[geos-commits] [SCM] GEOS branch master updated. 6c8ed469f0475d36a68c15912c170e55d2c3ac02
Tue Feb 23 16:48:25 PST 2021
the project "GEOS".
       via  6c8ed469f0475d36a68c15912c170e55d2c3ac02 (commit)
      from  0738016155bba63fb456e31c952522e6d3140441 (commit)
revisions in full, below.
commit 6c8ed469f0475d36a68c15912c170e55d2c3ac02
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Feb 23 16:48:18 2021 -0800
    Fix geosop compile warnings
diff --git a/util/geosop/GeomFunction.cpp b/util/geosop/GeomFunction.cpp
index 5493792..b63f8e2 100644
--- a/util/geosop/GeomFunction.cpp
+++ b/util/geosop/GeomFunction.cpp
@@ -74,39 +74,48 @@ GeomFunction::init()
     add("area",
         [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geomB, double d)->Result* {
+            (void) geomB; (void)d;  // prevent unused variable warning
             return new Result( geom->getArea() );
     add("boundary",
             return new Result( geom->getBoundary() );
     add("buffer", "computes the buffer of geometry A to a distance", 1, 1,
+            (void) geomB;  // prevent unused variable warning
             return new Result( geom->buffer( d ) );
     add("centroid",
             return new Result( geom->getCentroid() );
     add("copy",
             return new Result( geom->clone() );
     add("convexHull",
             return new Result( geom->convexHull() );
     add("contains", "tests if geometry A contains geometry B", 2, 0,
+            (void)d;  // prevent unused variable warning
             return new Result( geom->contains( geomB.get() ) );
     add("covers", "tests if geometry A covers geometry B", 2, 0,
             return new Result( geom->covers( geomB.get() ) );
     add("densify", "densifies geometry A to a distance ", 1, 1,
+            (void)geomB;  // prevent unused variable warning
             geom::util::Densifier densifier( geom.get() );
             densifier.setDistanceTolerance( d );
             return new Result( densifier.getResultGeometry() );
@@ -114,57 +123,68 @@ GeomFunction::init()
     add("distance", "computes distance between geometry A and B", 2, 0,
             return new Result( geom->distance( geomB.get() ) );
      add("envelope",
     add("interiorPoint",
             return new Result( geom->getInteriorPoint() );
     add("intersects", "tests if geometry A and B intersect", 2, 0,
             return new Result( geom->intersects( geomB.get() ) );
     add("isEmpty", "tests if geometry A is empty", 1, 0,
             return new Result( geom->isEmpty() );
     add("isSimple", "tests if geometry A is simple", 1, 0,
             return new Result( geom->isSimple() );
     add("isValid", "tests if geometry A is valid", 1, 0,
             return new Result( geom->isValid() );
     add("length",
             return new Result( geom->getLength() );
     add("makeValid",
             return new Result( geos::operation::valid::MakeValid().build( geom.get() ) );
     add("maxInscribedCircle", "computes maximum inscribed circle radius of Polygon A up to a distance tolerance", 2, 0,
             geos::algorithm::construct::MaximumInscribedCircle mc( geom.get(), d );
             std::unique_ptr<Geometry> res = mc.getRadiusLine();
             return new Result( std::move(res) );
     add("minBoundingCircle",
             geos::algorithm::MinimumBoundingCircle mc( geom.get() );
             std::unique_ptr<Geometry> res = mc.getCircle();
@@ -172,6 +192,7 @@ GeomFunction::init()
     add("nearestPoints", "computes a line containing the nearest points of geometry A and B", 2, 0,
             std::unique_ptr<CoordinateSequence> cs = geos::operation::distance::DistanceOp::nearestPoints(geom.get(), geomB.get());
             auto factory = geom->getFactory();
             auto res = factory->createLineString( std::move(cs) );
@@ -179,6 +200,7 @@ GeomFunction::init()
     add("normalize", "normalizes geometry A", 1, 0,
             auto res = geom->clone();
             res->normalize();
@@ -186,6 +208,7 @@ GeomFunction::init()
     add("lineMerge", "merges the lines of geometry A", 1, 0,
