[geos-commits] [SCM] GEOS branch main updated. d880957a155d095988ff97060bc1d4ca5643cf90
git at osgeo.org
git at osgeo.org
Tue Jul 13 08:42:19 PDT 2021
the project "GEOS".
The branch, main has been updated
via d880957a155d095988ff97060bc1d4ca5643cf90 (commit)
via 2e49624cb4cad5225806279a26644d38727ae709 (commit)
from 2df86bc1191f578047fb30331cae254486ace191 (commit)
revisions in full, below.
commit d880957a155d095988ff97060bc1d4ca5643cf90
Merge: 2df86bc 2e49624
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jul 13 08:41:26 2021 -0700
Merge branch 'GeoJson' of https://github.com/whuaegeanse/geos into main
commit 2e49624cb4cad5225806279a26644d38727ae709
Author: whuaegeansea <whuaegeansea at gmail.com>
Date: Tue Jul 13 11:11:04 2021 +0800
Fix bug of wrong index in encodeMultiPolygon. Remove unsed variables.
And enhance functions by removing temp const reference before returning.
diff --git a/src/io/GeoJSONWriter.cpp b/src/io/GeoJSONWriter.cpp
index c35f3a3..c8bbab5 100644
--- a/src/io/GeoJSONWriter.cpp
+++ b/src/io/GeoJSONWriter.cpp
@@ -43,24 +43,21 @@ std::string GeoJSONWriter::write(const geom::Geometry* geometry, GeoJSONType typ
json j;
encode(geometry, type, j);
- const std::string& geojson = j.dump();
- return geojson;
+ return j.dump();
std::string GeoJSONWriter::writeFormatted(const geom::Geometry* geometry, GeoJSONType type, int indent)
json j;
- const std::string& geojson = j.dump(indent);
- return geojson;
+ return j.dump(indent);
std::string GeoJSONWriter::write(const GeoJSONFeature& feature)
json j;
encodeFeature(feature, j);
- return geojson;
+ return j.dump();
void GeoJSONWriter::encodeGeoJSONValue(const std::string& key, const GeoJSONValue& value,
@@ -123,8 +120,7 @@ std::string GeoJSONWriter::write(const GeoJSONFeatureCollection& features)
featuresJson.push_back(featureJson);
j["features"] = featuresJson;
- return geojson;
+ return j.dump();
void GeoJSONWriter::encodeFeature(const GeoJSONFeature& feature, geos_nlohmann::ordered_json& j)
@@ -223,7 +219,7 @@ void GeoJSONWriter::encodePolygon(const geom::Polygon* poly, geos_nlohmann::orde
j["type"] = "Polygon";
std::vector<std::vector<std::pair<double, double>>> rings;
auto ring = poly->getExteriorRing();
- auto coords = ring->getCoordinates();
+ rings.reserve(poly->getNumInteriorRing()+1);
rings.push_back(convertCoordinateSequence(ring->getCoordinates().get()));
for (size_t i = 0; i < poly->getNumInteriorRing(); i++) {
rings.push_back(convertCoordinateSequence(poly->getInteriorRingN(i)->getCoordinates().get()));
@@ -241,6 +237,7 @@ void GeoJSONWriter::encodeMultiLineString(const geom::MultiLineString* multiLine
j["type"] = "MultiLineString";
std::vector<std::vector<std::pair<double, double>>> lines;
+ lines.reserve(multiLineString->getNumGeometries());
for (size_t i = 0; i < multiLineString->getNumGeometries(); i++) {
lines.push_back(convertCoordinateSequence(multiLineString->getGeometryN(i)->getCoordinates().get()));
@@ -256,10 +253,10 @@ void GeoJSONWriter::encodeMultiPolygon(const geom::MultiPolygon* multiPolygon, g
const Polygon* polygon = multiPolygon->getGeometryN(i);
auto ring = polygon->getExteriorRing();
+ rings.reserve(polygon->getNumInteriorRing() + 1);
for (size_t j = 0; j < polygon->getNumInteriorRing(); j++) {
- rings.push_back(convertCoordinateSequence(polygon->getInteriorRingN(i)->getCoordinates().get()));
+ rings.push_back(convertCoordinateSequence(polygon->getInteriorRingN(j)->getCoordinates().get()));
polygons.push_back(rings);
Summary of changes:
src/io/GeoJSONWriter.cpp | 19 ++++++++-----------
1 file changed, 8 insertions(+), 11 deletions(-)
hooks/post-receive
More information about the geos-commits
