[geos-commits] [SCM] GEOS branch master updated. 3dd712169049be0c38665765979234968be6540f
git at osgeo.org
git at osgeo.org
Tue Feb 23 17:02:29 PST 2021
the project "GEOS".
via 3dd712169049be0c38665765979234968be6540f (commit)
via 2b807c02de4b4eec51a6f47c756def22af403e3e (commit)
via dedd10e993494064d91697f70d13af908d083d48 (commit)
via f00492a6904bc990282c2aa9d687bed7abc2cfe9 (commit)
via d1adac1d1d488560af4d5aa22727ddca55ff94e7 (commit)
from 6c8ed469f0475d36a68c15912c170e55d2c3ac02 (commit)
revisions in full, below.
commit 3dd712169049be0c38665765979234968be6540f
Merge: 6c8ed46 2b807c0
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Feb 23 20:02:14 2021 -0500
Merge branch 'cmake-vendor-libs'
commit 2b807c02de4b4eec51a6f47c756def22af403e3e
Date: Sun Jan 31 16:04:33 2021 -0500
Add comment [ci skip]
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 82e2e3c..6890225 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -252,6 +252,8 @@ set(CMAKE_CXX_FLAGS_COVERAGE "-fprofile-arcs -ftest-coverage")
add_library(geos "")
target_link_libraries(geos PUBLIC geos_cxx_flags PRIVATE $<BUILD_INTERFACE:ryu>)
+# ryu is an object library, nothing is actually being linked here. The BUILD_INTERFACE
+# switch was necessary to build on AppVeyor (CMake 3.16.2) but not locally (CMake 3.16.3)
add_subdirectory(include)
add_subdirectory(src)
commit dedd10e993494064d91697f70d13af908d083d48
Date: Sun Jan 31 10:02:26 2021 -0500
Avoid install error about ryu?
index 47c8eab..82e2e3c 100644
@@ -251,7 +251,7 @@ set(CMAKE_CXX_FLAGS_COVERAGE "-fprofile-arcs -ftest-coverage")
# Target geos: C++ API library
-target_link_libraries(geos PUBLIC geos_cxx_flags PRIVATE ryu)
+target_link_libraries(geos PUBLIC geos_cxx_flags PRIVATE $<BUILD_INTERFACE:ryu>)
commit f00492a6904bc990282c2aa9d687bed7abc2cfe9
Date: Sun Jan 31 08:52:16 2021 -0500
[appveyor] Emit CMake version
diff --git a/appveyor.yml b/appveyor.yml
index 8d61646..fb2a2b3 100644
--- a/appveyor.yml
+++ b/appveyor.yml
@@ -60,18 +60,16 @@ init:
before_build:
- ps: 'Write-Host "Running $env:BUILDER with $env:GENERATOR" -ForegroundColor Magenta'
- - if "%BUILDER%"=="CMake" cmake.exe -G "%GENERATOR%" -DBUILD_SHARED_LIBS=OFF -DCMAKE_BUILD_TYPE=%CONFIGURATION% %APPVEYOR_BUILD_FOLDER%
- - if "%BUILDER%"=="NMake" .\autogen.bat
+ - cmake --version
+ - cmake -G "%GENERATOR%" -DBUILD_SHARED_LIBS=OFF -DCMAKE_BUILD_TYPE=%CONFIGURATION% %APPVEYOR_BUILD_FOLDER%
build_script:
- ps: 'Write-Host "Running $env:BUILDER:" -ForegroundColor Magenta'
- - if "%BUILDER%"=="CMake" cmake --build . --config %CONFIGURATION%
- - if "%BUILDER%"=="NMake" nmake /f makefile.vc
+ - cmake --build . --config %CONFIGURATION%
test_script:
- ps: 'Write-Host "Running tests:" -ForegroundColor Magenta'
- - if "%BUILDER%"=="CMake" ctest --output-on-failure -C %CONFIGURATION%
- - if "%BUILDER%"=="NMake" echo *** NMake does NOT build tests ***
+ - ctest --output-on-failure -C %CONFIGURATION%
# If you need to debug AppVeyor session (https://www.appveyor.com/docs/how-to/rdp-to-build-worker), then:
# 1. Uncomment the on_finish section below:
commit d1adac1d1d488560af4d5aa22727ddca55ff94e7
Date: Fri Jan 29 19:57:21 2021 -0500
Exclude vendored libs from GEOS compiler warnings
index df264f2..47c8eab 100644
-target_link_libraries(geos PUBLIC geos_cxx_flags)
+target_link_libraries(geos PUBLIC geos_cxx_flags PRIVATE ryu)
diff --git a/src/deps/CMakeLists.txt b/src/deps/CMakeLists.txt
index 48caade..7a6fac1 100644
--- a/src/deps/CMakeLists.txt
+++ b/src/deps/CMakeLists.txt
@@ -9,7 +9,9 @@
# See the COPYING file for more information.
file(GLOB_RECURSE _sources ${CMAKE_CURRENT_LIST_DIR}/*.c CONFIGURE_DEPEND)
-target_sources(geos PRIVATE ${_sources})
+add_library(ryu OBJECT ${_sources})
+target_include_directories(ryu PUBLIC ${CMAKE_CURRENT_LIST_DIR})
+set_target_properties(ryu PROPERTIES POSITION_INDEPENDENT_CODE ON)
unset(_sources)
target_include_directories(geos
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 9b8040c..87113ac 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -13,16 +13,24 @@
add_executable(test_simplewkttester SimpleWKTTester.cpp)
target_link_libraries(test_simplewkttester PRIVATE geos)
+# Setup tinyxml as a separate library so we can avoid picking up GEOS compile flags
+add_library(tinyxml2 OBJECT
+ tinyxml2/tinyxml2.h
+ tinyxml2/tinyxml2.cpp)
+target_compile_options(
+ tinyxml2 PRIVATE
+ $<$<CXX_COMPILER_ID:GNU>:-Wno-conversion>
+ $<$<CXX_COMPILER_ID:Clang>:-Wno-conversion>
add_executable(test_xmltester
XMLTester.cpp
BufferResultMatcher.cpp
- SingleSidedBufferResultMatcher.cpp
- tinyxml2/tinyxml2.h
- tinyxml2/tinyxml2.cpp)
-target_link_libraries(test_xmltester PRIVATE geos)
+ SingleSidedBufferResultMatcher.cpp)
+target_link_libraries(test_xmltester PRIVATE geos tinyxml2)
target_include_directories(test_xmltester
- PRIVATE
- $<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>/tinyxml)
+ SYSTEM PRIVATE
+ $<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>/tinyxml2)
# Scan the directories of XML tests and create a test for each.
foreach(_testdir general issue misc robust validate)
diff --git a/tests/xmltester/XMLTester.h b/tests/xmltester/XMLTester.h
index 5233060..34a08cb 100644
--- a/tests/xmltester/XMLTester.h
+++ b/tests/xmltester/XMLTester.h
@@ -18,7 +18,7 @@
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/PrecisionModel.h>
#include <geos/profiler.h>
-#include "tinyxml2/tinyxml2.h"
+#include <tinyxml2.h>
using namespace geos;
Summary of changes:
CMakeLists.txt | 4 +++-
appveyor.yml | 10 ++++------
src/deps/CMakeLists.txt | 4 +++-
tests/xmltester/CMakeLists.txt | 20 ++++++++++++++------
tests/xmltester/XMLTester.h | 2 +-
5 files changed, 25 insertions(+), 15 deletions(-)
hooks/post-receive
More information about the geos-commits
