[geos-commits] [SCM] GEOS branch 3.9 updated. e98528f9e8d09df1e3223dc37ac283c2f79c05df
git at osgeo.org
git at osgeo.org
Mon Apr 26 10:49:10 PDT 2021
the project "GEOS".
The branch, 3.9 has been updated
via e98528f9e8d09df1e3223dc37ac283c2f79c05df (commit)
from 5c31f0f130c8bedd729fe7785c2be24854d2adfb (commit)
revisions in full, below.
commit e98528f9e8d09df1e3223dc37ac283c2f79c05df
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Apr 26 10:49:04 2021 -0700
Add void to no-argument prototypes. References https://github.com/libgeos/geos/issues/437
diff --git a/NEWS b/NEWS
index 7a90f89..2fafc2c 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ Changes in 3.9.2
POINT EMPTY input (Even Rouault)
- Fix IsValidOp to correctly report invalid nested MultiPolygons (#1112, Martin Davis)
- Fix BufferOp to avoid artifacts in certain polygon buffers (#1101, Martin Davis)
+ - Declare parameterless functions in geos_c.h as func(void) (Paul Ramsey)
Changes in 3.9.1
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 7cb3d57..6da0fd9 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -157,12 +157,12 @@ typedef int (*GEOSDistanceCallback)(const void *item1, const void* item2, double
* The callback will be invoked _before_ checking for
* interruption, so can be used to request it.
-typedef void (GEOSInterruptCallback)();
+typedef void (GEOSInterruptCallback)(void);
extern GEOSInterruptCallback GEOS_DLL *GEOS_interruptRegisterCallback(GEOSInterruptCallback* cb);
/* Request safe interruption of operations */
-extern void GEOS_DLL GEOS_interruptRequest();
+extern void GEOS_DLL GEOS_interruptRequest(void);
/* Cancel a pending interruption request */
-extern void GEOS_DLL GEOS_interruptCancel();
+extern void GEOS_DLL GEOS_interruptCancel(void);
* @deprecated in 3.5.0
@@ -177,7 +177,7 @@ extern GEOSContextHandle_t GEOS_DLL initGEOS_r(
extern void GEOS_DLL finishGEOS_r(GEOSContextHandle_t handle);
-extern GEOSContextHandle_t GEOS_DLL GEOS_init_r();
+extern GEOSContextHandle_t GEOS_DLL GEOS_init_r(void);
extern void GEOS_DLL GEOS_finish_r(GEOSContextHandle_t handle);
@@ -212,7 +212,7 @@ extern GEOSMessageHandler_r GEOS_DLL GEOSContext_setErrorMessageHandler_r(GEOSCo
GEOSMessageHandler_r ef,
void *userData);
-extern const char GEOS_DLL *GEOSversion();
+extern const char GEOS_DLL *GEOSversion(void);
@@ -1396,14 +1396,14 @@ extern char GEOS_DLL *GEOSGeomToWKT(const GEOSGeometry* g);
* Specify whether output WKB should be 2d or 3d.
* Return previously set number of dimensions.
-extern int GEOS_DLL GEOS_getWKBOutputDims();
+extern int GEOS_DLL GEOS_getWKBOutputDims(void);
extern int GEOS_DLL GEOS_setWKBOutputDims(int newDims);
* Specify whether the WKB byte order is big or little endian.
* The return value is the previous byte order.
-extern int GEOS_DLL GEOS_getWKBByteOrder();
+extern int GEOS_DLL GEOS_getWKBByteOrder(void);
extern int GEOS_DLL GEOS_setWKBByteOrder(int byteOrder);
extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKB_buf(const unsigned char *wkb, size_t size);
@@ -1526,7 +1526,7 @@ extern GEOSGeometry GEOS_DLL *GEOSBuffer(const GEOSGeometry* g,
double width, int quadsegs);
/* @return 0 on exception */
-extern GEOSBufferParams GEOS_DLL *GEOSBufferParams_create();
+extern GEOSBufferParams GEOS_DLL *GEOSBufferParams_create(void);
extern void GEOS_DLL GEOSBufferParams_destroy(GEOSBufferParams* parms);
@@ -1592,17 +1592,17 @@ extern GEOSGeometry GEOS_DLL *GEOSOffsetCurve(const GEOSGeometry* g,
extern GEOSGeometry GEOS_DLL *GEOSGeom_createPoint(GEOSCoordSequence* s);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createPointFromXY(double x, double y);
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPoint();
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPoint(void);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createLinearRing(GEOSCoordSequence* s);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createLineString(GEOSCoordSequence* s);
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyLineString();
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyLineString(void);
* Second argument is an array of GEOSGeometry* objects.
* The caller remains owner of the array, but pointed-to
* objects become ownership of the returned GEOSGeometry.
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPolygon();
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPolygon(void);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createPolygon(GEOSGeometry* shell,
GEOSGeometry** holes, unsigned int nholes);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createCollection(int type,
@@ -2207,12 +2207,12 @@ extern int GEOS_DLL GEOSOrientationIndex(double Ax, double Ay, double Bx, double
/* WKT Reader */
-extern GEOSWKTReader GEOS_DLL *GEOSWKTReader_create();
+extern GEOSWKTReader GEOS_DLL *GEOSWKTReader_create(void);
extern void GEOS_DLL GEOSWKTReader_destroy(GEOSWKTReader* reader);
extern GEOSGeometry GEOS_DLL *GEOSWKTReader_read(GEOSWKTReader* reader, const char *wkt);
/* WKT Writer */
-extern GEOSWKTWriter GEOS_DLL *GEOSWKTWriter_create();
+extern GEOSWKTWriter GEOS_DLL *GEOSWKTWriter_create(void);
extern void GEOS_DLL GEOSWKTWriter_destroy(GEOSWKTWriter* writer);
extern char GEOS_DLL *GEOSWKTWriter_write(GEOSWKTWriter* writer, const GEOSGeometry* g);
extern void GEOS_DLL GEOSWKTWriter_setTrim(GEOSWKTWriter *writer, char trim);
@@ -2222,13 +2222,13 @@ extern int GEOS_DLL GEOSWKTWriter_getOutputDimension(GEOSWKTWriter *writer);
extern void GEOS_DLL GEOSWKTWriter_setOld3D(GEOSWKTWriter *writer, int useOld3D);
/* WKB Reader */
-extern GEOSWKBReader GEOS_DLL *GEOSWKBReader_create();
+extern GEOSWKBReader GEOS_DLL *GEOSWKBReader_create(void);
extern void GEOS_DLL GEOSWKBReader_destroy(GEOSWKBReader* reader);
extern GEOSGeometry GEOS_DLL *GEOSWKBReader_read(GEOSWKBReader* reader, const unsigned char *wkb, size_t size);
extern GEOSGeometry GEOS_DLL *GEOSWKBReader_readHEX(GEOSWKBReader* reader, const unsigned char *hex, size_t size);
/* WKB Writer */
-extern GEOSWKBWriter GEOS_DLL *GEOSWKBWriter_create();
+extern GEOSWKBWriter GEOS_DLL *GEOSWKBWriter_create(void);
extern void GEOS_DLL GEOSWKBWriter_destroy(GEOSWKBWriter* writer);
/* The caller owns the results for these two methods! */
Summary of changes:
NEWS | 1 +
capi/geos_c.h.in | 30 +++++++++++++++---------------
2 files changed, 16 insertions(+), 15 deletions(-)
hooks/post-receive
More information about the geos-commits
