[geos-commits] [SCM] GEOS branch main updated. 6bc91ff0f985abb96e44f1c8ef9cf010d9d2006c
git at osgeo.org
git at osgeo.org
Fri Jun 30 16:33:58 PDT 2023
the project "GEOS".
The branch, main has been updated
via 6bc91ff0f985abb96e44f1c8ef9cf010d9d2006c (commit)
via 01a976f53f5bc74dc029f2f288ce5d6078b5d473 (commit)
from fa3b4ef70cd386135f5687720d0efc22ab770c22 (commit)
revisions in full, below.
commit 6bc91ff0f985abb96e44f1c8ef9cf010d9d2006c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Jun 30 16:23:56 2023 -0700
Explicitly set endianness for some tests so that output matches expected. Closes #934
diff --git a/tests/unit/capi/GEOSWKBWriterTest.cpp b/tests/unit/capi/GEOSWKBWriterTest.cpp
index c50dfa55b..9b49cba8f 100644
--- a/tests/unit/capi/GEOSWKBWriterTest.cpp
+++ b/tests/unit/capi/GEOSWKBWriterTest.cpp
@@ -15,7 +15,9 @@ struct test_geoswkbwriter_data : public capitest::utility {
test_geoswkbwriter_data() :
wkbwriter_(GEOSWKBWriter_create()),
buf_(nullptr)
+ GEOSWKBWriter_setByteOrder(wkbwriter_, GEOS_WKB_NDR);
~test_geoswkbwriter_data() {
GEOSWKBWriter_destroy(wkbwriter_);
diff --git a/tests/unit/io/WKBWriterTest.cpp b/tests/unit/io/WKBWriterTest.cpp
index 79ea973dc..eb4cf3102 100644
--- a/tests/unit/io/WKBWriterTest.cpp
+++ b/tests/unit/io/WKBWriterTest.cpp
@@ -327,6 +327,7 @@ void object::test<11>
std::stringstream iso_result_stream;
wkbwriter.setOutputDimension(4);
wkbwriter.setFlavor(geos::io::WKBConstants::wkbFlavour::wkbIso);
+ wkbwriter.setByteOrder(1); // little endian
wkbwriter.writeHEX(*geom, iso_result_stream);
ensure_equals("XYZM ISO",
@@ -358,6 +359,7 @@ void object::test<12>
ensure_equals("XYM ISO",
commit 01a976f53f5bc74dc029f2f288ce5d6078b5d473
Date: Fri Jun 30 08:56:02 2023 -0700
Use DD algorithm in mitred buffer calculation: relatively low
performance impact, and more stable output. References GH-933.
diff --git a/src/operation/buffer/OffsetSegmentGenerator.cpp b/src/operation/buffer/OffsetSegmentGenerator.cpp
index 32ab310f0..729f6c7ac 100644
--- a/src/operation/buffer/OffsetSegmentGenerator.cpp
+++ b/src/operation/buffer/OffsetSegmentGenerator.cpp
@@ -32,7 +32,7 @@
#include <geos/geom/Coordinate.h>
#include <geos/geom/PrecisionModel.h>
#include <geos/algorithm/NotRepresentableException.h>
-#include <geos/algorithm/Intersection.h>
+#include <geos/algorithm/CGAlgorithmsDD.h>
#include <geos/util.h>
#ifndef GEOS_DEBUG
@@ -483,7 +483,7 @@ OffsetSegmentGenerator::addMitreJoin(const geom::Coordinate& cornerPt,
* However, this situation should have been eliminated earlier by the check
* for whether the offset segment endpoints are almost coincident
- CoordinateXY intPt = algorithm::Intersection::intersection(p_offset0.p0, p_offset0.p1, p_offset1.p0, p_offset1.p1);
+ CoordinateXY intPt = algorithm::CGAlgorithmsDD::intersection(p_offset0.p0, p_offset0.p1, p_offset1.p0, p_offset1.p1);
if (!intPt.isNull() && intPt.distance(cornerPt) <= mitreLimitDistance) {
segList.addPt(Coordinate(intPt));
Summary of changes:
src/operation/buffer/OffsetSegmentGenerator.cpp | 4 ++--
tests/unit/capi/GEOSWKBWriterTest.cpp | 4 +++-
tests/unit/io/WKBWriterTest.cpp | 2 ++
3 files changed, 7 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
