[geos-commits] [SCM] GEOS branch master updated. 3e3bf5074031cf86a10a017bddfdf693389a322f
git at osgeo.org
git at osgeo.org
Sat Nov 28 12:29:03 PST 2020
the project "GEOS".
via 3e3bf5074031cf86a10a017bddfdf693389a322f (commit)
via b8cc3850e31f5d13a9ac79e416209da041fdb83b (commit)
via f1074ea2ad4a09543bb3df2c136d5f89a9dac982 (commit)
via 3997aae9feaebbe5d5295b67d41a5d941b7d0664 (commit)
via 48d02f65db373bf915ad225a9385c5713077c39e (commit)
from 166faaea066d129999af7e7897ea994627bc097f (commit)
revisions in full, below.
commit 3e3bf5074031cf86a10a017bddfdf693389a322f
Merge: f1074ea b8cc385
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Sat Nov 28 12:28:47 2020 -0800
Merge branch 'jorisvandenbossche-fix-setordinate-error'
commit b8cc3850e31f5d13a9ac79e416209da041fdb83b
Merge: f1074ea 48d02f6
Date: Sat Nov 28 12:23:28 2020 -0800
Merge branch 'fix-setordinate-error' of https://github.com/jorisvandenbossche/geos into jorisvandenbossche-fix-setordinate-error
commit f1074ea2ad4a09543bb3df2c136d5f89a9dac982
Merge: 3997aae 166faae
Date: Sat Nov 28 11:56:29 2020 -0800
Merge branch 'master' of https://git.osgeo.org/gitea/geos/geos
commit 3997aae9feaebbe5d5295b67d41a5d941b7d0664
Date: Sat Nov 28 11:56:20 2020 -0800
Add unit test that matches failure described by python community
diff --git a/tests/unit/capi/GEOSSTRtreeTest.cpp b/tests/unit/capi/GEOSSTRtreeTest.cpp
index daf2675..5d6c2a4 100644
--- a/tests/unit/capi/GEOSSTRtreeTest.cpp
+++ b/tests/unit/capi/GEOSSTRtreeTest.cpp
@@ -62,7 +62,6 @@ struct test_capistrtree_data {
std::fprintf(stdout, "\n");
typedef test_group<test_capistrtree_data> group;
@@ -259,6 +258,54 @@ void object::test<7>
GEOSSTRtree_destroy(tree);
+// querying tree with box
+template<>
+template<>
+void object::test<8>
+ GEOSSTRtree* tree = GEOSSTRtree_create(10);
+ GEOSGeometry* g = GEOSGeomFromWKT("POINT (2 3)");
+ GEOSSTRtree_insert(tree, g, g);
+ GEOSGeometry* q = GEOSGeomFromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))");
+ typedef std::vector<GEOSGeometry*> GList;
+ GList geoms;
+ ensure_equals(geoms.size(), 0);
+ GEOSSTRtree_query(
+ tree,
+ q,
+ [](void* item, void* userdata) {
+ GList* geoms = (GList*)userdata;
+ geoms->push_back((GEOSGeometry*)item);
+ &geoms);
+ ensure_equals(geoms.size(), 1);
+ const GEOSCoordSequence* seq = GEOSGeom_getCoordSeq(geoms[0]);
+ double x = -1;
+ double y = -1;
+ GEOSCoordSeq_getXY(seq, 0, &x, &y);
+ ensure_equals(x, 2.0);
+ ensure_equals(y, 3.0);
+ GEOSGeom_destroy(q);
+ GEOSGeom_destroy(g);
+ GEOSSTRtree_destroy(tree);
+// >>> import pygeos
+// >>> pygeos.geos_version
+// (3, 9, 0)
+// >>> point = pygeos.Geometry("POINT (2 3)")
+// >>> tree = pygeos.STRtree([point])
+// >>> tree.query(pygeos.box(0, 0, 10, 10))
+// array([], dtype=int64)
} // namespace tut
commit 48d02f65db373bf915ad225a9385c5713077c39e
Author: Joris Van den Bossche <jorisvandenbossche at gmail.com>
Date: Sat Nov 28 16:46:01 2020 +0100
Fix return error code of GEOSCoordSeq_setOrdinate (closes #1078)
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index cbc94a8..a65e260 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -2164,7 +2164,7 @@ extern "C" {
GEOSCoordSeq_setOrdinate_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs,
unsigned int idx, unsigned int dim, double val)
- return execute(extHandle, 1, [&]() {
+ return execute(extHandle, 0, [&]() {
cs->setOrdinate(idx, dim, val);
return 1;
diff --git a/include/geos/geom/FixedSizeCoordinateSequence.h b/include/geos/geom/FixedSizeCoordinateSequence.h
index 20e661d..0d5f228 100644
--- a/include/geos/geom/FixedSizeCoordinateSequence.h
+++ b/include/geos/geom/FixedSizeCoordinateSequence.h
@@ -74,7 +74,7 @@ namespace geom {
break;
default: {
std::stringstream ss;
- ss << "Unknown ordinate index " << index;
+ ss << "Unknown ordinate index " << ordinateIndex;
throw geos::util::IllegalArgumentException(ss.str());
break;
diff --git a/src/geom/CoordinateArraySequence.cpp b/src/geom/CoordinateArraySequence.cpp
index f7015e2..22a5fe1 100644
--- a/src/geom/CoordinateArraySequence.cpp
+++ b/src/geom/CoordinateArraySequence.cpp
@@ -228,7 +228,7 @@ CoordinateArraySequence::setOrdinate(size_t index, size_t ordinateIndex,
break;
default: {
throw util::IllegalArgumentException(ss.str());
break;
diff --git a/tests/unit/capi/GEOSCoordSeqTest.cpp b/tests/unit/capi/GEOSCoordSeqTest.cpp
index 05a59f1..b7da46c 100644
--- a/tests/unit/capi/GEOSCoordSeqTest.cpp
+++ b/tests/unit/capi/GEOSCoordSeqTest.cpp
@@ -151,9 +151,9 @@ void object::test<3>
double z = 12;
// X, Y, Z
- GEOSCoordSeq_setOrdinate(cs_, 0, 0, x);
- GEOSCoordSeq_setOrdinate(cs_, 0, 1, y);
- GEOSCoordSeq_setOrdinate(cs_, 0, 2, z);
+ ensure(0 != GEOSCoordSeq_setOrdinate(cs_, 0, 0, x));
+ ensure(0 != GEOSCoordSeq_setOrdinate(cs_, 0, 1, y));
+ ensure(0 != GEOSCoordSeq_setOrdinate(cs_, 0, 2, z));
double xcheck, ycheck, zcheck;
ensure(0 != GEOSCoordSeq_getOrdinate(cs_, 0, 1, &ycheck));
@@ -163,6 +163,9 @@ void object::test<3>
ensure_equals(xcheck, x);
ensure_equals(ycheck, y);
ensure_equals(zcheck, z);
+ // correct error on wrong ordinate index
+ ensure(0 == GEOSCoordSeq_setOrdinate(cs_, 0, 3, z));
// Test swapped setX calls (see bug #133, fixed)
Summary of changes:
capi/geos_ts_c.cpp | 2 +-
include/geos/geom/FixedSizeCoordinateSequence.h | 2 +-
src/geom/CoordinateArraySequence.cpp | 2 +-
tests/unit/capi/GEOSCoordSeqTest.cpp | 9 +++--
tests/unit/capi/GEOSSTRtreeTest.cpp | 49 ++++++++++++++++++++++++-
5 files changed, 57 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
