[geos-commits] [SCM] GEOS branch main updated. 2df86bc1191f578047fb30331cae254486ace191
git at osgeo.org
git at osgeo.org
Mon Jul 12 16:21:36 PDT 2021
the project "GEOS".
The branch, main has been updated
via 2df86bc1191f578047fb30331cae254486ace191 (commit)
via 628391d30210802767bcaf19d6245512b163d491 (commit)
via 5a0c4cdb39241c8b520c0045b4ea7da808a0cf77 (commit)
from 413bdbc2014de87b3f1fda0895f5afc770226f53 (commit)
revisions in full, below.
commit 2df86bc1191f578047fb30331cae254486ace191
Merge: 413bdbc 628391d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Jul 12 16:21:29 2021 -0700
Merge branch 'whuaegeanse-GeoJson' into main
commit 628391d30210802767bcaf19d6245512b163d491
Author: whuaegeansea <whuaegeansea at gmail.com>
Date: Mon Jul 12 22:32:10 2021 +0800
Format files of GeoJson with AStyle in GEOS
diff --git a/include/geos/io/GeoJSON.h b/include/geos/io/GeoJSON.h
index cd54c6d..08c648d 100644
--- a/include/geos/io/GeoJSON.h
+++ b/include/geos/io/GeoJSON.h
@@ -77,7 +77,7 @@ public:
const std::string& getString() const;
std::nullptr_t getNull() const;
bool getBoolean() const;
- const std::map<std::string,GeoJSONValue>& getObject() const;
+ const std::map<std::string, GeoJSONValue>& getObject() const;
const std::vector<GeoJSONValue>& getArray() const;
bool isNumber() const;
@@ -93,17 +93,19 @@ class GEOS_DLL GeoJSONFeature {
public:
- GeoJSONFeature(std::unique_ptr<geom::Geometry> g, const std::map<std::string, GeoJSONValue> &p);
+ GeoJSONFeature(std::unique_ptr<geom::Geometry> g,
+ const std::map<std::string, GeoJSONValue>& p);
- GeoJSONFeature(std::unique_ptr<geom::Geometry> g, std::map<std::string, GeoJSONValue>&& p);
+ std::map<std::string, GeoJSONValue>&& p);
- GeoJSONFeature(GeoJSONFeature const &other);
+ GeoJSONFeature(GeoJSONFeature const& other);
- GeoJSONFeature(GeoJSONFeature && other);
+ GeoJSONFeature(GeoJSONFeature&& other);
GeoJSONFeature& operator=(const GeoJSONFeature&);
- GeoJSONFeature& operator=(GeoJSONFeature &&);
+ GeoJSONFeature& operator=(GeoJSONFeature&&);
const geom::Geometry* getGeometry() const;
@@ -121,7 +123,7 @@ class GEOS_DLL GeoJSONFeatureCollection {
public:
- GeoJSONFeatureCollection(const std::vector<GeoJSONFeature> &f);
+ GeoJSONFeatureCollection(const std::vector<GeoJSONFeature>& f);
GeoJSONFeatureCollection(std::vector<GeoJSONFeature>&& f);
diff --git a/src/io/GeoJSON.cpp b/src/io/GeoJSON.cpp
index 086799d..cfb28ea 100644
--- a/src/io/GeoJSON.cpp
+++ b/src/io/GeoJSON.cpp
@@ -19,59 +19,70 @@ namespace io { // geos.io
// GeoJSONValue
-GeoJSONValue::GeoJSONValue(double value) {
+GeoJSONValue::GeoJSONValue(double value)
type = Type::NUMBER;
d = value;
-GeoJSONValue::GeoJSONValue(const std::string& value) {
+GeoJSONValue::GeoJSONValue(const std::string& value)
type = Type::STRING;
- new(&s) std::string{value};
+ new (&s) std::string{value};
-GeoJSONValue::GeoJSONValue() {
+GeoJSONValue::GeoJSONValue()
type = Type::NULLTYPE;
n = nullptr;
-GeoJSONValue::GeoJSONValue(bool value) {
+GeoJSONValue::GeoJSONValue(bool value)
type = Type::BOOLEAN;
b = value;
-GeoJSONValue::GeoJSONValue(const std::map<std::string, GeoJSONValue>& value) {
+GeoJSONValue::GeoJSONValue(const std::map<std::string, GeoJSONValue>& value)
type = Type::OBJECT;
- new(&o) std::map<std::string, GeoJSONValue> {value};
+ new (&o) std::map<std::string, GeoJSONValue> {value};
-GeoJSONValue::GeoJSONValue(const std::vector<GeoJSONValue>& value) {
+GeoJSONValue::GeoJSONValue(const std::vector<GeoJSONValue>& value)
type = Type::ARRAY;
- new(&a) std::vector<GeoJSONValue> {};
+ new (&a) std::vector<GeoJSONValue> {};
a.reserve(value.size());
- for(const auto& v : value) {
+ for (const auto& v : value) {
a.push_back(v);
-void GeoJSONValue::cleanup() {
+void GeoJSONValue::cleanup()
using std::string;
using object = std::map<std::string, GeoJSONValue>;
using array = std::vector<GeoJSONValue>;
if (type == Type::STRING) {
s.~string();
- } else if (type == Type::OBJECT) {
+ else if (type == Type::OBJECT) {
o.~object();
- } else if (type == Type::ARRAY) {
+ else if (type == Type::ARRAY) {
a.~array();
-GeoJSONValue::~GeoJSONValue() {
+GeoJSONValue::~GeoJSONValue()
cleanup();
-GeoJSONValue::GeoJSONValue(const GeoJSONValue& v) {
- switch(v.type) {
+GeoJSONValue::GeoJSONValue(const GeoJSONValue& v)
+ switch (v.type) {
case Type::NUMBER:
d = v.d;
break;
@@ -79,18 +90,18 @@ GeoJSONValue::GeoJSONValue(const GeoJSONValue& v) {
b = v.b;
break;
case Type::STRING:
- new(&s) std::string{v.s};
+ new (&s) std::string{v.s};
break;
case Type::NULLTYPE:
n = v.n;
break;
case Type::OBJECT:
- new(&o) std::map<std::string, GeoJSONValue> {v.o};
+ new (&o) std::map<std::string, GeoJSONValue> {v.o};
break;
case Type::ARRAY:
a.reserve(v.a.size());
- for(const auto& i : v.a) {
+ for (const auto& i : v.a) {
a.push_back(i);
break;
@@ -98,21 +109,24 @@ GeoJSONValue::GeoJSONValue(const GeoJSONValue& v) {
type = v.type;
-GeoJSONValue& GeoJSONValue::operator=(const GeoJSONValue& v) {
+GeoJSONValue& GeoJSONValue::operator=(const GeoJSONValue& v)
if (type == Type::STRING && v.type == Type::STRING) {
s = v.s;
return *this;
- } else if (type == Type::OBJECT && v.type == Type::OBJECT) {
+ else if (type == Type::OBJECT && v.type == Type::OBJECT) {
o = v.o;
return *this;
- } else if (type == Type::ARRAY && v.type == Type::ARRAY) {
+ else if (type == Type::ARRAY && v.type == Type::ARRAY) {
a = v.a;
return *this;
cleanup();
- switch(v.type) {
+ switch (v.type) {
case Type::NUMBER:
d = v.d;
break;
@@ -120,18 +134,18 @@ GeoJSONValue& GeoJSONValue::operator=(const GeoJSONValue& v) {
b = v.b;
break;
case Type::STRING:
break;
n = v.n;
break;
case Type::OBJECT:
break;
case Type::ARRAY:
a.push_back(i);
break;
@@ -140,72 +154,89 @@ GeoJSONValue& GeoJSONValue::operator=(const GeoJSONValue& v) {
return *this;
-double GeoJSONValue::getNumber() const {
+double GeoJSONValue::getNumber() const
if (type != Type::NUMBER) throw GeoJSONTypeError{};
return d;
-const std::string& GeoJSONValue::getString() const {
+const std::string& GeoJSONValue::getString() const
if (type != Type::STRING) throw GeoJSONTypeError{};
return s;
-std::nullptr_t GeoJSONValue::getNull() const {
+std::nullptr_t GeoJSONValue::getNull() const
if (type != Type::NULLTYPE) throw GeoJSONTypeError{};
return n;
-bool GeoJSONValue::getBoolean() const {
