[geos-commits] [SCM] GEOS branch main updated. 80398b0377f9597f6c9b05b1684e00d97f04ebef
    git at osgeo.org
    git at osgeo.org
    Mon Oct  4 13:29:51 PDT 2021
the project "GEOS".
The branch, main has been updated
       via  80398b0377f9597f6c9b05b1684e00d97f04ebef (commit)
      from  f24c181ec306d8f92429d553a316653e2760e2d4 (commit)
revisions in full, below.
commit 80398b0377f9597f6c9b05b1684e00d97f04ebef
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Oct 4 13:14:01 2021 -0700
    Protect IsValidOp from null inputs
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index 5f27fbb..a54dc14 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -28,6 +28,7 @@
 #include <geos/operation/valid/IndexedNestedHoleTester.h>
 #include <geos/operation/valid/IndexedNestedPolygonTester.h>
 #include <geos/util/UnsupportedOperationException.h>
+#include <geos/util/IllegalArgumentException.h>
 #include <cmath>
@@ -80,9 +81,11 @@ IsValidOp::logInvalid(int code, const Coordinate* pt)
 bool
 IsValidOp::isValidGeometry(const Geometry* g)
-    assert(g);
     validErr.reset(nullptr);
+    if (!g)
+        throw util::IllegalArgumentException("Null geometry argument to IsValidOp");
     // empty geometries are always valid
     if (g->isEmpty()) return true;
     switch (g->getGeometryTypeId()) {
diff --git a/tests/unit/capi/GEOSisValidTest.cpp b/tests/unit/capi/GEOSisValidTest.cpp
index 86dcac5..a99684b 100644
--- a/tests/unit/capi/GEOSisValidTest.cpp
+++ b/tests/unit/capi/GEOSisValidTest.cpp
@@ -50,13 +50,18 @@ void object::test<3>()
         GEOSCoordSeq_setXY(shell_seq, i, shell_coords[2*i], shell_coords[2*i+1]);
+    // Unclosed ring fails in construction
+    // Linear ring takes ownership of coordinate sequence and
+    // frees it when construction fails
     GEOSGeometry* shell = GEOSGeom_createLinearRing(shell_seq);
     ensure(shell == nullptr);
+    // So we end up handing nullptr into create polygon
     GEOSGeometry* polygon = GEOSGeom_createPolygon(shell, nullptr, 0);
     ensure(polygon == nullptr);
-    // char isvalid = GEOSisValid(polygon);
-    // ensure_equals(0, isvalid);
-    // GEOSGeom_destroy(polygon);
+    // Which also returns nullptr and that goes into isvalid
+    char isvalid = GEOSisValid(polygon);
+    // Which causes an exception that we catch
+    ensure_equals(2, isvalid);
 } // namespace tut
Summary of changes:
 src/operation/valid/IsValidOp.cpp   |  5 ++++-
 tests/unit/capi/GEOSisValidTest.cpp | 11 ++++++++---
 2 files changed, 12 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
