[geos-commits] [SCM] GEOS branch 3.9 updated. 13abebc94abe7b269104e85ba57181bbc17911b8
Mon Mar 8 16:56:31 PST 2021
the project "GEOS".
The branch, 3.9 has been updated
       via  13abebc94abe7b269104e85ba57181bbc17911b8 (commit)
       via  57ca44f2edf16c08b86111d38b252c43b0851718 (commit)
      from  f0432996b098e4c8e7c1661ae9f12c62ac3fc367 (commit)
revisions in full, below.
commit 13abebc94abe7b269104e85ba57181bbc17911b8
Author: Daniel Baston <dbaston at gmail.com>
Date:   Mon Mar 8 19:55:38 2021 -0500
    Add NEWS entry
diff --git a/NEWS b/NEWS
index 106ffe3..afc8202 100644
--- a/NEWS
+++ b/NEWS
@@ -2,7 +2,9 @@ Changes in 3.9.2
 2021-xx-xx
 - Bug fixes / improvements:
-  - Add in interrupt points in OverlayNG (#4857, Paul Ramsey)
+  - Add in interrupt points in OverlayNG (#4857, Paul Ramsey)
+  - Fix crash in GEOSPreparedIntersects and GEOSPreparedContains for
+    POINT EMPTY input (Even Rouault)
 Changes in 3.9.1
commit 57ca44f2edf16c08b86111d38b252c43b0851718
Author: Even Rouault <even.rouault at spatialys.com>
Date:   Mon Mar 8 16:51:00 2021 +0100
    Fix crash with GEOSPreparedIntersects/Covers on a POINT EMPTY
    Fixes use case spotted by https://github.com/OSGeo/gdal/issues/3542#issuecomment-792659437
diff --git a/src/geom/prep/BasicPreparedGeometry.cpp b/src/geom/prep/BasicPreparedGeometry.cpp
index d637401..59f5d6e 100644
--- a/src/geom/prep/BasicPreparedGeometry.cpp
+++ b/src/geom/prep/BasicPreparedGeometry.cpp
@@ -42,7 +42,11 @@ bool
 BasicPreparedGeometry::envelopesIntersect(const geom::Geometry* g) const
     if (g->getGeometryTypeId() == GEOS_POINT) {
-        return baseGeom->getEnvelopeInternal()->intersects(*(g->getCoordinate()));
+        auto pt = g->getCoordinate();
+        if (pt == nullptr) {
+            return false;
+        return baseGeom->getEnvelopeInternal()->intersects(*pt);
     return baseGeom->getEnvelopeInternal()->intersects(g->getEnvelopeInternal());
@@ -52,7 +56,11 @@ bool
 BasicPreparedGeometry::envelopeCovers(const geom::Geometry* g) const
-        return baseGeom->getEnvelopeInternal()->covers(g->getCoordinate());
+            return false;
+        return baseGeom->getEnvelopeInternal()->covers(pt);
     return baseGeom->getEnvelopeInternal()->covers(g->getEnvelopeInternal());
diff --git a/tests/unit/capi/GEOSPreparedGeometryTest.cpp b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
index 040d0d1..a79d532 100644
--- a/tests/unit/capi/GEOSPreparedGeometryTest.cpp
+++ b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
@@ -393,5 +393,40 @@ void object::test<11>
         ensure_equals(ret, 0);
+// Test PreparedIntersects with Point EMPTY
+template<>
+template<>
+void object::test<12>
+    geom1_ = GEOSGeomFromWKT("POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))");
+    geom2_ = GEOSGeomFromWKT("POINT EMPTY");
+    prepGeom1_ = GEOSPrepare(geom1_);
+    ensure(nullptr != prepGeom1_);
+    ensure(nullptr != geom2_);
+    int ret = GEOSPreparedIntersects(prepGeom1_, geom2_);
+    ensure_equals(ret, 0);
+// Test PreparedCovers with Point EMPTY
+template<>
+template<>
+void object::test<13>
+    int ret = GEOSPreparedCovers(prepGeom1_, geom2_);
 } // namespace tut
Summary of changes:
 NEWS                                         |  4 +++-
 src/geom/prep/BasicPreparedGeometry.cpp      | 12 ++++++++--
 tests/unit/capi/GEOSPreparedGeometryTest.cpp | 35 ++++++++++++++++++++++++++++
 3 files changed, 48 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
