[geos-commits] [SCM] GEOS branch main updated. 2f9e7531804e3a4f09823d8f1b9536cb04d313bf
Tue Jul 18 11:47:38 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  2f9e7531804e3a4f09823d8f1b9536cb04d313bf (commit)
      from  356598a9de13d6964773546611e944ff851f8fab (commit)
revisions in full, below.
commit 2f9e7531804e3a4f09823d8f1b9536cb04d313bf
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Jul 18 11:46:19 2023 -0700
    Add LargestEmptyCircle handling of polygon obstacles (#939)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 781ff7c13..3466cef60 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -4129,8 +4129,7 @@ extern GEOSGeometry GEOS_DLL *GEOSMaximumInscribedCircle(
 * Constructs the "largest empty circle" (LEC) for a set of obstacle geometries
 * and within a polygonal boundary,
 * with accuracy to to a specified distance tolerance.
-* The obstacles are point and line geometries.
-* Polygonal obstacles are treated as linear features.
+* The obstacles may be any collection of points, lines and polygons.
 * The LEC is the largest circle whose interior does not intersect with any obstacle.
 * and which has its **center** inside the given boundary.
 * If no boundary is provided, the
@@ -4139,15 +4138,21 @@ extern GEOSGeometry GEOS_DLL *GEOSMaximumInscribedCircle(
 * the obstacles (up to the given distance tolerance).
 * The LEC is determined by the center point and a point indicating the circle radius
 * (which will lie on an obstacle).
+* To compute an LEC which lies **wholly** within a polygonal boundary,
+* include the boundary of the polygon(s) as a linear obstacle.
 * The implementation uses a successive-approximation technique over a grid of square cells covering the obstacles and boundary.
 * The grid is refined using a branch-and-bound algorithm.  Point containment and distance are computed in a performant
 * way by using spatial indexes.
 * Returns the LEC radius as a two-point linestring, with the start point at the center of the inscribed circle and the end
 * on the boundary of the circle.
 * \param obstacles The geometries that the LEC must not cross
 * \param boundary The area to contain the LEC center (may be null or empty)
 * \param tolerance Stop the algorithm when the search area is smaller than this tolerance
-* \return A newly allocated geometry of the LEC radius. NULL on exception.
+* \return A newly allocated geometry of the LEC radius line. NULL on exception.
 * Caller is responsible for freeing with GEOSGeom_destroy().
 * \see geos::algorithm::construct::LargestEmptyCircle
diff --git a/include/geos/algorithm/construct/IndexedDistanceToPoint.h b/include/geos/algorithm/construct/IndexedDistanceToPoint.h
new file mode 100644
index 000000000..68d845245
--- /dev/null
+++ b/include/geos/algorithm/construct/IndexedDistanceToPoint.h
@@ -0,0 +1,88 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2023 Martin Davis <mtnclimb at gmail.com>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: algorithm/construct/IndexedDistanceToPoint.java
+ * https://github.com/locationtech/jts/commit/d92f783163d9440fcc10c729143787bf7b9fe8f9
+#pragma once
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Point.h>
+#include <geos/algorithm/construct/IndexedPointInPolygonsLocator.h>
+#include <geos/operation/distance/IndexedFacetDistance.h>
+using geos::geom::Geometry;
+using geos::geom::Point;
+using geos::operation::distance::IndexedFacetDistance;
+namespace geos {
+namespace algorithm { // geos::algorithm
+namespace construct { // geos::algorithm::construct
+ * \brief Computes the distance between a point and a geometry
+ * (which may be a collection containing any type of geometry).
+ * Also computes the pair of points containing the input
+ * point and the nearest point on the geometry.
+ * \author Martin Davis
+class GEOS_DLL IndexedDistanceToPoint {
+public:
+     * \brief Creates an instance to find the distance from points to a geometry.
+     * \param geom the geometry to compute distances to
+    IndexedDistanceToPoint(const Geometry& geom);
+     * \brief Computes the distance from the base geometry to the given point.
+     * \param pt the point to compute the distance to
+     * \return the computed distance
+    double distance(const Point& pt);
+     * \brief Computes the nearest point on the geometry to the point.
+     * The first location lies on the geometry,
+     * and the second location is the provided point.
