[geos-commits] [SCM] GEOS branch main updated. 6a5566b0dc79e59984c03ddbd21d7c652e773fc1
Thu Jun 24 14:19:08 PDT 2021
the project "GEOS".
The branch, main has been updated
       via  6a5566b0dc79e59984c03ddbd21d7c652e773fc1 (commit)
       via  c5f9a3ded8f3c2b6d87d6b74b2e95805d96d9b26 (commit)
      from  edd209ae551bda9cdb6188230a1861937153ce79 (commit)
revisions in full, below.
commit 6a5566b0dc79e59984c03ddbd21d7c652e773fc1
Merge: edd209a c5f9a3d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jun 24 14:18:35 2021 -0700
    Merge branch 'jbronn-heuristicoverlay-debug-disable' into main
commit c5f9a3ded8f3c2b6d87d6b74b2e95805d96d9b26
Author: Justin Bronn <justin.bronn at maxar.com>
Date:   Thu Jun 24 11:56:05 2021 -0600
    Use `#if` instead of `#ifdef` macros for an already defined value, fixes #1116.
diff --git a/src/geom/HeuristicOverlay.cpp b/src/geom/HeuristicOverlay.cpp
index 005221a..361e90f 100644
--- a/src/geom/HeuristicOverlay.cpp
+++ b/src/geom/HeuristicOverlay.cpp
@@ -74,7 +74,7 @@
 #define GEOS_DEBUG_HEURISTICOVERLAY_PRINT_INVALID 0
-#ifdef GEOS_DEBUG_HEURISTICOVERLAY
+#if GEOS_DEBUG_HEURISTICOVERLAY
 # include <iostream>
 # include <iomanip>
 # include <sstream>
@@ -202,13 +202,13 @@ check_valid(const Geometry& g, const std::string& label, bool doThrow = false, b
         if(! ivo.isValid()) {
             using operation::valid::TopologyValidationError;
             TopologyValidationError* err = ivo.getValidationError();
             std::cerr << label << " is INVALID: "
                       << err->toString()
                       << " (" << std::setprecision(20)
                       << err->getCoordinate() << ")"
                       << std::endl
-#ifdef GEOS_DEBUG_HEURISTICOVERLAY_PRINT_INVALID
+#if GEOS_DEBUG_HEURISTICOVERLAY_PRINT_INVALID
                       << "<A>" << std::endl
                       << g.toString()
                       << std::endl
@@ -237,7 +237,7 @@ inline std::unique_ptr<Geometry>
 fix_self_intersections(std::unique_ptr<Geometry> g, const std::string& label)
     ::geos::ignore_unused_variable_warning(label);
     std::cerr << label << " fix_self_intersection (UnaryUnion)" << std::endl;
 #endif
@@ -262,18 +262,18 @@ fix_self_intersections(std::unique_ptr<Geometry> g, const std::string& label)
     switch(err->getErrorType()) {
     case TopologyValidationError::eRingSelfIntersection:
     case TopologyValidationError::eTooFewPoints: // collapsed lines
         std::cerr << label << " ATTEMPT_TO_FIX: " << err->getErrorType() << ": " << *g << std::endl;
 #endif
         g = g->Union();
         std::cerr << label << " ATTEMPT_TO_FIX succeeded.. " << std::endl;
 #endif
         return g;
     case TopologyValidationError::eSelfIntersection:
     // this one is within a single component, won't be fixed
     default:
         std::cerr << label << " invalidity is: " << err->getErrorType() << std::endl;
 #endif
         return g;
Summary of changes:
 src/geom/HeuristicOverlay.cpp | 14 +++++++-------
 1 file changed, 7 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
