[geos-commits] [SCM] GEOS branch master updated.	e2157728ed6c5a41155b8f9d69d79ab758d63ed4
    git at osgeo.org
    git at osgeo.org
    Wed Oct  7 13:06:39 PDT 2020
the project "GEOS".
       via  e2157728ed6c5a41155b8f9d69d79ab758d63ed4 (commit)
      from  23f7bbd3dd3558b17432402429f1cfb8ec0b7bf1 (commit)
revisions in full, below.
commit e2157728ed6c5a41155b8f9d69d79ab758d63ed4
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Oct 7 22:03:49 2020 +0200
    Port JTS fix for very close nodes on same segment.
    References #1051 fixing its root cause.
    This commit partially reverts abb96620c275 to avoid hiding
    eventual other missing ports from JTS.
diff --git a/include/geos/noding/SegmentNode.h b/include/geos/noding/SegmentNode.h
index bf85019..204bcc8 100644
--- a/include/geos/noding/SegmentNode.h
+++ b/include/geos/noding/SegmentNode.h
@@ -12,7 +12,7 @@
- *  Last port: noding/SegmentNode.java rev. 1.6 (JTS-1.9)
+ * Last port: noding/SegmentNode.java 4667170ea (JTS-1.17)
diff --git a/src/noding/SegmentNode.cpp b/src/noding/SegmentNode.cpp
index b7913cb..840d518 100644
--- a/src/noding/SegmentNode.cpp
+++ b/src/noding/SegmentNode.cpp
@@ -13,7 +13,7 @@
@@ -99,6 +99,13 @@ SegmentNode::compareTo(const SegmentNode& other)
     cerr << " Coordinates do not equal!" << endl;
 #endif
+    // an exterior node is the segment start point,
+    // so always sorts first
+    // this guards against a robustness problem
+    // where the octants are not reliable
+    if (! isInteriorVar) return -1;
+    if (! other.isInteriorVar) return 1;
     return SegmentPointComparator::compare(segmentOctant, coord,
                                            other.coord);
diff --git a/src/operation/overlayng/EdgeMerger.cpp b/src/operation/overlayng/EdgeMerger.cpp
index 48c1a35..605180c 100644
--- a/src/operation/overlayng/EdgeMerger.cpp
+++ b/src/operation/overlayng/EdgeMerger.cpp
@@ -16,7 +16,7 @@
 #include <geos/geom/Dimension.h>
 #include <geos/geom/Coordinate.h>
 #include <geos/geom/CoordinateSequence.h>
-#include <geos/util/TopologyException.h>
+#include <geos/util/Assert.h>
 namespace geos {      // geos
@@ -52,15 +52,17 @@ EdgeMerger::merge()
         else {
             // found an existing edge
+            Edge *baseEdge = it->second;
             // Assert: edges are identical (up to direction)
             // this is a fast (but incomplete) sanity check
-            Edge *baseEdge = it->second;
-            /* NOTE: we throw a TopologyException here as per
-             * https://trac.osgeo.org/geos/ticket/1051#comment:7
-            if ( baseEdge->size() != edge->size() ) {
-                throw geos::util::TopologyException("Merge of edges of different sizes - probable noding error.");
+            // NOTE: we throw an exception to avoid crashing processes
+            // See https://trac.osgeo.org/geos/ticket/1051#comment:29
+            util::Assert::isTrue(
+                baseEdge->size() == edge->size(),
+                "Merge of edges of different sizes - probable noding error."
             baseEdge->merge(edge);
             //Debug.println("edge merged: " + existing);
Summary of changes:
 include/geos/noding/SegmentNode.h      |  2 +-
 src/noding/SegmentNode.cpp             |  9 ++++++++-
 src/operation/overlayng/EdgeMerger.cpp | 18 ++++++++++--------
 3 files changed, 19 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits
