[geos-commits] [SCM] GEOS branch main updated. 5b22130203397bb9c7a1d701d0b67e8513ca8372
git at osgeo.org
git at osgeo.org
Fri Aug 2 12:29:16 PDT 2024
the project "GEOS".
The branch, main has been updated
via 5b22130203397bb9c7a1d701d0b67e8513ca8372 (commit)
from 7791300797a36a326b27d7eb031ac4a600b90a07 (commit)
revisions in full, below.
commit 5b22130203397bb9c7a1d701d0b67e8513ca8372
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Aug 2 12:28:55 2024 -0700
Fix testing doc path
diff --git a/web/content/project/development/tests.md b/web/content/project/development/tests.md
index 2298639a3..89ba0df2e 100644
--- a/web/content/project/development/tests.md
+++ b/web/content/project/development/tests.md
@@ -40,11 +40,11 @@ $ bin/test_geos_unit capi::GEOSBuffer 1
### XML Tests
The XML test suite is a set of portable, declarative tests which can be run in both GEOS and JTS.
-They are located in `../geos/tests/xmltester/tests`.
+They are located in `tests/xmltester/tests`.
XML tests can be run using `test_xmltester`:
-bin/test_xmltester ../geos/tests/xmltester/tests/robust/overlay/TestOverlay-geos-837.xml
+bin/test_xmltester ../tests/xmltester/tests/robust/overlay/TestOverlay-geos-837.xml
The XML Tester provides the following options:
Summary of changes:
web/content/project/development/tests.md | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