+     * \param pt the point to compute the nearest point for
+     * \return the points that are nearest
+    std::unique_ptr<geom::CoordinateSequence> nearestPoints(const Point& pt);
+private:
+    void init();
+    bool isInArea(const Point& pt);
+    //-- members
+    const Geometry& targetGeometry;
+    std::unique_ptr<operation::distance::IndexedFacetDistance> facetDistance;
+    std::unique_ptr<IndexedPointInPolygonsLocator> ptLocator;
\ No newline at end of file
diff --git a/include/geos/algorithm/construct/IndexedPointInPolygonsLocator.h b/include/geos/algorithm/construct/IndexedPointInPolygonsLocator.h
index 000000000..dd82d55a4
--- /dev/null
+++ b/include/geos/algorithm/construct/IndexedPointInPolygonsLocator.h
@@ -0,0 +1,79 @@
+#pragma once
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/Location.h>
+#include <geos/index/strtree/TemplateSTRtree.h>
+#include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
+using geos::geom::CoordinateXY;
+using geos::geom::Location;
+using geos::index::strtree::TemplateSTRtree;
+using geos::algorithm::locate::IndexedPointInAreaLocator;
+namespace geos {
+ * \brief Determines the location of a point in the polygonal elements of a geometry.
+ * Uses spatial indexing to provide efficient performance.
+class GEOS_DLL IndexedPointInPolygonsLocator {
+public:
+     * \brief Creates an instance to locate a point in polygonal elements.
+     * \param geom the geometry to locate in
+    IndexedPointInPolygonsLocator(const Geometry& geom);
+    /** \brief
+     * Determines the [Location](@ref geom::Location) of a point in
+     * the polygonal elements of a
+     * [Geometry](@ref geom::Geometry).
+     * @param p the point to test
+     * @return the location of the point in the geometry
+    Location locate(const CoordinateXY* /*const*/ p);
+private:
+    void init();
+    // Declare type as noncopyable
+    IndexedPointInPolygonsLocator(const IndexedPointInPolygonsLocator& other) = delete;
+    IndexedPointInPolygonsLocator& operator=(const IndexedPointInPolygonsLocator& rhs) = delete;
+    //-- members
+    const Geometry& geom;
+    bool isInitialized;
+    TemplateSTRtree<IndexedPointInAreaLocator*> index;
+    std::vector<std::unique_ptr<IndexedPointInAreaLocator>> locators;
diff --git a/include/geos/algorithm/construct/LargestEmptyCircle.h b/include/geos/algorithm/construct/LargestEmptyCircle.h
index b84ccb3f4..f19931488 100644
--- a/include/geos/algorithm/construct/LargestEmptyCircle.h
+++ b/include/geos/algorithm/construct/LargestEmptyCircle.h
@@ -22,14 +22,13 @@
 #include <geos/geom/Envelope.h>
+#include <geos/algorithm/construct/IndexedDistanceToPoint.h>
 #include <memory>
 #include <queue>
 namespace geos {
 namespace geom {
 class Coordinate;
@@ -39,13 +38,9 @@ class GeometryFactory;
 class LineString;
 class Point;
-namespace operation {
-namespace distance {
-class IndexedFacetDistance;
 namespace geos {
@@ -53,15 +48,23 @@ namespace construct { // geos::algorithm::construct
 * Constructs the Largest Empty Circle for a set of obstacle geometries,
-* up to a specified tolerance. The obstacles are point and line geometries.
+* up to a specified tolerance.
+* The obstacles may be any combination of point, linear and polygonal geometries.
-* The Largest Empty Circle is the largest circle which has its center
-* in the convex hull of the obstacles (the boundary), and whose
-* interior does not intersect with any obstacle. The circle center
-* is the point in the interior of the boundary which has the
-* farthest distance from the obstacles (up to tolerance).
-* The circle is determined by the center point and a point lying
-* on an obstacle indicating the circle radius.
+* The Largest Empty Circle (LEC) is the largest circle
+* whose interior does not intersect with any obstacle
+* and whose center lies within a polygonal boundary.
+* The circle center is the point in the interior of the boundary
+* which has the farthest distance from the obstacles
+* (up to the accuracy of the distance tolerance).
+* The circle itself is determined by the center point
+* and a point lying on an obstacle determining the circle radius.
+* The polygonal boundary may be supplied explicitly.
+* If it is not specified the convex hull of the obstacles is used as the boundary.
+* To compute an LEC which lies wholly within
+* a polygonal boundary, include the boundary of the polygon(s) as an obstacle.
 * over a grid of square cells covering the obstacles and boundary.
@@ -77,19 +80,36 @@ public:
     * Creates a new instance of a Largest Empty Circle construction.
+    * The obstacles may be any collection of points, lines and polygons.
+    * The constructed circle center lies within the convex hull of the obstacles.
