[geos-commits] [SCM] GEOS branch 3.8 updated. dca69c5135f5b1876cd6e2acafa4bac3b0a593ae
git at osgeo.org
git at osgeo.org
Mon Oct 19 03:31:28 PDT 2020
the project "GEOS".
The branch, 3.8 has been updated
via dca69c5135f5b1876cd6e2acafa4bac3b0a593ae (commit)
via 07611d4ac8cdba9ad662263bc62f34df4ef82a5b (commit)
via f60cd0c1c623012feca00ee8b287dd66d45dd2d6 (commit)
from bc5429f45fc16a6c39dba2d4b9bcb841d70d01ee (commit)
revisions in full, below.
commit dca69c5135f5b1876cd6e2acafa4bac3b0a593ae
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Oct 19 12:31:20 2020 +0200
Fix catch-by-value
diff --git a/tests/unit/operation/geounion/CoverageUnionTest.cpp b/tests/unit/operation/geounion/CoverageUnionTest.cpp
index 2fed702..fefe1e3 100644
--- a/tests/unit/operation/geounion/CoverageUnionTest.cpp
+++ b/tests/unit/operation/geounion/CoverageUnionTest.cpp
@@ -78,7 +78,7 @@ namespace tut {
try {
auto u1 = CoverageUnion::Union(coll.get());
fail();
- } catch(const geos::util::TopologyException e) {}
+ } catch(const geos::util::TopologyException&) {}
template<>
commit 07611d4ac8cdba9ad662263bc62f34df4ef82a5b
Author: Joris Van den Bossche <jorisvandenbossche at gmail.com>
Date: Fri Oct 16 15:55:41 2020 +0200
Fix GEOSProjectNormalized return -1 on exception
Includes testcase and NEWS entry
diff --git a/NEWS b/NEWS
index f74067b..b029530 100644
--- a/NEWS
+++ b/NEWS
@@ -9,6 +9,7 @@ Changes in 3.8.2
- Fix buffering problem (#1022, JTS-525, Paul Ramsey)
- Fix segfault in GEOSInterpolate against empty eollections (#1055,
Sandro Santilli)
+ - Fix GEOSProjectNormalized return -1 on exception (Joris Van den Bossche)
Changes in 3.8.1
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 31f2f1e..763be98 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -6265,10 +6265,17 @@ extern "C" {
GEOSProjectNormalized_r(GEOSContextHandle_t extHandle, const Geometry* g,
const Geometry* p)
double length;
- GEOSLength_r(extHandle, g, &length);
- return GEOSProject_r(extHandle, g, p) / length;
+ double distance;
+ if(GEOSLength_r(extHandle, g, &length) != 1) {
+ return -1.0;
+ distance = GEOSProject_r(extHandle, g, p);
+ if (distance == -1.0) {
+ return -1.0;
+ } else {
+ return distance / length;
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 88c4816..45293f3 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -98,6 +98,7 @@ geos_unit_SOURCES = \
capi/GEOSPointOnSurfaceTest.cpp \
capi/GEOSPolygonizeTest.cpp \
capi/GEOSPreparedGeometryTest.cpp \
+ capi/GEOSProjectTest.cpp \
capi/GEOSRelateBoundaryNodeRuleTest.cpp \
capi/GEOSRelatePatternMatchTest.cpp \
capi/GEOSReverseTest.cpp \
diff --git a/tests/unit/capi/GEOSProjectTest.cpp b/tests/unit/capi/GEOSProjectTest.cpp
new file mode 100644
index 0000000..8a71566
--- /dev/null
+++ b/tests/unit/capi/GEOSProjectTest.cpp
@@ -0,0 +1,111 @@
+// Test Suite for C-API LineString project functions
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cmath>
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capiproject_data {
+ GEOSGeometry* geom1_;
+ GEOSGeometry* geom2_;
+ static void
+ notice(const char* fmt, ...)
+ std::fprintf(stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capiproject_data()
+ : geom1_(nullptr), geom2_(nullptr)
+ initGEOS(notice, notice);
+ ~test_capiproject_data()
+ GEOSGeom_destroy(geom1_);
+ GEOSGeom_destroy(geom2_);
+ geom1_ = nullptr;
+ geom2_ = nullptr;
+ finishGEOS();
+typedef test_group<test_capiproject_data> group;
+typedef group::object object;
+group test_capiproject_group("capi::GEOSProject");
+// Test Cases
+// Test basic usage
+template<>
+template<>
+void object::test<1>
+ geom1_ = GEOSGeomFromWKT("LINESTRING (0 0, 0 2)");
+ geom2_ = GEOSGeomFromWKT("POINT (1 1)");
+ double dist = GEOSProject(geom1_, geom2_);
+ ensure_equals(dist, 1.0);
+ double dist_norm = GEOSProjectNormalized(geom1_, geom2_);
+ ensure_equals(dist_norm, 0.5);
+// Test non-linestring geometry (first argument) correctly returns -1.0
+template<>
+template<>
+void object::test<2>
+ geom1_ = GEOSGeomFromWKT("POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0))");
+ ensure_equals(dist, -1.0);
+ ensure_equals(dist_norm, -1.0);
+// Test non-point geometry (second argument) correctly returns -1.0
+// https://trac.osgeo.org/geos/ticket/1058
+template<>
+template<>
+void object::test<3>
+ geom2_ = GEOSGeomFromWKT("LINESTRING (0 0, 0 2)");
+} // namespace tut
commit f60cd0c1c623012feca00ee8b287dd66d45dd2d6
Date: Thu Oct 15 11:15:57 2020 +0200
DOC: clarify that GEOSProject returns -1 on exception (C API)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 31da35e..cf66d6f 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -369,7 +369,8 @@ extern int GEOS_DLL GEOSCoordSeq_isCCW_r(GEOSContextHandle_t handle,
/* Return distance of point 'p' projected on 'g' from origin
- * of 'g'. Geometry 'g' must be a lineal geometry */
+ * of 'g'. Geometry 'g' must be a lineal geometry.
+ * Return -1 on exception*/
extern double GEOS_DLL GEOSProject_r(GEOSContextHandle_t handle,
const GEOSGeometry *g,
const GEOSGeometry *p);
@@ -1461,7 +1462,8 @@ extern int GEOS_DLL GEOSCoordSeq_isCCW(const GEOSCoordSequence* s, char* is_ccw)
+ * Return -1 on exception */
extern double GEOS_DLL GEOSProject(const GEOSGeometry *g,
const GEOSGeometry* p);
Summary of changes:
NEWS | 1 +
capi/geos_c.h.in | 6 +-
capi/geos_ts_c.cpp | 13 ++-
tests/unit/Makefile.am | 1 +
tests/unit/capi/GEOSProjectTest.cpp | 111 +++++++++++++++++++++
.../unit/operation/geounion/CoverageUnionTest.cpp | 2 +-
6 files changed, 128 insertions(+), 6 deletions(-)
create mode 100644 tests/unit/capi/GEOSProjectTest.cpp
hooks/post-receive
More information about the geos-commits