             geos::operation::linemerge::LineMerger lmrgr;
             lmrgr.add(geom.get());
@@ -200,6 +223,7 @@ GeomFunction::init()
     add("delaunay", "computes the Delaunay Triangulation of geometry A vertices", 1, 0,
             geos::triangulate::DelaunayTriangulationBuilder builder;
             builder.setTolerance(0);
             builder.setSites( *geom );
@@ -215,6 +239,7 @@ GeomFunction::init()
     add("voronoi", "computes the Voronoi Diagram of geometry A vertices", 1, 0,
             geos::triangulate::VoronoiDiagramBuilder builder;
@@ -230,6 +255,7 @@ GeomFunction::init()
     add("polygonize",
             geos::operation::polygonize::Polygonizer p;
             p.add(geom.get());
@@ -243,51 +269,62 @@ GeomFunction::init()
     add("reducePrecision", "reduces precision of geometry to a precision scale factor", 1, 1,
             PrecisionModel pm(d);
             return new Result( geos::precision::GeometryPrecisionReducer::reduce( *geom, pm ) );
     add("relate", "computes DE-9IM matrix for geometry A and B", 2, 0,
             std::unique_ptr<geom::IntersectionMatrix> im(geom->relate( geomB.get() ));
             return new Result( im->toString() );
     add("reverse", "reverses geometry A", 1, 0,
             return new Result( geom->reverse() );
     add("simplifyDP", "simplifies geometry A using Douglas-Peucker with a distance tolerance", 1, 1,
             return new Result( geos::simplify::DouglasPeuckerSimplifier::simplify(geom.get(), d) );
     add("simplifyTP", "simplifies geometry A using Douglas-Peucker with a distance tolerance, preserving topology", 1, 1,
             return new Result( geos::simplify::TopologyPreservingSimplifier::simplify(geom.get(), d) );
     add("containsPrep", "tests if geometry A contains geometry B, using PreparedGeometry", 2, 0,
             return new Result( prepGeomCache.get(geom.get())->contains( geomB.get() ) );
     add("containsProperlyPrep", "tests if geometry A properly contains geometry B using PreparedGeometry", 2, 0,
             return new Result( prepGeomCache.get(geom.get())->containsProperly( geomB.get() ) );
     add("coversPrep", "tests if geometry A covers geometry B using PreparedGeometry", 2, 0,
             return new Result( prepGeomCache.get(geom.get())->covers( geomB.get() ) );
     add("intersectsPrep", "tests if geometry A intersects B using PreparedGeometry", 2, 0,
             return new Result( prepGeomCache.get(geom.get())->intersects( geomB.get() ) );
     add("distancePrep", "computes distance between geometry A and B using PreparedGeometry", 2, 0,
             return new Result( prepGeomCache.get(geom.get())->distance( geomB.get() ) );
     add("nearestPointsPrep", "computes a line containing the nearest points of geometry A and B using PreparedGeometry", 2, 0,
             auto cs = prepGeomCache.get(geom.get())->nearestPoints( geomB.get() );
@@ -298,22 +335,27 @@ GeomFunction::init()
     add("difference", "computes difference of geometry A from B", 2, 0,
             return new Result( geom->difference( geomB.get() ) );
     add("intersection", "computes intersection of geometry A and B", 2, 0,
             return new Result( geom->intersection( geomB.get() ) );
     add("symDifference", "computes symmetric difference of geometry A and B", 2, 0,
             return new Result( geom->symDifference( geomB.get() ) );
     add("unaryUnion",
+            (void)geomB; (void)d;  // prevent unused variable warning
             return new Result( geom->Union() );
     add("union", "computes union of geometry A and B", 2, 0,
             return new Result( geom->Union( geomB.get() ) );
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index bbeb4c4..fcefbbf 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -143,10 +143,10 @@ GeosOp::GeosOp(GeosOpArgs& arg)
 GeosOp::~GeosOp() {
-std::string formatNum(int n)
+std::string formatNum(long n)
     auto fmt = std::to_string(n);
-    int insertPosition = static_cast<int>(fmt.length()) - 3;
+    size_t insertPosition = fmt.length() - 3;
     while (insertPosition > 0) {