-    * @param p_obstacles a geometry representing the obstacles (points and lines)
+    * @param p_obstacles a geometry representing the obstacles
     * @param p_tolerance the distance tolerance for computing the circle center point
     LargestEmptyCircle(const geom::Geometry* p_obstacles, double p_tolerance);
+    * Creates a new instance of a Largest Empty Circle construction,
+    * interior-disjoint to a set of obstacle geometries
+    * and having its center within a polygonal boundary.
+    * If the boundary is null or empty the convex hull
+    * of the obstacles is used as the boundary.
+    * @param p_boundary a polygonal geometry to contain the LEC center
+    * @param p_tolerance the distance tolerance for computing the circle center point
     LargestEmptyCircle(const geom::Geometry* p_obstacles, const geom::Geometry* p_boundary, double p_tolerance);
     ~LargestEmptyCircle() = default;
     * Computes the center point of the Largest Empty Circle
     * within a set of obstacles, up to a given tolerance distance.
     * @param p_tolerance the distance tolerance for computing the center point
     * @return the center point of the Largest Empty Circle
@@ -98,8 +118,9 @@ public:
     * Computes a radius line of the Largest Empty Circle
     * within a set of obstacles, up to a given distance tolerance.
     * @return a line from the center of the circle to a point on the edge
@@ -118,10 +139,10 @@ private:
     std::unique_ptr<geom::Geometry> boundary;
     const geom::GeometryFactory* factory;
     geom::Envelope gridEnv;
-    operation::distance::IndexedFacetDistance obstacleDistance;
     bool done;
-    std::unique_ptr<algorithm::locate::IndexedPointInAreaLocator> ptLocator;
-    std::unique_ptr<operation::distance::IndexedFacetDistance> boundaryDistance;
+    std::unique_ptr<algorithm::locate::IndexedPointInAreaLocator> boundaryPtLocater;
+    IndexedDistanceToPoint obstacleDistance;
+    std::unique_ptr<IndexedFacetDistance> boundaryDistance;
     geom::CoordinateXY centerPt;
     geom::CoordinateXY radiusPt;
diff --git a/include/geos/geom/util/PolygonalExtracter.h b/include/geos/geom/util/PolygonalExtracter.h
index 000000000..9dfba65d5
--- /dev/null
+++ b/include/geos/geom/util/PolygonalExtracter.h
@@ -0,0 +1,54 @@
+ * Copyright (C) 2001-2002 Vivid Solutions Inc.
+ * Copyright (C) 2006 Refractions Research Inc.
+#pragma once
+#include <geos/export.h>
+#include <vector>
+namespace geos {
+namespace geom { // geos.geom
+namespace util { // geos.geom.util
+ * \brief Extracts the polygonal (Polygon and MultiPolygon) elements from a Geometry.
+class GEOS_DLL PolygonalExtracter {
+public:
+     * Pushes the polygonal (Polygon and MultiPolygon) elements from a geometry into
+     * the provided vector.
+     * @param geom the geometry to extract from
+     * @param polys the vector to add the polygonal elements to
+    static void getPolygonals(const Geometry& geom, std::vector<const Geometry*>& polys);
+private:
+    static void getPolygonals(const Geometry* geom, std::vector<const Geometry*>& polys);
+    PolygonalExtracter(const PolygonalExtracter& other) = delete;
+    PolygonalExtracter& operator=(const PolygonalExtracter& rhs) = delete;
+} // namespace geos.geom.util
diff --git a/src/algorithm/construct/IndexedDistanceToPoint.cpp b/src/algorithm/construct/IndexedDistanceToPoint.cpp
index 000000000..92c703ef8
--- /dev/null
+++ b/src/algorithm/construct/IndexedDistanceToPoint.cpp
@@ -0,0 +1,68 @@
+//using namespace geos::geom;
+namespace geos {
+namespace algorithm { // geos.algorithm
+namespace construct { // geos.algorithm.construct
+IndexedDistanceToPoint::IndexedDistanceToPoint(const Geometry& geom)
+    : targetGeometry(geom)
+/* private */
+void IndexedDistanceToPoint::init()
+    if (facetDistance != nullptr)
