[geos-commits] [SCM] GEOS branch master updated. e4fd106f4f66167b554389c7b441d9bc5ee89b1b
git at osgeo.org
git at osgeo.org
Fri Feb 19 04:50:33 PST 2021
the project "GEOS".
via e4fd106f4f66167b554389c7b441d9bc5ee89b1b (commit)
via 5e9f7ada73dcbdfd9e9bc1148924ebc4ecd0b087 (commit)
from bab2a01a744b5bb300fa7276012cda29a0570f33 (commit)
revisions in full, below.
commit e4fd106f4f66167b554389c7b441d9bc5ee89b1b
Merge: bab2a01 5e9f7ad
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri Feb 19 07:49:09 2021 -0500
Merge branch 'rm-cascaded-union'
commit 5e9f7ada73dcbdfd9e9bc1148924ebc4ecd0b087
Date: Thu Feb 18 15:02:36 2021 -0500
Remove linear CascadedUnion
This was added as a robustness improvement, but it appears no longer
necessary with the use of OverlayNG. Removing this eliminates a
significant amount of duplicated code.
diff --git a/include/geos/operation/union/CascadedUnion.h b/include/geos/operation/union/CascadedUnion.h
deleted file mode 100644
index 91d3f28..0000000
--- a/include/geos/operation/union/CascadedUnion.h
+++ /dev/null
@@ -1,199 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://trac.osgeo.org/geos
- * Copyright (C) 2011 Sandro Santilli <strk at kbt.io>
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: ORIGINAL WORK, generalization of CascadedPolygonUnion
-#ifndef GEOS_OP_UNION_CASCADEDUNION_H
-#define GEOS_OP_UNION_CASCADEDUNION_H
-#include <geos/export.h>
-#include <vector>
-#include <algorithm>
-#include "GeometryListHolder.h"
-// Forward declarations
-namespace geos {
-namespace geom {
-class GeometryFactory;
-class Geometry;
-class Geometry;
-class Envelope;
-namespace index {
-namespace strtree {
-class ItemsList;
-namespace geos {
-namespace operation { // geos::operation
-namespace geounion { // geos::operation::geounion
- * \brief
- * Provides an efficient method of unioning a collection of Geometries
- * This algorithm is more robust than the simple iterated approach
- * of repeatedly unioning each geometry to a result geometry.
-class GEOS_DLL CascadedUnion {
-private:
- const std::vector<geom::Geometry*>* inputGeoms;
- geom::GeometryFactory const* geomFactory;
- * The effectiveness of the index is somewhat sensitive
- * to the node capacity.
- * Testing indicates that a smaller capacity is better.
- * For an STRtree, 4 is probably a good number (since
- * this produces 2x2 "squares").
- static int const STRTREE_NODE_CAPACITY = 4;
-public:
- CascadedUnion();
- * Computes the union of a collection of {@link geom::Geometry}s.
- * @param geoms a collection of {@link geom::Geometry}s.
- * ownership of elements _and_ vector are left to caller.
- static geom::Geometry* Union(std::vector<geom::Geometry*>* geoms);
- * Computes the union of a set of {@link geom::Geometry}s.
- * @tparam T an iterator yelding something castable to const Geometry *
- * @param start start iterator
- * @param end end iterator
- template <class T>
- Union(T start, T end)
- std::vector<geom::Geometry*> polys;
- for(T i = start; i != end; ++i) {
- const geom::Geometry* p = dynamic_cast<const geom::Geometry*>(*i);
- polys.push_back(const_cast<geom::Geometry*>(p));
- return Union(&polys);
- * Creates a new instance to union
- * the given collection of {@link geom::Geometry}s.
- * Ownership of elements _and_ vector are left to caller.
- CascadedUnion(const std::vector<geom::Geometry*>* geoms)
- : inputGeoms(geoms),
- geomFactory(nullptr)
- * Computes the union of the input geometries.
- * @return the union of the input geometries
- * @return null if no input geometries were provided
- geom::Geometry* Union();
-private:
- geom::Geometry* unionTree(index::strtree::ItemsList* geomTree);
- * Unions a list of geometries
- * by treating the list as a flattened binary tree,
- * and performing a cascaded union on the tree.
- geom::Geometry* binaryUnion(GeometryListHolder* geoms);
- * Unions a section of a list using a recursive binary union on each half
- * of the section.
- * @param geoms
- * @param start
- * @param end
- * @return the union of the list section
- geom::Geometry* binaryUnion(GeometryListHolder* geoms, std::size_t start,
- std::size_t end);
- * Reduces a tree of geometries to a list of geometries
- * by recursively unioning the subtrees in the list.
- * @param geomTree a tree-structured list of geometries
- * @return a list of Geometrys
- GeometryListHolder* reduceToGeometries(index::strtree::ItemsList* geomTree);
- * Computes the union of two geometries,
- * either of both of which may be null.
