[geos-commits] [SCM] GEOS branch 3.9 updated. 3fcdbcfe30d42f814ff00da49a195c8f2298186f
git at osgeo.org
git at osgeo.org
Thu Jun 24 14:31:12 PDT 2021
the project "GEOS".
The branch, 3.9 has been updated
via 3fcdbcfe30d42f814ff00da49a195c8f2298186f (commit)
from d71872bc5a5b9fea27d3d9cf4031953926960af1 (commit)
revisions in full, below.
commit 3fcdbcfe30d42f814ff00da49a195c8f2298186f
Author: Justin Bronn <justin.bronn at maxar.com>
Date: Thu Jun 24 11:56:05 2021 -0600
Use `#if` instead of `#ifdef` macros for an already defined value, fixes #1116.
diff --git a/src/geom/HeuristicOverlay.cpp b/src/geom/HeuristicOverlay.cpp
index 04c4041..bb88002 100644
--- a/src/geom/HeuristicOverlay.cpp
+++ b/src/geom/HeuristicOverlay.cpp
@@ -74,7 +74,7 @@
#define GEOS_DEBUG_HEURISTICOVERLAY_PRINT_INVALID 0
-#ifdef GEOS_DEBUG_HEURISTICOVERLAY
+#if GEOS_DEBUG_HEURISTICOVERLAY
# include <iostream>
# include <iomanip>
# include <sstream>
@@ -202,13 +202,13 @@ check_valid(const Geometry& g, const std::string& label, bool doThrow = false, b
if(! ivo.isValid()) {
using operation::valid::TopologyValidationError;
TopologyValidationError* err = ivo.getValidationError();
std::cerr << label << " is INVALID: "
<< err->toString()
<< " (" << std::setprecision(20)
<< err->getCoordinate() << ")"
<< std::endl
-#ifdef GEOS_DEBUG_HEURISTICOVERLAY_PRINT_INVALID
+#if GEOS_DEBUG_HEURISTICOVERLAY_PRINT_INVALID
<< "<A>" << std::endl
<< g.toString()
<< std::endl
@@ -237,7 +237,7 @@ inline std::unique_ptr<Geometry>
fix_self_intersections(std::unique_ptr<Geometry> g, const std::string& label)
::geos::ignore_unused_variable_warning(label);
std::cerr << label << " fix_self_intersection (UnaryUnion)" << std::endl;
#endif
@@ -262,18 +262,18 @@ fix_self_intersections(std::unique_ptr<Geometry> g, const std::string& label)
switch(err->getErrorType()) {
case TopologyValidationError::eRingSelfIntersection:
case TopologyValidationError::eTooFewPoints: // collapsed lines
std::cerr << label << " ATTEMPT_TO_FIX: " << err->getErrorType() << ": " << *g << std::endl;
#endif
g = g->Union();
std::cerr << label << " ATTEMPT_TO_FIX succeeded.. " << std::endl;
#endif
return g;
case TopologyValidationError::eSelfIntersection:
// this one is within a single component, won't be fixed
default:
std::cerr << label << " invalidity is: " << err->getErrorType() << std::endl;
#endif
return g;
Summary of changes:
src/geom/HeuristicOverlay.cpp | 14 +++++++-------
1 file changed, 7 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
