[geos-commits] [SCM] GEOS branch 3.8 updated. 81329ab2c8da8b5b980b4a947ff102b660b29f0f
git at osgeo.org
git at osgeo.org
Mon Apr 26 10:51:36 PDT 2021
the project "GEOS".
The branch, 3.8 has been updated
via 81329ab2c8da8b5b980b4a947ff102b660b29f0f (commit)
via 0bc3b6c96a8fa9b88d1aef2a5818233756f2711a (commit)
via 4e4701edf4ffbe3fb44031e50ee74f154925cefe (commit)
from 8721ea66b23427c1eee2ee49318690a63684fe51 (commit)
revisions in full, below.
commit 81329ab2c8da8b5b980b4a947ff102b660b29f0f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Apr 26 10:51:30 2021 -0700
Update NEWS
diff --git a/NEWS b/NEWS
index e41356f..46038f4 100644
--- a/NEWS
+++ b/NEWS
@@ -3,12 +3,10 @@ Changes in 3.8.3
2021-xx-xx
- Bug fixes / improvements
- - Add void to no-argument prototypes. References libgeos#437 (Paul Ramsey)
+ - Add void to no-argument prototypes. References libgeos#437 (Paul Ramsey)
- Fix BufferOp to avoid artifacts in certain polygon buffers (#1101, Martin Davis)
Changes in 3.8.2
2021-04-10
commit 0bc3b6c96a8fa9b88d1aef2a5818233756f2711a
Merge: 4e4701e 8721ea6
Date: Mon Apr 26 10:51:08 2021 -0700
Merge branch '3.8' of https://git.osgeo.org/gitea/geos/geos into 3.8
diff --cc NEWS
index 9b784d9,d877517..e41356f
--- a/NEWS
+++ b/NEWS
@@@ -3,8 -3,10 +3,11 @@@ Changes in 3.8.
2021-xx-xx
+ - Fix BufferOp to avoid artifacts in certain polygon buffers (#1101, Martin Davis)
Changes in 3.8.2
2021-04-10
commit 4e4701edf4ffbe3fb44031e50ee74f154925cefe
Date: Mon Apr 26 10:51:00 2021 -0700
Add void to no-argument prototypes. References https://github.com/libgeos/geos/issues/437
index a4c2d73..9b784d9 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,7 @@ Changes in 3.8.3
2021-xx-xx
Changes in 3.8.2
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index cf66d6f..ef82f69 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -157,12 +157,12 @@ typedef int (*GEOSDistanceCallback)(const void *item1, const void* item2, double
* The callback will be invoked _before_ checking for
* interruption, so can be used to request it.
-typedef void (GEOSInterruptCallback)();
+typedef void (GEOSInterruptCallback)(void);
extern GEOSInterruptCallback GEOS_DLL *GEOS_interruptRegisterCallback(GEOSInterruptCallback* cb);
/* Request safe interruption of operations */
-extern void GEOS_DLL GEOS_interruptRequest();
+extern void GEOS_DLL GEOS_interruptRequest(void);
/* Cancel a pending interruption request */
-extern void GEOS_DLL GEOS_interruptCancel();
+extern void GEOS_DLL GEOS_interruptCancel(void);
* @deprecated in 3.5.0
@@ -177,7 +177,7 @@ extern GEOSContextHandle_t GEOS_DLL initGEOS_r(
extern void GEOS_DLL finishGEOS_r(GEOSContextHandle_t handle);
-extern GEOSContextHandle_t GEOS_DLL GEOS_init_r();
+extern GEOSContextHandle_t GEOS_DLL GEOS_init_r(void);
extern void GEOS_DLL GEOS_finish_r(GEOSContextHandle_t handle);
@@ -212,7 +212,7 @@ extern GEOSMessageHandler_r GEOS_DLL GEOSContext_setErrorMessageHandler_r(GEOSCo
GEOSMessageHandler_r ef,
void *userData);
-extern const char GEOS_DLL *GEOSversion();
+extern const char GEOS_DLL *GEOSversion(void);
@@ -1360,14 +1360,14 @@ extern char GEOS_DLL *GEOSGeomToWKT(const GEOSGeometry* g);
* Specify whether output WKB should be 2d or 3d.
* Return previously set number of dimensions.
