[geos-commits] [SCM] GEOS branch master updated. f2dc73df8f93b6994a59ff2b53be28ab074c5b61
git at osgeo.org
git at osgeo.org
Mon Feb 22 13:48:22 PST 2021
the project "GEOS".
via f2dc73df8f93b6994a59ff2b53be28ab074c5b61 (commit)
via 8b024bbdd1ce8fe951e30ddccd5932d15e1995c0 (commit)
from e4fd106f4f66167b554389c7b441d9bc5ee89b1b (commit)
revisions in full, below.
commit f2dc73df8f93b6994a59ff2b53be28ab074c5b61
Merge: 8b024bb e4fd106
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Feb 22 13:48:16 2021 -0800
Merge branch 'master' of https://git.osgeo.org/gitea/geos/geos
commit 8b024bbdd1ce8fe951e30ddccd5932d15e1995c0
Date: Mon Feb 22 13:48:04 2021 -0800
Add in interrupt points through major stages of overlay code. References #4857
diff --git a/src/operation/overlayng/OverlayNG.cpp b/src/operation/overlayng/OverlayNG.cpp
index 5bfd524..709f288 100644
--- a/src/operation/overlayng/OverlayNG.cpp
+++ b/src/operation/overlayng/OverlayNG.cpp
@@ -35,6 +35,7 @@
#include <geos/geom/Envelope.h>
#include <geos/geom/Location.h>
#include <geos/geom/Geometry.h>
+#include <geos/util/Interrupt.h>
#include <algorithm>
@@ -211,6 +212,8 @@ OverlayNG::computeEdgeOverlay()
EdgeNodingBuilder nodingBuilder(pm, noder);
+ GEOS_CHECK_FOR_INTERRUPTS();
if (isOptimized) {
Envelope clipEnv;
bool gotClipEnv = OverlayUtil::clippingEnvelope(opCode, &inputGeom, pm, clipEnv);
@@ -223,6 +226,8 @@ OverlayNG::computeEdgeOverlay()
inputGeom.getGeometry(0),
inputGeom.getGeometry(1));
* Record if an input geometry has collapsed.
* This is used to avoid trying to locate disconnected edges
@@ -249,6 +254,7 @@ OverlayNG::computeEdgeOverlay()
return OverlayUtil::toLines(&graph, isOutputEdges, geomFact);
labelGraph(&graph);
// std::cout << std::endl << graph << std::endl;
@@ -257,6 +263,7 @@ OverlayNG::computeEdgeOverlay()
return extractResult(opCode, &graph);
@@ -291,6 +298,7 @@ OverlayNG::extractResult(int p_opCode, OverlayGraph* graph)
std::vector<std::unique_ptr<LineString>> resultLineList;
std::vector<std::unique_ptr<Point>> resultPointList;
if (!isAreaResultOnly) {
//--- Build lines
bool allowResultLines = !hasResultAreaComponents ||
Summary of changes:
src/operation/overlayng/OverlayNG.cpp | 8 ++++++++
1 file changed, 8 insertions(+)
hooks/post-receive
More information about the geos-commits