+bool GeoJSONValue::getBoolean() const
if (type != Type::BOOLEAN) throw GeoJSONTypeError{};
return b;
-const std::map<std::string,GeoJSONValue>& GeoJSONValue::getObject() const {
+const std::map<std::string, GeoJSONValue>& GeoJSONValue::getObject() const
if (type != Type::OBJECT) throw GeoJSONTypeError{};
return o;
-const std::vector<GeoJSONValue>& GeoJSONValue::getArray() const {
+const std::vector<GeoJSONValue>& GeoJSONValue::getArray() const
if (type != Type::ARRAY) throw GeoJSONTypeError{};
return a;
-bool GeoJSONValue::isNumber() const {
+bool GeoJSONValue::isNumber() const
return type == Type::NUMBER;
-bool GeoJSONValue::isString() const {
+bool GeoJSONValue::isString() const
return type == Type::STRING;
-bool GeoJSONValue::isNull() const {
+bool GeoJSONValue::isNull() const
return type == Type::NULLTYPE;
-bool GeoJSONValue::isBoolean() const {
+bool GeoJSONValue::isBoolean() const
return type == Type::BOOLEAN;
-bool GeoJSONValue::isObject() const {
+bool GeoJSONValue::isObject() const
return type == Type::OBJECT;
-bool GeoJSONValue::isArray() const {
+bool GeoJSONValue::isArray() const
return type == Type::ARRAY;
// GeoJSONFeature
-GeoJSONFeature::GeoJSONFeature(std::unique_ptr<geom::Geometry> g, const std::map<std::string, GeoJSONValue>& p) : geometry(std::move(g)), properties(p) {}
+GeoJSONFeature::GeoJSONFeature(std::unique_ptr<geom::Geometry> g,
+ const std::map<std::string, GeoJSONValue>& p) : geometry(std::move(g)), properties(p) {}
-GeoJSONFeature::GeoJSONFeature(std::unique_ptr<geom::Geometry> g, std::map<std::string, GeoJSONValue>&& p) : geometry(std::move(g)), properties(std::move(p)) {}
+ std::map<std::string, GeoJSONValue>&& p) : geometry(std::move(g)), properties(std::move(p)) {}
-GeoJSONFeature::GeoJSONFeature(GeoJSONFeature const &other) : geometry(other.geometry->clone()), properties(other.properties) {}
+GeoJSONFeature::GeoJSONFeature(GeoJSONFeature const& other) : geometry(other.geometry->clone()),
+ properties(other.properties) {}
-GeoJSONFeature::GeoJSONFeature(GeoJSONFeature && other) : geometry(std::move(other.geometry)), properties(std::move(other.properties)) {}
+GeoJSONFeature::GeoJSONFeature(GeoJSONFeature&& other) : geometry(std::move(other.geometry)),
+ properties(std::move(other.properties)) {}
-GeoJSONFeature& GeoJSONFeature::operator=(const GeoJSONFeature& other) {
+GeoJSONFeature& GeoJSONFeature::operator=(const GeoJSONFeature& other)
if (this == &other) {
return *this;
@@ -214,27 +245,31 @@ GeoJSONFeature& GeoJSONFeature::operator=(const GeoJSONFeature& other) {
return *this;
-GeoJSONFeature& GeoJSONFeature::operator=(GeoJSONFeature&& other) {
+GeoJSONFeature& GeoJSONFeature::operator=(GeoJSONFeature&& other)
geometry = std::move(other.geometry);
properties = std::move(other.properties);
return *this;
-const geom::Geometry* GeoJSONFeature::getGeometry() const {
+const geom::Geometry* GeoJSONFeature::getGeometry() const
return geometry.get();
-const std::map<std::string, GeoJSONValue>& GeoJSONFeature::getProperties() const {
+const std::map<std::string, GeoJSONValue>& GeoJSONFeature::getProperties() const
return properties;
// GeoJSONFeatureCollection
-GeoJSONFeatureCollection::GeoJSONFeatureCollection(const std::vector<GeoJSONFeature> &f) : features(f) {}
+GeoJSONFeatureCollection::GeoJSONFeatureCollection(const std::vector<GeoJSONFeature>& f) : features(f) {}
GeoJSONFeatureCollection::GeoJSONFeatureCollection(std::vector<GeoJSONFeature>&& f) : features(std::move(f)) {}
-const std::vector<GeoJSONFeature>& GeoJSONFeatureCollection::getFeatures() const {
+const std::vector<GeoJSONFeature>& GeoJSONFeatureCollection::getFeatures() const
return features;
diff --git a/src/io/GeoJSONReader.cpp b/src/io/GeoJSONReader.cpp
index 70aeefa..82cb922 100644
--- a/src/io/GeoJSONReader.cpp
+++ b/src/io/GeoJSONReader.cpp
@@ -45,94 +45,112 @@ GeoJSONReader::GeoJSONReader(): GeoJSONReader(*(GeometryFactory::getDefaultInsta
GeoJSONReader::GeoJSONReader(const geom::GeometryFactory& gf) : geometryFactory(gf) {}
-std::unique_ptr<geom::Geometry> GeoJSONReader::read(const std::string& geoJsonText) const {
+std::unique_ptr<geom::Geometry> GeoJSONReader::read(const std::string& geoJsonText) const
try {
const json& j = json::parse(geoJsonText);
const std::string& type = j["type"];
if (type == "Feature") {
return readFeatureForGeometry(j);
- } else if (type == "FeatureCollection") {
+ else if (type == "FeatureCollection") {
return readFeatureCollectionForGeometry(j);
- } else {
+ else {
return readGeometry(j);
- } catch (json::exception& ex) {
+ catch (json::exception& ex) {
throw ParseException("Error parsing JSON", ex.what());
-GeoJSONFeatureCollection GeoJSONReader::readFeatures(const std::string& geoJsonText) const {
+GeoJSONFeatureCollection GeoJSONReader::readFeatures(const std::string& geoJsonText) const
try {
const auto& feature = readFeature(j);
return GeoJSONFeatureCollection { std::vector<GeoJSONFeature>{feature} };
return readFeatureCollection(j);
- } else {
+ else {
auto g = readGeometry(j);
return GeoJSONFeatureCollection { std::vector<GeoJSONFeature>{GeoJSONFeature{std::move(g), std::map<std::string, GeoJSONValue>{} }}};
std::unique_ptr<geom::Geometry> GeoJSONReader::readFeatureForGeometry(
- const geos_nlohmann::json& j) const {
+ const geos_nlohmann::json& j) const
const auto& geometryJson = j["geometry"];
auto geometry = readGeometry(geometryJson);
return geometry;
-GeoJSONFeature GeoJSONReader::readFeature(const geos_nlohmann::json& j) const {
+GeoJSONFeature GeoJSONReader::readFeature(const geos_nlohmann::json& j) const
const auto& properties = j["properties"];
return GeoJSONFeature{readGeometry(geometryJson), readProperties(properties)};
std::map<std::string, GeoJSONValue> GeoJSONReader::readProperties(
- const geos_nlohmann::json& p) const {
- std::map<std::string,GeoJSONValue> map;
- for(const auto& prop : p.items()) {
+ const geos_nlohmann::json& p) const
+ std::map<std::string, GeoJSONValue> map;
+ for (const auto& prop : p.items()) {
map[prop.key()] = std::move(readProperty(prop.value()));
return map;
GeoJSONValue GeoJSONReader::readProperty(
- const geos_nlohmann::json& value) const {
+ const geos_nlohmann::json& value) const
if (value.is_string()) {
return GeoJSONValue { value.get<std::string>() };
- } else if (value.is_number()) {
