[geos-commits] [SCM] GEOS branch master updated. e282cbe1e774d22f43c3acfdcd98d820acc32201
git at osgeo.org
git at osgeo.org
Sun Mar 7 09:31:13 PST 2021
the project "GEOS".
via e282cbe1e774d22f43c3acfdcd98d820acc32201 (commit)
from d2482e91dd35ebbf3f992e5338809d44767a0340 (commit)
revisions in full, below.
commit e282cbe1e774d22f43c3acfdcd98d820acc32201
Author: Daniel Baston <dbaston at gmail.com>
Date: Sat Mar 6 18:37:04 2021 -0500
Reduce heap allocs in SegmentNodeList
createSplitPts is usually returning a vector of length 2, so switch to a
FixedCoordinateSequence instead.
diff --git a/include/geos/noding/SegmentNodeList.h b/include/geos/noding/SegmentNodeList.h
index a8c1407..d3644ac 100644
--- a/include/geos/noding/SegmentNodeList.h
+++ b/include/geos/noding/SegmentNodeList.h
@@ -95,7 +95,7 @@ private:
* @param ei1 the end node of the split edge
* @return the points for the split edge
- void createSplitEdgePts(const SegmentNode* ei0, const SegmentNode* ei1, std::vector<geom::Coordinate>& pts) const;
+ std::unique_ptr<geom::CoordinateSequence> createSplitEdgePts(const SegmentNode* ei0, const SegmentNode* ei1) const;
* Adds nodes for any collapsed edge pairs.
diff --git a/src/noding/SegmentNodeList.cpp b/src/noding/SegmentNodeList.cpp
index 84c49dd..b6c3391 100644
--- a/src/noding/SegmentNodeList.cpp
+++ b/src/noding/SegmentNodeList.cpp
@@ -30,6 +30,7 @@
#include <geos/geom/Coordinate.h>
#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/CoordinateArraySequence.h> // FIXME: should we really be using this ?
+#include <geos/geom/FixedSizeCoordinateSequence.h>
#ifndef GEOS_DEBUG
#define GEOS_DEBUG 0
@@ -241,24 +242,23 @@ SegmentNodeList::checkSplitEdgesCorrectness(const std::vector<SegmentString*>& s
std::unique_ptr<SegmentString>
SegmentNodeList::createSplitEdge(const SegmentNode* ei0, const SegmentNode* ei1) const
- std::vector<Coordinate> pts;
- createSplitEdgePts(ei0, ei1, pts);
- return detail::make_unique<NodedSegmentString>(new CoordinateArraySequence(std::move(pts)), edge.getData());
+ auto pts = createSplitEdgePts(ei0, ei1);
+ return detail::make_unique<NodedSegmentString>(pts.release(), edge.getData());
/*private*/
-void
-SegmentNodeList::createSplitEdgePts(const SegmentNode* ei0, const SegmentNode* ei1, std::vector<Coordinate>& pts) const
+std::unique_ptr<CoordinateSequence>
+SegmentNodeList::createSplitEdgePts(const SegmentNode* ei0, const SegmentNode* ei1) const
- //int npts = ei1->segmentIndex - (ei0->segmentIndex + 2);
bool twoPoints = (ei1->segmentIndex == ei0->segmentIndex);
// if only two points in split edge they must be the node points
if (twoPoints) {
- pts.emplace_back(ei0->coord);
- pts.emplace_back(ei1->coord);
- return;
+ auto pts = detail::make_unique<FixedSizeCoordinateSequence<2>>();
+ pts->setAt(ei0->coord, 0);
+ pts->setAt(ei1->coord, 1);
+ return RETURN_UNIQUE_PTR(pts);
const Coordinate& lastSegStartPt = edge.getCoordinate(ei1->segmentIndex);
@@ -270,9 +270,9 @@ SegmentNodeList::createSplitEdgePts(const SegmentNode* ei0, const SegmentNode* e
* The check for point equality is 2D only - Z values are ignored
bool useIntPt1 = ei1->isInterior() || ! ei1->coord.equals2D(lastSegStartPt);
- //if (!useIntPt1) {
- // npts--;
+ std::vector<Coordinate> pts;
+ pts.reserve(1 + (ei1->segmentIndex - ei0->segmentIndex) + useIntPt1);
for (std::size_t i = ei0->segmentIndex + 1; i <= ei1->segmentIndex; i++) {
@@ -281,6 +281,8 @@ SegmentNodeList::createSplitEdgePts(const SegmentNode* ei0, const SegmentNode* e
if (useIntPt1) {
+ return std::unique_ptr<CoordinateSequence>(new CoordinateArraySequence(std::move(pts)));
@@ -306,10 +308,9 @@ SegmentNodeList::getSplitCoordinates()
/*private*/
void
SegmentNodeList::addEdgeCoordinates(const SegmentNode* ei0, const SegmentNode* ei1, std::vector<Coordinate>& coordList) const {
// Append pts to coordList
- coordList.insert(coordList.end(), pts.begin(), pts.end());
+ pts->toVector(coordList);
// Remove duplicate Coordinates from coordList
coordList.erase(std::unique(coordList.begin(), coordList.end()), coordList.end());
Summary of changes:
include/geos/noding/SegmentNodeList.h | 2 +-
src/noding/SegmentNodeList.cpp | 31 ++++++++++++++++---------------
2 files changed, 17 insertions(+), 16 deletions(-)
hooks/post-receive
More information about the geos-commits
