[geos-commits] [SCM] GEOS branch main updated. 8c550f74b86a400b6e9c7685a6d4339eab979294
git at osgeo.org
git at osgeo.org
Tue Aug 20 07:57:46 PDT 2024
the project "GEOS".
The branch, main has been updated
via 8c550f74b86a400b6e9c7685a6d4339eab979294 (commit)
from d9422f5ef776c87c78dabd705e486ee08ca39be7 (commit)
revisions in full, below.
commit 8c550f74b86a400b6e9c7685a6d4339eab979294
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Aug 20 07:57:08 2024 -0700
Add support for bnRule testing relates
diff --git a/tests/unit/operation/relateng/RelateNGTest.cpp b/tests/unit/operation/relateng/RelateNGTest.cpp
index 7e54c71c9..98ed898bd 100644
--- a/tests/unit/operation/relateng/RelateNGTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGTest.cpp
@@ -875,5 +875,16 @@ void object::test<62> ()
checkRelate(a, b, "212101212");
+// Boundary node
+// template<>
+// template<>
+// void object::test<63> ()
+// std::string a = "POLYGON((0 0,140 0,140 140,0 140,0 0))";
+// std::string b = "POLYGON((140 0,0 0,0 140,140 140,140 0))";
+// checkRelateRule(a, b, "2FFF0FFF2", geos::algorithm::BoundaryNodeRule::getBoundaryMultivalentEndPoint());
} // namespace tut
diff --git a/tests/unit/operation/relateng/RelateNGTest.h b/tests/unit/operation/relateng/RelateNGTest.h
index 70526d6de..8231f886b 100644
--- a/tests/unit/operation/relateng/RelateNGTest.h
+++ b/tests/unit/operation/relateng/RelateNGTest.h
@@ -1,5 +1,6 @@
// geos
+#include <geos/algorithm/BoundaryNodeRule.h>
#include <geos/io/WKTReader.h>
#include <geos/io/WKTWriter.h>
#include <geos/geom/Geometry.h>
@@ -94,13 +95,13 @@ struct test_relateng_support {
checkPredicate(*RelatePredicate::equalsTopo(), wktb, wkta, expectedValue);
- void checkRelate(const std::string& wkta, const std::string& wktb, const std::string expectedValue)
+ void checkRelateRule(const std::string& wkta, const std::string& wktb, const std::string expectedValue, const BoundaryNodeRule& bnRule)
std::unique_ptr<Geometry> a = r.read(wkta);
std::unique_ptr<Geometry> b = r.read(wktb);
RelateMatrixPredicate pred;
// TopologyPredicate predTrace = trace(pred);
- RelateNG::relate(a.get(), b.get(), pred);
+ RelateNG::relate(a.get(), b.get(), pred, bnRule);
std::string actualVal = pred.getIM()->toString();
if (actualVal != expectedValue) {
std::cerr << std::endl << w.write(*a) << " relate " << w.write(*b) << " = " << actualVal << std::endl;
@@ -109,6 +110,11 @@ struct test_relateng_support {
checkPrepared(a.get(), b.get());
+ void checkRelate(const std::string& wkta, const std::string& wktb, const std::string expectedValue)
+ checkRelateRule(wkta, wktb, expectedValue, BoundaryNodeRule::getBoundaryRuleMod2());
void checkRelateMatches(const std::string& wkta, const std::string& wktb, const std::string pattern, bool expectedValue)
auto pred = RelatePredicate::matches(pattern);
Summary of changes:
tests/unit/operation/relateng/RelateNGTest.cpp | 11 +++++++++++
tests/unit/operation/relateng/RelateNGTest.h | 10 ++++++++--
2 files changed, 19 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
