[geos-commits] [SCM] GEOS branch main updated. 77a07030a76245862b11442f793a58b7b93151a0
git at osgeo.org
git at osgeo.org
Thu Oct 21 13:23:59 PDT 2021
the project "GEOS".
The branch, main has been updated
via 77a07030a76245862b11442f793a58b7b93151a0 (commit)
from d3d9620fbdc31193813984c9525d9cb6b72eb841 (commit)
revisions in full, below.
commit 77a07030a76245862b11442f793a58b7b93151a0
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Oct 21 13:23:56 2021 -0700
Update web site for 3.10 release
diff --git a/web/config.toml b/web/config.toml
index 7c24b49f7..c336e74f1 100644
--- a/web/config.toml
+++ b/web/config.toml
@@ -8,9 +8,11 @@ disablePathToLower = true
enableGitInfo = true
[params]
- current_release = "3.9.1"
+ current_release = "3.10.0"
geekdocLogo = "web-logo.png"
- # turn these on when we move to the main branch
+ # turn these on when we move to the gh/main branch
#geekdocRepo = "https://github.com/libgeos/geos"
- #geekdocEditPath = "web"
+ #geekdocEditPath = "edit/main/web/content"
geekdocBackToTop = true
diff --git a/web/content/usage/download.md b/web/content/usage/download.md
index 5b1a42abe..65dfaae36 100644
--- a/web/content/usage/download.md
+++ b/web/content/usage/download.md
@@ -6,7 +6,8 @@ draft: false
| Release Date | Release | Download Link |
-| 2020/12/10 | **{{<current_release>}}** | [geos-{{<current_release>}}.tar.bz2](http://download.osgeo.org/geos/geos-{{<current_release>}}.tar.bz2) |
+| 2021/10/21 | **{{<current_release>}}** | [geos-{{<current_release>}}.tar.bz2](http://download.osgeo.org/geos/geos-{{<current_release>}}.tar.bz2) |
+| 2020/12/10 | **3.9.1** | [geos-3.9.1.tar.bz2](http://download.osgeo.org/geos/geos-3.9.1.tar.bz2) |
| 2020/03/10 | **3.8.1** | [geos-3.8.1.tar.bz2](http://download.osgeo.org/geos/geos-3.8.1.tar.bz2) |
| 2019/10/04 | **3.7.3** | [geos-3.7.3.tar.bz2](http://download.osgeo.org/geos/geos-3.7.3.tar.bz2) |
| 2020/12/11 | **3.6.5** | [geos-3.6.5.tar.bz2](http://download.osgeo.org/geos/geos-3.6.5.tar.bz2) |
@@ -17,7 +18,7 @@ draft: false
### Build Requirements
-* [CMake](https://cmake.org/download/) 3.8 or later.
+* [CMake](https://cmake.org/download/) 3.13 or later.
* C++11 compiler. We regularly test GCC, Clang and Microsoft Visual C++.
* [Doxygen](https://www.doxygen.nl/) to build the API documentation.
@@ -33,7 +34,7 @@ mkdir _build
cd _build
# Set up the build
cmake \
- -DCMAKE_BUILD_TYPE=Release
+ -DCMAKE_BUILD_TYPE=Release \
-DCMAKE_INSTALL_PREFIX=/usr/local \
# Run the build, test, install steps
@@ -48,7 +49,7 @@ The GEOS build can be customized using build options.
| Option | Default | Note |
-| CMAKE_BUILD_TYPE | Release | Use `Debug` to build with debug flags and optimizations off. Use `Release` for packaging and working installs. |
+| CMAKE_BUILD_TYPE | Release | Use `Debug` to build with debug flags and optimizations off. Use `Release` for packaging and production installs. Use `RelWithDebInfo` for optimized build with debug symbols. |
| CMAKE_INSTALL_PREFIX | /usr/local | Set to install root. Librarys end up in `./libs` headers in `./include` |
| BUILD_DOCUMENTATION | ON | Attempt to find `doxygen` executable and build API docs |
| BUILD_SHARED_LIBS | ON | Build dynamically linkable libraries. |
Summary of changes:
web/config.toml | 8 +++++---
web/content/usage/download.md | 9 +++++----
2 files changed, 10 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
