644 tests/unit/operation/overlayng/ElevationModelTest.cpp
hooks/post-receive
More information about the geos-commits
