[geos-commits] [SCM] GEOS branch main updated. de4ede4cd057500b744039bbc9b5d3f7b19de3ff
git at osgeo.org
git at osgeo.org
Wed Nov 10 16:02:40 PST 2021
the project "GEOS".
The branch, main has been updated
via de4ede4cd057500b744039bbc9b5d3f7b19de3ff (commit)
from 69d92910013e37171ec864834b22778cbc104723 (commit)
revisions in full, below.
commit de4ede4cd057500b744039bbc9b5d3f7b19de3ff
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Nov 10 16:02:18 2021 -0800
Add new committer to web site, pivot CI table
diff --git a/web/content/development/_index.md b/web/content/development/_index.md
index 8ceec04fa..2c3db2cee 100644
--- a/web/content/development/_index.md
+++ b/web/content/development/_index.md
@@ -6,13 +6,27 @@ draft: false
## Developer Resources
-* Code repository: https://github.com/libgeos/geos
-* Developer mailing list: https://lists.osgeo.org/mailman/listinfo/geos-devel
-* Developer chat channel:
+* **git** repository: https://github.com/libgeos/geos
+* [**geos-devel** mailing list](https://lists.osgeo.org/mailman/listinfo/geos-devel) and [archive](https://lists.osgeo.org/pipermail/geos-devel/)
+* **#geos** chat channel:
* Matrix: https://matrix.to/#/#geos:osgeo.org
* Slack: https://osgeo.slack.com/messages/C07RKJ06B/
+## Bug Reporting
+Defects should be reported using [GitHub Issues](https://github.com/libgeos/geos/issues).
+When submitting bugs caused by particular geometries, you must submit the geometries that cause the failure, preferably in hex-encoded [WKB]({{< ref "../specifications/wkb" >}}), so that we can re-produce the failure cases.
+## Contributing
+To contribute fixes to outstanding issues, enhancements, and other smaller changes, open a [pull request](https://github.com/libgeos/geos/pulls) with your change and a fullsome description of what you are trying to achieve.
+If you have any doubts as to whether your work, or planned work, is not a "smaller" change, please join the [**geos-devel** mailing list](https://lists.osgeo.org/mailman/listinfo/geos-devel) and describe your plans. **Join the list!** It is a great way to get acquainted with what the development community is working on.
## Relationship to JTS
GEOS started as a direct port to C++ of the [JTS Topology Suite](http://tsusiatsoftware.net/jts/main.html) (JTS), and remains tightly bound to that project. Most core algorithms have been prototyped in JTS and ported to GEOS when complete.
diff --git a/web/content/development/ci_status.md b/web/content/development/ci_status.md
index 299c8a568..3eb096bd5 100644
--- a/web/content/development/ci_status.md
+++ b/web/content/development/ci_status.md
@@ -4,21 +4,26 @@ date: 2021-10-04T14:21:00-07:00
draft: false
-| Branch | GitHub | Debbie | Winnie | Dronie | GitLab | Bessie | Bessie32 |
-| **main** | [](https://github.com/libgeos/geos/actions?query=workflow%3ACI+branch%3Amain) | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Master/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Master/) | [](https://dronie.osgeo.org/geos/geos?ref=refs/heads/main) | [](https://gitlab.com/geos/libgeos/commits/main) | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Worker_Run/label=bessie) | [](https://
debbie.postgis.net/view/GEOS/job/GEOS_Worker_Run/label=bessie32) |
-| **3.10** | [](https://github.com/libgeos/geos/actions?query=branch%3A3.10) | [](https://debbie.postgis.net/view/job/GEOS_Branch_3.10/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.10/) | [](https://dronie.osgeo.org/geos/geos?refs/heads/3.10) | [](https://gitlab.com/geos/libgeos/commits/3.10) | | |
-| **3.9** | [](https://github.com/libgeos/geos/actions?query=branch%3A3.9) | [](https://debbie.postgis.net/view/job/GEOS_Branch_3.9/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.9/) | [](https://dronie.osgeo.org/geos/geos?refs/heads/3.9) | [](https://gitlab.com/geos/libgeos/commits/3.9) | | |
-| **3.8** | [](https://github.com/libgeos/geos/actions?query=branch%3A3.8) | [](https://debbie.postgis.net/view/job/GEOS_Branch_3.8/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.8/) | [](https://dronie.osgeo.org/geos/geos?refs/heads/3.8) | [](https://gitlab.com/geos/libgeos/commits/3.8) | | |
-| **3.7** | [](https://github.com/libgeos/geos/actions?query=branch%3A3.7) | [](https://debbie.postgis.net/view/job/GEOS_Branch_3.7/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.7/) | [](https://dronie.osgeo.org/geos/geos?refs/heads/3.7) | [](https://gitlab.com/geos/libgeos/commits/3.7) | | |
+| CI | main | 3.10 | 3.9 | 3.8 | 3.7 |
+| **GitHub** | [](https://github.com/libgeos/geos/actions?query=workflow%3ACI+branch%3Amain) | [](https://github.com/libgeos/geos/actions?query=branch%3A3.10) | [](https://github.com/libgeos/geos/actions?query=branch%3A3.9)| [](https://github.com/libgeos/geos/actions?query=branch%3A3.8)| [](https://github.com/libgeos/geos/actions?query=branch%3A3.7) |