- * @param g0 a Geometry
- * @param g1 a Geometry
- * @return the union of the input(s)
- * @return null if both inputs are null
- geom::Geometry* unionSafe(geom::Geometry* g0, geom::Geometry* g1);
- geom::Geometry* unionOptimized(geom::Geometry* g0, geom::Geometry* g1);
- * Unions two geometries.
- * The case of multi geometries is optimized to union only
- * the components which lie in the intersection of the two geometry's
- * envelopes.
- * Geometrys outside this region can simply be combined with the union
- * result, which is potentially much faster.
- * This case is likely to occur often during cascaded union, and may also
- * occur in real world data (such as unioning data for parcels on
- * different street blocks).
- * @param g0 a geometry
- * @param g1 a geometry
- * @param common the intersection of the envelopes of the inputs
- * @return the union of the inputs
- geom::Geometry* unionUsingEnvelopeIntersection(geom::Geometry* g0,
- geom::Geometry* g1, geom::Envelope const& common);
- geom::Geometry* extractByEnvelope(geom::Envelope const& env,
- geom::Geometry* geom, std::vector<const geom::Geometry*>& disjointGeoms);
- * Encapsulates the actual unioning of two polygonal geometries.
- * @param g0
- * @param g1
- * @return
- static geom::Geometry* unionActual(geom::Geometry* g0, geom::Geometry* g1);
-} // namespace geos::operation::union
-#endif
diff --git a/src/operation/union/CascadedUnion.cpp b/src/operation/union/CascadedUnion.cpp
index f320df1..0000000
--- a/src/operation/union/CascadedUnion.cpp
+++ /dev/null
@@ -1,209 +0,0 @@
-#include <geos/operation/union/CascadedUnion.h>
-#include <geos/geom/Geometry.h>
-#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/util/GeometryCombiner.h>
-#include <geos/index/strtree/STRtree.h>
-// std
-#include <cassert>
-#include <cstddef>
-#include <memory>
-#include <vector>
-namespace geos {
-namespace operation { // geos.operation
-namespace geounion { // geos.operation.geounion
-geom::Geometry*
-CascadedUnion::Union(std::vector<geom::Geometry*>* polys)
- CascadedUnion op(polys);
- return op.Union();
-geom::Geometry*
-CascadedUnion::Union()
- if(inputGeoms->empty()) {
- return nullptr;
- geomFactory = inputGeoms->front()->getFactory();
- * A spatial index to organize the collection
- * into groups of close geometries.
- * This makes unioning more efficient, since vertices are more likely
- * to be eliminated on each round.
- index::strtree::STRtree index(STRTREE_NODE_CAPACITY);
- typedef std::vector<geom::Geometry*>::const_iterator iterator_type;
- iterator_type end = inputGeoms->end();
- for(iterator_type i = inputGeoms->begin(); i != end; ++i) {
- geom::Geometry* g = *i;
- index.insert(g->getEnvelopeInternal(), g);
- std::unique_ptr<index::strtree::ItemsList> itemTree(index.itemsTree());
- return unionTree(itemTree.get());
-geom::Geometry*
-CascadedUnion::unionTree(
- index::strtree::ItemsList* geomTree)
- * Recursively unions all subtrees in the list into single geometries.
- * The result is a list of Geometry's only
- std::unique_ptr<GeometryListHolder> geoms(reduceToGeometries(geomTree));
- return binaryUnion(geoms.get());
-geom::Geometry*
-CascadedUnion::binaryUnion(GeometryListHolder* geoms)
- return binaryUnion(geoms, 0, geoms->size());
-geom::Geometry*
-CascadedUnion::binaryUnion(GeometryListHolder* geoms,
- std::size_t start, std::size_t end)
- if(end - start <= 1) {
- return unionSafe(geoms->getGeometry(start), nullptr);
- else if(end - start == 2) {
- return unionSafe(geoms->getGeometry(start), geoms->getGeometry(start + 1));
- else {
- // recurse on both halves of the list
- std::size_t mid = (end + start) / 2;
- std::unique_ptr<geom::Geometry> g0(binaryUnion(geoms, start, mid));
- std::unique_ptr<geom::Geometry> g1(binaryUnion(geoms, mid, end));
- return unionSafe(g0.get(), g1.get());
-GeometryListHolder*
-CascadedUnion::reduceToGeometries(index::strtree::ItemsList* geomTree)
- std::unique_ptr<GeometryListHolder> geoms(new GeometryListHolder());
- typedef index::strtree::ItemsList::iterator iterator_type;
- iterator_type end = geomTree->end();
