[geos-commits] [SCM] GEOS branch main-relate-ng updated. 2c9b3cd652118d17af99e1ee902d498f780f7af9
Fri Aug 2 12:19:26 PDT 2024
the project "GEOS".
The branch, main-relate-ng has been updated
       via  2c9b3cd652118d17af99e1ee902d498f780f7af9 (commit)
      from  41bd100781782aabc477892db73a937ba08e6cb9 (commit)
revisions in full, below.
commit 2c9b3cd652118d17af99e1ee902d498f780f7af9
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Aug 2 12:19:05 2024 -0700
    Allow empty geoms to test equal
diff --git a/include/geos/operation/relateng/RelatePredicate.h b/include/geos/operation/relateng/RelatePredicate.h
index fc5fc000d..ca1db412f 100644
--- a/include/geos/operation/relateng/RelatePredicate.h
+++ b/include/geos/operation/relateng/RelatePredicate.h
@@ -490,12 +490,20 @@ class EqualsTopoPredicate : public IMPredicate {
         return std::string("equals");
+    bool requireInteraction() const override {
+        //-- allow EMPTY = EMPTY
+        return false;
     void init(int _dimA, int _dimB) override {
         IMPredicate::init(_dimA, _dimB);
-        require(dimA == dimB);
+        //-- don't require equal dims, because EMPTY = EMPTY for all dims
     void init(const Envelope& envA, const Envelope& envB) override {
+        //-- handle EMPTY = EMPTY cases
+        setValueIf(true, envA.isNull() && envB.isNull());
         require(envA.equals(&envB));
diff --git a/src/operation/relateng/RelateNG.cpp b/src/operation/relateng/RelateNG.cpp
index d4b8baea5..13ab5a1ff 100644
--- a/src/operation/relateng/RelateNG.cpp
+++ b/src/operation/relateng/RelateNG.cpp
@@ -151,10 +151,6 @@ RelateNG::evaluate(const Geometry* b, TopologyPredicate& predicate)
     RelateGeometry geomB(b, boundaryNodeRule);
-    if (geomA.isEmpty() && geomB.isEmpty()) {
-        //TODO: what if predicate is disjoint?  Perhaps use result on disjoint envs?
-        return finishValue(predicate);
     int dimA = geomA.getDimensionReal();
     int dimB = geomB.getDimensionReal();
diff --git a/tests/unit/operation/relateng/RelateNGTest.cpp b/tests/unit/operation/relateng/RelateNGTest.cpp
index cf0a2403b..5e3fca8d2 100644
--- a/tests/unit/operation/relateng/RelateNGTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGTest.cpp
@@ -841,37 +841,32 @@ void object::test<60> ()
 //================  Empty Geometries  ==============
+//-- test equals against all combinations of empty geometries
 template<>
 template<>
 void object::test<61> ()
-    std::string a = "POINT EMPTY";
-    std::string b = "POINT EMPTY";
-    checkRelate(a, b, "FFFFFFFF2");
-    checkEquals(a, b, true);
+    std::string empties[] = {
+        "POINT EMPTY",
+        "LINESTRING EMPTY",
+        "POLYGON EMPTY",
+        "MULTIPOINT EMPTY",
+        "MULTILINESTRING EMPTY",
+        "MULTIPOLYGON EMPTY",
+        "GEOMETRYCOLLECTION EMPTY"
+    int nempty = 7;
+    for (int i = 0; i < nempty; i++) {
+        for (int j = 0; j < nempty; j++) {
+            std::string a = empties[i];
+            std::string b = empties[j];
+            checkRelate(a, b, "FFFFFFFF2");
+            checkEquals(a, b, true);
-template<>
-template<>
-void object::test<62> ()
-    std::string a = "LINESTRING EMPTY";
-    std::string b = "LINESTRING EMPTY";
-template<>
-template<>
-void object::test<63> ()
-    std::string a = "GEOMETRYCOLLECTION EMPTY";
-    std::string b = "GEOMETRYCOLLECTION EMPTY";
 } // namespace tut
Summary of changes:
 include/geos/operation/relateng/RelatePredicate.h | 10 +++++-
 src/operation/relateng/RelateNG.cpp               |  4 ---
 tests/unit/operation/relateng/RelateNGTest.cpp    | 43 ++++++++++-------------
 3 files changed, 28 insertions(+), 29 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
