[geos-commits] [SCM] GEOS branch main updated. f8d57eceff948dd4b3c62f2e6a1abcfbbef22bd4
git at osgeo.org
git at osgeo.org
Tue Aug 13 13:17:02 PDT 2024
the project "GEOS".
The branch, main has been updated
via f8d57eceff948dd4b3c62f2e6a1abcfbbef22bd4 (commit)
from e0977f165bd295fc37bd9bddf8daab455d70db8b (commit)
revisions in full, below.
commit f8d57eceff948dd4b3c62f2e6a1abcfbbef22bd4
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Aug 13 13:16:30 2024 -0700
Minor C API doc fixes
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index b4f46c7e8..201d47060 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -4934,7 +4934,7 @@ extern char GEOS_DLL GEOSEqualsIdentical(
* The pattern is a 9-character string
* containing symbols in the set "012TF*".
* "012F" match the corresponding dimension symbol;
-* "T" matches any non-empty dimension.; "*" matches any dimension.
+* "T" matches any non-empty dimension; "*" matches any dimension.
* \see geos::geom::Geometry::relate
* \param g1 First geometry in pair
* \param g2 Second geometry in pair
@@ -4948,7 +4948,7 @@ extern char GEOS_DLL GEOSRelatePattern(
const char *imPattern);
-* Calculate and return the DE9IM string for this geometry pair.
+* Calculate the DE9IM string for this geometry pair.
* The result is a 9-character string containing dimension symbols in the set "012F".
@@ -4975,7 +4975,7 @@ extern char GEOS_DLL GEOSRelatePatternMatch(
-* Calculate and return the DE9IM string for this geometry pair,
+* Calculate the DE9IM string for this geometry pair,
* using the supplied \ref GEOSRelateBoundaryNodeRules.
* \see geos::algorithm::BoundaryNodeRule
Summary of changes:
capi/geos_c.h.in | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
