[geos-commits] [SCM] GEOS branch main updated. eb3299023a884547efd423df8b9dbc9ef59802ca
git at osgeo.org
git at osgeo.org
Mon Oct 4 14:10:27 PDT 2021
the project "GEOS".
The branch, main has been updated
via eb3299023a884547efd423df8b9dbc9ef59802ca (commit)
from 80398b0377f9597f6c9b05b1684e00d97f04ebef (commit)
revisions in full, below.
commit eb3299023a884547efd423df8b9dbc9ef59802ca
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Oct 4 23:09:46 2021 +0200
Always return false from DistanceWithin if any operand is empty
See https://trac.osgeo.org/postgis/ticket/5008#comment:1
diff --git a/src/operation/distance/DistanceOp.cpp b/src/operation/distance/DistanceOp.cpp
index b96f892..fa73b1b 100644
--- a/src/operation/distance/DistanceOp.cpp
+++ b/src/operation/distance/DistanceOp.cpp
@@ -528,6 +528,7 @@ DistanceOp::isWithinDistance(const geom::Geometry& g0,
double distance)
// check envelope distance for a short-circuit negative result
+ if ( g0.isEmpty() || g1.isEmpty() ) return false;
const Envelope* env0 = g0.getEnvelopeInternal();
const Envelope* env1 = g1.getEnvelopeInternal();
double envDist = env0->distance(*env1);
diff --git a/tests/unit/capi/GEOSDistanceWithinTest.cpp b/tests/unit/capi/GEOSDistanceWithinTest.cpp
index 9469179..498cb53 100644
--- a/tests/unit/capi/GEOSDistanceWithinTest.cpp
+++ b/tests/unit/capi/GEOSDistanceWithinTest.cpp
@@ -6,6 +6,7 @@
#include <geos/constants.h>
#include <geos_c.h>
// std
+#include <limits>
#include <cstdarg>
#include <cstdio>
#include <cstdlib>
@@ -360,7 +361,7 @@ void object::test<26>() {
-// empty geometries should always return true (distance 1)
+// empty geometries should return false (distance 1)
template <>
template <>
void object::test<27>() {
@@ -368,11 +369,11 @@ void object::test<27>() {
"POINT EMPTY",
"LINESTRING EMPTY",
1.0,
- 1
+ 0
-// empty geometries should always return true (distance 0)
+// empty geometries should return false (distance 0)
template <>
template <>
void object::test<28>() {
@@ -380,7 +381,43 @@ void object::test<28>() {
"POINT EMPTY",
"LINESTRING EMPTY",
0.0,
- 1
+ 0
+// empty geometries should return false (distance Infinity)
+template <>
+template <>
+void object::test<29>() {
+ testGEOSDistanceWithin(
+ "POINT EMPTY",
+ "LINESTRING EMPTY",
+ std::numeric_limits<double>::infinity(),
+ 0
+// empty geometry is never within any distance
+template <>
+template <>
+void object::test<30>() {
+ "POINT EMPTY",
+ "LINESTRING(0 0, 20 0)",
+ 0
+template <>
+template <>
+void object::test<31>() {
+ "POINT EMPTY",
+ 0
diff --git a/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp b/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp
index 96a654c..32b0397 100644
--- a/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp
+++ b/tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp
@@ -66,7 +66,7 @@ void object::test<1>
"POLYGON EMPTY",
"POLYGON EMPTY",
- 1
+ 0
@@ -145,7 +145,7 @@ void object::test<7>
"LINESTRING EMPTY",
"POINT EMPTY",
- 1
+ 0
@@ -158,7 +158,33 @@ void object::test<8>
"POINT EMPTY",
"LINESTRING EMPTY",
- 1
+ 0
+template<>
+template<>
+void object::test<9>
+ checkDistanceWithin(
+ "POINT EMPTY",
+ "POINT(0 0)",
+ 0
+template<>
+template<>
+void object::test<10>
+ "LINESTRING(0 0, 10 0)",
+ "POLYGON EMPTY",
+ 0
Summary of changes:
src/operation/distance/DistanceOp.cpp | 1 +
tests/unit/capi/GEOSDistanceWithinTest.cpp | 45 ++++++++++++++++++++--
tests/unit/capi/GEOSPreparedDistanceWithinTest.cpp | 32 +++++++++++++--
3 files changed, 71 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