+ else if (value.is_number()) {
return GeoJSONValue { value.get<double>() };
- } else if (value.is_boolean()) {
+ else if (value.is_boolean()) {
return GeoJSONValue { value.get<bool>() };
- } else if (value.is_array()) {
+ else if (value.is_array()) {
std::vector<GeoJSONValue> v {};
v.reserve(value.size());
for (const auto& el : value.items()) {
v.push_back(readProperty(el.value()));
return GeoJSONValue{ v };
- } else if (value.is_object()) {
+ else if (value.is_object()) {
std::map<std::string, GeoJSONValue> v {};
v[el.key()] = std::move(readProperty(el.value()));
- } else {
+ else {
return GeoJSONValue{};
std::unique_ptr<geom::Geometry> GeoJSONReader::readFeatureCollectionForGeometry(
- const auto &featuresJson = j["features"];
+ const auto& featuresJson = j["features"];
std::vector<std::unique_ptr<geom::Geometry>> geometries;
geometries.reserve(featuresJson.size());
- for(const auto& featureJson : featuresJson) {
+ for (const auto& featureJson : featuresJson) {
auto g = readFeatureForGeometry(featureJson);
geometries.push_back(std::move(g));
@@ -140,11 +158,12 @@ std::unique_ptr<geom::Geometry> GeoJSONReader::readFeatureCollectionForGeometry(
GeoJSONFeatureCollection GeoJSONReader::readFeatureCollection(
- const auto & featuresJson = j["features"];
std::vector<GeoJSONFeature> features;
features.reserve(featuresJson.size());
features.push_back(readFeature(featureJson));
return GeoJSONFeatureCollection{std::move(features)};
@@ -152,57 +171,72 @@ GeoJSONFeatureCollection GeoJSONReader::readFeatureCollection(
std::unique_ptr<geom::Geometry> GeoJSONReader::readGeometry(
- const std::string & type = j["type"];
+ const std::string& type = j["type"];
if (type == "Point") {
return readPoint(j);
- } else if (type == "LineString") {
+ else if (type == "LineString") {
return readLineString(j);
- } else if (type == "Polygon") {
+ else if (type == "Polygon") {
return readPolygon(j);
- } else if (type == "MultiPoint") {
+ else if (type == "MultiPoint") {
return readMultiPoint(j);
- } else if (type == "MultiLineString") {
+ else if (type == "MultiLineString") {
return readMultiLineString(j);
- } else if (type == "MultiPolygon") {
+ else if (type == "MultiPolygon") {
return readMultiPolygon(j);
- } else if (type == "GeometryCollection") {
+ else if (type == "GeometryCollection") {
return readGeometryCollection(j);
- } else {
+ else {
throw ParseException{"Unknown geometry type!"};
geom::Coordinate GeoJSONReader::readCoordinate(
- const std::vector<double>& coords) const {
+ const std::vector<double>& coords) const
if (coords.size() == 1) {
throw ParseException("Expected two coordinates found one");
- } else if (coords.size() > 2) {
+ else if (coords.size() > 2) {
throw ParseException("Expected two coordinates found more than two");
- } else {
+ else {
return geom::Coordinate {coords[0], coords[1]};
std::unique_ptr<geom::Point> GeoJSONReader::readPoint(
- const auto &coords = j["coordinates"].get<std::vector<double>>();
+ const auto& coords = j["coordinates"].get<std::vector<double>>();
- } else if (coords.size() < 2) {
+ else if (coords.size() < 2) {
return geometryFactory.createPoint(2);
- } else {
+ else {
const geom::Coordinate& coord = readCoordinate(coords);
return std::unique_ptr<geom::Point>(geometryFactory.createPoint(coord));
std::unique_ptr<geom::LineString> GeoJSONReader::readLineString(
- const auto &coords = j["coordinates"].get<std::vector<std::vector<double>>>();
+ const auto& coords = j["coordinates"].get<std::vector<std::vector<double>>>();
std::vector<geom::Coordinate> coordinates;
coordinates.reserve(coords.size());
- for(const auto& coord : coords) {
+ for (const auto& coord : coords) {
const geom::Coordinate& c = readCoordinate(coord);
coordinates.push_back(c);
@@ -211,17 +245,19 @@ std::unique_ptr<geom::LineString> GeoJSONReader::readLineString(
std::unique_ptr<geom::Polygon> GeoJSONReader::readPolygon(
- const geos_nlohmann::json& json) const {
+ const geos_nlohmann::json& json) const
const auto& polygonCoords = json["coordinates"].get<std::vector<std::vector<std::vector<double>>>>();
return readPolygon(polygonCoords);
- const std::vector<std::vector<std::vector<double>>>& polygonCoords) const {
+ const std::vector<std::vector<std::vector<double>>>& polygonCoords) const
std::unique_ptr<geom::LinearRing> shell;
std::vector<std::unique_ptr<geom::LinearRing>> rings;
rings.reserve(polygonCoords.size());
- for(const auto& ring : polygonCoords) {
+ for (const auto& ring : polygonCoords) {
coordinates.reserve(ring.size());
for (const auto& coord : ring) {
@@ -231,25 +267,29 @@ std::unique_ptr<geom::Polygon> GeoJSONReader::readPolygon(
auto coordinateSequence = geometryFactory.getCoordinateSequenceFactory()->create(std::move(coordinates));
if (!shell) {
shell = geometryFactory.createLinearRing(std::move(coordinateSequence));
- } else {
+ else {
rings.push_back(geometryFactory.createLinearRing(std::move(coordinateSequence)));
if (!shell) {
return geometryFactory.createPolygon(2);
- } else if (rings.size() == 0) {
+ else if (rings.size() == 0) {
return geometryFactory.createPolygon(std::move(shell));
- } else {
+ else {
return geometryFactory.createPolygon(std::move(shell), std::move(rings));
std::unique_ptr<geom::MultiPoint> GeoJSONReader::readMultiPoint(
std::vector<std::unique_ptr<geom::Point>> points;
points.reserve(coords.size());
points.push_back(std::unique_ptr<geom::Point>(geometryFactory.createPoint(c)));
@@ -257,11 +297,12 @@ std::unique_ptr<geom::MultiPoint> GeoJSONReader::readMultiPoint(
std::unique_ptr<geom::MultiLineString> GeoJSONReader::readMultiLineString(
- const auto &listOfCoords = json["coordinates"].get<std::vector<std::vector<std::vector<double>>>>();
+ const auto& listOfCoords = json["coordinates"].get<std::vector<std::vector<std::vector<double>>>>();
std::vector<std::unique_ptr<geom::LineString>> lines;
lines.reserve(listOfCoords.size());
- for(const auto& coords : listOfCoords) {
+ for (const auto& coords : listOfCoords) {
@@ -275,18 +316,20 @@ std::unique_ptr<geom::MultiLineString> GeoJSONReader::readMultiLineString(
std::unique_ptr<geom::MultiPolygon> GeoJSONReader::readMultiPolygon(
- const auto &multiPolygonCoords = json["coordinates"].get<std::vector<std::vector<std::vector<std::vector<double>>>>>();