+      return;
+    ptLocator.reset(new IndexedPointInPolygonsLocator(targetGeometry));
+    facetDistance.reset(new IndexedFacetDistance(&targetGeometry));
+/* public */
+double IndexedDistanceToPoint::distance(const Point& pt)
+    init();
+    //-- distance is 0 if point is inside a target polygon
+    if (isInArea(pt)) {
+        return 0;
+    return facetDistance->distance(&pt);
+/* private */
+bool IndexedDistanceToPoint::isInArea(const Point& pt)
+    return Location::EXTERIOR != ptLocator->locate(pt.getCoordinate());
+/* public */
+std::unique_ptr<geom::CoordinateSequence>
+IndexedDistanceToPoint::nearestPoints(const Point& pt)
+    return facetDistance->nearestPoints(&pt);
diff --git a/src/algorithm/construct/IndexedPointInPolygonsLocator.cpp b/src/algorithm/construct/IndexedPointInPolygonsLocator.cpp
index 000000000..bb9e51abe
--- /dev/null
+++ b/src/algorithm/construct/IndexedPointInPolygonsLocator.cpp
@@ -0,0 +1,70 @@
+#include <geos/geom/Envelope.h>
+#include <geos/geom/util/PolygonalExtracter.h>
+#include <vector>
+using geos::geom::Envelope;
+using geos::geom::util::PolygonalExtracter;
+namespace geos {
+/* public */
+IndexedPointInPolygonsLocator::IndexedPointInPolygonsLocator(const Geometry& g)
+    : geom(g), isInitialized(false)
+/* private */
+void IndexedPointInPolygonsLocator::init()
+    if (isInitialized) {
+        return;
+    isInitialized = true;
+    std::vector<const Geometry*> polys;
+    PolygonalExtracter::getPolygonals(geom, polys);
+    for (const Geometry* poly : polys) {
+        IndexedPointInAreaLocator* ptLocator = new IndexedPointInAreaLocator(*poly);
+        locators.emplace_back(ptLocator);
+        index.insert(poly->getEnvelopeInternal(), ptLocator);
+/* public */
+Location IndexedPointInPolygonsLocator::locate(const CoordinateXY* /*const*/ pt)
+    init();
+    Envelope queryEnv(*pt);
+    std::vector<IndexedPointInAreaLocator*> result;
+    index.query(queryEnv, result);
+    for (IndexedPointInAreaLocator* ptLocater : result) {
+      Location loc = ptLocater->locate(pt);
+      if (loc != Location::EXTERIOR)
+        return loc;
+    return Location::EXTERIOR;
diff --git a/src/algorithm/construct/LargestEmptyCircle.cpp b/src/algorithm/construct/LargestEmptyCircle.cpp
index 68f50223a..c4fc40f09 100644
--- a/src/algorithm/construct/LargestEmptyCircle.cpp
+++ b/src/algorithm/construct/LargestEmptyCircle.cpp
@@ -49,8 +49,8 @@ LargestEmptyCircle::LargestEmptyCircle(const Geometry* p_obstacles, const Geomet
     : tolerance(p_tolerance)
     , obstacles(p_obstacles)
     , factory(p_obstacles->getFactory())
-    , obstacleDistance(p_obstacles)
     , done(false)
+    , obstacleDistance(*p_obstacles)
     if (obstacles->isEmpty()) {
         throw util::IllegalArgumentException("Empty obstacles geometry is not supported");
@@ -164,14 +164,14 @@ LargestEmptyCircle::mayContainCircleCenter(const Cell& cell, const Cell& farthes
 double
 LargestEmptyCircle::distanceToConstraints(const Coordinate& c)
-    bool isOutside = ptLocator && (Location::EXTERIOR == ptLocator->locate(&c));
+    bool isOutside = boundaryPtLocater && (Location::EXTERIOR == boundaryPtLocater->locate(&c));
     std::unique_ptr<Point> pt(factory->createPoint(c));
     if (isOutside) {
         double boundaryDist = boundaryDistance->distance(pt.get());
         return -boundaryDist;
-    double dist = obstacleDistance.distance(pt.get());
+    double dist = obstacleDistance.distance(*(pt.get()));
     return dist;
@@ -200,8 +200,8 @@ LargestEmptyCircle::initBoundary()
     gridEnv = *(boundary->getEnvelopeInternal());
     // if boundary does not enclose an area cannot create a ptLocator
     if (boundary->getDimension() >= 2) {
-        ptLocator.reset(new algorithm::locate::IndexedPointInAreaLocator(*(boundary.get())));
