[geos-commits] [SCM] GEOS branch main updated. d9422f5ef776c87c78dabd705e486ee08ca39be7
git at osgeo.org
git at osgeo.org
Fri Aug 16 12:28:04 PDT 2024
the project "GEOS".
The branch, main has been updated
via d9422f5ef776c87c78dabd705e486ee08ca39be7 (commit)
from 7cb7e3f9fe1d858a56d78fa91feffa0279a86104 (commit)
revisions in full, below.
commit d9422f5ef776c87c78dabd705e486ee08ca39be7
Author: Mike Taves <mwtoews at gmail.com>
Date: Sat Aug 17 07:27:46 2024 +1200
Establish minimum CMake version 3.15 (#1143)
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index bf0ccab67..54564f531 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -54,7 +54,7 @@ jobs:
cxxstd: 14
arch: 64
packages: 'g++-7-multilib gcc-7-multilib'
- cmake: 3.13.*
+ cmake: 3.17.*
os: ubuntu-20.04
- cxx_compiler: g++-7
@@ -63,7 +63,7 @@ jobs:
cxxstd: 14
arch: 32
packages: 'g++-7-multilib gcc-7-multilib g++-multilib gcc-multilib'
- cmake: 3.13.*
+ cmake: 3.18.*
os: ubuntu-20.04
- cxx_compiler: g++-8
@@ -72,7 +72,7 @@ jobs:
cxxstd: 14
arch: 64
packages: 'g++-8-multilib gcc-8-multilib'
- cmake: 3.13.*
+ cmake: 3.21.*
os: ubuntu-20.04
- cxx_compiler: g++-9
@@ -81,7 +81,7 @@ jobs:
cxxstd: 14
arch: 64
packages: 'g++-9-multilib gcc-9-multilib'
- cmake: 3.13.*
+ cmake: 3.23.*
os: ubuntu-20.04
- cxx_compiler: g++-10
@@ -90,7 +90,7 @@ jobs:
cxxstd: 14
arch: 64
packages: 'g++-10-multilib gcc-10-multilib'
- cmake: 3.13.*
+ cmake: 3.25.*
os: ubuntu-20.04
# gcc 10 and lower are not supported
@@ -102,7 +102,7 @@ jobs:
cxxstd: 17
arch: 64
packages: 'g++-11-multilib gcc-11-multilib'
- cmake: 3.22.*
+ cmake: 3.27.*
os: ubuntu-22.04
- cxx_compiler: g++-12
@@ -111,7 +111,7 @@ jobs:
cxxstd: 20
arch: 64
packages: 'g++-12-multilib gcc-12-multilib'
- cmake: 3.22.*
+ cmake: 3.29.*
os: ubuntu-22.04
# - cxx_compiler: g++-13
@@ -132,7 +132,7 @@ jobs:
cxxstd: 14
arch: 64
packages: 'clang-7'
- cmake: 3.13.*
+ cmake: 3.15.*
os: ubuntu-20.04
- cxx_compiler: clang++-8
@@ -141,7 +141,7 @@ jobs:
cxxstd: 14
arch: 64
packages: 'clang-8'
- cmake: 3.13.*
+ cmake: 3.17.*
os: ubuntu-20.04
- cxx_compiler: clang++-9
@@ -150,7 +150,7 @@ jobs:
cxxstd: 14
arch: 64
packages: 'clang-9'
- cmake: 3.13.*
+ cmake: 3.20.*
os: ubuntu-20.04
- cxx_compiler: clang++-10
@@ -159,7 +159,7 @@ jobs:
cxxstd: 14
arch: 64
packages: 'clang-10'
- cmake: 3.17.*
+ cmake: 3.21.*
os: ubuntu-20.04
# clang 10 and lower are not supported
@@ -171,7 +171,7 @@ jobs:
cxxstd: 14
arch: 64
packages: 'clang-11'
- cmake: 3.25.*
+ cmake: 3.23.*
os: ubuntu-22.04
- cxx_compiler: clang++-12
@@ -189,7 +189,7 @@ jobs:
cxxstd: 17
arch: 64
packages: 'clang-13'
- cmake: 3.25.*
+ cmake: 3.27.*
os: ubuntu-22.04
- cxx_compiler: clang++-14
@@ -198,7 +198,7 @@ jobs:
cxxstd: 20
arch: 64
packages: 'clang-14'
- cmake: 3.25.*
+ cmake: 3.29.*
os: ubuntu-22.04
runs-on: ${{ matrix.ci.os }}
@@ -544,7 +544,7 @@ jobs:
sudo -E apt-get update
sudo -E apt-get autopurge -y needrestart
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make python3-pip g++
- python3 -m pip install --disable-pip-version-check --user cmake==3.13.*
+ python3 -m pip install --disable-pip-version-check --user cmake==3.15.*
echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
- name: 'Check Out'
diff --git a/CMakeLists.txt b/CMakeLists.txt
index d9f332217..c5548cecc 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -9,9 +9,7 @@
