[geos-commits] [SCM] GEOS branch main updated. 5a2afd88a1e938f6ed6f42a675ec62152b0fdce9
git at osgeo.org
git at osgeo.org
Tue Aug 13 16:28:42 PDT 2024
the project "GEOS".
The branch, main has been updated
via 5a2afd88a1e938f6ed6f42a675ec62152b0fdce9 (commit)
from f8d57eceff948dd4b3c62f2e6a1abcfbbef22bd4 (commit)
revisions in full, below.
commit 5a2afd88a1e938f6ed6f42a675ec62152b0fdce9
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Aug 13 16:28:09 2024 -0700
Add C API link to DE9IM page
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 201d47060..19f0dcb27 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -4927,7 +4927,7 @@ extern char GEOS_DLL GEOSEqualsIdentical(
const GEOSGeometry* g2);
-* Calculate the DE9IM string for a geometry pair
+* Calculate the [DE9IM](https://en.wikipedia.org/wiki/DE-9IM) string for a geometry pair
* and compare against a DE9IM pattern to check for
* consistency.
* If the result matches the pattern return true.
@@ -4948,7 +4948,7 @@ extern char GEOS_DLL GEOSRelatePattern(
const char *imPattern);
-* Calculate the DE9IM string for this geometry pair.
+* Calculate the [DE9IM](https://en.wikipedia.org/wiki/DE-9IM) string for this geometry pair.
* The result is a 9-character string containing dimension symbols in the set "012F".
* \see geos::geom::Geometry::relate
* \param g1 First geometry in pair
@@ -4962,7 +4962,7 @@ extern char GEOS_DLL *GEOSRelate(
-* Compare a DE9IM string to a pattern and return true if they
+* Compare a [DE9IM](https://en.wikipedia.org/wiki/DE-9IM) string to a pattern and return true if they
* are consistent.
* \param intMatrix DE9IM string (contains symbols "012F")
* \param imPattern Pattern to match to (may also contain symbols "T" and "*")
@@ -4975,7 +4975,7 @@ extern char GEOS_DLL GEOSRelatePatternMatch(
-* Calculate the DE9IM string for this geometry pair,
+* Calculate the [DE9IM](https://en.wikipedia.org/wiki/DE-9IM) string for this geometry pair,
* using the supplied \ref GEOSRelateBoundaryNodeRules.
* \see geos::algorithm::BoundaryNodeRule
@@ -5207,7 +5207,7 @@ extern char GEOS_DLL GEOSPreparedWithin(
* Use a \ref GEOSPreparedGeometry do a high-performance
-* calculation of the DE9IM relationship between the
+* calculation of the [DE9IM](https://en.wikipedia.org/wiki/DE-9IM) relationship between the
* prepared and provided geometry.
* \param pg1 The prepared geometry
* \param g2 The geometry to test
@@ -5224,7 +5224,7 @@ extern char GEOS_DLL * GEOSPreparedRelate(
* prepared and provided geometry, and compare the
* relationship to the provided DE9IM pattern.
* Returns true if the patterns are consistent and false otherwise.
Summary of changes:
capi/geos_c.h.in | 12 ++++++------
1 file changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
