[geos-commits] [SCM] GEOS branch main updated. dbcd4ecb73d54edc47ec3cd69dbe2223a7195342
git at osgeo.org
git at osgeo.org
Thu Oct 21 16:09:25 PDT 2021
the project "GEOS".
The branch, main has been updated
via dbcd4ecb73d54edc47ec3cd69dbe2223a7195342 (commit)
via 494846aa2f236925f0ebee43911d396aa17d4b5d (commit)
via 927e442ab1da361d3f487e2b620a878dd11f191d (commit)
from 77a07030a76245862b11442f793a58b7b93151a0 (commit)
revisions in full, below.
commit dbcd4ecb73d54edc47ec3cd69dbe2223a7195342
Merge: 77a07030a 494846aa2
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Oct 21 16:09:22 2021 -0700
Merge branch 'manisandro-main' into main
commit 494846aa2f236925f0ebee43911d396aa17d4b5d
Merge: 77a07030a 927e442ab
Date: Thu Oct 21 16:09:10 2021 -0700
Merge branch 'main' of https://github.com/manisandro/geos into manisandro-main
commit 927e442ab1da361d3f487e2b620a878dd11f191d
Author: Sandro Mani <manisandro at gmail.com>
Date: Thu Oct 21 10:56:59 2021 +0200
Set shared library suffix for mingw builds
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 20c890702..b1bdf4954 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -280,6 +280,9 @@ if(BUILD_SHARED_LIBS)
set_target_properties(geos PROPERTIES VERSION ${GEOS_VERSION_NOPATCH})
set_target_properties(geos PROPERTIES SOVERSION ${GEOS_VERSION_NOPATCH})
+ if(MINGW)
+ set_target_properties(geos PROPERTIES SUFFIX "-${GEOS_VERSION_NOPATCH}${CMAKE_SHARED_LIBRARY_SUFFIX}")
+ endif(MINGW)
endif()
@@ -293,9 +296,12 @@ if(BUILD_SHARED_LIBS)
PRIVATE $<IF:$<CXX_COMPILER_ID:MSVC>,GEOS_DLL_EXPORT,DLL_EXPORT>)
set_target_properties(geos_c PROPERTIES VERSION ${CAPI_VERSION})
- if(NOT WIN32)
+ if(NOT WIN32 OR MINGW)
set_target_properties(geos_c PROPERTIES SOVERSION ${CAPI_VERSION_MAJOR})
endif()
+ if(MINGW)
+ set_target_properties(geos_c PROPERTIES SUFFIX "-${CAPI_VERSION_MAJOR}${CMAKE_SHARED_LIBRARY_SUFFIX}")
+ endif(MINGW)
endif()
add_subdirectory(capi)
Summary of changes:
CMakeLists.txt | 8 +++++++-
1 file changed, 7 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
