[geos-commits] [SCM] GEOS branch main updated. e0977f165bd295fc37bd9bddf8daab455d70db8b
git at osgeo.org
git at osgeo.org
Tue Aug 13 12:17:27 PDT 2024
the project "GEOS".
The branch, main has been updated
via e0977f165bd295fc37bd9bddf8daab455d70db8b (commit)
from da5bdb4656b43e7d46b6b065514b142c24a8656f (commit)
revisions in full, below.
commit e0977f165bd295fc37bd9bddf8daab455d70db8b
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Aug 13 12:16:50 2024 -0700
Improve API doc for DE-9IM strings
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index e274a257d..b4f46c7e8 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -4927,15 +4927,18 @@ extern char GEOS_DLL GEOSEqualsIdentical(
const GEOSGeometry* g2);
-* Calculate the DE9IM pattern for this geometry pair
-* and compare against the provided pattern to check for
-* consistency. If the result and pattern are consistent
-* return true. The pattern may include glob "*" characters
-* for portions that are allowed to match any value.
+* Calculate the DE9IM string for a geometry pair
+* and compare against a DE9IM pattern to check for
+* consistency.
+* If the result matches the pattern return true.
+* The pattern is a 9-character string
+* containing symbols in the set "012TF*".
+* "012F" match the corresponding dimension symbol;
+* "T" matches any non-empty dimension.; "*" matches any dimension.
* \see geos::geom::Geometry::relate
* \param g1 First geometry in pair
* \param g2 Second geometry in pair
-* \param imPattern DE9IM pattern to check
+* \param imPattern DE9IM pattern to match
* \return 1 on true, 0 on false, 2 on exception
* \since 2.2
@@ -4945,7 +4948,8 @@ extern char GEOS_DLL GEOSRelatePattern(
const char *imPattern);
-* Calculate and return the DE9IM pattern for this geometry pair.
+* Calculate and return the DE9IM string for this geometry pair.
+* The result is a 9-character string containing dimension symbols in the set "012F".
@@ -4958,10 +4962,10 @@ extern char GEOS_DLL *GEOSRelate(
-* Compare two DE9IM patterns and return true if they
+* Compare a DE9IM string to a pattern and return true if they
* are consistent.
-* \param intMatrix Complete DE9IM string (does not have "*")
-* \param imPattern Pattern to match to (may contain "*")
+* \param intMatrix DE9IM string (contains symbols "012F")
+* \param imPattern Pattern to match to (may also contain symbols "T" and "*")
* \since 3.3
@@ -4971,8 +4975,8 @@ extern char GEOS_DLL GEOSRelatePatternMatch(
-* Apply the supplied \ref GEOSRelateBoundaryNodeRules.
+* Calculate and return the DE9IM string for this geometry pair,
+* using the supplied \ref GEOSRelateBoundaryNodeRules.
* \see geos::algorithm::BoundaryNodeRule
@@ -5202,14 +5206,12 @@ extern char GEOS_DLL GEOSPreparedWithin(
-* Use a \ref GEOSPreparedGeometry do a high performance
+* Use a \ref GEOSPreparedGeometry do a high-performance
* calculation of the DE9IM relationship between the
-* prepared and provided geometry, and compare that
-* relationship to the provided DE9IM, returning
-* true if the patterns are consistent and false otherwise.
+* prepared and provided geometry.
* \param pg1 The prepared geometry
* \param g2 The geometry to test
-* \returns The DE9IM relate pattern string
+* \returns The DE9IM string
* \see GEOSPrepare
* \see GEOSRelate
* \see GEOSPreparedRelatePattern
@@ -5221,9 +5223,11 @@ extern char GEOS_DLL * GEOSPreparedRelate(
-* prepared and provided geometry.
+* prepared and provided geometry, and compare the
+* relationship to the provided DE9IM pattern.
+* Returns true if the patterns are consistent and false otherwise.
* \param imPattern The DE9IM pattern to test
Summary of changes:
capi/geos_c.h.in | 42 +++++++++++++++++++++++-------------------
1 file changed, 23 insertions(+), 19 deletions(-)
hooks/post-receive
More information about the geos-commits