-extern int GEOS_DLL GEOS_getWKBOutputDims();
+extern int GEOS_DLL GEOS_getWKBOutputDims(void);
extern int GEOS_DLL GEOS_setWKBOutputDims(int newDims);
* Specify whether the WKB byte order is big or little endian.
* The return value is the previous byte order.
-extern int GEOS_DLL GEOS_getWKBByteOrder();
+extern int GEOS_DLL GEOS_getWKBByteOrder(void);
extern int GEOS_DLL GEOS_setWKBByteOrder(int byteOrder);
extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKB_buf(const unsigned char *wkb, size_t size);
@@ -1490,7 +1490,7 @@ extern GEOSGeometry GEOS_DLL *GEOSBuffer(const GEOSGeometry* g,
double width, int quadsegs);
/* @return 0 on exception */
-extern GEOSBufferParams GEOS_DLL *GEOSBufferParams_create();
+extern GEOSBufferParams GEOS_DLL *GEOSBufferParams_create(void);
extern void GEOS_DLL GEOSBufferParams_destroy(GEOSBufferParams* parms);
@@ -1556,17 +1556,17 @@ extern GEOSGeometry GEOS_DLL *GEOSOffsetCurve(const GEOSGeometry* g,
extern GEOSGeometry GEOS_DLL *GEOSGeom_createPoint(GEOSCoordSequence* s);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createPointFromXY(double x, double y);
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPoint();
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPoint(void);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createLinearRing(GEOSCoordSequence* s);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createLineString(GEOSCoordSequence* s);
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyLineString();
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyLineString(void);
* Second argument is an array of GEOSGeometry* objects.
* The caller remains owner of the array, but pointed-to
* objects become ownership of the returned GEOSGeometry.
-extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPolygon();
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPolygon(void);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createPolygon(GEOSGeometry* shell,
GEOSGeometry** holes, unsigned int nholes);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createCollection(int type,
@@ -2132,12 +2132,12 @@ extern int GEOS_DLL GEOSOrientationIndex(double Ax, double Ay, double Bx, double
/* WKT Reader */
-extern GEOSWKTReader GEOS_DLL *GEOSWKTReader_create();
+extern GEOSWKTReader GEOS_DLL *GEOSWKTReader_create(void);
extern void GEOS_DLL GEOSWKTReader_destroy(GEOSWKTReader* reader);
extern GEOSGeometry GEOS_DLL *GEOSWKTReader_read(GEOSWKTReader* reader, const char *wkt);
/* WKT Writer */
-extern GEOSWKTWriter GEOS_DLL *GEOSWKTWriter_create();
+extern GEOSWKTWriter GEOS_DLL *GEOSWKTWriter_create(void);
extern void GEOS_DLL GEOSWKTWriter_destroy(GEOSWKTWriter* writer);
extern char GEOS_DLL *GEOSWKTWriter_write(GEOSWKTWriter* writer, const GEOSGeometry* g);
extern void GEOS_DLL GEOSWKTWriter_setTrim(GEOSWKTWriter *writer, char trim);
@@ -2147,13 +2147,13 @@ extern int GEOS_DLL GEOSWKTWriter_getOutputDimension(GEOSWKTWriter *writer);
extern void GEOS_DLL GEOSWKTWriter_setOld3D(GEOSWKTWriter *writer, int useOld3D);
/* WKB Reader */
-extern GEOSWKBReader GEOS_DLL *GEOSWKBReader_create();
+extern GEOSWKBReader GEOS_DLL *GEOSWKBReader_create(void);
extern void GEOS_DLL GEOSWKBReader_destroy(GEOSWKBReader* reader);
extern GEOSGeometry GEOS_DLL *GEOSWKBReader_read(GEOSWKBReader* reader, const unsigned char *wkb, size_t size);
extern GEOSGeometry GEOS_DLL *GEOSWKBReader_readHEX(GEOSWKBReader* reader, const unsigned char *hex, size_t size);
/* WKB Writer */
-extern GEOSWKBWriter GEOS_DLL *GEOSWKBWriter_create();
+extern GEOSWKBWriter GEOS_DLL *GEOSWKBWriter_create(void);
extern void GEOS_DLL GEOSWKBWriter_destroy(GEOSWKBWriter* writer);
/* The caller owns the results for these two methods! */
Summary of changes:
NEWS | 3 +--
capi/geos_c.h.in | 30 +++++++++++++++---------------
2 files changed, 16 insertions(+), 17 deletions(-)
hooks/post-receive
More information about the geos-commits
