[geos-commits] [SCM] GEOS branch 3.8 updated. 798b6e79ca4bf257757f4fec09c6d41729da27e6
git at osgeo.org
git at osgeo.org
Mon Mar 8 16:58:59 PST 2021
the project "GEOS".
The branch, 3.8 has been updated
via 798b6e79ca4bf257757f4fec09c6d41729da27e6 (commit)
via 63c7f6c42ceee33a5553ca32c3b79fd252adcf73 (commit)
from 70906a91f58a26bbd2a0c25140a8d88459abfc54 (commit)
revisions in full, below.
commit 798b6e79ca4bf257757f4fec09c6d41729da27e6
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Mar 8 19:58:36 2021 -0500
Add NEWS entry
diff --git a/NEWS b/NEWS
index dc7a06d..de3b7af 100644
--- a/NEWS
+++ b/NEWS
@@ -16,7 +16,8 @@ Changes in 3.8.2dev
- Fix GEOSProjectNormalized return -1 on exception (#1058, Joris Van den Bossche)
- Fix memory management quirk in CAPI (#1050, Paul Ramsey)
- Allow build on Apple ARM64 (Taras Zakharko)
+ - Fix crash in GEOSPreparedIntersects and GEOSPreparedContains for
+ POINT EMPTY input (Even Rouault)
Changes in 3.8.1
2020-03-10
commit 63c7f6c42ceee33a5553ca32c3b79fd252adcf73
Author: Even Rouault <even.rouault at spatialys.com>
Date: Mon Mar 8 16:51:00 2021 +0100
Fix crash with GEOSPreparedIntersects/Covers on a POINT EMPTY
Fixes use case spotted by https://github.com/OSGeo/gdal/issues/3542#issuecomment-792659437
diff --git a/src/geom/prep/BasicPreparedGeometry.cpp b/src/geom/prep/BasicPreparedGeometry.cpp
index 65fca75..73f0581 100644
--- a/src/geom/prep/BasicPreparedGeometry.cpp
+++ b/src/geom/prep/BasicPreparedGeometry.cpp
@@ -41,7 +41,11 @@ bool
BasicPreparedGeometry::envelopesIntersect(const geom::Geometry* g) const
if (g->getGeometryTypeId() == GEOS_POINT) {
- return baseGeom->getEnvelopeInternal()->intersects(*(g->getCoordinate()));
+ auto pt = g->getCoordinate();
+ if (pt == nullptr) {
+ return false;
+ return baseGeom->getEnvelopeInternal()->intersects(*pt);
return baseGeom->getEnvelopeInternal()->intersects(g->getEnvelopeInternal());
@@ -51,7 +55,11 @@ bool
BasicPreparedGeometry::envelopeCovers(const geom::Geometry* g) const
- return baseGeom->getEnvelopeInternal()->covers(g->getCoordinate());
+ return false;
+ return baseGeom->getEnvelopeInternal()->covers(pt);
return baseGeom->getEnvelopeInternal()->covers(g->getEnvelopeInternal());
diff --git a/tests/unit/capi/GEOSPreparedGeometryTest.cpp b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
index ca760b9..8d3b888 100644
--- a/tests/unit/capi/GEOSPreparedGeometryTest.cpp
+++ b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
@@ -392,5 +392,40 @@ void object::test<11>
ensure_equals(ret, 0);
+// Test PreparedIntersects with Point EMPTY
+template<>
+template<>
+void object::test<12>
+ geom1_ = GEOSGeomFromWKT("POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))");
+ geom2_ = GEOSGeomFromWKT("POINT EMPTY");
+ prepGeom1_ = GEOSPrepare(geom1_);
+ ensure(nullptr != prepGeom1_);
+ ensure(nullptr != geom2_);
+ int ret = GEOSPreparedIntersects(prepGeom1_, geom2_);
+ ensure_equals(ret, 0);
+// Test PreparedCovers with Point EMPTY
+template<>
+template<>
+void object::test<13>
+ int ret = GEOSPreparedCovers(prepGeom1_, geom2_);
} // namespace tut
Summary of changes:
NEWS | 3 ++-
src/geom/prep/BasicPreparedGeometry.cpp | 12 ++++++++--
tests/unit/capi/GEOSPreparedGeometryTest.cpp | 35 ++++++++++++++++++++++++++++
3 files changed, 47 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