+| **GitLab** | [](https://gitlab.com/geos/libgeos/commits/main) | [](https://gitlab.com/geos/libgeos/commits/3.10)| [](https://gitlab.com/geos/libgeos/commits/3.9)| [](https://gitlab.com/geos/libgeos/commits/3.8) | [](https://gitlab.com/geos/libgeos/commits/3.7) |
+| **Azure** | [](https://dev.azure.com/libgeos/geos/_build/latest?definitionId=2&branchName=main)| [](https://dev.azure.com/libgeos/geos/_build/latest?definitionId=2&branchName=3.10) | [](https://dev.azure.com/libgeos/geos/_build/latest?definitionId=2&branchName=3.9)| [](https://dev.azure.com/libgeos/geos/_build/latest?definitionId=2&branchName=3.8)| [](https://dev.azure.com/libgeos/geos/_build/latest?definitionId=2&branchName=3.7) |
+| **Debbie** | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Master/)| [](https://debbie.postgis.net/view/job/GEOS_Branch_3.10/)| [](https://debbie.postgis.net/view/job/GEOS_Branch_3.9/)| [](https://debbie.postgis.net/view/job/GEOS_Branch_3.8/)| [](https://debbie.postgis.net/view/job/GEOS_Branch_3.7/)|
+| **Winnie** | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Master/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.10/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.9/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.8/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.7/) |
+| **Dronie** | [](https://dronie.osgeo.org/geos/geos?ref=refs/heads/main) | [](https://dronie.osgeo.org/geos/geos?refs/heads/3.10) | [](https://dronie.osgeo.org/geos/geos?refs/heads/3.9) | [](https://dronie.osgeo.org/geos/geos?refs/heads/3.8) | [](https://dronie.osgeo.org/geos/geos?refs/heads/3.7) |
+| **Bessie** | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Worker_Run/label=bessie) | | | | |
+| **Bessie32** | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Worker_Run/label=bessie32) | | | | |
## Runners
+* **GitHub** - Ubuntu various, Windows various, CMake
+* **GitLab** - Debian 8.2, GNU/Linux 64bit, GCC, automake
+* **Azure** - Ubunbu 20.04, Windows, MacOS, GCC various, clang various, cmake
* **Debbie** - Debian 8.2, GNU/Linux 64bit, GCC Debian 8.2.0-3, automake
* **Winnie** - Windows Mingw64, 32bit GCC 8.1.0, 64bit GCC 8.1.0, MSys CMake
* **Dronie** - Alpine Linux 3.4, 64bit, GCC 5.3.0, automake
-* **GitLab** - Debian 8.2, GNU/Linux 64bit, gcc, automake
* **Bessie** - FreeBSD 12.2, 64-bit clang 6.0, 64bit gcc, CMake (3.11) >=3.8, autotools < 3.8
* **Bessie32** - FreeBSD 12.2, 32-bit clang 6.0, 64bit gcc, CMake (3.11) >=3.8, autotools < 3.8
-* **GitHub** - Ubuntu various versions, Windows various, CMake
diff --git a/web/content/development/psc.md b/web/content/development/psc.md
index 32ee8d62b..664e0ad60 100644
--- a/web/content/development/psc.md
+++ b/web/content/development/psc.md
@@ -7,22 +7,21 @@ weight: 30
The GEOS project is run by a Project Steering Committee made up of developers and contributors to the project and is a project of [OSGeo](https://www.osgeo.org/projects/geos/). Major project decisions are made via a [Request for Comments]({{< ref "rfcs" >}}) (RFC) process, where proposals are first documented and then voted on by the steering committee.
-The current PSC will refresh itself using the mechanisms in RFC-1.
+This PSC list is valid as of November 10, 2021.
-This PSC list is valid as of Oct 23, 2019.
+* [Sandro Santilli](https://gitlab.com/strk) (chair)
+* [Martin Davis](https://github.com/drjts)
+* [Howard Butler](https://github.com/hobu)
+* [Regina Obe](https://github.com/robe2)
+* Dale Lutz
+* [Paul Ramsey](https://github.com/pramsey)
+* [Dan Baston](https://github.com/dbaston)
-* Sandro Santilli <strk at kbt dot io> (chair)
-* Martin Davis <mtnclimb at gmail dot com>
-* Howard Butler <hobu.inc at gmail dot com>
-* Regina Obe <lr at pcorp dot us>
-* Dale Lutz <dale at safe dot com>
-* Paul Ramsey <pramsey at cleverelephant dot ca>
-* Dan Baston <dbaston at gmail dot com>
+The PSC approves major changes and RFC documents. Other work is always ongoing, by the PSC and by the other committers, listed below:
-The PSC approves major changes and RFC documents. Minor work is ongoing, by the PSC and by the other committers, listed below:
-* Vicky Vergara
-* Kurt Schwehr
+* [Vicky Vergara](https://github.com/cvvergara)
+* [Kurt Schwehr](https://github.com/schwehr)
+* [Mike Taves](https://github.com/mwtoews)
Historical committers:
Summary of changes:
web/content/development/_index.md | 20 +++++++++++++++++---
web/content/development/ci_status.md | 23 ++++++++++++++---------
web/content/development/psc.md | 25 ++++++++++++-------------
3 files changed, 43 insertions(+), 25 deletions(-)
hooks/post-receive
More information about the geos-commits