-        boundaryDistance.reset(new operation::distance::IndexedFacetDistance(boundary.get()));
+        boundaryPtLocater = detail::make_unique<algorithm::locate::IndexedPointInAreaLocator>(*(boundary.get()));
+        boundaryDistance = detail::make_unique<operation::distance::IndexedFacetDistance>(boundary.get());
@@ -214,7 +214,7 @@ LargestEmptyCircle::compute()
     initBoundary();
     // if ptLocator is not present then result is degenerate (represented as zero-radius circle)
-    if (!ptLocator) {
+    if (!boundaryPtLocater) {
         const CoordinateXY* pt = obstacles->getCoordinate();
         centerPt = *pt;
         radiusPt = *pt;
@@ -273,7 +273,7 @@ LargestEmptyCircle::compute()
     // compute radius point
     std::unique_ptr<Point> centerPoint(factory->createPoint(centerPt));
-    const auto& nearestPts = obstacleDistance.nearestPoints(centerPoint.get());
+    const auto& nearestPts = obstacleDistance.nearestPoints(*(centerPoint.get()));
     radiusPt = nearestPts->getAt(0);
     // flag computation
diff --git a/src/geom/util/PolygonalExtracter.cpp b/src/geom/util/PolygonalExtracter.cpp
index 000000000..009b10969
--- /dev/null
+++ b/src/geom/util/PolygonalExtracter.cpp
@@ -0,0 +1,49 @@
+#include <geos/geom/Polygon.h>
+#include <geos/geom/MultiPolygon.h>
+#include <vector>
+namespace geos {
+void
+PolygonalExtracter::getPolygonals(const Geometry& geom, std::vector<const Geometry*>& polys)
+    getPolygonals(&geom, polys);
+void
+PolygonalExtracter::getPolygonals(const Geometry* geom, std::vector<const Geometry*>& polys)
+   if (dynamic_cast<const Polygon*>(geom) != nullptr
+         || dynamic_cast<const MultiPolygon*>(geom) != nullptr ) {
+  		polys.push_back(geom);
+  	else if (dynamic_cast<const GeometryCollection*>(geom) != nullptr) {
+  	  for (std::size_t i = 0; i < geom->getNumGeometries(); i++) {
+  	    getPolygonals(geom->getGeometryN(i), polys);
diff --git a/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp b/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
index 959beb4a0..b0110fa0f 100644
--- a/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
+++ b/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
@@ -1,30 +1,21 @@
 // Test Suite for geos::algorithm::construct::LargestEmptyCircle
 #include <tut/tut.hpp>
 // geos
-#include <geos/operation/distance/IndexedFacetDistance.h>
 #include <geos/algorithm/construct/LargestEmptyCircle.h>
-#include <geos/geom/Dimension.h>
 #include <geos/geom/GeometryFactory.h>
-#include <geos/geom/LineString.h>
 #include <geos/geom/PrecisionModel.h>
 #include <geos/io/WKTReader.h>
-#include <geos/io/WKTWriter.h>
 #include <geos/constants.h>
 // std
 #include <sstream>
 #include <string>
 #include <memory>
-using namespace geos;
 using geos::algorithm::construct::LargestEmptyCircle;
 namespace tut {
@@ -32,30 +23,24 @@ namespace tut {
 // Test Group
-// dummy data, not used
-struct test_lec_data {
-    geos::geom::Geometry* geom_;
-    geos::geom::PrecisionModel pm_;
-    geos::geom::GeometryFactory::Ptr factory_;
+struct test_data_LargestEmptyCircle {
+    PrecisionModel pm_;
+    GeometryFactory::Ptr factory_;
     geos::io::WKTReader reader_;
-    geos::io::WKTWriter writer_;
-    test_lec_data():
-        geom_(nullptr),
-        pm_(geos::geom::PrecisionModel::FLOATING),
+    test_data_LargestEmptyCircle():
+        pm_(PrecisionModel::FLOATING),
         factory_(GeometryFactory::create(&pm_, 0)),
         reader_(factory_.get())
-    ~test_lec_data()
+    ~test_data_LargestEmptyCircle()
-        factory_->destroyGeometry(geom_);
-        geom_ = nullptr;
     void
-    ensure_equals_coordinate(const geos::geom::Coordinate &lhs,
-                             const geos::geom::Coordinate &rhs, double tolerance)
+    ensure_equals_coordinate(const Coordinate &lhs,
