[geos-commits] [SCM] GEOS branch main updated. ef3cb817095e1439bcce5876b5e9c8ac92b308e3
git at osgeo.org
git at osgeo.org
Tue Jul 18 12:16:35 PDT 2023
the project "GEOS".
The branch, main has been updated
via ef3cb817095e1439bcce5876b5e9c8ac92b308e3 (commit)
via 423dcdc06c5e7194129d96ab992f89edda3e321b (commit)
from cf1e312f0f6707ec74facbaababf00424006456b (commit)
revisions in full, below.
commit ef3cb817095e1439bcce5876b5e9c8ac92b308e3
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Jul 18 12:16:16 2023 -0700
Update NEWS
diff --git a/NEWS.md b/NEWS.md
index 80c45cb9c..effecd7b6 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -10,6 +10,7 @@
- WKTWriter: Points with all-NaN coordinates are written as such (GH-927, Casper van der Wel)
- ConvexHull: Performance improvement for larger geometries (JTS-985, Martin Davis)
- Intersection: change to using DoubleDouble computation to improve robustness (GH-937, Martin Davis)
+ - Fix LargestEmptyCircle to respect polygonal obstacles (GH-939, Martin Davis)
## Changes in 3.12.0
commit 423dcdc06c5e7194129d96ab992f89edda3e321b
Date: Tue Jul 18 12:14:00 2023 -0700
Add geosop op largestEmptyCircleBdy
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index b66531293..34a854918 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -379,13 +379,22 @@ std::vector<GeometryOpCreator> opRegistry {
{"largestEmptyCircle", [](std::string name) { return GeometryOp::create(name,
catConst,
- "compute radius line of largest empty circle of geometry up to a distance tolerance",
+ "compute radius line of largest empty circle between obstacles, up to a distance tolerance",
[](const std::unique_ptr<Geometry>& geom, double d) {
geos::algorithm::construct::LargestEmptyCircle lec( geom.get(), d );
std::unique_ptr<Geometry> res = lec.getRadiusLine();
return new Result( std::move(res) );
+{"largestEmptyCircleBdy", [](std::string name) { return GeometryOp::create(name,
+ catConst,
+ "compute radius line of largest empty circle between obstacles with center in a boundary, up to a distance tolerance",
+ [](const std::unique_ptr<Geometry>& geom, const std::unique_ptr<Geometry>& geom2, double d) {
+ geos::algorithm::construct::LargestEmptyCircle lec( geom.get(), geom2.get(), d );
+ std::unique_ptr<Geometry> res = lec.getRadiusLine();
+ return new Result( std::move(res) );
{"maxInscribedCircle", [](std::string name) { return GeometryOp::create(name,
catConst,
"compute maximum inscribed circle radius of Polygon up to a distance tolerance",
Summary of changes:
NEWS.md | 1 +
util/geosop/GeometryOp.cpp | 11 ++++++++++-
2 files changed, 11 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
