[geos-commits] [SCM] GEOS branch master updated. 4b518f34d55756b4404ae9bcd0840ee80db17eef
git at osgeo.org
git at osgeo.org
Sat Nov 28 12:58:59 PST 2020
the project "GEOS".
via 4b518f34d55756b4404ae9bcd0840ee80db17eef (commit)
via ce650cf01a73b08f34662fa2db8667d014584a34 (commit)
from 3e3bf5074031cf86a10a017bddfdf693389a322f (commit)
revisions in full, below.
commit 4b518f34d55756b4404ae9bcd0840ee80db17eef
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Sat Nov 28 12:58:55 2020 -0800
Add another test like the Python tests currently failing
diff --git a/tests/unit/capi/GEOSSTRtreeTest.cpp b/tests/unit/capi/GEOSSTRtreeTest.cpp
index 5d6c2a4..f88807f 100644
--- a/tests/unit/capi/GEOSSTRtreeTest.cpp
+++ b/tests/unit/capi/GEOSSTRtreeTest.cpp
@@ -297,6 +297,42 @@ void object::test<8>
+// querying tree with box
+template<>
+template<>
+void object::test<9>
+ GEOSSTRtree* tree = GEOSSTRtree_create(10);
+ GEOSGeometry* g = GEOSGeomFromWKT("POINT (2 3)");
+ int payload = 876;
+ GEOSSTRtree_insert(tree, g, &payload);
+ GEOSGeometry* q = GEOSGeomFromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))");
+ typedef std::vector<int*> IList;
+ IList items;
+ ensure_equals(items.size(), 0);
+ GEOSSTRtree_query(
+ tree,
+ q,
+ [](void* item, void* userdata) {
+ IList* items = (IList*)userdata;
+ items->push_back((int*)item);
+ &items);
+ ensure_equals(items.size(), 1);
+ ensure_equals(*(items[0]), payload);
+ GEOSGeom_destroy(q);
+ GEOSGeom_destroy(g);
+ GEOSSTRtree_destroy(tree);
// >>> import pygeos
// >>> pygeos.geos_version
// (3, 9, 0)
commit ce650cf01a73b08f34662fa2db8667d014584a34
Date: Sat Nov 28 12:58:38 2020 -0800
Rename parameter variable shadowing member var
diff --git a/src/index/strtree/SimpleSTRnode.cpp b/src/index/strtree/SimpleSTRnode.cpp
index ee66664..36299f7 100644
--- a/src/index/strtree/SimpleSTRnode.cpp
+++ b/src/index/strtree/SimpleSTRnode.cpp
@@ -74,10 +74,10 @@ SimpleSTRnode::getNumLeafNodes() const
bool
-SimpleSTRnode::removeItem(void *item)
+SimpleSTRnode::removeItem(void *itemToRemove)
for (auto it = childNodes.begin(); it != childNodes.end(); ++it) {
- if ((*it)->getItem() == item) {
+ if ((*it)->getItem() == itemToRemove) {
childNodes.erase(it);
return true;
Summary of changes:
src/index/strtree/SimpleSTRnode.cpp | 4 ++--
tests/unit/capi/GEOSSTRtreeTest.cpp | 36 ++++++++++++++++++++++++++++++++++++
2 files changed, 38 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