+                             const Coordinate &rhs, double tolerance)
         ensure_equals("x coordinate does not match", lhs.x, rhs.x, tolerance);
         ensure_equals("y coordinate does not match", lhs.y, rhs.y, tolerance);
@@ -145,117 +130,88 @@ struct test_lec_data {
-typedef test_group<test_lec_data> group;
+typedef test_group<test_data_LargestEmptyCircle> group;
 typedef group::object object;
-group test_lec_group("geos::algorithm::construct::LargestEmptyCircle");
+group test_group_LargestEmptyCircle("geos::algorithm::construct::LargestEmptyCircle");
 // testPointsSquare
+template<>
 template<>
-template<>
-void object::test<1>
+void object::test<1>()
     checkCircle("MULTIPOINT ((100 100), (100 200), (200 200), (200 100))",
-       0.01, 150, 150, 70.71 );}
+       0.01, 150, 150, 70.71 );
 // testPointsTriangleOnHull
 template<>
 template<>
-void object::test<2>
+void object::test<2>()
     checkCircle("MULTIPOINT ((100 100), (300 100), (150 50))",
        0.01, 216.66, 99.99, 83.33 );
 // testPointsTriangleInterior
 template<>
 template<>
-void object::test<3>
+void object::test<3>()
  checkCircle("MULTIPOINT ((100 100), (300 100), (200 250))",
        0.01, 200.00, 141.66, 108.33 );
 // testLinesOpenDiamond
 template<>
 template<>
-void object::test<4>
+void object::test<4>()
     checkCircle("MULTILINESTRING ((50 100, 150 50), (250 50, 350 100), (350 150, 250 200), (50 150, 150 200))",
-       0.01, 200, 125, 90.13 );}
+       0.01, 200, 125, 90.13 );
 //    testLinesCrossed
 template<>
 template<>
-void object::test<5>
+void object::test<5>()
   checkCircle("MULTILINESTRING ((100 100, 300 300), (100 200, 300 0))",
        0.01, 299.99, 150.00, 106.05 );
 // testLinesZigzag
 template<>
 template<>
-void object::test<6>
+void object::test<6>()
     checkCircle("MULTILINESTRING ((100 100, 200 150, 100 200, 250 250, 100 300, 300 350, 100 400), (70 380, 0 350, 50 300, 0 250, 50 200, 0 150, 50 120))",
        0.01, 77.52, 249.99, 54.81 );
 // testPointsLinesTriangle
 template<>
 template<>
-void object::test<7>
+void object::test<7>()
 checkCircle("GEOMETRYCOLLECTION (LINESTRING (100 100, 300 100), POINT (250 200))",
        0.01, 196.49, 164.31, 64.31 );
 template<>
 template<>
-void object::test<8>
+void object::test<8>()
 checkCircleZeroRadius("POINT (100 100)",
        0.01 );
 // testLineFlat
 template<>
 template<>
-void object::test<9>
+void object::test<9>()
  checkCircleZeroRadius("LINESTRING (0 0, 50 50)",
        0.01 );
@@ -264,18 +220,47 @@ void object::test<9>
 // testThinExtent
 template<>
 template<>
-void object::test<10>
+void object::test<10>()
     checkCircle("MULTIPOINT ((100 100), (300 100), (200 100.1))",
        0.01 );
+//------------ Polygon Obstacles -----------------
+// testPolygonConcave
+template<>
+template<>
+void object::test<11>()
+    checkCircle("POLYGON ((1 9, 9 6, 6 5, 5 3, 8 3, 9 4, 9 1, 1 1, 1 9))",
+        0.01, 7.495, 4.216, 1.21);
+// testPolygonsBoxes
+template<>
+template<>
+void object::test<12>()
+    checkCircle("MULTIPOLYGON (((1 6, 6 6, 6 1, 1 1, 1 6)), ((6 7, 4 7, 4 9, 6 9, 6 7)))",
+        0.01, 2.50, 7.50, 1.50);
+// testPolygonLines
+template<>
+template<>
+void object::test<13>()
+    checkCircle("GEOMETRYCOLLECTION (POLYGON ((1 6, 6 6, 6 1, 1 1, 1 6)), LINESTRING (6 7, 3 9), LINESTRING (1 7, 3 8))",
+        0.01, 3.74, 7.14, 1.14);
+//----------  Obstacles and Boundary  --------------
 // testBoundaryEmpty
 template<>
 template<>
-void object::test<11>
+void object::test<14>()
  checkCircle("MULTIPOINT ((2 2), (8 8), (7 5))",
         "POLYGON EMPTY",
@@ -285,8 +270,7 @@ void object::test<11>
 // testBoundarySquare
 template<>
 template<>
-void object::test<12>
+void object::test<15>()
     checkCircle("MULTIPOINT ((2 2), (6 4), (8 8))",
         "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))",