+ const auto& multiPolygonCoords = json["coordinates"].get<std::vector<std::vector<std::vector<std::vector<double>>>>>();
std::vector<std::unique_ptr<geom::Polygon>> polygons;
polygons.reserve(multiPolygonCoords.size());
- for(const auto& polygonCoords : multiPolygonCoords) {
+ for (const auto& polygonCoords : multiPolygonCoords) {
polygons.push_back(readPolygon(polygonCoords));
return geometryFactory.createMultiPolygon(std::move(polygons));
std::unique_ptr<geom::GeometryCollection> GeoJSONReader::readGeometryCollection(
const auto& jsonGeometries = j["geometries"];
geometries.reserve(jsonGeometries.size());
diff --git a/src/io/GeoJSONWriter.cpp b/src/io/GeoJSONWriter.cpp
index 807f0fe..c35f3a3 100644
--- a/src/io/GeoJSONWriter.cpp
+++ b/src/io/GeoJSONWriter.cpp
@@ -39,58 +39,72 @@ using json = geos_nlohmann::ordered_json;
namespace geos {
-std::string GeoJSONWriter::write(const geom::Geometry* geometry, GeoJSONType type) {
+std::string GeoJSONWriter::write(const geom::Geometry* geometry, GeoJSONType type)
json j;
encode(geometry, type, j);
const std::string& geojson = j.dump();
return geojson;
-std::string GeoJSONWriter::writeFormatted(const geom::Geometry* geometry, GeoJSONType type, int indent) {
+std::string GeoJSONWriter::writeFormatted(const geom::Geometry* geometry, GeoJSONType type, int indent)
json j;
const std::string& geojson = j.dump(indent);
return geojson;
-std::string GeoJSONWriter::write(const GeoJSONFeature& feature) {
+std::string GeoJSONWriter::write(const GeoJSONFeature& feature)
json j;
encodeFeature(feature, j);
return geojson;
-void GeoJSONWriter::encodeGeoJSONValue(const std::string& key, const GeoJSONValue& value, geos_nlohmann::ordered_json& j) {
+void GeoJSONWriter::encodeGeoJSONValue(const std::string& key, const GeoJSONValue& value,
+ geos_nlohmann::ordered_json& j)
if (value.isNumber()) {
if (j.is_object()) {
j[key] = value.getNumber();
- } else {
+ else {
j.push_back(value.getNumber());
- } else if (value.isString()) {
+ else if (value.isString()) {
j[key] = value.getString();
- } else {
+ else {
j.push_back(value.getString());
- } else if (value.isBoolean()) {
+ else if (value.isBoolean()) {
j[key] = value.getBoolean();
- } else {
+ else {
j.push_back(value.getBoolean());
- } else if (value.isNull()) {
+ else if (value.isNull()) {
j[key] = nullptr;
- } else {
+ else {
j.push_back(nullptr);
- } else if (value.isArray()) {
+ else if (value.isArray()) {
j[key] = json::array();
for (const GeoJSONValue& v : value.getArray()) {
encodeGeoJSONValue("", v, j[key]);
- } else if (value.isObject()) {
+ else if (value.isObject()) {
j[key] = json::object();
for (const auto& entry : value.getObject()) {
encodeGeoJSONValue(entry.first, entry.second, j[key]);
@@ -98,11 +112,12 @@ void GeoJSONWriter::encodeGeoJSONValue(const std::string& key, const GeoJSONValu
-std::string GeoJSONWriter::write(const GeoJSONFeatureCollection& features) {
+std::string GeoJSONWriter::write(const GeoJSONFeatureCollection& features)
json j;
j["type"] = "FeatureCollection";
json featuresJson = json::array();
- for(auto const& feature : features.getFeatures()) {
+ for (auto const& feature : features.getFeatures()) {
json featureJson;
encodeFeature(feature, featureJson);
featuresJson.push_back(featureJson);
@@ -112,13 +127,14 @@ std::string GeoJSONWriter::write(const GeoJSONFeatureCollection& features) {
return geojson;
-void GeoJSONWriter::encodeFeature(const GeoJSONFeature& feature, geos_nlohmann::ordered_json& j) {
+void GeoJSONWriter::encodeFeature(const GeoJSONFeature& feature, geos_nlohmann::ordered_json& j)
j["type"] = "Feature";
json geometryJson;
encodeGeometry(feature.getGeometry(), geometryJson);
j["geometry"] = geometryJson;
json propertiesJson = json::object();
- for(auto const& property : feature.getProperties()) {
+ for (auto const& property : feature.getProperties()) {
std::string key = property.first;
GeoJSONValue value = property.second;
encodeGeoJSONValue(key, value, propertiesJson);
@@ -126,24 +142,29 @@ void GeoJSONWriter::encodeFeature(const GeoJSONFeature& feature, geos_nlohmann::
j["properties"] = propertiesJson;
-void GeoJSONWriter::encode(const geom::Geometry* geometry, GeoJSONType geojsonType, geos_nlohmann::ordered_json& j) {
- if(geojsonType == GeoJSONType::GEOMETRY) {
+void GeoJSONWriter::encode(const geom::Geometry* geometry, GeoJSONType geojsonType, geos_nlohmann::ordered_json& j)
+ if (geojsonType == GeoJSONType::GEOMETRY) {
encodeGeometry(geometry, j);
- } else if (geojsonType == GeoJSONType::FEATURE) {
+ else if (geojsonType == GeoJSONType::FEATURE) {
encodeFeature(geometry, j);
- } else if (geojsonType == GeoJSONType::FEATURE_COLLECTION) {
+ else if (geojsonType == GeoJSONType::FEATURE_COLLECTION) {
encodeFeatureCollection(geometry, j);
-void GeoJSONWriter::encodeFeature(const geom::Geometry* g, geos_nlohmann::ordered_json& j) {
+void GeoJSONWriter::encodeFeature(const geom::Geometry* g, geos_nlohmann::ordered_json& j)
json geometryJson;
encodeGeometry(g, geometryJson);
-void GeoJSONWriter::encodeFeatureCollection(const geom::Geometry* g, geos_nlohmann::ordered_json& j) {
+void GeoJSONWriter::encodeFeatureCollection(const geom::Geometry* g, geos_nlohmann::ordered_json& j)
json featureJson;
encodeFeature(g, featureJson);
std::vector<json> features;
@@ -152,79 +173,92 @@ void GeoJSONWriter::encodeFeatureCollection(const geom::Geometry* g, geos_nlohma
j["features"] = features;
-void GeoJSONWriter::encodeGeometry(const geom::Geometry* geometry, geos_nlohmann::ordered_json& j) {
+void GeoJSONWriter::encodeGeometry(const geom::Geometry* geometry, geos_nlohmann::ordered_json& j)
auto type = geometry->getGeometryTypeId();
if (type == GEOS_POINT) {
auto point = static_cast<const geom::Point*>(geometry);
encodePoint(point, j);
- } else if (type == GEOS_LINESTRING) {
+ else if (type == GEOS_LINESTRING) {
auto line = static_cast<const geom::LineString*>(geometry);
encodeLineString(line, j);
- } else if (type == GEOS_POLYGON) {
+ else if (type == GEOS_POLYGON) {
auto poly = static_cast<const geom::Polygon*>(geometry);
encodePolygon(poly, j);
- } else if (type == GEOS_MULTIPOINT) {
+ else if (type == GEOS_MULTIPOINT) {
auto multiPoint = static_cast<const geom::MultiPoint*>(geometry);
encodeMultiPoint(multiPoint, j);
- } else if (type == GEOS_MULTILINESTRING) {
+ else if (type == GEOS_MULTILINESTRING) {