         fmt.insert(insertPosition, ",");
         insertPosition-=3;
@@ -167,7 +167,7 @@ bool isWKTLiteral(std::string s) {
     if (endsWith(s, " EMPTY")) return true;
     // assume if string contains a ( it is WKT
-    int numLParen = std::count(s.begin(), s.end(), '(');
+    long numLParen = std::count(s.begin(), s.end(), '(');
     return numLParen > 0;
@@ -293,7 +293,7 @@ GeosOp::loadInput(std::string name, std::string src, int limit) {
     auto geoms = readInput( name, src, limit );
     sw.stop();
     auto stats = summaryStats(geoms);
-    log("Read " + stats  + "  -- " + formatNum( sw.getTot() ) + " usec");
+    log("Read " + stats  + "  -- " + formatNum( (long) sw.getTot() ) + " usec");
     return geoms;
@@ -321,7 +321,7 @@ void GeosOp::run() {
         std::cout
             << "Ran " <<  formatNum( opCount ) << " " << args.opName << " ops ( "
             << formatNum( vertexCount ) << " vertices)"
-            << "  -- " << formatNum( totalTime ) <<  " usec"
+            << "  -- " << formatNum( (long) totalTime ) <<  " usec"
             << "    (GEOS " << geosversion() << ")"
             << std::endl;
@@ -372,7 +372,7 @@ void GeosOp::executeBinary(GeomFunction * fun) {
-std::string inputDesc(std::string name, int index, const std::unique_ptr<Geometry>& geom)
+std::string inputDesc(std::string name, unsigned int index, const std::unique_ptr<Geometry>& geom)
     if (geom == nullptr) {
         return "";
@@ -383,29 +383,29 @@ std::string inputDesc(std::string name, int index, const std::unique_ptr<Geometr
 Result* GeosOp::executeOpRepeat(GeomFunction * fun,
-    int indexA,
-    const std::unique_ptr<Geometry>& geomA,
-    int indexB,
-    const std::unique_ptr<Geometry>& geomB)
+    unsigned int indexA,
+    const std::unique_ptr<Geometry>& gA,
+    unsigned int indexB,
+    const std::unique_ptr<Geometry>& gB)
     Result * res;
     for (int i = 0; i < args.repeatNum; i++) {
-        res = executeOp(fun, indexA, geomA, indexB, geomB);
+        res = executeOp(fun, indexA, gA, indexB, gB);
     return res;
 Result* GeosOp::executeOp(GeomFunction * fun,
-    int indexA,
-    int indexB,
-    const std::unique_ptr<Geometry>& geomB) {
+    const std::unique_ptr<Geometry>& gB) {
     opCount++;
     geos::util::Profile sw( "op" );
     sw.start();
-    Result* result = fun->execute( geomA, geomB, args.opArg1  );
+    Result* result = fun->execute( gA, gB, args.opArg1  );
     sw.stop();
     double time = sw.getTot();
     totalTime += time;
@@ -414,10 +414,10 @@ Result* GeosOp::executeOp(GeomFunction * fun,
     if (args.isVerbose) {
         log(
             "[ " + std::to_string(opCount) + "] " + fun->name() + ": "
-            + inputDesc("A", indexA, geomA) + " "
-            + inputDesc("B", indexB, geomB)
+            + inputDesc("A", indexA, gA) + " "
+            + inputDesc("B", indexB, gB)
             + " -> " + result->metadata()
-            + "  --  " + formatNum( time ) + " usec"
+            + "  --  " + formatNum( (int) time ) + " usec"
diff --git a/util/geosop/GeosOp.h b/util/geosop/GeosOp.h
index df8d2f9..1aea4fa 100644
--- a/util/geosop/GeosOp.h
+++ b/util/geosop/GeosOp.h
@@ -75,11 +75,11 @@ private:
     void executeUnary(GeomFunction * fun);
     void executeBinary(GeomFunction * fun);
     Result* executeOpRepeat(GeomFunction * fun,
-        int indexA, const  std::unique_ptr<Geometry>& geomA,
-        int indexB, const  std::unique_ptr<Geometry>& geomB);
+        unsigned int indexA, const  std::unique_ptr<Geometry>& geomA,
+        unsigned int indexB, const  std::unique_ptr<Geometry>& geomB);
     Result* executeOp(GeomFunction * fun,
     void output(Result* result);
     void outputExplode(std::unique_ptr<Geometry>& geom);
     void outputGeometry( const Geometry* geom);
Summary of changes:
 util/geosop/GeomFunction.cpp | 42 ++++++++++++++++++++++++++++++++++++++++++
 util/geosop/GeosOp.cpp       | 38 +++++++++++++++++++-------------------
 util/geosop/GeosOp.h         |  8 ++++----
 3 files changed, 65 insertions(+), 23 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