@@ -296,8 +280,7 @@ void object::test<12>
 //testBoundarySquareObstaclesOutside
 template<>
 template<>
-void object::test<13>
+void object::test<16>()
     checkCircle("MULTIPOINT ((10 10), (10 0))",
@@ -307,8 +290,7 @@ void object::test<13>
 // testBoundaryMultiSquares
 template<>
 template<>
-void object::test<14>
+void object::test<17>()
     checkCircle("MULTIPOINT ((10 10), (10 0), (5 5))",
         "MULTIPOLYGON (((1 9, 9 9, 9 1, 1 1, 1 9)), ((15 20, 20 20, 20 15, 15 15, 15 20)))",
@@ -318,12 +300,20 @@ void object::test<14>
 // testBoundaryAsObstacle
 template<>
 template<>
-void object::test<15>
+void object::test<18>()
-    checkCircle("GEOMETRYCOLLECTION (POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9)), POINT (4 3), POINT (7 6))",
+    checkCircle("GEOMETRYCOLLECTION (LINESTRING (1 9, 9 9, 9 1, 1 1, 1 9), POINT (4 3), POINT (7 6))",
         0.01, 4, 6, 3 );
+// testObstacleEmptyElement
+template<>
+template<>
+void object::test<19>()
+    checkCircle("GEOMETRYCOLLECTION (LINESTRING EMPTY, POINT (4 3), POINT (7 6), POINT (4 6))",
+        0.01, 5.5, 4.5, 2.12 );
 } // namespace tut
diff --git a/tests/unit/capi/GEOSLargestEmptyCircleTest.cpp b/tests/unit/capi/GEOSLargestEmptyCircleTest.cpp
index 000000000..aff84e2ec
--- /dev/null
+++ b/tests/unit/capi/GEOSLargestEmptyCircleTest.cpp
@@ -0,0 +1,69 @@
+// $Id$
+// Test Suite for C-API GEOSLargestEmptyCircle
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_data_GEOSLargestEmptyCircle : public capitest::utility {
+    test_data_GEOSLargestEmptyCircle()
+    ~test_data_GEOSLargestEmptyCircle()
+typedef test_group<test_data_GEOSLargestEmptyCircle> group;
+typedef group::object object;
+group test_capi_largestemptycircle_group("capi::GEOSLargestEmptyCircle");
+// Test Cases
+// Points of a square
+template<>
+template<>
+    input_ = GEOSGeomFromWKT("MULTIPOINT ((100 100), (100 200), (200 200), (200 100))");
+    result_ = GEOSLargestEmptyCircle(input_, nullptr, 0.001);
+    expected_ = GEOSGeomFromWKT("LINESTRING (150 150, 100 100)");
+    ensure_geometry_equals_exact(result_, expected_, 0.0001);
+// Line obstacles with square boundary
+template<>
+template<>
+    input_ = GEOSGeomFromWKT("MULTILINESTRING ((40 90, 90 60), (90 40, 40 10))");
+    geom2_ = GEOSGeomFromWKT("POLYGON ((0 100, 100 100, 100 0, 0 0, 0 100))");
+    result_ = GEOSLargestEmptyCircle(input_, geom2_, 0.001);
+    expected_ = GEOSGeomFromWKT("LINESTRING (0.00038147 49.99961853, 40 10)");
+} // namespace tut
diff --git a/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp b/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
index 556c9a993..60ef3f10b 100644
--- a/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
+++ b/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
@@ -1,6 +1,6 @@
 // $Id$
-// Test Suite for C-API GEOSGetCentroid
+// Test Suite for C-API GEOSMaximumInscribedCircle
 // geos
@@ -44,7 +44,7 @@ group test_capimaximuminscribedcircle_group("capi::GEOSMaximumInscribedCircle");
 // Test Cases
-// Single point
+// Square
 template<>
 template<>
@@ -60,28 +60,11 @@ void object::test<1>
     ensure_equals(std::string(wkt_), std::string("LINESTRING (150 150, 150 200)"));
-// Single point
-template<>
-template<>
-    geom1_ = GEOSGeomFromWKT("MULTIPOINT ((100 100), (100 200), (200 200), (200 100))");
-    ensure(nullptr != geom1_);
-    geom2_ = GEOSLargestEmptyCircle(geom1_, nullptr, 0.001);
-    ensure(nullptr != geom2_);
-    wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
-    ensure_equals(std::string(wkt_), std::string("LINESTRING (150 150, 100 100)"));
 // Crash with Inf coords
 // https://github.com/libgeos/geos/issues/821
 template<>
 template<>
     std::string wkb("0106000020E61000000100000001030000000100000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F");
