[geos-commits] [SCM] GEOS branch master updated. 23f7bbd3dd3558b17432402429f1cfb8ec0b7bf1
git at osgeo.org
git at osgeo.org
Fri Oct 2 06:46:44 PDT 2020
the project "GEOS".
via 23f7bbd3dd3558b17432402429f1cfb8ec0b7bf1 (commit)
via 3fb13aa761df6898fc992318d031537b137a5451 (commit)
via 5b5763569f3e3f77f097ad2a40a2a610ea389bd3 (commit)
from e1982464794e489eccd5732d23ad19da6f054a6c (commit)
revisions in full, below.
commit 23f7bbd3dd3558b17432402429f1cfb8ec0b7bf1
Author: Even Rouault <even.rouault at spatialys.com>
Date: Fri Oct 2 10:52:54 2020 +0200
HotPixel.cpp: fix -Wreorder warning
diff --git a/src/noding/snapround/HotPixel.cpp b/src/noding/snapround/HotPixel.cpp
index bddafcd..0ba6d34 100644
--- a/src/noding/snapround/HotPixel.cpp
+++ b/src/noding/snapround/HotPixel.cpp
@@ -41,8 +41,8 @@ namespace snapround { // geos.noding.snapround
HotPixel::HotPixel(const Coordinate& newPt, double newScaleFactor)
: originalPt(newPt)
- , hpIsNode(false)
, scaleFactor(newScaleFactor)
+ , hpIsNode(false)
, hpx(newPt.x)
, hpy(newPt.y)
commit 3fb13aa761df6898fc992318d031537b137a5451
Date: Fri Oct 2 10:52:34 2020 +0200
KdTree.cpp: remove useless duplicated condition
diff --git a/src/index/kdtree/KdTree.cpp b/src/index/kdtree/KdTree.cpp
index f2891fb..c36fbce 100644
--- a/src/index/kdtree/KdTree.cpp
+++ b/src/index/kdtree/KdTree.cpp
@@ -112,15 +112,13 @@ KdTree::insertExact(const geom::Coordinate& p, void* data)
while (currentNode != nullptr) {
// test if point is already a node (not strictly necessary)
- if (currentNode != nullptr) {
- bool isInTolerance = p.distance(currentNode->getCoordinate()) <= tolerance;
- // check if point is already in tree (up to tolerance) and if so simply
- // return existing node
- if (isInTolerance) {
- currentNode->increment();
- return currentNode;
+ bool isInTolerance = p.distance(currentNode->getCoordinate()) <= tolerance;
+ // check if point is already in tree (up to tolerance) and if so simply
+ // return existing node
+ if (isInTolerance) {
+ currentNode->increment();
+ return currentNode;
if (isOddLevel) {
commit 5b5763569f3e3f77f097ad2a40a2a610ea389bd3
Date: Fri Oct 2 10:52:16 2020 +0200
EdgeList.cpp: *(&foo)) is equivalent to foo
diff --git a/src/geomgraph/EdgeList.cpp b/src/geomgraph/EdgeList.cpp
index f865a86..534342a 100644
--- a/src/geomgraph/EdgeList.cpp
+++ b/src/geomgraph/EdgeList.cpp
@@ -129,7 +129,7 @@ void
EdgeList::clearList()
for(unsigned int pos = 0; pos < edges.size(); pos++) {
- delete *(&edges[pos]);
+ delete edges[pos];
edges.clear();
Summary of changes:
src/geomgraph/EdgeList.cpp | 2 +-
src/index/kdtree/KdTree.cpp | 16 +++++++---------
src/noding/snapround/HotPixel.cpp | 2 +-
3 files changed, 9 insertions(+), 11 deletions(-)
hooks/post-receive
More information about the geos-commits