- for(iterator_type i = geomTree->begin(); i != end; ++i) {
- if((*i).get_type() == index::strtree::ItemsListItem::item_is_list) {
- std::unique_ptr<geom::Geometry> geom(unionTree((*i).get_itemslist()));
- geoms->push_back_owned(geom.get());
- geom.release();
- else if((*i).get_type() == index::strtree::ItemsListItem::item_is_geometry) {
- geoms->push_back(reinterpret_cast<geom::Geometry*>((*i).get_geometry()));
- else {
- assert(!static_cast<bool>("should never be reached"));
- return geoms.release();
-geom::Geometry*
-CascadedUnion::unionSafe(geom::Geometry* g0, geom::Geometry* g1)
- if(g0 == nullptr && g1 == nullptr) {
- return nullptr;
- if(g0 == nullptr) {
- return g1->clone().release();
- if(g1 == nullptr) {
- return g0->clone().release();
- return unionOptimized(g0, g1);
-geom::Geometry*
-CascadedUnion::unionOptimized(geom::Geometry* g0, geom::Geometry* g1)
- geom::Envelope const* g0Env = g0->getEnvelopeInternal();
- geom::Envelope const* g1Env = g1->getEnvelopeInternal();
- if(!g0Env->intersects(g1Env)) {
- return geom::util::GeometryCombiner::combine(g0, g1).release();
- if(g0->getNumGeometries() <= 1 && g1->getNumGeometries() <= 1) {
- return unionActual(g0, g1);
- geom::Envelope commonEnv;
- g0Env->intersection(*g1Env, commonEnv);
- return unionUsingEnvelopeIntersection(g0, g1, commonEnv);
-geom::Geometry*
-CascadedUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
- std::vector<const geom::Geometry*> disjointPolys;
- std::unique_ptr<geom::Geometry> g0Int(extractByEnvelope(common, g0, disjointPolys));
- std::unique_ptr<geom::Geometry> g1Int(extractByEnvelope(common, g1, disjointPolys));
- std::unique_ptr<geom::Geometry> u(unionActual(g0Int.get(), g1Int.get()));
- disjointPolys.push_back(u.get());
- return geom::util::GeometryCombiner::combine(disjointPolys).release();
-geom::Geometry*
-CascadedUnion::extractByEnvelope(geom::Envelope const& env,
- std::vector<const geom::Geometry*> intersectingGeoms;
- for(std::size_t i = 0; i < geom->getNumGeometries(); i++) {
- const geom::Geometry* elem = geom->getGeometryN(i);
- if(elem->getEnvelopeInternal()->intersects(env)) {
- intersectingGeoms.push_back(elem);
- else {
- disjointGeoms.push_back(elem);
- return geomFactory->buildGeometry(intersectingGeoms);
-geom::Geometry*
-CascadedUnion::unionActual(geom::Geometry* g0, geom::Geometry* g1)
- return g0->Union(g1).release();
-} // namespace geos.operation.union
diff --git a/src/operation/union/UnaryUnionOp.cpp b/src/operation/union/UnaryUnionOp.cpp
index ba2f4d0..ae18770 100644
--- a/src/operation/union/UnaryUnionOp.cpp
+++ b/src/operation/union/UnaryUnionOp.cpp
@@ -21,7 +21,6 @@
#include <algorithm> // for copy
#include <geos/operation/union/UnaryUnionOp.h>
#include <geos/operation/union/CascadedPolygonUnion.h>
#include <geos/operation/union/PointGeometryUnion.h>
#include <geos/geom/Coordinate.h>
@@ -88,25 +87,8 @@ UnaryUnionOp::Union()
GeomPtr unionLines;
if(!lines.empty()) {
- /* JTS compatibility NOTE:
- * we use cascaded here for robustness [1]
- * but also add a final unionNoOpt step to deal with
- * self-intersecting lines [2]
- * [1](http://trac.osgeo.org/geos/ticket/392
- * [2](http://trac.osgeo.org/geos/ticket/482
- try {
- auto combinedLines = geomFact->buildGeometry(lines.begin(), lines.end());
- unionLines = unionNoOpt(*combinedLines);
- } catch (geos::util::TopologyException &) {
- unionLines.reset(CascadedUnion::Union(lines.begin(),
- lines.end()));
- if(unionLines.get()) {
- unionLines = unionNoOpt(*unionLines);
+ auto combinedLines = geomFact->buildGeometry(lines.begin(), lines.end());
+ unionLines = unionNoOpt(*combinedLines);
GeomPtr unionPolygons;
Summary of changes:
include/geos/operation/union/CascadedUnion.h | 199 -------------------------
src/operation/union/CascadedUnion.cpp | 209 ---------------------------
src/operation/union/UnaryUnionOp.cpp | 22 +--
3 files changed, 2 insertions(+), 428 deletions(-)
delete mode 100644 include/geos/operation/union/CascadedUnion.h
delete mode 100644 src/operation/union/CascadedUnion.cpp
hooks/post-receive
More information about the geos-commits
