[geos-commits] [SCM] GEOS branch main updated. cf1e312f0f6707ec74facbaababf00424006456b
Tue Jul 18 12:03:51 PDT 2023
the project "GEOS".
The branch, main has been updated
       via  cf1e312f0f6707ec74facbaababf00424006456b (commit)
       via  a911163d5f4d065695be733d46fd078901928c86 (commit)
       via  c7c4495543bb91ed902ca068da3ac7d512e6a66c (commit)
      from  2f9e7531804e3a4f09823d8f1b9536cb04d313bf (commit)
revisions in full, below.
commit cf1e312f0f6707ec74facbaababf00424006456b
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Jul 18 12:00:52 2023 -0700
    Improve C API doc for LineMerge
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index a45685cf4..271624334 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -4449,10 +4449,12 @@ extern GEOSGeometry GEOS_DLL *GEOSDensify(
     double tolerance);
-* Sews together a set of fully noded LineStrings
-* removing any cardinality 2 nodes in the linework.
+* Merges a set of LineStrings,
+* joining them at nodes which have cardinality 2.
+* Lines may have their direction reversed.
 * \param g The input linework
-* \return The merged linework
+* \return The merged linework.
 * Caller is responsible for freeing with GEOSGeom_destroy().
 * \see geos::operation::linemerge::LineMerger
 * \since 2.2
@@ -4460,11 +4462,13 @@ extern GEOSGeometry GEOS_DLL *GEOSDensify(
 extern GEOSGeometry GEOS_DLL *GEOSLineMerge(const GEOSGeometry* g);
-* only if possible without changing order of points.
+* and where the lines have the same direction.
+* This means that lines do not have their direction reversed.
commit a911163d5f4d065695be733d46fd078901928c86
Date:   Tue Jul 18 11:53:39 2023 -0700
    Add doxygen formatting
index 7ff9f9de0..a45685cf4 100644
@@ -4140,14 +4140,14 @@ extern GEOSGeometry GEOS_DLL *GEOSMaximumInscribedCircle(
 * the obstacles (up to the given distance tolerance).
 * The LEC is determined by the center point and a point indicating the circle radius
 * (which will lie on an obstacle).
+* \n
 * To compute an LEC which lies **wholly** within a polygonal boundary,
 * include the boundary of the polygon(s) as a linear obstacle.
+* \n
 * The implementation uses a successive-approximation technique over a grid of square cells covering the obstacles and boundary.
 * The grid is refined using a branch-and-bound algorithm.  Point containment and distance are computed in a performant
 * way by using spatial indexes.
+* \n
 * Returns the LEC radius as a two-point linestring, with the start point at the center of the inscribed circle and the end
 * on the boundary of the circle.
commit c7c4495543bb91ed902ca068da3ac7d512e6a66c
Date:   Tue Jul 18 11:50:14 2023 -0700
    Improve comment for GEOSFree
index 3466cef60..7ff9f9de0 100644
@@ -2098,7 +2098,9 @@ extern void GEOS_DLL finishGEOS(void);
 * Free strings and byte buffers returned by functions such
 * as GEOSWKBWriter_write(),
 * GEOSWKBWriter_writeHEX() and GEOSWKTWriter_write(), etc.
-* \param buffer The memory to free
+* If passed a null pointer the function does nothing.
+* \param buffer The memory to free (may be null)
 * \since 3.1
 extern void GEOS_DLL GEOSFree(void *buffer);
Summary of changes:
 capi/geos_c.h.in | 28 +++++++++++++++++-----------
 1 file changed, 17 insertions(+), 11 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