auto multiLineString = static_cast<const geom::MultiLineString*>(geometry);
encodeMultiLineString(multiLineString, j);
- } else if (type == GEOS_MULTIPOLYGON) {
+ else if (type == GEOS_MULTIPOLYGON) {
auto multiPolygon = static_cast<const geom::MultiPolygon*>(geometry);
encodeMultiPolygon(multiPolygon, j);
- } else if (type == GEOS_GEOMETRYCOLLECTION) {
+ else if (type == GEOS_GEOMETRYCOLLECTION) {
auto geometryCollection = static_cast<const geom::GeometryCollection*>(geometry);
encodeGeometryCollection(geometryCollection, j);
-void GeoJSONWriter::encodePoint(const geom::Point* point, geos_nlohmann::ordered_json& j) {
+void GeoJSONWriter::encodePoint(const geom::Point* point, geos_nlohmann::ordered_json& j)
j["type"] = "Point";
j["coordinates"] = convertCoordinate(point->getCoordinate());
-void GeoJSONWriter::encodeLineString(const geom::LineString* line, geos_nlohmann::ordered_json& j) {
+void GeoJSONWriter::encodeLineString(const geom::LineString* line, geos_nlohmann::ordered_json& j)
j["type"] = "LineString";
j["coordinates"] = convertCoordinateSequence(line->getCoordinates().get());
-void GeoJSONWriter::encodePolygon(const geom::Polygon* poly, geos_nlohmann::ordered_json& j) {
+void GeoJSONWriter::encodePolygon(const geom::Polygon* poly, geos_nlohmann::ordered_json& j)
j["type"] = "Polygon";
std::vector<std::vector<std::pair<double, double>>> rings;
auto ring = poly->getExteriorRing();
auto coords = ring->getCoordinates();
rings.push_back(convertCoordinateSequence(ring->getCoordinates().get()));
- for(size_t i = 0; i < poly->getNumInteriorRing(); i++) {
+ for (size_t i = 0; i < poly->getNumInteriorRing(); i++) {
rings.push_back(convertCoordinateSequence(poly->getInteriorRingN(i)->getCoordinates().get()));
j["coordinates"] = rings;
-void GeoJSONWriter::encodeMultiPoint(const geom::MultiPoint* multiPoint, geos_nlohmann::ordered_json& j) {
+void GeoJSONWriter::encodeMultiPoint(const geom::MultiPoint* multiPoint, geos_nlohmann::ordered_json& j)
j["type"] = "MultiPoint";
j["coordinates"] = convertCoordinateSequence(multiPoint->getCoordinates().get());
-void GeoJSONWriter::encodeMultiLineString(const geom::MultiLineString* multiLineString, geos_nlohmann::ordered_json& j) {
+void GeoJSONWriter::encodeMultiLineString(const geom::MultiLineString* multiLineString, geos_nlohmann::ordered_json& j)
j["type"] = "MultiLineString";
std::vector<std::vector<std::pair<double, double>>> lines;
- for(size_t i = 0; i < multiLineString->getNumGeometries(); i++) {
+ for (size_t i = 0; i < multiLineString->getNumGeometries(); i++) {
lines.push_back(convertCoordinateSequence(multiLineString->getGeometryN(i)->getCoordinates().get()));
j["coordinates"] = lines;
-void GeoJSONWriter::encodeMultiPolygon(const geom::MultiPolygon* multiPolygon, geos_nlohmann::ordered_json& json) {
+void GeoJSONWriter::encodeMultiPolygon(const geom::MultiPolygon* multiPolygon, geos_nlohmann::ordered_json& json)
json["type"] = "MultiPolygon";
std::vector<std::vector<std::vector<std::pair<double, double>>>> polygons;
polygons.reserve(multiPolygon->getNumGeometries());
- for(size_t i = 0; i < multiPolygon->getNumGeometries(); i++) {
+ for (size_t i = 0; i < multiPolygon->getNumGeometries(); i++) {
const Polygon* polygon = multiPolygon->getGeometryN(i);
auto ring = polygon->getExteriorRing();
- for(size_t j = 0; j < polygon->getNumInteriorRing(); j++) {
+ for (size_t j = 0; j < polygon->getNumInteriorRing(); j++) {
rings.push_back(convertCoordinateSequence(polygon->getInteriorRingN(i)->getCoordinates().get()));
polygons.push_back(rings);
@@ -232,10 +266,11 @@ void GeoJSONWriter::encodeMultiPolygon(const geom::MultiPolygon* multiPolygon, g
json["coordinates"] = polygons;
-void GeoJSONWriter::encodeGeometryCollection(const geom::GeometryCollection* g, geos_nlohmann::ordered_json& j) {
+void GeoJSONWriter::encodeGeometryCollection(const geom::GeometryCollection* g, geos_nlohmann::ordered_json& j)
j["type"] = "GeometryCollection";
auto geometryArray = j.array();
- for(size_t i = 0; i < g->getNumGeometries(); i++) {
+ for (size_t i = 0; i < g->getNumGeometries(); i++) {
auto geometryObj = j.object();
encodeGeometry(g->getGeometryN(i), geometryObj);
geometryArray.push_back(geometryObj);
@@ -243,14 +278,17 @@ void GeoJSONWriter::encodeGeometryCollection(const geom::GeometryCollection* g,
j["geometries"] = geometryArray;
-std::pair<double, double> GeoJSONWriter::convertCoordinate(const Coordinate* c) {
- return std::make_pair(c->x,c->y);
+std::pair<double, double> GeoJSONWriter::convertCoordinate(const Coordinate* c)
+ return std::make_pair(c->x, c->y);
-std::vector<std::pair<double, double>> GeoJSONWriter::convertCoordinateSequence(const CoordinateSequence* coordinateSequence) {
+std::vector<std::pair<double, double>> GeoJSONWriter::convertCoordinateSequence(const CoordinateSequence*
+ coordinateSequence)
std::vector<std::pair<double, double>> coordinates;
coordinates.reserve(coordinateSequence->size());
- for(size_t i = 0; i<coordinateSequence->size(); i++) {
+ for (size_t i = 0; i<coordinateSequence->size(); i++) {
const geom::Coordinate& c = coordinateSequence->getAt(i);
coordinates.push_back(convertCoordinate(&c));
commit 5a0c4cdb39241c8b520c0045b4ea7da808a0cf77
Date: Sun Jul 11 23:41:17 2021 +0800
Modify GeoJSON module
index 14989e5..cd54c6d 100644
@@ -41,87 +41,95 @@ namespace io {
class GEOS_DLL GeoJSONValue {
- private:
- enum class Type { NUMBER, STRING, NULLTYPE, BOOLEAN, OBJECT, ARRAY };
- Type type;
- union {
- double d;
- std::string s;
- std::nullptr_t n;
- bool b;
- std::map<std::string, GeoJSONValue> o;
- std::vector<GeoJSONValue> a;
- void cleanup();
- public:
- struct GeoJSONTypeError {};
- GeoJSONValue(double);
- GeoJSONValue(const std::string&);
- GeoJSONValue();
- GeoJSONValue(bool);
- GeoJSONValue(const std::map<std::string, GeoJSONValue>&);
- GeoJSONValue(const std::vector<GeoJSONValue>&);
- ~GeoJSONValue();
- GeoJSONValue(const GeoJSONValue&);
- GeoJSONValue& operator=(const GeoJSONValue&);
- double getNumber() const;
- const std::string& getString() const;
- std::nullptr_t getNull() const;
- bool getBoolean() const;
- const std::vector<GeoJSONValue>& getArray() const;
- bool isNumber() const;
- bool isString() const;
- bool isNull() const;
- bool isBoolean() const;
- bool isObject() const;
- bool isArray() const;
