[geos-commits] [SCM] GEOS branch master updated. c06450ef893f63319c360568b18726475b1e39c7
git at osgeo.org
git at osgeo.org
Mon Oct 19 03:20:19 PDT 2020
the project "GEOS".
via c06450ef893f63319c360568b18726475b1e39c7 (commit)
from 4f099194d449b987cf9349f65731fce89891152f (commit)
revisions in full, below.
commit c06450ef893f63319c360568b18726475b1e39c7
Author: Joris Van den Bossche <jorisvandenbossche at gmail.com>
Date: Fri Oct 16 15:55:41 2020 +0200
BUG: Fix GEOSProjectNormalized return -1 on exception
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 39f3dfc..c8abec2 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -3098,10 +3098,16 @@ extern "C" {
double length;
+ double distance;
if(GEOSLength_r(extHandle, g, &length) != 1) {
return -1.0;
- return GEOSProject_r(extHandle, g, p) / length;
+ distance = GEOSProject_r(extHandle, g, p);
+ if (distance == -1.0) {
+ return -1.0;
+ } else {
+ return distance / length;
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index f8d4c8c..87a56b2 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -106,6 +106,7 @@ geos_unit_SOURCES = \
capi/GEOSPointOnSurfaceTest.cpp \
capi/GEOSPolygonizeTest.cpp \
capi/GEOSPreparedGeometryTest.cpp \
+ capi/GEOSProjectTest.cpp \
capi/GEOSRelateBoundaryNodeRuleTest.cpp \
capi/GEOSRelatePatternMatchTest.cpp \
capi/GEOSReverseTest.cpp \
diff --git a/tests/unit/capi/GEOSProjectTest.cpp b/tests/unit/capi/GEOSProjectTest.cpp
new file mode 100644
index 0000000..8a71566
--- /dev/null
+++ b/tests/unit/capi/GEOSProjectTest.cpp
@@ -0,0 +1,111 @@
+// Test Suite for C-API LineString project functions
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cmath>
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capiproject_data {
+ GEOSGeometry* geom1_;
+ GEOSGeometry* geom2_;
+ static void
+ notice(const char* fmt, ...)
+ std::fprintf(stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capiproject_data()
+ : geom1_(nullptr), geom2_(nullptr)
+ initGEOS(notice, notice);
+ ~test_capiproject_data()
+ GEOSGeom_destroy(geom1_);
+ GEOSGeom_destroy(geom2_);
+ geom1_ = nullptr;
+ geom2_ = nullptr;
+ finishGEOS();
+typedef test_group<test_capiproject_data> group;
+typedef group::object object;
+group test_capiproject_group("capi::GEOSProject");
+// Test Cases
+// Test basic usage
+template<>
+template<>
+void object::test<1>
+ geom1_ = GEOSGeomFromWKT("LINESTRING (0 0, 0 2)");
+ geom2_ = GEOSGeomFromWKT("POINT (1 1)");
+ double dist = GEOSProject(geom1_, geom2_);
+ ensure_equals(dist, 1.0);
+ double dist_norm = GEOSProjectNormalized(geom1_, geom2_);
+ ensure_equals(dist_norm, 0.5);
+// Test non-linestring geometry (first argument) correctly returns -1.0
+template<>
+template<>
+void object::test<2>
+ geom1_ = GEOSGeomFromWKT("POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0))");
+ ensure_equals(dist, -1.0);
+ ensure_equals(dist_norm, -1.0);
+// Test non-point geometry (second argument) correctly returns -1.0
+// https://trac.osgeo.org/geos/ticket/1058
+template<>
+template<>
+void object::test<3>
+ geom2_ = GEOSGeomFromWKT("LINESTRING (0 0, 0 2)");
+} // namespace tut
Summary of changes:
capi/geos_ts_c.cpp | 8 ++-
tests/unit/Makefile.am | 1 +
tests/unit/capi/GEOSProjectTest.cpp | 111 ++++++++++++++++++++++++++++++++++++
3 files changed, 119 insertions(+), 1 deletion(-)
create mode 100644 tests/unit/capi/GEOSProjectTest.cpp
hooks/post-receive
More information about the geos-commits
