[geos-commits] [SCM] GEOS branch master updated. 8d203e348716efed8da34c18b40309259a90024e
git at osgeo.org
git at osgeo.org
Mon Oct 12 07:18:44 PDT 2020
the project "GEOS".
via 8d203e348716efed8da34c18b40309259a90024e (commit)
from e2157728ed6c5a41155b8f9d69d79ab758d63ed4 (commit)
revisions in full, below.
commit 8d203e348716efed8da34c18b40309259a90024e
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Oct 12 16:14:21 2020 +0200
Add test for https://trac.osgeo.org/geos/ticket/1051
References #1051
diff --git a/tests/unit/noding/NodedSegmentStringTest.cpp b/tests/unit/noding/NodedSegmentStringTest.cpp
index 21b3af2..a86923b 100644
--- a/tests/unit/noding/NodedSegmentStringTest.cpp
+++ b/tests/unit/noding/NodedSegmentStringTest.cpp
@@ -2,16 +2,28 @@
// Test Suite for geos::noding::NodedSegmentString class.
#include <tut/tut.hpp>
+#include <utility.h>
// geos
+#include <geos/io/WKTReader.h>
#include <geos/noding/NodedSegmentString.h>
+#include <geos/noding/SegmentString.h>
#include <geos/noding/Octant.h>
#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/CoordinateArraySequence.h>
#include <geos/geom/CoordinateArraySequenceFactory.h>
+#include <geos/geom/GeometryFactory.h>
#include <geos/util.h>
// std
#include <memory>
+using geos::io::WKTReader;
+using geos::geom::CoordinateSequence;
+using geos::geom::Geometry;
+//using geos::geom::LineString;
+using geos::geom::GeometryFactory;
+using geos::noding::SegmentString;
namespace tut {
// Test Group
@@ -28,6 +40,8 @@ struct test_nodedsegmentstring_data {
const geos::geom::CoordinateSequenceFactory* csFactory;
+ WKTReader r;
SegmentStringAutoPtr
makeSegmentString(geos::geom::CoordinateSequence* cs, void* d = nullptr)
@@ -36,6 +50,44 @@ struct test_nodedsegmentstring_data {
+ std::unique_ptr<Geometry>
+ toLines(SegmentString::NonConstVect& ss, const GeometryFactory* gf)
+ std::vector<Geometry *> *lines = new std::vector<Geometry *>();
+ for (auto s: ss)
+ std::unique_ptr<CoordinateSequence> cs = s->getCoordinates()->clone();
+ lines->push_back(gf->createLineString(*cs));
+ return std::unique_ptr<Geometry>(gf->createMultiLineString(lines));
+ void
+ checkNoding(const std::string& wktLine, const std::string& wktNodes, std::vector<int> segmentIndex, const std::string& wktExpected)
+ using geos::noding::NodedSegmentString;
+ std::unique_ptr<Geometry> line = r.read(wktLine);
+ std::unique_ptr<Geometry> pts = r.read(wktNodes);
+ NodedSegmentString nss(line->getCoordinates().release(), 0);
+ std::unique_ptr<CoordinateSequence> node = pts->getCoordinates();
+ for (size_t i = 0, n=node->size(); i < n; ++i) {
+ nss.addIntersection(node->getAt(i), segmentIndex.at(i));
+ SegmentString::NonConstVect nodedSS;
+ nss.getNodeList().addSplitEdges(nodedSS);
+ std::unique_ptr<Geometry> result = toLines(nodedSS, line->getFactory());
+ //System.out.println(result);
+ for (auto ss: nodedSS) {
+ delete ss;
+ std::unique_ptr<Geometry> expected = r.read(wktExpected);
+ ensure_equals_geometry(expected.get(), result.get());
test_nodedsegmentstring_data()
csFactory(geos::geom::CoordinateArraySequenceFactory::instance())
@@ -236,6 +288,33 @@ void object::test<5>
+ * Tests a case which involves nodes added when using the SnappingNoder.
+ * In this case one of the added nodes is relatively "far" from its segment,
+ * and "near" the start vertex of the segment.
+ * Computing the noding correctly requires the fix to {@link SegmentNode#compareTo(Object)}
+ * added in https://github.com/locationtech/jts/pull/399
+ * See https://trac.osgeo.org/geos/ticket/1051
+template<>
+template<>
+void object::test<6>
+ std::vector<int> segmentIndex;
+ segmentIndex.push_back(0);
+ segmentIndex.push_back(1);
+ checkNoding("LINESTRING(655103.6628454948 1794805.456674405, 655016.20226 1794940.10998, 655014.8317182435 1794941.5196832407)",
+ "MULTIPOINT((655016.29615051334 1794939.965427252),(655016.20226531825 1794940.1099718122), (655016.20226 1794940.10998),(655016.20225819293 1794940.1099794197))",
+ segmentIndex,
+ "MULTILINESTRING ((655014.8317182435 1794941.5196832407,655016.2022581929 1794940.1099794197), (655016.2022581929 1794940.1099794197, 655016.20226 1794940.10998), (655016.20226 1794940.10998, 655016.2022653183 1794940.1099718122), (655016.2022653183 1794940.1099718122, 655016.2961505133 1794939.965427252), (655016.2961505133 1794939.965427252, 655103.6628454948 1794805.456674405))");
// TODO: test getting noded substrings
// template<>
// template<>
Summary of changes:
tests/unit/noding/NodedSegmentStringTest.cpp | 79 ++++++++++++++++++++++++++++
1 file changed, 79 insertions(+)
hooks/post-receive
More information about the geos-commits