+private:
+ enum class Type { NUMBER, STRING, NULLTYPE, BOOLEAN, OBJECT, ARRAY };
+ Type type;
+ union {
+ double d;
+ std::string s;
+ std::nullptr_t n;
+ bool b;
+ std::map<std::string, GeoJSONValue> o;
+ std::vector<GeoJSONValue> a;
+ void cleanup();
+public:
+ struct GeoJSONTypeError {};
+ GeoJSONValue(double);
+ GeoJSONValue(const std::string&);
+ GeoJSONValue();
+ GeoJSONValue(bool);
+ GeoJSONValue(const std::map<std::string, GeoJSONValue>&);
+ GeoJSONValue(const std::vector<GeoJSONValue>&);
+ ~GeoJSONValue();
+ GeoJSONValue(const GeoJSONValue&);
+ GeoJSONValue& operator=(const GeoJSONValue&);
+ double getNumber() const;
+ const std::string& getString() const;
+ std::nullptr_t getNull() const;
+ bool getBoolean() const;
+ const std::map<std::string,GeoJSONValue>& getObject() const;
+ const std::vector<GeoJSONValue>& getArray() const;
+ bool isNumber() const;
+ bool isString() const;
+ bool isNull() const;
+ bool isBoolean() const;
+ bool isObject() const;
+ bool isArray() const;
- public:
+public:
+ GeoJSONFeature(std::unique_ptr<geom::Geometry> g, const std::map<std::string, GeoJSONValue> &p);
- GeoJSONFeature(std::unique_ptr<geom::Geometry> g, std::map<std::string, GeoJSONValue> p);
+ GeoJSONFeature(std::unique_ptr<geom::Geometry> g, std::map<std::string, GeoJSONValue>&& p);
+ GeoJSONFeature(GeoJSONFeature const &other);
- GeoJSONFeature& operator=(const GeoJSONFeature&);
+ GeoJSONFeature(GeoJSONFeature && other);
- const geom::Geometry* getGeometry() const;
+ GeoJSONFeature& operator=(const GeoJSONFeature&);
- const std::map<std::string, GeoJSONValue>& getProperties() const;
+ GeoJSONFeature& operator=(GeoJSONFeature &&);
- private:
+ const geom::Geometry* getGeometry() const;
- std::unique_ptr<geom::Geometry> geometry;
+ const std::map<std::string, GeoJSONValue>& getProperties() const;
- std::map<std::string, GeoJSONValue> properties;
+private:
+ std::unique_ptr<geom::Geometry> geometry;
+ std::map<std::string, GeoJSONValue> properties;
- public:
+public:
+ GeoJSONFeatureCollection(const std::vector<GeoJSONFeature> &f);
- GeoJSONFeatureCollection(std::vector<GeoJSONFeature> f);
+ GeoJSONFeatureCollection(std::vector<GeoJSONFeature>&& f);
- const std::vector<GeoJSONFeature>& getFeatures() const;
+ const std::vector<GeoJSONFeature>& getFeatures() const;
- private:
+private:
- std::vector<GeoJSONFeature> features;
+ std::vector<GeoJSONFeature> features;
diff --git a/include/geos/io/GeoJSONReader.h b/include/geos/io/GeoJSONReader.h
index 612e98f..65ea159 100644
--- a/include/geos/io/GeoJSONReader.h
+++ b/include/geos/io/GeoJSONReader.h
@@ -69,45 +69,55 @@ public:
~GeoJSONReader() = default;
/// Parse a GeoJSON string returning a Geometry
- std::unique_ptr<geom::Geometry> read(const std::string& geoJsonText);
+ std::unique_ptr<geom::Geometry> read(const std::string& geoJsonText) const;
- GeoJSONFeatureCollection readFeatures(const std::string& geoJsonText);
+ GeoJSONFeatureCollection readFeatures(const std::string& geoJsonText) const;
private:
const geom::GeometryFactory& geometryFactory;
- std::unique_ptr<geom::Geometry> readFeatureForGeometry(const geos_nlohmann::json& j);
+ std::unique_ptr<geom::Geometry> readFeatureForGeometry(const geos_nlohmann::json& j) const;
- GeoJSONFeature readFeature(const geos_nlohmann::json& j);
+ GeoJSONFeature readFeature(const geos_nlohmann::json& j) const;
- std::map<std::string,GeoJSONValue> readProperties(const geos_nlohmann::json& p);
+ std::map<std::string, GeoJSONValue> readProperties(const geos_nlohmann::json& p) const;
- GeoJSONValue readProperty(const geos_nlohmann::json& p);
+ GeoJSONValue readProperty(const geos_nlohmann::json& p) const;
- std::unique_ptr<geom::Geometry> readFeatureCollectionForGeometry(const geos_nlohmann::json& j);
+ std::unique_ptr<geom::Geometry> readFeatureCollectionForGeometry(
+ const geos_nlohmann::json& j) const;
- GeoJSONFeatureCollection readFeatureCollection(const geos_nlohmann::json& j);
+ GeoJSONFeatureCollection readFeatureCollection(
- std::unique_ptr<geom::Geometry> readGeometry(const geos_nlohmann::json& j);
+ std::unique_ptr<geom::Geometry> readGeometry(
- std::unique_ptr<geom::Point> readPoint(const geos_nlohmann::json& j);
+ std::unique_ptr<geom::Point> readPoint(const geos_nlohmann::json& j) const;
- geom::Coordinate readCoordinate(const std::vector<double>& coords);
+ geom::Coordinate readCoordinate(const std::vector<double>& coords) const;
- std::unique_ptr<geom::LineString> readLineString(const geos_nlohmann::json& j);
+ std::unique_ptr<geom::LineString> readLineString(
- std::unique_ptr<geom::Polygon> readPolygon(const geos_nlohmann::json& j);
+ std::unique_ptr<geom::Polygon> readPolygon(
- std::unique_ptr<geom::Polygon> readPolygon(const std::vector<std::vector<std::vector<double>>>& c);
+ const std::vector<std::vector<std::vector<double>>>& c) const;
- std::unique_ptr<geom::MultiPoint> readMultiPoint(const geos_nlohmann::json& j);
+ std::unique_ptr<geom::MultiPoint> readMultiPoint(
- std::unique_ptr<geom::MultiLineString> readMultiLineString(const geos_nlohmann::json& j);
+ std::unique_ptr<geom::MultiLineString> readMultiLineString(
- std::unique_ptr<geom::MultiPolygon> readMultiPolygon(const geos_nlohmann::json& j);
+ std::unique_ptr<geom::MultiPolygon> readMultiPolygon(
- std::unique_ptr<geom::GeometryCollection> readGeometryCollection(const geos_nlohmann::json& j);
+ std::unique_ptr<geom::GeometryCollection> readGeometryCollection(
diff --git a/include/geos/io/GeoJSONWriter.h b/include/geos/io/GeoJSONWriter.h
index dcd283f..f8e2ec7 100644
--- a/include/geos/io/GeoJSONWriter.h
+++ b/include/geos/io/GeoJSONWriter.h
@@ -65,7 +65,6 @@ enum class GeoJSONType {
class GEOS_DLL GeoJSONWriter {
public:
~GeoJSONWriter() = default;
std::string write(const geom::Geometry* geometry, GeoJSONType type = GeoJSONType::GEOMETRY);
index 38b4cdf..086799d 100644
@@ -41,12 +41,13 @@ GeoJSONValue::GeoJSONValue(bool value) {
- new(&o) std::map<std::string, GeoJSONValue>{value};
+ new(&o) std::map<std::string, GeoJSONValue> {value};
type = Type::ARRAY;
- new(&a) std::vector<GeoJSONValue>{};
+ new(&a) std::vector<GeoJSONValue> {};
+ a.reserve(value.size());
a.push_back(v);
@@ -60,7 +61,7 @@ void GeoJSONValue::cleanup() {
s.~string();
o.~object();
+ } else if (type == Type::ARRAY) {