# See the COPYING file for more information.
-# Require CMake 3.13+ with support for meta-features that request compiler
-# modes for specific C/C++ language standard levels, and object libraries.
-cmake_minimum_required(VERSION 3.13)
+cmake_minimum_required(VERSION 3.15)
# Version
@@ -24,6 +22,7 @@ string(REGEX MATCH "GEOS_VERSION_MINOR=([0-9]+)" _ ${_version_txt})
set(_version_minor ${CMAKE_MATCH_1})
string(REGEX MATCH "GEOS_VERSION_PATCH=([0-9]+)" _ ${_version_txt})
set(_version_patch ${CMAKE_MATCH_1})
+set(GEOS_VERSION_NOPATCH "${_version_major}.${_version_minor}.${_version_patch}")
# OPTIONS: "", "dev", "rc1" etc.
string(REGEX MATCH "GEOS_PATCH_WORD=([a-zA-Z0-9]+)" _ ${_version_txt})
set(_version_patch_word ${CMAKE_MATCH_1})
@@ -56,23 +55,19 @@ unset(_version_capi_revision)
# Project
-if(CMAKE_VERSION VERSION_GREATER_EQUAL 3.9)
- list(APPEND _project_info DESCRIPTION "GEOS - C++ port of the Java Topology Suite (JTS)")
-endif()
-if(CMAKE_VERSION VERSION_GREATER_EQUAL 3.12)
- list(APPEND _project_info HOMEPAGE_URL "https://libgeos.org/")
-endif()
-project(GEOS VERSION "${_version_major}.${_version_minor}.${_version_patch}"
+project(GEOS
+ VERSION ${GEOS_VERSION_NOPATCH}
LANGUAGES C CXX
- ${_project_info})
+ DESCRIPTION "GEOS - C++ port of the Java Topology Suite (JTS)"
+ HOMEPAGE_URL "https://libgeos.org/"
if(NOT "${_version_patch_word}" STREQUAL "")
# Re-write VERSION variables after project()
set(GEOS_VERSION "${GEOS_VERSION}${_version_patch_word}")
set(GEOS_VERSION_PATCH "${_version_patch}${_version_patch_word}")
endif()
-set(GEOS_VERSION_NOPATCH "${_version_major}.${_version_minor}.${_version_patch}")
unset(_version_major)
unset(_version_minor)
@@ -98,12 +93,6 @@ endif()
# Default to release build so packagers don't release debug builds
set(DEFAULT_BUILD_TYPE Release)
-# Require CMake 3.13+ with VS generator for complete support of VS versions
-# and support by AppVeyor.
-if(${CMAKE_GENERATOR} MATCHES "Visual Studio")
- cmake_minimum_required(VERSION 3.13 FATAL_ERROR)
-endif()
list(APPEND CMAKE_MODULE_PATH "${CMAKE_CURRENT_SOURCE_DIR}/cmake")
# TODO: Follow CMake detection of git and version tagging
Summary of changes:
.github/workflows/ci.yml | 30 +++++++++++++++---------------
CMakeLists.txt | 25 +++++++------------------
2 files changed, 22 insertions(+), 33 deletions(-)
hooks/post-receive
More information about the geos-commits