diff --git a/tests/unit/capi/capi_test_utils.h b/tests/unit/capi/capi_test_utils.h
index 11305e956..d6a9dc668 100644
--- a/tests/unit/capi/capi_test_utils.h
+++ b/tests/unit/capi/capi_test_utils.h
@@ -93,17 +93,30 @@ namespace capitest {
         void
         ensure_geometry_equals(GEOSGeometry* g1, GEOSGeometry* g2, double tolerance)
-            GEOSNormalize(g1);
-            GEOSNormalize(g2);
-            char rslt = GEOSEqualsExact(g1, g2, tolerance);
-            if (rslt != 1)
-                char* wkt1 = GEOSWKTWriter_write(wktw_, g1);
-                char* wkt2 = GEOSGeomToWKT(g2);
-                std::fprintf(stdout, "\n%s != %s\n", wkt1, wkt2);
-                GEOSFree(wkt1);
-                GEOSFree(wkt2);
+            char rslt;
+            if (g1 == nullptr || g2 == nullptr) {
+                rslt = (g1 == nullptr && g2 == nullptr) ? 1 : 0;
+            else {
+                GEOSNormalize(g1);
+                GEOSNormalize(g2);
+                rslt = GEOSEqualsExact(g1, g2, tolerance);
+            report_not_equal("ensure_equals_norm", g1, g2, tolerance, rslt);
+            tut::ensure_equals("GEOSEqualsExact(g1, g2, tolerance)", rslt, 1);
+        void
+        ensure_geometry_equals_exact(GEOSGeometry* g1, GEOSGeometry* g2, double tolerance)
+            char rslt;
+            else {
+            report_not_equal("ensure_equals_exact", g1, g2, tolerance, rslt);
@@ -133,7 +146,24 @@ namespace capitest {
             tut::ensure_equals("GEOSEqualsExact(g1, g2, 1e-12)", rslt, 1);
+        void
+        report_not_equal(const char* tag, GEOSGeometry* g1, GEOSGeometry* g2, double tolerance, char rslt)
+            if (rslt == 1) return;
+            //TODO: handle rslt exception value
+            char* wkt1 = nullptr;
+            char* wkt2 = nullptr;
+            if (g1 != nullptr)
+                wkt1 = GEOSWKTWriter_write(wktw_, g1);
+            if (g2 != nullptr)
+                wkt2 = GEOSWKTWriter_write(wktw_, g2);
+            const char* val1 = (g1 == nullptr) ? "null" : wkt1;
+            const char* val2 = (g2 == nullptr) ? "null" : wkt2;
+            std::fprintf(stdout, "\n%s : %s != %s (tol = %f)\n", tag, val1, val2, tolerance);
+            GEOSFree(wkt1);
+            GEOSFree(wkt2);
Summary of changes:
 capi/geos_c.h.in                                   |  11 +-
 .../algorithm/construct/IndexedDistanceToPoint.h   |  88 ++++++++++++
 .../construct/IndexedPointInPolygonsLocator.h      |  79 +++++++++++
 .../geos/algorithm/construct/LargestEmptyCircle.h  |  63 ++++++---
 include/geos/geom/util/PolygonalExtracter.h        |  54 ++++++++
 src/algorithm/construct/IndexedDistanceToPoint.cpp |  68 +++++++++
 .../construct/IndexedPointInPolygonsLocator.cpp    |  70 ++++++++++
 src/algorithm/construct/LargestEmptyCircle.cpp     |  14 +-
 .../{PointExtracter.cpp => PolygonalExtracter.cpp} |  42 ++----
 .../algorithm/construct/LargestEmptyCircleTest.cpp | 152 ++++++++++-----------
 tests/unit/capi/GEOSLargestEmptyCircleTest.cpp     |  69 ++++++++++
 tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp |  23 +---
 tests/unit/capi/capi_test_utils.h                  |  52 +++++--
 13 files changed, 615 insertions(+), 170 deletions(-)
 create mode 100644 include/geos/algorithm/construct/IndexedDistanceToPoint.h
 create mode 100644 include/geos/algorithm/construct/IndexedPointInPolygonsLocator.h
 create mode 100644 include/geos/geom/util/PolygonalExtracter.h
 create mode 100644 src/algorithm/construct/IndexedDistanceToPoint.cpp
 create mode 100644 src/algorithm/construct/IndexedPointInPolygonsLocator.cpp
 copy src/geom/util/{PointExtracter.cpp => PolygonalExtracter.cpp} (50%)
 create mode 100644 tests/unit/capi/GEOSLargestEmptyCircleTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