a.~array();
@@ -71,27 +72,28 @@ GeoJSONValue::~GeoJSONValue() {
switch(v.type) {
- case Type::NUMBER:
- d = v.d;
- break;
- case Type::BOOLEAN:
- b = v.b;
- break;
- case Type::STRING:
- break;
- case Type::NULLTYPE:
- n = v.n;
- break;
- case Type::OBJECT:
- new(&o) std::map<std::string, GeoJSONValue>{v.o};
- break;
- case Type::ARRAY:
- a.push_back(i);
- break;
+ case Type::NUMBER:
+ d = v.d;
+ break;
+ case Type::BOOLEAN:
+ b = v.b;
+ break;
+ case Type::STRING:
+ new(&s) std::string{v.s};
+ break;
+ case Type::NULLTYPE:
+ n = v.n;
+ break;
+ case Type::OBJECT:
+ new(&o) std::map<std::string, GeoJSONValue> {v.o};
+ break;
+ case Type::ARRAY:
+ a.reserve(v.a.size());
+ for(const auto& i : v.a) {
+ a.push_back(i);
+ break;
type = v.type;
@@ -106,32 +108,33 @@ GeoJSONValue& GeoJSONValue::operator=(const GeoJSONValue& v) {
a = v.a;
return *this;
cleanup();
switch(v.type) {
- d = v.d;
- break;
- b = v.b;
- break;
- break;
- n = v.n;
- break;
- break;
- case Type::ARRAY:
- a.push_back(i);
- break;
+ d = v.d;
+ break;
+ b = v.b;
+ break;
+ break;
+ n = v.n;
+ break;
+ break;
+ case Type::ARRAY:
+ a.push_back(i);
+ break;
type = v.type;
return *this;
@@ -194,10 +197,14 @@ bool GeoJSONValue::isArray() const {
// GeoJSONFeature
-GeoJSONFeature::GeoJSONFeature(std::unique_ptr<geom::Geometry> g, std::map<std::string, GeoJSONValue> p) : geometry(std::move(g)), properties(p) {}
+GeoJSONFeature::GeoJSONFeature(std::unique_ptr<geom::Geometry> g, const std::map<std::string, GeoJSONValue>& p) : geometry(std::move(g)), properties(p) {}
+GeoJSONFeature::GeoJSONFeature(std::unique_ptr<geom::Geometry> g, std::map<std::string, GeoJSONValue>&& p) : geometry(std::move(g)), properties(std::move(p)) {}
+GeoJSONFeature::GeoJSONFeature(GeoJSONFeature && other) : geometry(std::move(other.geometry)), properties(std::move(other.properties)) {}
return *this;
@@ -207,6 +214,12 @@ GeoJSONFeature& GeoJSONFeature::operator=(const GeoJSONFeature& other) {
return *this;
+GeoJSONFeature& GeoJSONFeature::operator=(GeoJSONFeature&& other) {
+ geometry = std::move(other.geometry);
+ properties = std::move(other.properties);
+ return *this;
@@ -217,7 +230,9 @@ const std::map<std::string, GeoJSONValue>& GeoJSONFeature::getProperties() const
-GeoJSONFeatureCollection::GeoJSONFeatureCollection(std::vector<GeoJSONFeature> f) : features(f) {}
+GeoJSONFeatureCollection::GeoJSONFeatureCollection(const std::vector<GeoJSONFeature> &f) : features(f) {}
+GeoJSONFeatureCollection::GeoJSONFeatureCollection(std::vector<GeoJSONFeature>&& f) : features(std::move(f)) {}
return features;
index ae015c7..70aeefa 100644
@@ -45,31 +45,31 @@ GeoJSONReader::GeoJSONReader(): GeoJSONReader(*(GeometryFactory::getDefaultInsta
-std::unique_ptr<geom::Geometry> GeoJSONReader::read(const std::string& geoJsonText) {
+std::unique_ptr<geom::Geometry> GeoJSONReader::read(const std::string& geoJsonText) const {
try {
- json j = json::parse(geoJsonText);
- std::string type = j["type"];
+ const json& j = json::parse(geoJsonText);
- return readFeatureForGeometry(j);
+ return readFeatureForGeometry(j);
- return readFeatureCollectionForGeometry(j);
+ return readFeatureCollectionForGeometry(j);
} else {
-GeoJSONFeatureCollection GeoJSONReader::readFeatures(const std::string& geoJsonText) {
+GeoJSONFeatureCollection GeoJSONReader::readFeatures(const std::string& geoJsonText) const {
try {
- auto feature = readFeature(j);
+ const auto& feature = readFeature(j);
- return readFeatureCollection(j);
+ return readFeatureCollection(j);
} else {
@@ -79,22 +79,21 @@ GeoJSONFeatureCollection GeoJSONReader::readFeatures(const std::string& geoJsonT
-std::unique_ptr<geom::Geometry> GeoJSONReader::readFeatureForGeometry(const geos_nlohmann::json& j) {
- auto geometryJson = j["geometry"];
+std::unique_ptr<geom::Geometry> GeoJSONReader::readFeatureForGeometry(
+ const geos_nlohmann::json& j) const {
+ const auto& geometryJson = j["geometry"];
return geometry;
-GeoJSONFeature GeoJSONReader::readFeature(const geos_nlohmann::json& j) {
- auto geometry = readGeometry(geometryJson);
- auto properties = j["properties"];
- std::map<std::string,GeoJSONValue> map = readProperties(properties);
- GeoJSONFeature f = GeoJSONFeature{ std::move(geometry), std::move(map) };
- return f;
+GeoJSONFeature GeoJSONReader::readFeature(const geos_nlohmann::json& j) const {
+ const auto& properties = j["properties"];
+ return GeoJSONFeature{readGeometry(geometryJson), readProperties(properties)};
-std::map<std::string,GeoJSONValue> GeoJSONReader::readProperties(const geos_nlohmann::json& p) {
+std::map<std::string, GeoJSONValue> GeoJSONReader::readProperties(
+ const geos_nlohmann::json& p) const {
@@ -102,7 +101,8 @@ std::map<std::string,GeoJSONValue> GeoJSONReader::readProperties(const geos_nloh
return map;
-GeoJSONValue GeoJSONReader::readProperty(const geos_nlohmann::json& value) {
+GeoJSONValue GeoJSONReader::readProperty(
+ const geos_nlohmann::json& value) const {
@@ -111,15 +111,15 @@ GeoJSONValue GeoJSONReader::readProperty(const geos_nlohmann::json& value) {
+ v.reserve(value.size());
- const GeoJSONValue item = readProperty(el.value());
- v.push_back(item);
+ v.push_back(readProperty(el.value()));
- v[el.key()] = readProperty(el.value());
+ v[el.key()] = std::move(readProperty(el.value()));
} else {
@@ -127,9 +127,11 @@ GeoJSONValue GeoJSONReader::readProperty(const geos_nlohmann::json& value) {
-std::unique_ptr<geom::Geometry> GeoJSONReader::readFeatureCollectionForGeometry(const geos_nlohmann::json& j) {
- auto featuresJson = j["features"];
+std::unique_ptr<geom::Geometry> GeoJSONReader::readFeatureCollectionForGeometry(
+ const auto &featuresJson = j["features"];
+ geometries.reserve(featuresJson.size());
@@ -137,19 +139,21 @@ std::unique_ptr<geom::Geometry> GeoJSONReader::readFeatureCollectionForGeometry(
return geometryFactory.createGeometryCollection(std::move(geometries));
-GeoJSONFeatureCollection GeoJSONReader::readFeatureCollection(const geos_nlohmann::json& j) {
+GeoJSONFeatureCollection GeoJSONReader::readFeatureCollection(
+ const auto & featuresJson = j["features"];
+ features.reserve(featuresJson.size());
- auto f = readFeature(featureJson);
- features.push_back(f);
+ features.push_back(readFeature(featureJson));
- return GeoJSONFeatureCollection{features};
