[geos-commits] [SCM] GEOS branch master updated. 34918fd50f8cb42c75a5a16c9e6d9f315068d1f8
git at osgeo.org
git at osgeo.org
Mon Mar 8 14:52:59 PST 2021
the project "GEOS".
via 34918fd50f8cb42c75a5a16c9e6d9f315068d1f8 (commit)
via ca61be30e93ab6f508ce9d6fca7c822297ff74d5 (commit)
from e282cbe1e774d22f43c3acfdcd98d820acc32201 (commit)
revisions in full, below.
commit 34918fd50f8cb42c75a5a16c9e6d9f315068d1f8
Merge: e282cbe ca61be3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Mar 8 14:52:49 2021 -0800
Merge branch 'rouault-fix_gdal_3542'
commit ca61be30e93ab6f508ce9d6fca7c822297ff74d5
Author: Even Rouault <even.rouault at spatialys.com>
Date: Mon Mar 8 16:51:00 2021 +0100
Fix crash with GEOSPreparedIntersects/Covers on a POINT EMPTY
Fixes use case spotted by https://github.com/OSGeo/gdal/issues/3542#issuecomment-792659437
diff --git a/src/geom/prep/BasicPreparedGeometry.cpp b/src/geom/prep/BasicPreparedGeometry.cpp
index 7d15f1a..78acb8a 100644
--- a/src/geom/prep/BasicPreparedGeometry.cpp
+++ b/src/geom/prep/BasicPreparedGeometry.cpp
@@ -42,7 +42,11 @@ bool
BasicPreparedGeometry::envelopesIntersect(const geom::Geometry* g) const
if (g->getGeometryTypeId() == GEOS_POINT) {
- return baseGeom->getEnvelopeInternal()->intersects(*(g->getCoordinate()));
+ auto pt = g->getCoordinate();
+ if (pt == nullptr) {
+ return false;
+ return baseGeom->getEnvelopeInternal()->intersects(*pt);
return baseGeom->getEnvelopeInternal()->intersects(g->getEnvelopeInternal());
@@ -52,7 +56,11 @@ bool
BasicPreparedGeometry::envelopeCovers(const geom::Geometry* g) const
- return baseGeom->getEnvelopeInternal()->covers(g->getCoordinate());
+ return false;
+ return baseGeom->getEnvelopeInternal()->covers(pt);
return baseGeom->getEnvelopeInternal()->covers(g->getEnvelopeInternal());
diff --git a/tests/unit/capi/GEOSPreparedGeometryTest.cpp b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
index fa5f961..a9611c4 100644
--- a/tests/unit/capi/GEOSPreparedGeometryTest.cpp
+++ b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
@@ -370,5 +370,40 @@ void object::test<11>
ensure_equals(ret, 0);
+// Test PreparedIntersects with Point EMPTY
+template<>
+template<>
+void object::test<12>
+ geom1_ = GEOSGeomFromWKT("POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))");
+ geom2_ = GEOSGeomFromWKT("POINT EMPTY");
+ prepGeom1_ = GEOSPrepare(geom1_);
+ ensure(nullptr != prepGeom1_);
+ ensure(nullptr != geom2_);
+ int ret = GEOSPreparedIntersects(prepGeom1_, geom2_);
+ ensure_equals(ret, 0);
+// Test PreparedCovers with Point EMPTY
+template<>
+template<>
+void object::test<13>
+ int ret = GEOSPreparedCovers(prepGeom1_, geom2_);
} // namespace tut
Summary of changes:
src/geom/prep/BasicPreparedGeometry.cpp | 12 ++++++++--
tests/unit/capi/GEOSPreparedGeometryTest.cpp | 35 ++++++++++++++++++++++++++++
2 files changed, 45 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