+ return GeoJSONFeatureCollection{std::move(features)};
-std::unique_ptr<geom::Geometry> GeoJSONReader::readGeometry(const geos_nlohmann::json& j) {
+std::unique_ptr<geom::Geometry> GeoJSONReader::readGeometry(
+ const std::string & type = j["type"];
@@ -169,7 +173,8 @@ std::unique_ptr<geom::Geometry> GeoJSONReader::readGeometry(const geos_nlohmann:
-geom::Coordinate GeoJSONReader::readCoordinate(const std::vector<double>& coords) {
+geom::Coordinate GeoJSONReader::readCoordinate(
+ const std::vector<double>& coords) const {
@@ -179,42 +184,49 @@ geom::Coordinate GeoJSONReader::readCoordinate(const std::vector<double>& coords
-std::unique_ptr<geom::Point> GeoJSONReader::readPoint(const geos_nlohmann::json& j) {
- auto coords = j["coordinates"].get<std::vector<double>>();
+std::unique_ptr<geom::Point> GeoJSONReader::readPoint(
+ const auto &coords = j["coordinates"].get<std::vector<double>>();
} else {
- geom::Coordinate coord = readCoordinate(coords);
+ const geom::Coordinate& coord = readCoordinate(coords);
-std::unique_ptr<geom::LineString> GeoJSONReader::readLineString(const geos_nlohmann::json& j) {
- auto coords = j["coordinates"].get<std::vector<std::vector<double>>>();
+std::unique_ptr<geom::LineString> GeoJSONReader::readLineString(
+ const auto &coords = j["coordinates"].get<std::vector<std::vector<double>>>();
+ coordinates.reserve(coords.size());
- geom::Coordinate c = readCoordinate(coord);
- coordinates.push_back(geom::Coordinate{c.x,c.y});
+ const geom::Coordinate& c = readCoordinate(coord);
+ coordinates.push_back(c);
return geometryFactory.createLineString(std::move(coordinateSequence));
-std::unique_ptr<geom::Polygon> GeoJSONReader::readPolygon(const geos_nlohmann::json& json) {
- auto polygonCoords = json["coordinates"].get<std::vector<std::vector<std::vector<double>>>>();
+std::unique_ptr<geom::Polygon> GeoJSONReader::readPolygon(
+ const geos_nlohmann::json& json) const {
+ const auto& polygonCoords = json["coordinates"].get<std::vector<std::vector<std::vector<double>>>>();
-std::unique_ptr<geom::Polygon> GeoJSONReader::readPolygon(const std::vector<std::vector<std::vector<double>>>& polygonCoords) {
+ const std::vector<std::vector<std::vector<double>>>& polygonCoords) const {
+ rings.reserve(polygonCoords.size());
+ coordinates.reserve(ring.size());
- coordinates.push_back(geom::Coordinate{c.x, c.y});
if (!shell) {
@@ -228,27 +240,32 @@ std::unique_ptr<geom::Polygon> GeoJSONReader::readPolygon(const std::vector<std:
} else {
- return geometryFactory.createPolygon(std::move(shell), std::move(rings));
+ return geometryFactory.createPolygon(std::move(shell), std::move(rings));
-std::unique_ptr<geom::MultiPoint> GeoJSONReader::readMultiPoint(const geos_nlohmann::json& j) {
+std::unique_ptr<geom::MultiPoint> GeoJSONReader::readMultiPoint(
+ points.reserve(coords.size());
return geometryFactory.createMultiPoint(std::move(points));
-std::unique_ptr<geom::MultiLineString> GeoJSONReader::readMultiLineString(const geos_nlohmann::json& json) {
- auto listOfCoords = json["coordinates"].get<std::vector<std::vector<std::vector<double>>>>();
+std::unique_ptr<geom::MultiLineString> GeoJSONReader::readMultiLineString(
+ const auto &listOfCoords = json["coordinates"].get<std::vector<std::vector<std::vector<double>>>>();
+ lines.reserve(listOfCoords.size());
+ for(const auto& coords : listOfCoords) {
@@ -257,18 +274,22 @@ std::unique_ptr<geom::MultiLineString> GeoJSONReader::readMultiLineString(const
return geometryFactory.createMultiLineString(std::move(lines));
-std::unique_ptr<geom::MultiPolygon> GeoJSONReader::readMultiPolygon(const geos_nlohmann::json& json) {
- auto multiPolygonCoords = json["coordinates"].get<std::vector<std::vector<std::vector<std::vector<double>>>>>();
+std::unique_ptr<geom::MultiPolygon> GeoJSONReader::readMultiPolygon(
+ const auto &multiPolygonCoords = json["coordinates"].get<std::vector<std::vector<std::vector<std::vector<double>>>>>();
+ polygons.reserve(multiPolygonCoords.size());
+ for(const auto& polygonCoords : multiPolygonCoords) {
-std::unique_ptr<geom::GeometryCollection> GeoJSONReader::readGeometryCollection(const geos_nlohmann::json& j) {
+std::unique_ptr<geom::GeometryCollection> GeoJSONReader::readGeometryCollection(
+ const auto& jsonGeometries = j["geometries"];
- auto jsonGeometries = j["geometries"];
+ geometries.reserve(jsonGeometries.size());
for (const auto& jsonGeometry : jsonGeometries) {
auto g = readGeometry(jsonGeometry);
@@ -277,4 +298,4 @@ std::unique_ptr<geom::GeometryCollection> GeoJSONReader::readGeometryCollection(
} // namespace geos.io
-} // namespace geos
\ No newline at end of file
+} // namespace geos
index 64945b7..807f0fe 100644
@@ -42,21 +42,21 @@ namespace io { // geos.io
json j;
- std::string geojson = j.dump();
+ const std::string& geojson = j.dump();
return geojson;
json j;
- std::string geojson = j.dump(indent);
+ const std::string& geojson = j.dump(indent);
return geojson;
json j;
return geojson;
@@ -87,12 +87,12 @@ void GeoJSONWriter::encodeGeoJSONValue(const std::string& key, const GeoJSONValu
- for (GeoJSONValue v : value.getArray()) {
+ for (const GeoJSONValue& v : value.getArray()) {
- for (auto entry : value.getObject()) {
+ for (const auto& entry : value.getObject()) {
@@ -108,7 +108,7 @@ std::string GeoJSONWriter::write(const GeoJSONFeatureCollection& features) {
j["features"] = featuresJson;
return geojson;
@@ -217,6 +217,7 @@ void GeoJSONWriter::encodeMultiLineString(const geom::MultiLineString* multiLine
+ polygons.reserve(multiPolygon->getNumGeometries());
@@ -248,12 +249,13 @@ std::pair<double, double> GeoJSONWriter::convertCoordinate(const Coordinate* c)
+ coordinates.reserve(coordinateSequence->size());
- const geom::Coordinate c = coordinateSequence->getAt(i);
+ const geom::Coordinate& c = coordinateSequence->getAt(i);
return coordinates;
Summary of changes:
include/geos/io/GeoJSON.h | 128 ++++++++++----------
include/geos/io/GeoJSONReader.h | 46 +++++---
include/geos/io/GeoJSONWriter.h | 1 -
src/io/GeoJSON.cpp | 214 +++++++++++++++++++++-------------
src/io/GeoJSONReader.cpp | 250 +++++++++++++++++++++++++---------------
src/io/GeoJSONWriter.cpp | 148 +++++++++++++++---------
6 files changed, 480 insertions(+), 307 deletions(-)
hooks/post-receive
More information about the geos-commits
